Thanks Thanks:  33
Likes Likes:  19
Page 1 of 6 12345 ... LastLast
Results 1 to 15 of 83
Thread: Oscam si liste pentru Amiko A4
    95 Post(s)
    Default Oscam si liste pentru Amiko A4
    OscamNew Based on svn 11359
    Arhiva contine un apk pe care il instalati din file manager. MiihaiP e autorul
    19 Post(s)
    oscam-EMU-11375.zip
    Iata si un Oscam EMU la zi ... svn11375 ... se poate
    instala prin intermediul functiei "plugin" ... cu destinatia
    /var/bin si atribute "777" ... se poate lansa din ferestra
    executabilului OscamNew
    Functia "plugin" transfera automat de pe un memory
    stick datele aflate in folderul "plugin" si subfolderele sale
    plugin(var(bin,keys,tuxbox(config)))
    - executabilul in /var/bin
    - SoftCam.Key in /var/keys sau /var/tuxbox/config
    - fisiere de confugyrare Oscam /var/tuxbox/config
    Iata si un pachet de settings "demo" creat pentru
    a inventaria in principal canalele UHD ( 4K ) si
    cateva canale HD care merita vazute ...
    Settings.zip
    19 Post(s)
    Versiunea FW 1.0.18 Beta este online !
    Changelog :
    - change background of menus, make text more readable
    - add provider info on infobar
    - fix bug: can not add satellite when longitude is duplicate
    - fix bug: in Romanian menu some items naming
    - new feature: fetch local USALS position from server in SAT edit
    - new feature: add A3 Combo smart RCU support - wi-fi airmouse
    19 Post(s)
    Gasiti aici OscamNew based on svn11378
    19 Post(s)
    In teste versiunea FW Beta 1.0.19 daca nu are probleme,
    si din cate vad eu pana acum ... nu are ! va aparea pe server !!!
    1) fix bug: lipsync on some channels
    2) fix bug: dvb-c auto scan ( F1 ) can not get all channels
    3) fix bug: USALS coordinates detection from local IP
    4) update: Hebrew osd strings
    5) new feature: add video brightness/contrast/saturation settings
    ... zis si facut !!!
    Standard RSP member barghy's Avatar
    06 Mar 2007
    Lista canale A4:
    Testat pe A4 _ 1.17 => 0.8W to 23.5 E => based on E2 RDI settings ( THX to FZ )
    https://www.mediafire.com/?yza3jnh77lg48a5
    Succes !!!
    ... astept sugestii ...
    Libertatea vine din...cer !
    19 Post(s)
    In teste se afla versiune 1.0.20 ... speram sa apara la Beta
    inca in cursul zilei de azi !
    1. Iptv button allocation
    2. Fix mulitiplp problem
    3. Fix 'Android is upgrading' issue when boot
    4. Add official Conax support !!!
    5. Improve lipsync problem
    6. Improve channel zap problem
    19 Post(s)
    In teste se afla FW 1.0.21 !!!
    - fix bug: play failed when zapping to fast
    - fix bug: EPG load takes too long
    - fix bug: auto Diseqc can not correctly
    - update DVB-T/T2 TP list for Russia
    - stbemu keymap support ( Stalker )
    - recording from false Standby - ok
    95 Post(s)
    E o reala imbunatatire a calitatii imaginii video.
    Nu uitati sa dezactivati picons daca aveti liste mari de satelit.
    Standard RSP member Ovidon's Avatar
    10 Mar 2014
    Interesant, mie nu-mi gaseste versiunea 1.0.21. Nici la test. Momentan am 1.0.20 si as fi vrut sa o incerc si eu pe cea superioara.
    19 Post(s)
    Versiunea este deocamdata in validare ... daca totul este OK va fi publica ca Beta !
    10 Mar 2014
    Am inteles, mersi. Nu stiu cum as putea sa le cer sa introduca optiunea de oprire a ledului; adica pe langa cele de preferinte in culoare sa existe si optiunea "off". Nu ai habar unde le pot cere acest lucru?
    19 Post(s)
    Home-Settings-System-Misc.Settings
    - Standby LED ON/OFF ( ledul rosu )
    - LED Brightness 1 - 8 ( ledul albastru )
    10 Mar 2014
    Era deja optiunea asta? N-am observat, mersi frumos.
    ---------- Post added at 16:46 ---------- Previous post was at 16:39 ----------
    Optiunea e valabila doar pentru standby. Nu si cand este pornit, eu asta as fi vrut.
    19 Post(s)
    NU ! Led Brightness = 1 aproape i-l stinge !!!
    reduce luminozitatea la o valoare foarte mica ...
