Results 1 to 10 of 10
Thread: ViPER4Android_FX_v2401 - Samsung
    Golden Member qwess's Avatar
    26 Oct 2009
    Walachia / Paname
    Default ViPER4Android_FX_v2401 - Samsung
    ViPER4Android Audio Effects
    { **root** }
    ViPER’s Audio is an audio enhancing software to provide everyone with better audio experiences in various platforms such as smartphones and PCs.
    Necesar:
    *Andoid 6 rooted
    *Samsung stock sau custom ROM
    *TWRP recovery
    *SuperSU instalat
    *Busybox instalat
    *SELinux in mod "permisive"- Samsung Custom ROM
    **pentru dispozitivele Samsung cu stock ROM se copiaza pe sdcard ViPER4Android-supolicy.zip si se instaleaza din TWRP Recovery Reboot- Voulme UP/Home/Power(prin install .zip) >> Download Viper4Android SELinux Policy fix
    ViPER4Android_FX_v2401_A4.x-A6.x.apk se copiaza in ./system/priv-app/ cu permisiune 0644 (-rw -r -r)
    Download audio_effects.conf si se inlocuieste in ./system/etc/ cel de origine se redenumeste in audio_effects.conf.bak
    (IMPORTANT) se dezactiveaza sau ingheata cu Titanium Bachup "SoundAlive v.X"
    Reboot Dispozitiv
    se ruleaza aplicatia ViPER4Android si se instaleaza driverul V4A-FX (cu permisiune SuperSU)
    Reboot Dispozitiv
    se dezarhiveaza ImpulseResponseSamples.rar si se copiaza fisierele .irs dorite in ./sdcard/emulated/0/ViPER4Android/Kernel (folder creat de catre aplicatie dupa activarea "Convolver/Impulse Response" ! )
    pentru test, download 24BIT/96kHz Music High Resolution
    Despre
    http://vipersaudio.com/blog/
    Azbox HD with OpenSPA 3.0 powered by OSCam
    UE46F8000 powered by SamyGO_OSCam
    86 Post(s)
    Dupa ce am pus telefonul "in cap" de doua ori , am reusit sa fac viper sa mearga pe android 7.1.1Nu recomand nimanui daca nu are full backup la telefon.Am testat pe i9300 cu cm14.Chiar voiam un audio enhancer bun.
    26 Oct 2009
    Walachia / Paname
    cum ai reusit si de doua ori?
    l-am instalat de nenumarate ori si nu am avut probleme, insa e bine de prevenit. avand custom CM sper ca nu ai mai instalat SELinux supolicy.zip ... doar se trece din setari "enforcing" in "permissive" dupa care instalarea "aplicatiei de system"
    .apk-ul se copiaza in /system/priv-app/(folderul trebuie sa fie in RW eu folosesc Root Explorer) se da atribut 644 si se restarteaza dispozitivul, fara a se da click de instalare! dupa reboot se instaleaza automat ca app de system.
    86 Post(s)
    Cerd ca din neatentie am stricat telefonul.Oricum, nu a fost nimic grav.Am twrp si un backup full pe stik.Duteaza 3 minute sa-l resuscitez.
    LE : Am schimbat din enforcing in permissive cu aplicatia SELinuxModeChanger.In setari nu am sau nu gasesc eu optiunea respectiva.
    86 Post(s)
    După cateva săptamani de teste , pot să spun că e superior faţă de dolby atmos.Singurul inconvenient e că trebuie să-l reinstalez de la zero după fiecare update de sistem.(sunt pe night build.LineageOS nu au scos pană acum snapshot).Am testat și pe dispozitive cu chipset MTK pe care nu a mers dolby atmos.In mare , un audio enhancer de nota zece.
    86 Post(s)
    Din păcate , pe LineageOS 14 (android 7.1.2) nu mai vrea...
    Pe CyanogenMod 12 ,13 merge vis.(android 5.1 - 6.0)
    08 Feb 2014
    folositi cu incredere magisk(se instaleaza modulul viper) pe lineageos, si Viper FX+ 2.5.0.5 by guitardedhero. va merge cu siguranta pe 7.1.2
    86 Post(s)
    A fost bună și metoda postată de tine(dar bateria se descărca instant).Problema era de la SE LinuxPolicy. Au rezolvat-o băieții de pe XDA-"The SELinux Toggler"
    86 Post(s)
    Am trecut la R.R de la LOs .R.R are deja implementat in interfață Magisk.Ce e drept , e versiune "neoficială".
    Thanks again!
    86 Post(s)
    La ultima vers. de viper4android din magisk, se copiaza conţinutul dosarului "ImpulseResponseSamples" in directorul viper4android/kernel.
