Thanks Thanks:  40
Likes Likes:  22
Page 4 of 4 FirstFirst 1234
Results 46 to 56 of 56
Thread: VITMOD-LE K1 Plus S2/T2-C
  1. #46
    Put ip adress lyke 192.168... :port not cccam.line.org:port
  2. #47
    04 Dec 2009
    Yes, I type and it does not work.
    C: 1.cccam3.com 19000 Mmfwuq1 cccam3.com
    [reader]
    active = 1
    name = CCCAM.SERVER
    type = cccam
    auto_provider = all
    auto_idents = 1
    auto_update = 1
    konto = Mmfwuq1:cccam3.com @ 1.cccam3.com:19000
    debug = 3
    cc_hop = 3
    reconnect_delay = 10
    emm_cache = 1
    ecm_ttl = 15000
  3. #48
    Code:
    [reader]
    active = 1
    name = superserver
    type = cccam
    account = user:parola@111.1xx.2xx.112:port
    debug = 0
    auto_provider = all
    auto_idents = 1
    auto_update = 1
    reconnect_delay = 1
    emm_cache = 1
    ecm_ttl = 15000
    Check filter:
    Code:
    [filter]
    name = dvb
    rule = caid=2600;accept
    rule = caid=0100,1803,0B02,0B0F,0B01,0BAA,090D,090F,09CD;accept
    rule = caid=0500;ident=040600,060A00,060C00,040620,032500,040810,041700,042300,042800,043800,050C00,041200;accept
    rule = caid=098C;ident=000000;accept
    rule = caid=0652;chid=15,FFFF;accept
    rule = caid=1880;ident=002011,002111,000000;accept
    rule = caid=1801;accept
    rule = caid=1843;ident=003411,008011,000000;accept
    rule = caid=1803;ident=007001,007101,000000;accept
    rule = caid=4ae1;ident=11,14;accept
    rule = reject
  4. #49
    04 Dec 2009
    It still does not work, yes I have an entry in the file wicardd.conf
    Code:
    [global]
    #log_udp = 192.168.1.92:514
    syslog = 1
    #ecm_cache_size = 256
    #ecm_dedup_delay = 1500
    daemon = 0
    debug = 1
    [webif]
    port = 8081
    debug = 0
    [dvb]
    active = 1
    type = aml
    emm_filter_mode = 0
    filter = dvb,emm,ecm
    ecm_info = 2
    sdt = 1
    auto_update = 1
    debug = 3
    [reader]
    active = 1
    name = dreAU
    type = batch
    filter = dreauecm
    provider = 4ae1@66000000:11@66000000
    #provider = 4ae1_2E000000:11_2E000000 # Для 4-го ключа
    #provider = 4ae1_18000000:11_18000000 # Для 7-го ключа
    #provider = 4ae1_BB000000:11_BB000000 # Для 8-го ключа
    #provider = 4ae1_12000000:11_12000000 # Для 9-го ключа
    request_handler = /usr/config/wicard/emm_dre2_au_102
    debug = 3
    auto_update = 1
    [reader]
    active = 1
    name = funcard
    type = funcard
    force_ua = FF000000
    fw_file = /usr/config/wicard/FunCard.a90
    intee_file = /usr/config/wicard/int_ee.bin
    extee_file = /usr/config/wicard/ee.bin
    snippet_file = /usr/config/wicard/initial_snippet.bin
    #extee_size = 64
    emm_cache = 0
    force_ua = FF000000
    debug = 3
    auto_update = 1
    #Сюда можно добавлять ридеры для шары
    [reader]
    name = 1cent
    type = newcamd525
    account = login:password@server
    multiport = 4000,4002,4003,4004,4005,4008,4010,4011,4012,4013,4018,4019,4022
    debug = 3
    emm_cache = 1
    ecm_ttl = 5000
    [reader]
    active = 1
    name = biss
    type = emubiss
    file = /usr/config/wicard/SoftCam.Key
    debug = 3
    [reader]
    active = 0
    name = cryptworks
    type = emucworks
    debug = 1
    [server]                                                   #Сервер для внешних клиентов (Tvheadend, etc...)
    type = newcamd525
    auto_provider = Tricolor                                   #Tricolor
    auto_update = 1
    au_reader = Tricolor
    port = 11111
    debug = 3
    active = 0
    type = newcamd525
    auto_provider = NTV                                        #HTB++
    auto_update = 0
    port = 11112
    debug = 3
    active = 0
    [account]
    login = vdr
    password = vdr
    auto_update = 1
    [filter]
    name = emm
    type = emm
    rule = caid=4AE1;ident=FE;emm[0]=82;accept=funcard
    rule = caid=4AE1;ident=11;privdata=110010000102,110000000102;emm[3]!=FF;accept
    #добавлять правила для офкарт требующих ау
    rule = reject
    [filter]
    name = ecm
    type = pre
    rule = caid=4AE1;ident=11;accept=funcard
    rule = caid=0500;ident=040620,032500,040810,041700,042300,042800,043800,050C00,041200;accept
    rule = reject
    [filter]
    name = dreauecm
    type = pre
    rule = reject
    [filter]
    name = dvb
    rule = reject
    _________________________________________________________________________________________________________________
    [reader]
    active = 1
    name = superserver
    type = cccam
    account = XXXXX:xxxxx@ip:port
    debug = 0
    auto_provider = all
    auto_idents = 1
    auto_update = 1
    reconnect_delay = 1
    emm_cache = 1
    ecm_ttl = 15000
  5. #50
    [filter]
    name = ecm
    type = pre
    rule = reject
    remove from config this part
  6. #51
    04 Dec 2009
    No change still does not work.
  7. #52
    28 Jun 2008
    Tu c line is ok android tv ?
  8. #53
    04 Dec 2009
    Here it means where
  9. #54
    04 Dec 2009
    Hello, maybe this version of wicardd 1.18 does not support cccam , in this softy, vitmod_os_v2_rc6_k1plus.img.
  10. #55
    17 Jan 2008
    Buna ziua, va rog daca stiti cum pot rezolva cateva probleme :
    - cum trebuie setat wicard ca sa deschida cablu doar din softcam ( merge acum cu linie din cccam)
    - s-a gasit ceva pentru subtitrarile in neutrino ?
    - cum se pot adauga sateliti in vdr ?
    Multumesc.
  11. #56
    Raspund dupa 2 ani pentru ca azi am scanat cu VDR pe alt aparat
    se editeaza: /storage/.kodi/userdata/addon_data/service.multimedia.vdr-addon/config/sources.conf
    https://www.linuxtv.org/vdrwiki/index.php/Sources.conf
    Lista de canle se editeaza : /storage/.kodi/userdata/addon_data/service.multimedia.vdr-addon/config/channels.conf
    https://www.linuxtv.org/vdrwiki/inde..._channels.conf
    Eu am adaugat in channels.conf canalele 4k de pe cablu pentru statia Craiova:
    Digi 4k;DIGI:490000:M256:C:6900:6801=36:6802=eng@15:0:1880,6BB,1874:680:0:0:0
    Eurosport 4k;DIGI2:490000:M256:C:6900:6811=36:6812=ron@3,6813=eng@3:0:1880,6BB,1874:681:0:0:0
    Nu le-a scanat automat!
