Results 1 to 8 of 8
Thread: iptv plugin for enigma 2
    Thumbs up iptv plugin for enigma 2
    Hello Everyone,
    We are proud to announce that our new E2 plugin is now ready.
    There are 3 common methods for installation of ipk files (E2 plugin)
    1. Telnet Methods:
    a. Connect your E2 device with Putty or DCC.
    b. Go to FTP and copy one of this plugin on /tmp/ folder.
    c. Go to Telnet and Copy and paste one of this command.
    opkg install /tmp/XtreamTV_0.0.1_armv7a.ipk
    opkg install /tmp/XtreamTV_0.0.1_mips32el.ipk
    opkg install /tmp/XtreamTV_0.0.1_mipsel.ipk
    opkg install /tmp/XtreamTV_0.0.1_sh4.ipk
    2. FTP Methods:
    ​a. Download the plugin (downwold the attachment) and connect your E2 device with Putty or DCC
    c. After copy the ipk file to E2 device (tmp folder) from E2 device follow the demonstration (this is for old Gemini but same principal apply to all images)
    3. DCC - Upload Packages Method
    Information about which you version you need to install on boxes:
    - Mips32el is used for the most boxes. Example VU zero, Vu+ Duo, Zgemma and mostly above openpli 4 boxes or new images.
    - Mipsel is used for old boxes DM800 clones with old openpli 2.1
    - sh4 is used for boxes like spark
    - armv7a is used by new boxes like Vu+ 4k and gigablue sf4008
    So most used and strongly suggested is using the mips32el.
    When you have it installed the plugin should appear in the menu called XtreamTV, open this and there will be an MAC written. This MAC you can write inside your panel, after that you can verify the box.
    N.B. Before you install our plugin please remore old XtreamTV plugin from your device. If you want to remove the plugin from the box, write this code on Telnet opkg remove XtreamTV
    After installation please reboot your device. All is done. In plugin section you find "XtremeTV"
    Enjoy.
    https://www.mediafire.com/file/vxtkm...vxd/plugin.zip
    https://www.mediafire.com/file/3axf7...DCC_E2_150.zip
    ---------- Post added at 23:42 ---------- Previous post was at 23:26 ----------
    after you need to add mak adres from your reciver same like mag iptv box in the panel
    new E2 plugin XtreamTV_0.0.6
    via Telnet manual Methods:​
    opkg install http://yourserveraddres:port/enigma2...6_mips32el.ipk
    opkg install http://yourserveraddres:port/enigma2...0.6_mipsel.ipk
    opkg install http://yourserveraddres:port/enigma2...0.6_armv7a.ipk
    opkg install http://yourserveraddres:port/enigma2..._0.0.6_sh4.ipk
    after add reciver mak id: on Enigma2 Devices ( Plugin ) from your pannel
    Enjoi
    ---------- Post added at 14:25 ---------- Previous post was at 14:22 ----------
    https://www.mediafire.com/file/0e0cz...amTV_0.0.6.txt
    23 Apr 2008
    Bucharest West
    where we have to send the mac address for activation ?
    Vu+Zero4K, Offset Motor 1m
    acest serviciu merge doar pt cei care au xtremecode cu enigma 2 plugin activat in panel
    23 Apr 2008
    Bucharest West
    si cum il activam ? eu am incercat din panel, dar nu stiu daca s-a activat sau nu..
    acest serviciu nu e gratuit se plateste separat la xtremecode Enigma2 Devices ( Plugin )
    ---------- Post added at 22:18 ---------- Previous post was at 22:16 ----------
    Quote Originally Posted by lukas26 View Post
    XtreamTV Enigma2 Plugin
