Thanks Thanks:  94
Likes Likes:  107
Page 8 of 22 FirstFirst ... 45678910111218 ... LastLast
Results 106 to 120 of 330
Thread: Videostrong (Mecool) K III PRO DVB
  1. #106
    31 Aug 2010
    @zildan
    "Even so, the real display area may be smaller than the physical size of the display if the window manager is emulating a smaller display using (adb shell wm size)." https://developer.android.com/refere...w/Display.html
    Se pare că e o păcăleală cunoscută la dispozitivele cu Android:
    "xperia xz premium (5.5inch, 2160P/4K)
    wm size - physical size: 1080x1920
    wm density - physical density: 403
    note: see how they deal with 2160x3840 display? phone is running only 1080p exept in specific apps." https://forum.xda-developers.com/htc...1080p-t3638543
    Underpowered CPU's on Sony Bravia (x85d/x8500d)? Any good ones? : AndroidTV https://www.reddit.com/r/AndroidTV/c...85dx8500d_any/
    Dacă știam, nu aș fi cumpărat KIII sau alt dispozitiv cu Android.
  2. #107
    Tu ce televizor ai?
    Una e grafica playerului sau a aplicatiilor, alta e la stream-ul video.
    Nu are rost sa deseneze meniurile 4K, nici televizoarele nu o fac.
    Tu sustii ca mint astia si youtube de fapt e 720p la televizoarele 4k ?
  3. #108
    19 Dec 2012
    Problema rezolvata. Am schimbat in RGB din Ycbcr cum vine in mod standard si nu a mai facut nici o problema.
    Pana luna urmatoare cand o sa imi iau alt tv 4K o sa las asa.
    Multumesc ptr sfaturi.
  4. #109
    Default Videostrong (Mecool) K III PRO DVB
    Am testat wm size 3840x2160 si 2160x3840, nu afecteaza calitatea imaginii 4k, doar a meniurilor.
    DTV nu are treaba cu setarea asta.
    Faza e ca ramane si dupa reboot valabila setarea
    1920x1080
    3840x2160
    2160x3840
    ---------- Post added at 16:53 ---------- Previous post was at 16:36 ----------
    Si in Plex la fel, influenteaza doar rezolutia meniurilor nu pe cea video.
    ---------- Post added at 16:58 ---------- Previous post was at 16:53 ----------
    Aplicatia DTV poate fi refacuta cu grafica 4k .... nu stiu daca are sens.
  5. #110
    31 Aug 2010
    Folosesc K3 cu un monitor 4K 100% sRGB.
    Se revine ușor la valorile inițiale cu wm size reset și wm density reset
    Probabil merită făcută modificarea doar la vizionarea de conținut 4k. In rest, Android+K3 nu fac față și interfața are lag.
  6. #111
    Pai conținutul 4K se vede 4K pe ecran
  7. #112
    Standard RSP member omul24's Avatar
    04 Nov 2012
    Sighetu Marmatiei
    Cum se face sa vezi ecm time sursa de la care vine,etc,etc like in enigma2 dacă nu se poate maine il scot la vanzare
  8. #113
    Asta numai in oscam vezi
    Dacă faci reducere il iau eu
  9. #114
    31 Aug 2010
    Conținut 4k rulat intr-o fereastră 1920x1080 "intinsă" pe un ecran 4k. Am reprodus aproximativ situația in Windows.
  10. #115
    Si ce vrei sa spui? Ca sunt meniurile mai mici?
    Alea sunt in alt layer.
    E ca si cum ai incerca sa faci autorotire la tv si auto luminare .... dacă tot nu ințelegi ca asta nu e tableta.
    Nu face nimeni meniuri 4K la televizoare.
    ---------- Post added at 13:06 ---------- Previous post was at 13:01 ----------
    In Android nu funcționează așa treaba.
    Netflix nu tine cont de rezoluție, plex la fel.
  11. #116
    Ca sa ințeleagă toată lumea cand are imagine 4K pe YouTube
    Scrie sus pe al 2-le-a rand 4K restul ...vise erotice
  12. #117
    31 Aug 2010
    Pentru cine vrea să ințeleagă diferența
    Clipul pentru teste in orice browser https://www.youtube.com/tv#/watch/vi...?v=IlXhywbggFY
  13. #118
    Esti putin in lumea ta.
    Iar vii cu exemple din windows!
    Mergi in magazin si testeaza pe un tv 4k sa vezi ce scrie acolo.
    Daca mai scrii despre asta cu rezoluția iei BAN.
  14. #119
    31 Aug 2010
    Acel 4k apare și dacă e rulat pe un tv FullHD. E rezoluția clipului, nu rezoluția la care e afișat. Am făcut proba pe un Samsung din 2010.
  15. #120
    Ai 20 de ani?
    Iar scrii tampenii !!!!!
    OK, o sa iti mut aberatiile in "topicul tau", semeni cu mario08 .
