Page 1 of 3 123 LastLast
Results 1 to 15 of 41
Thread: Vu + Uno 4K
    Thumbs up Vu + Uno 4K
    Vu + Uno 4K
    http://vuplus.com/sub/sub0115.php
    Vu+ UNO 4K instalacion y funcionamiento:
    https://www.youtube.com/watch?v=1koJ9-j1QyQ
    Satelitný prijmač VU+ UNO 4K:
    https://www.youtube.com/watch?v=HOmAUFSY56c
    Thumbs up Open Source 3.0 VU+ Uno4k Image
    http://code.vuplus.com/download/boxi...043629_usb.zip
    OpenATV 5.3 VU+ Uno4k Image
    http://images.mynonpublic.com/openat...p?open=vuuno4k
    Thumbs up VuPlus FBC DVB S2X ?
    VuPlus FBC DVB S2X
    a aparut in oferta de la satmultimedia.ro
    VU+ Plus UNO 4K UHD DualCore Linux Receiver----------Pret: Lei 1.355
    succes tuturor
    ---------- Post added at 09:31 ---------- Previous post was at 08:48 ----------
    http://code.vuplus.com/index.html?ac...&model=vuuno4k
    VU+ UNO 4K - Unboxing
    https://youtu.be/43QgvM15I-Y
    Vu+ UNO 4K - Rýchlosť prepínania programov - Fast Channel Change [SatelitnaTV.sk]
    https://youtu.be/H8LGNUiOpX0
    Thumbs up New VTi - Vu+ Team Image - VTi 11.0.x
    From VTi Team
    VTi Panel (Blue Button)
    Supported languages:
    English, German, Dutch, Italian, Turkish, Danish, Polish,
    Russian, Ukrainian, Czech, Arabic, French, Swedish,
    Portuguese (Portugal), Greek, Bulgarian, Hungarian
    With modular, flexible VTi skins
    VTi Bootlogos and Radiomode Logo.
    Short press on blue button opens VTi Panel, long press opens Pluginmenu
    Support for FTDI chipset cardreader like smargo and easymouse2
    Running Softcam shown in the Infobar
    MovieList with extended functions
    Support for full image backup and restore (not Vu+ Solo 4K / Uno 4K)
    Supports VTi image flash online (not Vu+ Solo 4K / Uno 4K)
    Restore Plugins, Bouquets, Settings, etc. during installation
    Remove preinstalled packages during installation (VTi Zero)
    Basic image information
    Build tree: openvuplus-3.0 (more)
    Kernel: 3.14.28 (Solo 4K, Uno 4K, Ultimo 4K)
    Kernel: 3.13.5 (Solo², Duo², Solo SE, Zero)
    Kernel: 3.9.6 (Duo, Solo, Uno, Ultimo)
    Gstreamer: 1.6.4
    HbbTV-Browser: Opera (Solo², Duo², Solo SE, Zero)
    HbbTV-Browser: WebKit (Solo 4K, Uno 4K, Ultimo 4K)
    CHANGELOG
    - default skin: VuHD1080p (Solo 4K, Uno 4K, Ultimo 4K, Duo2, Solo2, Solo SE, Zero, Ultimo)
    - default skin: MuteSpectator (Duo, Solo, Uno)
    - Update OpenWebinterface -> ver. 1.x
    - Switch from libav to ffmpeg
    - Update dvbapp2
    optimize showing available tuners (see: VuHD1080p skin)
    CI improvements (e.g. scrambled DVB-S2 / DVB-T2 with H.265 codec)
    display tuner name during tuner setup
    show correct color button function in InfoBar (see: VuHD1080p skin)
    display skin errors
    support horizontal listboxes (THX @hmmmdada)
    support eWall (THX @hmmmdada)
    alternative service list (horizontal)
    MediaPlayer: Skip to files with SMS-type input
    SleepTimer: allow standby also when screens are opened
    support power schedules
    new EPG matrix mode (press help to see functions)
    support automatic audio-/subtitle-track selection
    support Autotimer in all preinstalled EPG views
    show Choicelist with button "OK" for setup selections in setup screens
    support HbbTV fpr remote channels
    show search key at SMS-type input in service list (see: VuHD1080p skin)
    map CH+/CH- button for page up / page down in setup screens
    map button cross down to list old timeshift files
    support autofs for network shares
    support extplayer (serviceapp plugin by mx3l)
    Upgrade 9.0.X
    http://www.mediafire.com/file/nj431b...11-0-0_usb.zip
    VU+ Uno4k
    https://youtu.be/m2k__vjkffo
    se confirma ca tunerul este VuPlus FBC DVB- S2(X)_V1.0 2016.10.18-------------secunda 0.17
    thx to:wojtek0706
    https://youtu.be/uCakfp33Y9A
    Thumbs up OpenViX 4.2. VU+ Uno4k Image
    openvix: release 4.2.021
    Merge branch 'Dev'
    [ButtonSetup] Add streaming clients.
    [UsageConfig.py] PEP8 clean up and tidy up (#54)
    Use debug and error log level for python loggings (#541)
    Hide volumebar when mute and show when unmute
    ServiceInfo: Indicate IS_4K with some margin
    openvix: developer 4.2.021.005
    openvix: developer 4.2.021.004
    [MovieSelection] Tweaked context menu.
    openvix: developer 4.2.021.003
    openvix: developer 4.2.021.002
    [Translations] Update FI, thanks Samzam!
    Merge pull request #52 from rimasx/patch-1
    Update et.po
    [About] Remove recently added R/C-info, as it doesn't work properly for all hardware.
    Merge pull request #51 from original-birdman/Dev
    Ensure that zero does not get written to the remote control proc file.
    [TimeShift] add a repeat loop to allow more time to get tuner lock.
    openvix: developer 4.2.021.001
    [vuplus] Update libvugles2(uno4k, ultimo4k)
    [vuplus] [kodi] fix crash bug.
    [libdvbsi] update to last git rev
    [vuplus] update driver (ultimo4k)
    [openatv] azbox e2 patch only for master branch dont merge to 4.0 branch
    [ew7362] [vg2000 & vg5000] repack driver zip file
    fix build enigma2-plugin-systemplugins-serviceapp with new gcc on arm plattform
    [showiframe] fix openvix logo issue and fix play2 greenscreen
    [xcore] drivers update Changes Fixed the wake up issue after 18h 13m of deepstandby without timer on OS mini+ and SPYCAT mini+ Added a workaround for few radio channels without PCR
    [tripledot] vg2000 and vg5000 fix av out and optimise ci
    [entwopia] update drivers ew7362 fix a/v out
    dvbsnoop - fix silly mistake last commit...
    dvbsnoop - bump PR. had be reverted as it breaks build old boxes.
    Revert "dvbsnoop: move to PersianPros on github."
    Merge branch '3.4-iptables' into 3.4
    vuplus: bump kernel
    vuuno4k: add iptables modules
    vuultimo4k: add iptables modules
    vusolo4k: add iptables modules
    vusolo2: add iptables modules
    vuzero: add iptables modules
    Merge pull request #144 from persianpros/patch-1
    [azbox] update e2_pcr.patch for openatv
    [vuplus] fix uno4k pvr
    chromium fix depends issue multi build environment
    add missing module
    vusolose: iptables
    [OpenWebif] Fix truncated lines
    [OpenWebif] Fix last commit
    [OpenWebif] Prepare 1.1 No. 2
    [vuplus] update drivers(uno4k, ultimo4k) - Fix HDMI IN(ultimo4k) - Fix DVB-CI and PiP
    [3rd-party-feeds] Update.
    [openatv] wetek e2 merge now to atv main e2 git
    openbh: release 0.6.020
    [openMips] roll out packages themes webtv vxg of enigma2-plugin-extensions-openwebif only for boxes not having MACHINE_FEATURES smallflash
    [vuplus] update more drivers
    [OpenATV] PR bump
    [OpenATV] OWIF module selection All machines: - WebTV
    [OpenWebif] Prepare for 1.1 - READ! Beginning with version 1.1 OWIF will be modular: You can have OWIF with or without Themes and with or without WebTV and with or without VXG (WebTV support for Chrome) (more features as modules might come later)
    http://www.openvix.co.uk/index.php/d...ages/vu-uno4k/
    i​Black Hole 3.0.3 Kodi​ VU+ Uno4k Image
    Merry Christmas from the Black Hole Team
    What is new ?​
    - Add Support for Uno4K and Ultimo4K
    - Update default skin MX HQ10 for extra tuners
    - Update skin api
    - Update OpenMultiboot
    INFO: This Image has the latest drivers but CAN be installed in OpenMultiboot. The image does not need to be installed in flash.
    This latest version of the Black Hole series has been updated and improved for maximum stability and performance.
    - Integrated OpenEpg
    - Rytec dedicated epg.dat
    - New system epg.dat outside.
    This last feature offers the possibility to various forums or communities to create their favorite EPG data files and load them into a web space.
    Download EPG from any channel
    Yellow button = Audio menu
    Addons
    Infobar / OSD
    Analog Clock Gui
    Channel orbital location
    Signal SNR, BER
    Infobar picons
    Blue Panel
    Extra Settings
    Black Hole Speed Up
    Devices Manager
    Usb Format Wizard
    Telnet Panel ( Telnet Panel)
    FTP Panel ( FTP Panel)
    UPnP Client Djmount
    UpnP Server Minidlna
    Pcsc Panel
    Tuner Server
    Network Browse & Mountpoints
    Info Panel
    3 - About (info)
    Memory (Memory)
    Space (capacity)
    CPU (processor)
    Process (process)
    EPG Panel
    Green Panel
    Addons (added)
    Online Feeds Settings update
    Red Panel
    BlackHole
    Avalon
    Chaos
    Ghost
    Credits
    Thanks to plnick for help obtaining missing Ultimo4K files.
    Thanks to Pedro_Newbie for Backup script.
    Thanks to Littlesat and Pli Team for the original autolanguage and subtitle options code
    DISCLAIMER
    LICENSE (TERM OF USE)
    This is free hobbyist software and it comes with absolutely no warranty. Use it at your own risk.​
    https://www.easypaste.org/file/NeFtq...86.zip?lang=pl
    VTi 11.0.1- Vu+ Uno 4K Image
    Vom VTi Team
    VTi Panel (Blaue Taste)
    New VTi - Vu+ Team Image - VTi 11.0.1
    From VTi Team
    23.12.2016 - Software Update
    - increase image version: VTi 11.0.1
    - update driver 20161223 (solo4k, uno4k, ultimo4k)
    fix motorized dish (ultimo4k, uno4k)
    fix PES filter
    fix FastForward
    fix DTS media playback problem
    support 2160p24, 2160p25, 2160p30 video mode
    support DTS-HD MA Passthrough (needs modified gstreamer)
    fix Refresh rate
    fix misc and add more video codecs
    - update dvbapp2 20161223
    [MovieList] improve grouping movies
    fix misc. bugs
    - update plugin videomode autoframerate
    [INFO] autoframerate is not needed anymore for uno4k, ultimo4k, solo4k
    driver supports now frame rate swapping
    choose frame rate multi or multi (50/60/24p)
    https://www.4shared.com/zip/LRHyRsZY...612231237.html
    rudream-5.0 VU+ Uno4k Image
    update :23-12-2016
    rudream-5-vuuno4k_usb
    https://docviewer.yandex.com/?url=ya...c=585e4a7ecbb3
    http://code.vuplus.com/download/boxi...165848_usb.zip
    Vu+ Uno4K Tested for You
    Thanks @Evo
    Vu+ Uno4K Review.pdf:https://www.sendspace.com/file/5b9xdm
    Black Hole 3.0.3.A Kodi VU+ Uno4k Image
    What is new ?​
    - Update default skin MX HQ10 to fix some plugin issues
    - Update skin api to fix some plugin issues
    - Update Unicable and Unicable II LNB support​
    http://www.4shared.com/zip/10AJ1t3eb..._usb_rele.html
    https://docviewer.yandex.com/?url=ya...c=586a43af5259
    Backup VU+Uno 4k by mika22
    http://www.mediafire.com/file/a55tu3...up_vuuno4k.rar
    openATV 5.3 backup by @mika
    http://venuscs.net/SvPverzijaAUTO/en...el_6.1_all.ipk
    http://www.openvix.co.uk/openvix-bui...uuno4k_usb.zip
    http://code.vuplus.com/download/boxi...170018_usb.zip
    SFTEAM image 5.1 VU+ Uno4k Image
    http://images.sfteam.es/download.php...d4w8y5j2j3u6n8
    OpenPLi-5.0-beta-kodi16.1 VU+ Uno4k Image
    http://www48.zippyshare.com/v/r7XCSEUT/file.html
    Open ATV 6.0 VU+ Uno4k Image
    http://code.vuplus.com/download/boxi...172842_usb.zip
    OpenViX 4.2.030 VU+ Uno4k Image
    http://code.vuplus.com/download/boxi...170955_usb.zip
    OpenDroid 6.0 VU+ Uno4k Image
    http://images.opendroid.org/6.0/VU+/...170219_usb.zip
    http://code.vuplus.com/download/boxi...164538_usb.zip
    OpenESI 4.0 VU+ Uno4k Image
    http://www.openesi.eu/images/images/...VU%2B/vuuno4k/
    http://code.vuplus.com/download/boxi...165116_usb.zip
    http://images.opendroid.org/6.0/VU+/...170225_usb.zip
