Page 5 of 9 FirstFirst 123456789 LastLast
Results 61 to 75 of 122
Thread: Oscam emu powervu
  1. #61
    23 Apr 2008
    Bucharest West
    Va rog daca aveti un EMU reader periat, doar cu ce se prinde in zona noastra, am unul cu 866 de carduri..
    Oscam r11400 merge fara pb la mine, inainte avem o vers fara powervu..si non emu
    Vu+Zero4K, Offset Motor 1m
  2. #62
    pai de periat il perii tu.....stergi tot ce nu ai nevoie....entiltements din pacate nu ai cum sa le cureti...chiar de il compilezi tu....eu am ajuns pana la 29-35 de entiltements...
    oricum daca vrei sa l dai in share ca si local...si setezi readeru cum trebuie ....se va vedea doar 1 card...restu ce vezi e doar la tine...
    iti dau pm cum am eu
    ---------- Post added at 13:30 ---------- Previous post was at 12:43 ----------
    nu exista vers cu sau fara PW...exista oscam si oscam-emu
  3. #63
    02 Dec 2011
    Default PowerVu 1W?
    Salutare tuturor.
    La voi este "lumina" la PowerVu 1W ? Poate n-am eu cheile corecte, pentru ca am urmatoarele erori:
    2018/03/01 21:21:50 142EC697 r      (emu) Key not found: P 0A8E 01
    2018/03/01 21:21:50 142EC697 r      (emu) ECM failed: Key not found
    2018/03/01 21:21:50 2BC15088 c      (ecm) linux (0E00@000000/0000/0A8E/40:D7163D5B1AAFCA6D420CB0DEF5D58A33): not found (23 ms) by emulator - ID Xtra Europe HD
    2018/03/01 21:21:50 2BC15088 c      (ecm) cw:
    2018/03/01 21:21:50 2BC15088 c      (ecm)   00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    2018/03/01 21:21:50 2BC15088 c   (dvbapi) Demuxer 1 restarting decodingrequests after 3 ms with 1 enabled and 0 disabled ecmpids!
    2018/03/01 21:21:50 2BC15088 c   (dvbapi) Demuxer 1 trying to descramble PID 0 CAID 0E00 PROVID 000000 ECMPID 1793 ANY CHID PMTPID 0AE8 VPID 0A8C
    2018/03/01 21:21:51 2BC15088 c      (ecm) get cw for ecm:
    2018/03/01 21:21:51 2BC15088 c      (ecm)   80 30 3D 30 37 20 0E 00 00 00 00 D6 B0 00 14 2C
    2018/03/01 21:21:51 2BC15088 c      (ecm)   96 96 F1 7C 7B CD F3 E4 F4 E4 8A E7 00 A8 E0 00
    2018/03/01 21:21:51 2BC15088 c      (ecm)   00 8D 19 5D 57 79 5E 13 A6 B7 CD 55 2A B9 C7 E9
    2018/03/01 21:21:51 2BC15088 c      (ecm)   32 D6 36 38 92 32 D8 98 7E 84 16 85 3E 09 04 16
    2018/03/01 21:21:51 142EC697 r ecm:
    2018/03/01 21:21:51 142EC697 r 80 30 3D 30 37 20 0E 00 00 00 00 D6 B0 00 14 2C
    2018/03/01 21:21:51 142EC697 r 96 96 F1 7C 7B CD F3 E4 F4 E4 8A E7 00 A8 E0 00
    2018/03/01 21:21:51 142EC697 r 00 8D 19 5D 57 79 5E 13 A6 B7 CD 55 2A B9 C7 E9
    2018/03/01 21:21:51 142EC697 r 32 D6 36 38 92 32 D8 98 7E 84 16 85 3E 09 04 16
    2018/03/01 21:21:51 142EC697 r      (emu) Key not found: P 0A8E 01
    2018/03/01 21:21:51 142EC697 r      (emu) ECM failed: Key not found
    2018/03/01 21:21:51 2BC15088 c      (ecm) linux (0E00@000000/0000/0A8E/40:A59253EFE10FAF09CAE1F51AD342A78A): not found (10 ms) by emulator - ID Xtra Europe HD
    2018/03/01 21:21:51 2BC15088 c      (ecm) cw:
    2018/03/01 21:21:51 2BC15088 c      (ecm)   00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    Caut "P 0A8E 01" in /var/keys/SoftCam.Key si exista linia:
    P 0A8E 01 AA2A93CB38676A ;ID Xtra Europe HD, 1W, 12303
    Path-ul cheilor este corect:
    2018/03/01 21:56:01 608941A2 r (emu) Reading key file: /var/keys/SoftCam.Key
    2018/03/01 21:56:02 608941A2 r (emu) Total keys in memory: W:0 V:17 N:10 I:7 S:0 F:223 P:505 D:11 T:166
    Box
    Brand: Amiko
    Model: Alien 2
    Chipset: STi7162
    PKT Hyperion 5.5
    OSCam: 1.20-unstable_svn Build: r11399 Compiler: sh4-streamboard-linux-gnu
  4. #64
    Ai tu o imagine e2 de alien2 care deschide pvu?
  5. #65
    02 Dec 2011
    Oups.. asta o fi problema? Aveam OpenATV 4.5 si mergea obosit la un moment dat. Am instalat OpenATV 6.1 si avea loop reload la 100%
    Se misca perfect cu hyperion 5.5 doar ca imi lipsesc Discovery din PVU..
    Ce ar trebui sa contina imaginea aia in plus fata de versiunea pe care o am? Un patch,plugin, ..ceva?
    De fapt la voi pe ce device-uri se face lumina?
    Daca gasesc un amic cu o jucarie compatibila, ar putea apoi sa-mi dea din share PVU? Ar functiona in modul asta?
    Today edit:
    Am instalat Openpli 5 din Taapat modificat si s-a facut lumina la PVU 1W (Joeuser's Taapat based image with new hardware DES drivers)
    Dar.. am artefacte deranjante pe imagini. Ceva setari sa le rezolv exista?
  6. #66
    30 Aug 2007
    Mai merg AFN in EMU sau s-a schimbat ceva?
    Daca da, care e configuratia (dvbapi sau stream relay?) si pe ce STB/oscam?
    La mine ECM (din cache) zice ca e OK (i.e. keys OK, updated), dar ecranul e negru. Folosesc ultimul oscam compilat cu emu patch, aceiasi situatie pe dm900 si pe dm525.
  7. #67
    12 Nov 2007
    Aceeasi situatie este si la mine, ne poate confirma cineva daca mai functioneaza ?
  8. #68
    13 Jan 2018
    La mine pe KIII pro facea AU si era totul ok pina acum o saptamina.
    Cred ca au facut yankeii ceva de s-a stins lumina
  9. #69
    29 Sep 2017
    Bucharest
    Nici la mine nu functioneaza!
  10. #70
    Standard RSP member delsat's Avatar
    22 Jul 2007
    Crisana
    Oscam Emu 11424 r770.cu asta se deschide...
  11. #71
    30 Aug 2007
    Confirm, acum este OK cu noul EMU.
  12. #72
    13 Jan 2018
    Default AZBOX oscam powervu
    Si la mine pe AZbox cu ultima versiune de oscam se facu lumina.
  13. #73
    13 Jan 2018
    Default Reader powervu 0.8W si 4.8E
    Va salut,
    Ma poate ajuta cineva cu o configurare de reader(PW) pentru 0.8 grade W si 4,8 grade est.
    Momentan mege bine pe AFN cu ultimul oscam (face si AU) dar se pare ca or sa schimbe sistemul de codare
    in VeriMatrix.
    Multumesc
  14. #74
    12 Nov 2007
    Sal, nu reusesc nicicum sa fac lumina pe AFN-uri, rugamintea ar fi nu pune cineva un config functional ?
    Multumesc !
  15. #75
    13 Jan 2018
    Salut alex,
    Astea sunt setarile pe care le folosesc eu si care functioneaza ok pt. AFN si biss.
    Nu uita sa downloadezi ultima versiune de oscam.
    O zi buna
    oscam.conf
    [global]
    logfile = /dev/tty
    initial_debuglevel = 64
    clienttimeout = 3500
    fallbacktimeout = 120
    bindwait = 5
    unlockparental = 1
    emmlogdir = /var/tmp/
    failbantime = 1440
    [cache]
    max_time = 7
    cwcycle_check_enable = 1
    cwcycle_check_caid = 0100,1802,1810,1811,1814,1816,1817,1818,1819,1883,1863,0B00,0B0F,0602,0603,0604,0606,0608,0622,0624, 09CD,0500,090D,0930,0B02,0B1D,0B1C,1702,1708,1722,1802,1803,1833,1880,1815,1882,09AF,093E,090F,091F, 092B,0931,0940,09BD,0BAA,1803,1805,1836,1841,1843,1860,1861,186A,0B01,1830,1834,183D,183E,0629,0648, 0653,0664,09C7,09C4,098C,0D95,0D00,0D96,0963,4AEE,4AE0,4AE1,0D97,0D02,0D03,0D05,0D06,0D08,0D0F,5581
    [streamrelay]
    stream_relay_enabled = 0
    stream_emm_enabled = 0
    [dvbapi]
    enabled = 1
    au = 1
    pmt_mode = 1
    request_mode = 1
    delayer = 60
    user = azbox
    read_sdt = 1
    write_sdt_prov = 1
    extended_cw_api = 1
    [webif]
    httpport = 8888
    httpuser = azbox
    httpshowmeminfo = 1
    httpshowuserinfo = 1
    httpshowcacheexinfo = 1
    httpshowecminfo = 1
    httpshowloadinfo = 1
    httpallowed = 127.0.0.1,192.1.0.0-192.168.255.255
    oscam.user
    [account]
    description = dvbapi
    user = azbox
    group = 1
    au = 1
    oscam.server
    [reader]
    label = biss
    protocol = constcw
    device = /etc/tuxbox/config/constant.cw
    group = 1
    [reader]
    label = emulator
    description = emu
    protocol = emu
    device = emulator
    cacheex = 1
    caid = 0E00,0500,1801,2600,090F,0604,FFFF,4AE1,1010
    detect = cd
    ident = 090F:000000;0500:000000,023800,021110,007400,007800;1801:000000,007301,001101,002111;0604:000000;260 0:000000;FFFF:000000;0E00:000000;4AE1:000011,000014,0000FE;1010:000000
    group = 1
    emmcache = 2,1,2,1
    saveemm-u = 1
    emu_auproviders = 1801:000000,002011,002111;0604:010200;4AE1:000011,000014,0000FE;1010:000000
    [reader]
    label = AFN
    description = AFN-EMU
    protocol = emu
    device = Emulator
    services = afn
    cacheex_maxhop = 1
    cacheex_allow_request = 1
    caid = 0E00
    detect = cd
    group = 5
    emmcache = 2,2,2,0
    saveemm-u = 1
    emu_auproviders = 0E00:000000
    auprovid = 000E00
    oscam:
    http://oscam.dreamosat.net/index.php...ry=1.20_TRUNK&
