Results 1 to 1 of 1
Thread: EDISION Piccollo 3in1 CI
Threaded View
    85 Post(s)
    Default EDISION Piccollo 3in1 CI
    TEST_14000800_galaxy_combo_220_ps_starlight_1CA_1CI_2.4.15
    Test version for EDISION PICCOLLO 3in1 plus CI based on gi-phoenix software.
    Possible incompatibility with new remote of Edision.
    Works only with Amiko 8260+ remote controller.
    Versiune de test pt. EDISION PICCOLLO 3in1 plus CI bazata pe sw. gi-phoenix .
    Posibile incompatibilitati cu telecomenzile model nou de la Edision.
    Code:
    Test firmware ver.2.4.15
    This version of the test will continue to fix, but you can use it.
    Work YouTube, Adult (3 strawberries applications: YouPorn, Tube 8 and Empflix), Lite IPTV, KINO-LIVE and 3ko on the keys are updated directly from the Internet.
    To view the "Adult" application should be:
    - In the "parental control" to enable the position of "Adult",
    - In the "application" in the first column of characters go below the 3rd icon and "the Adult" application will appear.
    Finished testing and running: Plug-Import E2 database.
    Added: Disable the wireless connection, remove the access point (forget)
    Added: Application WEB Server to download the channel playlist in .m3u (at this point in the test)
    Posted: WEB Server application the ability to download LITE IPTV servers (currently in test)
    Posted: Appendix Stalker IPTV (at this point in the test)
    Posted: WEB TV application, sleep timer and change the display format.
    Posted: WEB TV application support ts-proxy playlists from Torrent TV
    Added: Added support for video in media player with a resolution of 1920x800
    Updated: write timer, change the duration to the end of time
    Updated: Function default start channel to OFF.
    Updated: Search TV after the search becomes the last channel in the list.
    Updated: Appendix Kino-live greater stability
    Updated: Appendix RSS, added news feed Sat24
    Updated: BISS List keys on the basic positions
    Fixed: WEB TV application, eliminated hangs when using USB
