Thanks Thanks:  2
Likes Likes:  1
Results 1 to 15 of 16
Thread: Vu+ uno 4k se
    Thumbs up Vu+ uno 4k se
    WILL COMING THE NEW VU+ UNO 4K SE
    The VU+ presented in Anga 2017 its new equipment's for 2017, the new VU+ Zero 4K and now it´s time for the new VU+ Uno 4K SE, the successor to the VU + Uno 4K receiver. It comes equipped with a Dual-Core 1.7GHz processor, 4GB flash, 2GB DDR4 RAM, a 2.4 "LCD, 1x CI, 1 Smartcard reader, supports Transcoding & HDR10/GAN.
    The first new feature is the Vu + UNO 4K SE, which has a 2.4 "color display, a 2.5" removable disk slot and is packed with an entirely new FBC tuner working on the DVB-S2X standard. Another new feature is the Vu + Zero 4K receiver, which will also be available with the new DVB-S2X or DVB-T2 / C tuner. The prices of both news are not yet known, as is the date of sale. However, it is possible to assume that they will appear in stores traditionally at the end of the year.
    Vu + features new plug-and-play DVB-S2X FBC tuners at the show in addition to the boxes. You will be able to insert them not only in the newcomers but also in the currently sold Vu + ULTIMO 4K and Vu + UNO 4K boxes. Another new feature from Vu + is the USB dongle Bluetooth to ensure collaboration with the new remote control for Bluetooth-free receivers.
    VU+ Uno 4K SE Sepcs:
    Plug Play- FBC DVB-S2 / S2X FBC ou DVB-C ou DVB-T2 duplo
    Dual Core de 1,7 GHz
    Flash de 4 GB
    2 GB de RAM DDR4
    2.4 "LCD / TV Mini
    Conector for 2,5 "HDD / SDD
    1x CI
    1x Smart Card reader
    HDMI & Output HDMI
    2x USB 3.0
    Suports Transcoding
    Suports HDR10 / GAN
    Technical specifications
    Front panel display 2.4 "color LCD display
    Real Panel tuner
    1x Plug and Play Dual FBC DVB-S2 / S2X or DVB-C FBCTuner or DUAL DVB-C / T2
    Video / Audio output (digital) 1x HDMI 2.0 output 1x HDMI input
    Audio output (digital) Standard optical (SPDIF)
    USB 3.0--------------- 2
    external IR sensor------1
    RS 232----------------1
    Gigabit Ethernet-------1
    HDD Plug & Play 2.5 "HDD hard drive
    power main power 100 - 240 V / 50 - 60 Hz (external power supply 12V 3.5A 15W / 0.5W)
    RF RF range DVB-S2 / DVB-C 47-864 MHz (C), 950-2.150 MHz (S2)
    FEC , de-multiplexer DVB-S / DVB-S2 / DVB-C standard
    Video Video resolution 576p, 720p 1080i, 1080p, 2160p
    Video decoding H.264 / MPEG-4 AVC MVC, H.265 / HEVC MP
    Imput data rate 2-45 MSymb / s
    S / N > 53 dB
    Audio Sampling rate 32 / 44.1 / 48 kHz
    S / N > 65 dB
    LNB
    LNB supply (horiz./vert.) 14V / 18V (max 400mA)
    Control signal 22kHz; ToneBurst; DiSEqC 1.0 / 1.1 / 1.2; USALS
    General Size (W x D x H) 280 x 195 x 45 mm
    mass 2 kg
    remote Control Bluetooth / IR remote control (voice control not possible)
    https://www.youtube.com/watch?v=FnmDqlgp90Q
    VU+ Uno 4K SE 1x DVB-S2 FBC Twin Tuner PVR ready Linux Receiver UHD 2160p--------------------------269,00 €
    VU+ Uno 4K SE 1x DVB-C FBC Twin Tuner PVR ready Linux Receiver UHD 2160p---------------------------269,00 €
    Delivery possible from 01.12.2017
    O chestie/caracteristica care nu am mai auzit-o/intalnit-o la vreun alt receptor din categoria - receptoare 4K - QUAD PIP
    Cum or fi cele patru imagini/posturi - 1 dinamic si 3 statice sau toate 4 dinamice ?
    Stiu ca o astfel de optiune era pe la tv tunerele de pc cu pana la 16 imagini in caroiaj de 4 x 4 si doar 1 din cele 16 era dinamica
    Open Source 3.0 VU+ Uno4K SE Image
    http://code.vuplus.com/index.html?ac...odel=vuuno4kse
    http://code.vuplus.com/download/boxi...094331_usb.zip
    VTi 13.0.x VU+ Uno4k SE Image
    Vu+ Team Image - VTi 13.0.x
    Build tree: openvuplus-3.0 (more)
    Kernel: 4.1.20 (Uno 4K SE, Zero 4K)
    Kernel: 3.14.28 (Solo 4K, Uno 4K, Ultimo 4K)
    Kernel: 3.13.5 (Solo², Duo², Solo SE, Zero)
    Kernel: 3.9.6 (Duo, Solo, Uno, Ultimo)
    Gstreamer: 1.6.4
    HbbTV-Browser: Opera (Solo², Duo², Solo SE, Zero)
    HbbTV-Browser: WebKit (Solo 4K, Uno 4K, Ultimo 4K, Uno 4K SE, Zero 4K)
    http://uploadfile.pl/pokaz/1283088---emgq.html
    thanks to @wojtek0706
    Reset der Fernbedienung
    Set-up Sequence: <<[PVR] + [EXIT]****
    [PVR] + [EXIT] bis LED 3x blinkt
    Werkseinstellung der Fernbedienung
    Set-up Sequence: <<[TV] + [MENU]****
    [TV] + [MENU] bis LED 3x blinkt
    https://vuplus-support.org/faq/Vu+_u..._BT_IR_RCU.pdf
    Openvix 5.1.004 VU+ Uno4k SE Image
    http://www.openvix.co.uk/openvix-builds/Vu+Uno4KSE/
    Openvix 5.1.006 VU+ Uno4k SE Image
    http://www.openvix.co.uk/openvix-bui...no4kse_usb.zip
    Thumbs up Black Hole 3.0.5 Quad PiP​ VU+ Uno4k SE Image
    What is new ?​
    - Update and fix CrossEPG
    - Fix Timer recording bug
    - Fix USB recording
    - Add Overlayfs for new kernel (Uno4KSE, Zero4K)
    - Add Uno4KSE support
    - Add Zero4K support (beta)
    - Add VP9 Support (Ultimo4K, Uno4KSE, Uno4K, Zero4K)
    - Add Dvb-S2X support (Zero4K)
    - Add Multistream/PLS support (Zero4K)
    - Add Blindscan support (Zero4K)
    - Update Drivers (Ultimo4K, Uno4KSE, Uno4K, Solo4K, Zero4K, Duo2, SoloSE, Solo2, Zero)​
    BlackHole-3.0.5-vuuno4kse_usb_release_20171224_610e58d.zip
    https://mega.nz/#!Tc9AxJhS!SZvksFdH7...1aTqVHEHZyn-Q0
    What is new ?
    - Fix USB recording
    SFTeam 6 for VU + UNO4kSE
    Changelog:
    - New skin SFTfullhd
    - New GStreamer 1.12.3
    - New version of Python 2.7.12
    - Updated Enigma2
    - Updated PLi Core
    - Updated third - party add / System
    - Updated drivers
    - Some further changes / updates
    http://www.mediafire.com/file/jo5b5i...no4kse_usb.zip
    01 Feb 2018
    Vu+ Uno 4K SE Unboxing.
    Thumbs up Vu+ UNO 4K SE User --- Manual english---
    http://vuplus.com/manual/UNO%204K%20...al_english.pdf
    Thumbs up Black Hole 3.0.5.A Quad PiP VU+ Uno4k SE Image
    What is new ?
    Update drivers(4k models)
    - Fix demux problem
    [bluetoothsetup/util] update for solo4k.
    [vuplus-blindscan-utils] update TT2L08/TT3L10
    [Scan] Fix DVB-T2 Network Scan. (need update libdvbsi++ 0.3.8)
    - Fix HDR/HLG problem
    - Fix grab problem
    - Fix demux problem
    - Improve overall performance
    - Update kernel config
    - Adjust driver memory allocations
    update kodiegl/chromium/directfb.
    [libdvbsi++] update to 0.3.8
    [dvbmediasink] update EXTRA_OECONF (solo4k, uno4k, ultimo4k, uno4kse).
    update driver(zero4k)
    - Fix DVB-CI problem
    - Fix PLS
    - Improve demux
    This is available as an online update from 3.0.5 or as a full flash update.
    https://mega.nz/#!ONNUnCIK!lD4Iz2s11...SqJi88InG-vOls
    Thumbs up Black Hole 3.0.5.E Quad PiP VU+ Uno4k SE Image
    Black Hole 3.0.5.E
    What is new ?
    update drivers(uno4k, uno4kse, ultimo4k)
    - Fix DiSEqC timing
    - Support Dual DVB-S2X FBC tuner(needs E2 update)
    update drivers(solo4k, uno4k, uno4kse)
    - Fix media playback(24Fps)
    Fix default recording path and usb recording.
    [dvbapp] update.
    [autofs] remove sync option for broken recording issue for ext4 filesystem.
    [udev] fix automount.
    https://mega.nz/#!rUNk0LBQ!ebTnsDzai...zfBcP-agUU5cfg
    Thumbs up New VTi - Vu+ Team Image - VTi 13.0.x
    From VTi Team
    VTi Panel (Blue Button)
    Supported languages:
    English, German, Dutch, Italian, Turkish, Danish, Polish,
    Russian, Ukrainian, Czech, Arabic, French, Swedish,
    Portuguese (Portugal), Greek, Bulgarian, Hungarian
    With modular, flexible VTi skins
    VTi Bootlogos and Radiomode Logo.
    Short press on blue button opens VTi Panel, long press opens Pluginmenu
    Support for FTDI chipset cardreader like smargo and easymouse2
    Running Softcam shown in the Infobar
    MovieList with extended functions
    Support for full image backup and restore (not Vu+ Solo 4K / Uno 4K)
    Supports VTi image flash online (not Vu+ Solo 4K / Uno 4K)
    Restore Plugins, Bouquets, Settings, etc. during installation
    Remove preinstalled packages during installation (VTi Zero)
    Support delayed descrambling in standby (Solo 4K, Uno 4K, Uno4K SE, Ultimo 4K, Zero 4K)
    Basic image information
    Gstreamer: 1.6.4
    CHANGELOG
    - update Samba --> 3.6.X version including backports for important securtiy patches
    - redesigned Openwebinterface (responsive design)
    - ChromiumOS is not preinstalled anymore - please install YouTubeTV plugin to use it
    - Update dvbapp2
    introducing database for media files
    search movies by title, description , tag or time intervall
    auto tagging for movie files (based on database)
    trashcan based on database including an auto delete function (ATTENTION: old movie trashcan will be removed by a future update)
    movie search with voice input at BT RCU (EPG-button)
    enhanced configuration for debug output
    mark recordings which are being made by another receiver
    enhanced virtual keyboard
    text input open virtual keyboard (need modified skin for showing SMS style input)
    improved displaying of long configuration lists
    ZapHistory button presses work like default InfoBar (no need for closing Zaphistory anymore)
    View top 20 downloads (Plugins / Skins) - VTi News, yellow button
    Bugfix: freezing PiP at Solo 4K
    Bugfix: support movie folders containing ":"
    Bugfix: parental control for folders in movielist
    https://mega.nz/#!LIdiDbCR!-baqrUcYj...rIow5nWSo0YPjk
    02 Aug 2018
    Braila
    Buna dimineata tuturor
    Sper ca am postat bine, nu am gasit un alt thread despre VU+ UNO 4K SE
    Mentionez de la inceput ca sunt novice in domeniul receptoarelor de satelit, asa ca, va rog nu aruncati cu pietre.
    Doresc sa achizitionez si eu un astfel de receptor, dar ma lovesc de doua probleme si, rog frumos pe cei avansati in acest domeniu si care
    detin/au detinut un astfel de receptor sa ma ajute :
    1. Modulul CI al receptorului este compatibil cu Cardurile de la Digi ?
    Detin actual 2 asemenea carduri :
    a Irdeto
    b - Nagra - redenumit de RDS - ca DIGI Smart Cam CI+ HD
    (informatia am gasit-o aici, este exact cel din foto : https://hdsatelit.blogspot.com/2013/...a-rcs-rds.html )
    2. Acest receptor se comercializeaza in Ro cu 2-3 tipuri de tunere DVB-C. Din ce am citit pe forum cele mai fiabile si sensibile tunere
    ar fi cele FBC cu chipset Silabs fata de cele Broadcom - poate gresesc si nu am inteles corect informatia.
    Intrebarea ar fi : ce model de tuner DVB-C sa aleg la configuratia receptorului pentru transmisia pe cablu Digi pentru
    a receptiona toate posturile transmise de RDS si care sa functioneze cu modulatiile 64, 128, 256 QAM ? (bineinteles digitale)
    Va multumesc anticipat pentru sprijinul acordat.
    Thumbs up Black Hole 3.0.6​ VU+ Uno4k SE Image
    Black Hole 3.0.6​
    Quote:
    What is new ?
    Completely re-written the BH EPG system.
    Added EPGImport support
    Added FreeSat, Netmed, ViaSat and Virgin EPG
    Updated Sky EPG
    Added options to Load-Save-Delete epg.dat
    Updated CrossEPG
    Fixed DVB Subtitles issue on some channels
    Swapped Buttons around in BH panels to match layout of other images
    Various Skin updates from MX10
    Quote:
    Please Note:
    Due to limited resources some end of life models will no longer be supported from BH 3.0.6 onwards. If you want to use BH with these receivers please use version 3.0.5
    The following is a list of the receivers that will not be supported in version 3.0.6 onwards:
    Vu+ Zero
    Vu+ Ultimo
    Vu+ Uno
    Vu+Duo
    Vu+ Solo
    This Image has the latest drivers but CAN be installed in OpenMultiboot. The image does not need to be installed in flash.
    This latest version of the Black Hole series has been updated and improved for maximum stability and performance.
    - Integrated OpenEpg
    - CrossEPG supported
    - EPG Import supported
    Yellow button = Audio menu
    Addons
    Infobar / OSD
    Analog Clock Gui
    Channel orbital location
    Signal SNR, BER
    Infobar picons
    Blue Panel
    Extra Settings
    Black Hole Speed Up
    Devices Manager
    Usb Format Wizard
    Telnet Panel ( Telnet Panel)
    FTP Panel ( FTP Panel)
    UPnP Client Djmount
    UpnP Server Minidlna
    Pcsc Panel
    Tuner Server
    Network Browse & Mountpoints
    Info Panel
    3 - About (info)
    Memory (Memory)
    Space (capacity)
    CPU (processor)
    Process (process)
    EPG Panel
    Green Panel
    Addons (added)
    Online Feeds Settings update
    Red Panel
    BlackHole
    Avalon
    Chaos
    Ghost
    Credits
    Thanks to plnick for help obtaining missing Ultimo4K files.
    Thanks to Pedro_Newbie for Backup script.
    DISCLAIMER
    LICENSE (TERM OF USE)
    This is free hobbyist software and it comes with absolutely no warranty. Use it at your own risk.​
    BlackHole-3.0.6-vuuno4kse_usb_release_20181003_578734e.zip
    https://mega.nz/#!2JMwkYpT!49pyiBNWZ...ilzBqUsGYOiKzg
    Satdreamgr-6.0- VU+ Uno4k SE Image
    http://sgcpm.com/satdreamgr-images-6/vu/
