Ma ajuta si pe mine cineva... plz. De 3 zile imi bat capul cu el, am citit si recitit tot topicul
Nu cred ca sunt atat de prost sa nu il dezleg.
Sigur mai trebuie pus ceva pe undeva
Daca deranjeaza se poate sterge postarea.
- 2018/07/22 14:35:52 00000000 s (main) System name = Linux
- 2018/07/22 14:35:52 00000000 s (main) Host name = localhost
- 2018/07/22 14:35:52 00000000 s (main) Release = 3.14.29
- 2018/07/22 14:35:52 00000000 s (main) Version = #30 SMP PREEMPT Wed Mar 21 12:13:48 CST 2018
- 2018/07/22 14:35:52 00000000 s (main) Machine = armv8l
- 2018/07/22 14:35:52 00000000 s (emu) oscam-emu version 732
- 2018/07/22 14:35:52 00000000 s (config) userdb reloaded: 1 accounts loaded, 0 expired, 0 disabled
- 2018/07/22 14:35:52 00000000 s (main) signal handling initialized
- 2018/07/22 14:35:52 00000000 s (reader) emulator [emu] creating thread for device emulator
- 2018/07/22 14:35:52 00000000 s (stat) loadbalancer: could not open /tmp/.oscam/stat for reading (errno=2 No such file or directory)
- 2018/07/22 14:35:52 00000000 s (main) waiting for local card init
- 2018/07/22 14:35:52 00000000 (emu) info: FFDecsa parallel mode = 32
- 2018/07/22 14:35:52 0C90C19B r (emu) reading key file: /data/data/th.dtv/supercam/SoftCam.Key
- 2018/07/22 14:35:52 0C90C19B r (reader) emulator [emu] Reader initialized (device=emulator, detect=cd, mhz=357, cardmhz=357)
- 2018/07/22 14:35:52 728981A2 h (webif) webif: decompressed 178901 bytes back into 441704 bytes
- 2018/07/22 14:35:52 728981A2 h (webif) HTTP Server running. ip=0.0.0.0 port=8888
- 2018/07/22 14:35:53 0C90C19B r (reader) emulator [emu] card detected
- 2018/07/22 14:35:54 0C90C19B r (reader) emulator [emu] found card system emu
- 2018/07/22 14:35:54 0C90C19B r (reader) emulator [emu] THIS WAS A SUCCESSFUL START ATTEMPT No 1 out of max alloted of 1
- 2018/07/22 14:35:54 0C90C19B r (emu) reading key file: /data/data/th.dtv/supercam/SoftCam.Key
- 2018/07/22 14:35:55 00000000 s (main) init for all local cards done
- 2018/07/22 14:35:55 00000000 s (emmcache) loading emmcache disabled since no reader is using it!
- 2018/07/22 14:35:55 00000000 s (emmcache) loading emmstats disabled since no reader is using it!
- 2018/07/22 14:35:55 00000000 s (anticasc) anti cascading disabled
- 2018/07/22 14:35:55 42199EFF c (client) plain dvbapi-client granted (anonymous, au=off)
- 2018/07/22 14:35:55 42199EFF c (dvbapi) dvbapi channelcache loaded from /data/data/th.dtv/supercam/oscam.ccache
- 2018/07/22 14:35:55 42199EFF c (dvbapi) Using sk_supercam listen socket, API forced to DVBAPIv3 (0), userconfig boxtype: 12
- 2018/07/22 14:35:56 42199EFF c (dvbapi) Client connected: 'test client' (protocol version = 1)
- 2018/07/22 14:35:56 42199EFF c (dvbapi) Demuxer 0 found 0 ECMpids and 2 STREAMpids in caPMT
- 2018/07/22 14:35:57 42199EFF c (dvbapi) Demuxer 0 found 0 ECMpids and 3 STREAMpids in PMT
- 2018/07/22 14:40:36 42199EFF c (dvbapi) Demuxer 0 stop descrambling program number 0020 (FFFE@FFFFFE:0020 unknown)
- 2018/07/22 14:40:36 42199EFF c (dvbapi) Demuxer 0 ecmpid 0 CAID: 1801 ECM_PID: 1585 PROVID: 000000
- 2018/07/22 14:40:36 42199EFF c (dvbapi) Demuxer 0 ecmpid 1 CAID: 1880 ECM_PID: 15B7 PROVID: 000000
- 2018/07/22 14:40:36 42199EFF c (dvbapi) Demuxer 0 ecmpid 2 CAID: 06BB ECM_PID: 15E9 PROVID: 000000
- 2018/07/22 14:40:36 42199EFF c (dvbapi) Demuxer 0 found 3 ECMpids and 2 STREAMpids in caPMT
- 2018/07/22 14:40:36 42199EFF c (dvbapi) Demuxer 0 trying to descramble PID 0 CAID 1801 PROVID 000000 ECMPID 1585 ANY CHID PMTPID 0000 VPID 1979
- 2018/07/22 14:40:36 0C90C19B r (emu) ECM failed: ECM not supported
- 2018/07/22 14:40:36 42199EFF c (ecm) anonymous (1801@002111/0000/028C/4A:A2866E8F869CAA52BF4268B0A5AC304E): not found (1 ms) by emulator
- 2018/07/22 14:40:36 42199EFF c (dvbapi) Demuxer 0 restarting decodingrequests after 0 ms with 1 enabled and 2 disabled ecmpids!
- 2018/07/22 14:40:36 42199EFF c (dvbapi) Demuxer 0 trying to descramble PID 0 CAID 1801 PROVID 002111 ECMPID 1585 ANY CHID PMTPID 0000 VPID 1979
- 2018/07/22 14:40:37 42199EFF c (dvbapi) Demuxer 0 found 3 ECMpids and 4 STREAMpids in PMT
- 2018/07/22 14:40:37 42199EFF c (dvbapi) Demuxer 0 restarting decodingrequests after 1 ms with 1 enabled and 2 disabled ecmpids!
- 2018/07/22 14:40:37 42199EFF c (dvbapi) Demuxer 0 trying to descramble PID 0 CAID 1801 PROVID 002111 ECMPID 1585 ANY CHID PMTPID 0000 VPID 1979
- 2018/07/22 14:40:37 42199EFF c (ecm) anonymous (1801@002111/0000/028C/4A:A2866E8F869CAA52BF4268B0A5AC304E): not found (2 ms) by emulator
- 2018/07/22 14:40:37 42199EFF c (dvbapi) Demuxer 0 restarting decodingrequests after 0 ms with 1 enabled and 2 disabled ecmpids!
- 2018/07/22 14:40:37 42199EFF c (ecm) anonymous (1801@002111/0000/028C/4A:A2866E8F869CAA52BF4268B0A5AC304E): not found (3 ms) by emulator
- 2018/07/22 14:40:38 42199EFF c (dvbapi) Demuxer 0 restarting decodingrequests after 0 ms with 1 enabled and 2 disabled ecmpids!
- 2018/07/22 14:40:38 42199EFF c (dvbapi) Demuxer 0 trying to descramble PID 0 CAID 1801 PROVID 002111 ECMPID 1585 ANY CHID PMTPID 0000 VPID 1979
- 2018/07/22 14:40:38 42199EFF c (ecm) anonymous (1801@002111/0000/028C/4A:A2866E8F869CAA52BF4268B0A5AC304E): not found (1 ms) by emulator
- 2018/07/22 14:40:39 42199EFF c (dvbapi) Demuxer 0 restarting decodingrequests after 1 ms with 1 enabled and 2 disabled ecmpids!
- 2018/07/22 14:40:39 42199EFF c (dvbapi) Demuxer 0 trying to descramble PID 0 CAID 1801 PROVID 002111 ECMPID 1585 ANY CHID PMTPID 0000 VPID 1979
- 2018/07/22 14:40:40 42199EFF c (dvbapi) Demuxer 0 stop descrambling program number 028C (1801@002111:028C unknown)
- 2018/07/22 14:40:40 42199EFF c (dvbapi) Demuxer 0 found 0 ECMpids and 2 STREAMpids in caPMT
- 2018/07/22 14:40:41 42199EFF c (dvbapi) Demuxer 0 found 0 ECMpids and 3 STREAMpids in PMT
Dislikes:
