Page 45 of 102 FirstFirst ... 354142434445464748495595 ... LastLast
Results 661 to 675 of 1528
Thread: cnx-software News
  1. #661
    NewsBot Supreme Member
    18 Jun 2016
    Default This Smartphone Tripod with Microphone is Designed for Audio/Video Rec
    More and more use cases are being handled by smartphones, and we’ve recently seen smartphone stands helping with specific applications such as keyboard and mouse mobile gaming, or a flexible...
    More...
    Primebook Laptop Runs Android based PrimeOS with Start Menu, Multi-Tasking Support, Key Mapping, etc…
    After solutions such as Remix OS and Phoenix OS, PrimeOS is the latest attempt to bring Android OS to the desktop with support for a start menu, a status bar with pinned apps, multiple windows &...
    More...
    Making a DIY Case Out of PVC Pipes & Fittings for Electronics Projects
    If you’ve ever visited Thailand, you may have noticed blue PVC pipes that are for water supplies, and usually visible since most of the time they are not placed underground. The pipes and...
    More...
    24 Orange Pi Zero Boards Cluster and ArmWizard’s Debian Image
    ArmWizard forum member “-W.-” needed a cluster to test his firmware build and deployment solution for Orange Pi Zero boards which can deploy the firmware to multiple boards from one...
    More...
    Run Linux Apps in (PixelBook) Chromebook with Crostini VM
    Ever since the first Chromebooks were released, it has been possible to run Ubuntu or other Linux distributions using Crouton (Chromium OS Universal Chroot Environment) on Chrome OS devices, but that...
    More...
  2. #662
    18 Jun 2016
    Default Pepper Jobs W10 GYRO is an Air Mouse Designed for Windows 10
    Air mice are remote controls including motion sensors allowing to wave the remote to emulate a mouse, as well as some buttons like in a standard remote control, and in some cases a keyboard. Some...
    More...
    Ubuntu 18.04 Released – What’s New?
    Canonical should release Ubuntu 18.04 “Bionic Beaver” long term support distribution later today. One of the most obvious change compared to Ubuntu 16.04 is the switch from Unity to GNOME...
    More...
    QEMU 2.12 Released with Raspberry Pi 3, RISC-V Support
    QEMU is open source machine emulator and virtualizer, which I used in the past at a time when Arm boards were more expensive or hard to get than today, and more recently I tested RISC-V Linux using...
    More...
    How-to Make Your Own 3D Printing Goo
    Karl here…just want to do a little post about bed adhesion and what I have been doing for the past month. What spurred this is I saw a ton of videos on Magigoo a while back. It is a product...
    More...
    Working on High Quality Low Cost DIY 3D Scanning using Structured Light
    Hello all, Karl here. I just wanted to send a note about what I have been working on. As the title says shows it is about 3d scanning. I have found it pretty fascinating so far. These are mainly...
    More...
    Xiaomi Mi AI Speaker Mini Smart Speaker is Selling for $27 (in China)
    Smart speakers are becoming cheaper and cheaper, and in the US and some other countries, Amazon Echo Dot can be purchased for under $50. But Xiaomi has come up with an even cheaper model – for...
    More...
  3. #663
    18 Jun 2016
    Default ESP8266 Loader App Allows you to Flash and Debug ESP8266 Boards from A
    In case you’d like to flash ESP8266 boards using a phone, you can now do so with ESP8266 Loader app for Android, which also gives you access to the serial console. All you’ll need to an...
    More...
    Acme Systems CM3-PANEL Panel PC based on Raspberry Pi Compute Module 3 Sells for 99 Euros and Up
    After their first Raspberry Pi Compute Module 3 based board called CM3-Home designed for home automation, Acme Systems has designed a new RPi CM3 carrier board called CM3-PANEL for panel PCs /...
    More...
    AAEON Releases an Intelligent Vending Machine Development Kit based on UP Board
    UP board is a low cost development board powered by an Intel Atom x5-Z8350 Cherry Trail processor with 1GB to 4GB RAM, and 16 to 64GB eMMC flash that mostly follows Raspberry Pi 3 form factor. AAEON...
    More...
    XH-M452 Board Helps Controlling a Cabinet or Room’s Temperature & Humidity
    XH-M452 is a board designed to control the temperature and humidity in a room or cabinet. It comes with two relays to control appliances like fans, air conditioners, (de-)humidifiers, or heaters, and...
    More...
    NXP QorIQ LayerScape LX2160A is a 16-core Arm Cortex A72 Communication Processor with 100 Gbit/s Ethernet
    NXP Semiconductors has been working on a high-end communication processor with their QorIQ LayerScape LX2160A SoC equipped with 16 Arm Cortex A72 cores, 16 Ethernet ports supporting 1 to 100 Gbit/s,...
    More...
    Microchip Offers Free PIC16F18446 8-bit MCU Development Boards
    Microchip announced several PIC and AVR microcontrollers with “Core Independent Peripherals and Intelligent Analog” in February with respectively PIC16F18446 family of microcontrollers,...
    More...
    Arm Cortex M35P Armv8-M MCU Core Gets Physical Security with Anti-tampering Features
    Armv8 and Armv8-M processor already support Arm TrustZone security, which aims to prevent software attacks against the target device. However, if a hacker has physical access to the hardware, it may...
    More...
    Ebyte Offers Low Cost Wireless Modules for LoRa, Zigbee, NB-IoT, Bluetooth, and More
    Chengdu Ebyte Electronic Technology Ltd (or just Ebyte for short) is a company based in Western China that design and manufacturer low cost wireless modules for LoRa, WiFi, Bluetooth, Zigbee, NB-IoT...
    More...
    Hardkernel & Libre Computer Release Ubuntu 18.04 Images for ODROID-XU4/3 & AML-S905X-CC Boards
    Ubuntu 18.04 “Bionic Beaver” LTS operating system was released just last week, and at least two Arm board companies have independently released Ubuntu 18.04 images for their boards....
    More...
    XTRX SDR Mini PCIe Card Supports 10 MHz to 3.8 GHz Tuning Range, up to 120 MSPS Sample Rate
    Fairwaves is a startup that aims to make deploying and operating mobile networks in rural regions profitable, and their latest project is called XTRX, a high performance Software Defined Radio (SDR)...
    More...
  4. #664
    18 Jun 2016
    Default MIPS I7200 Processor Core with nanoMIPS Architecture is Designed for L
    MIPS has recently unveiled the I7200 multi-threaded multi-core processor for advanced LTE/5G communications and networking SoCs, which also happens to be the first MIPS core based on the new nanoMIPS...
    More...
    HiFive Unleashed RISC-V Linux Development Board Gets a $2000 FPGA Expansion Board
    If you’re a RISC-V architecture’s enthusiast or represent a company working on products with the new ISA, you may have spent $999 or more on Hifive Unleashed RISC-V Linux development...
    More...
    Ubiquiti EdgeRouter X is a $60 Gigabit Ethernet PoE Router Supported by OpenWrt
    Stanislav needed a Gigabit Ethernet router to run OpenVPN, and after some research he settled on Ubiquiti EdgeRouter X router with 5 Gigabit Ethernet ports, PoE in and pass-through, with a decent 256...
    More...
    Review of Ubuntu 18.04 on ODROID-XU4Q Development Board
    Hardkernel released their first Samsung Exynos 5422 octa-core board in July 2014 with ODROID-XU3, which at the time was really a powerful board, but also pricey at $179. Later that year, the company...
    More...
    Allwinner Unveils A40i/A40pro and A60i/A60pro Industrial & Military Grade Processors
    Allwinner A20 dual core Cortex A7 processor was/is one of the most popular Allwinner SoCs thanks to its low cost, the availability of interfaces such as SATA, Gigabit Ethernet, HDMI 1.4, and...
    More...
    Lenovo Introduces Mirage Solo Daydream Standalone Virtual Reality Headset & Mirage Camera for VR180 Video Recording
    Standalone / All-in-One Android virtual reality headsets have been around for a couple of years, mostly from Chinese vendors. But the number and quality of VR apps available were rather low at the...
    More...
    More...
    More...
    More...
    More...
  5. #665
    18 Jun 2016
    Default Microchip Offers Free PIC16F18446 8-bit MCU Development Boards
    More...
    More...
    More...
    More...
    More...
    Amlogic S905D2 Quad Core Cortex A53 Processor Coming Soon with Google Fuchsia Support
    Earlier today, I wrote about the latest version of USB Burning Tool, and noticed added support for Amlogic “905D2” processor in the changelog. I had heard about Amlogic S905X2, but...
    More...
    USB Burning Tool v2.16 for Amlogic Processors Released
    Amlogic’s USB Burning Tool is a Windows based tool used to upgrade devices based on Amlogic processors over USB. Most devices now implement OTA firmware updates, so in most cases it is not...
    More...
    Chrome 67 to Support the Generic Sensor API for Accelerometers, Gyroscopes, and Fusion Sensors
    Once upon a time, web browsers were used to… well, browse the web, but overtime, features and API have been added to run apps with the ability to control hardware like webcams using the Media...
    More...
    The World’s Smallest ESP8285 WiFi Module?
    Taiwan based Blkbox may have designed the world’s smallest WiFi IoT module with their Espressif Systems ESP8285 based BB-E01P module pin-compatible with ESP-01 module, and measuring just...
    More...
    Easily Make DIY Battery Packs with this Building Kit for 18650 Batteries (Crowdfunding)
    If you have a project that requires some serious battery power, and can’t find a battery pack that matches your requirements, making your own is possible, but usually expensive as the commonly...
    More...
  6. #666
    18 Jun 2016
    Default TTGO T5 is an ESP32 WiFi + Bluetooth Board with ePaper Display and Spe
    Lilygo has made another ESP32 board part of their TTGO family with TTGO T5 board powered by Espressif System ESP32 WiFI & Bluetooth SoC, and offering a choice of ePaper displays from 1.54″...
    More...
    Measy RCA220 is a $35 Wireless AV Transmitter / Receiver Kit with a 200m Range
    There are several ways to send video & audio data over a distance without using long cables, from professional DVB-T transmitters with up to 10km range, to cheaper DIY SDR solutions with a...
    More...
    Ugoos Releases Android 7.1.2 Nougat (Beta) for Rockchip RK3288 TV Boxes
    Rockchip RK3288 quad core Arm Cortex A17 processor was first released in early 2014 with Android 4.4, and TV boxes that are still sold with the processor – e.g. Lenovo G66 – often still...
    More...
    Jorjin WS2118/WS2119 is a Sigfox & Bluetooth LE Module Based on STMicro BlueNRG-1 & S2-LP Chips
    Jorjin WS211X is a family of certified dual radio modules combining Sigfox wireless technology thanks to STMicro BlueNRG-1 BLE System-on-Chip (SoC) and Bluetooth Low Energy (BLE) using STMicro S2-LP...
    More...
  7. #667
    18 Jun 2016
    Default XH-M452 Board Helps Controlling a Cabinet or Room’s Temperature & Humi
    More...
    More...
    More...
    More...
    More...
    More...
  8. #668
    18 Jun 2016
    Default A 6-Part BeagleBone Webinar for Users, Developers and Education Starts
    The BeagleBone Black and derivatives like PocketBeagle or BeagleBone Green Wireless are still popular development boards, and if you are interested in the platform as a developer, user, or educator,...
    More...
    Armbian History, Infrastructure, and Progress Report
    Many of us rely on Armbian Debian and Ubuntu images for our cheap Arm development boards since they usually offer better support than vendor supplied firmware images. The community has just updated...
    More...
    Android Things 1.0 Released with Support for NXP i.MX 8M, Qualcomm SDA212/SDA624 and Mediatek MT8516 SoMs
    Brillo Project was renamed to Android Things with the release of a developer preview back in December 2014, and the operating system enabling developers and companies to build and maintain Internet...
    More...
    More...
    More...
    More...
    More...
    More...
    More...
    More...
  9. #669
    18 Jun 2016
    Default CrowPi is a Portable Learning Kit for Raspberry Pi 3 B+ / Zero Boards
    We have an embarrassment of choices for Raspberry Pi accessories from touchscreen displays, HAT add-ons boards, sensors, breadboard, and so on, as well as good software and support from Raspberry Pi...
    More...
    Wear OS by Google Developer Preview 2 Adds Actions on Google (AoG) Support and Power-related Enhancements
    Google has released the second developer preview of Wear OS by Google – previously known as Android Wear – that adds support for Actions on Google (AoG) and power-related enhancements...
    More...
    Toradex Launches Apalis iMX8 Computer-on-Module based on NXP i.MX 8QuadMax SoC
    Toradex Apalis iMX8 is another system-on-module powered by NXP i.MX 8QuadMax hexa core Arm Cortex A72 + 53 processor, which comes with 4GB LPDDR4 RAM, up to 16GB flash, and an on-board dual-band...
    More...
    Two Interesting Projects on Github: Zigbee to MQTT bridge & “Deep Painterly Harmonization”
    Hey Karl here. I thought I would try and showcase some GitHub projects that I run into that seem interesting or fun. This week I will start out with 2 projects. Zigbee to MQTT bridge The first one...
    More...
    Vorke V5 Plus Kaby Lake Mini PC Review with Windows 10 and Ubuntu 18.04
    The Vorke V5? Plus?? mini PC? just goes to show how initial impressions can be very misleading. Arriving in a plain manila-coloured box with the protection film on the top of the ?device starting to...
    More...
    Microsoft Introduces Project Kinect for Azure
    Kinect started as as motion sensing input device for Xbox 360 & One game consoles with an integrated webcam, infrared projector, and a microphone array, which enabled it to detect depth, motion,...
    More...
    Google ADT-2 is an Android TV Dongle for Developers
    You may remember we covered a “4K ATV Stick” last month, as a mostly unknown manufacturer (Shenzhen SEI Robotics) applied for FCC certification, with the device featuring a large G...
    More...
    Google Assistant Adds 6 New Voices, Supports Smart Displays, Will Expand to 80 Countries
    We’ve already seen announcements about Android P and Android Things 1.0 for Google I/O 2018, but the company also took the opportunity to provide an update to the new features coming to Google...
    More...
    Android P Beta Released. What’s New?
    Last March, Google released Android P developer preview with new features such as indoor positioning with WiFi RTT, support for display notch, HDR VP9, HEIF image compression, a new API to access two...
    More...
    Mi Mini PC is a $150 Pocket-Sized Windows 10 Mobile PC with a 5? Touchscreen Display (Crowdfunding)
    Around 2 years ago, I reviewed GOLE1 mini PC running Windows 10 and Android 5.1, powered by an Intel Atom x5-Z8300 Cherry Trail processor with 4GB RAM and 64GB SSD. It also came with a 5″...
    More...
  10. #670
    18 Jun 2016
    Default Google ADT-2 is an Android TV Dongle for Developers
    More...
    More...
    More...
    More...
    More...
    More...
    More...
    More...
    More...
    More...
  11. #671
    18 Jun 2016
    Default Google Assistant Adds 6 New Voices, Supports Smart Displays, Will Expa
    More...
    More...
    More...
    More...
    More...
  12. #672
    18 Jun 2016
    Default How to Run Chrome OS in Android Emulator
    While it’s possible to run the open source Chromium OS in your computer or a virtual machine, AFAIK there was only was way to test Chrome OS: purchasing an actual Chromebook, or other device...
    More...
    NeTV2 Open Video Development Board Works with Encrypted and Unencrypted Video Streams (Crowdfunding)
    Chumby NeTV was an open source hardware Linux IPTV media player based on a Xilinx Spartan FPGA and a Marvell Armada 166 processor, and unveiled in 2011. Many years have passed since then, and now...
    More...
    Astro Design HDMI Test Equipment Supports 8K @ 120 Hz
    8K media players and 8K TVs are coming, but if you develop one of those products how do you test them since 8K players/TVs are not available just yet. Answer: Test equipment. Astro Design offers just...
    More...
    Lenovo IdeaPad 330 Gemini Lake Laptops Sell for $250 and Up
    We’ve previously seen companies unveil Gemini Lake laptops but at price points ($400 to $600) that did not seem right, considering Gemini Lake (GLK) processors should cost about the same as the...
    More...
    Newport GW6400/GW6404 Arm SBC Comes with 5 Gigabit Ethernet Ports, 2 SFP Fiber Ports, and 4 mPCIe Sockets
    Gateworks introduced their Newport SBC family based on Cavium Octeon TX Dual/Quad Core Arm processors at the end of last year, and the company has now announced the availability of the higher end...
    More...
    More...
    More...
    More...
    More...
    More...
  13. #673
    18 Jun 2016
    Default Sens’it Discovery is a Sigfox IoT Solution with 6 Sensors
    Sigfox has just launched Sens’it Discovery, which they describe as a “end-to-end IoT solution, which aims to accelerate the adoption of the IoT (Internet of things) among business and...
    More...
    Intel NUC Kit NUC7PJYH Review – An Intel Gemini Lake Pentium Silver J5005 Barebone Mini PC
    When Intel released their latest NUC Gemini Lake mini PCs they prioritized cost over performance. As a result the processor they chose for the ‘Intel NUC 7 Essential’ mini PC is somewhat...
    More...
    AsteroidOS 1.0 Released – An Open Source Linux OS for Wear OS Smartwatches
    We first discovered AsteroidOS, a Linux based open source operating system working on some Android Wear (now Wear OS by Google) smartwatches, in early 2016 while looking at FOSDEM 2016 schedule. The...
    More...
    YC-CDA19Q is an 8-Port Quick Charge 3.0 Capable USB Charger with a Display Showing Power Consumption
    USB charger doctor is a cheap and easy way to monitor the voltage and current from a USB 2.0 port or charger, but you may have more than one device to monitor, and USB 3.0 type C ports as well as...
    More...
    Wi-Fi EasyMesh is a Standard for WiFi Mesh Networking
    It’s been possible for add multiple WiFi routers and/or WiFi repeaters in order to provide good coverage in a house / building for years, so this required some manual configuration. So in...
    More...
    Alfawise T1 Mini PC Powered by Intel Celeron N4100 Gemini Lake Processor is Going for $200
    It’s been a long wait, but it appears it’s now possible to purchase Gemini Lake mini PCs and get them shipped within a few days. One example would be Alfawise T1 mini PC based on Intel...
    More...
    MT3620 Development Board for Azure Sphere is Up for Pre-order for $84.90
    Microsoft unveiled Azure Sphere solutions last month in order to provide a complete secure IoT solution from the hardware to the cloud with three main components: a secure MCU, Linux based Azure...
    More...
    ULEWELL Z28 MINI is a $40 RK3328 TV Stick with 2GB RAM, 16GB Storage, and a USB 3.0 Port
    While we’ve already covered many Rockchip RK3328 TV boxes and development boards, if you want a TV stick form factor the choice becomes much more limited. So far I was only aware of Rikomagic...
    More...
    Arduino Introduces Two New IoT Boards – MKR WiFi 1010 (ESP32) and MKR NB 1500 (NB-IoT + eMTC)
    Arduino introduced its MKR family of breadboard compatible maker boards with MKR1000 featuring an Atmel SAMD21 microcontroller combined with a Microchip WINC1500 WiFi module. The board was followed...
    More...
    Running out of RAM in Ubuntu? Enable ZRAM
    Whenever I ran out of RAM on a Linux system, I used to enable swap memory using the storage device to provide an extra bit of memory. The main advantage is that it’s does not require extra...
    More...
  14. #674
    18 Jun 2016
    Default Arduino Unveils its First FPGA Board with MKR Vidor 4000, Updates UNO
    Arduino has been busy with new boards announcements in the last week, as after introducing MKR WiFi 1010 and MKR NB 1500 IoT boards with respectively WiFi + Bluetooth, and NB-IoT + eMTC connectivity,...
    More...
    R-TV BOX S10+ is an Android 8.1 TV Box with a Built-in Qi Wireless Charger
    A couple of years ago we wrote about ECS Live Station, an Intel Bay Trail mini PC with an integrated wireless charger that can be used to charge any compatible smartphone. But as I was checking out...
    More...
    Spreadtrum SC9863 Octa-core Cortex A55 Processor is Made for LTE Smartphones
    Arm unveiled Cortex A55 cores about a year ago, and while we have seen the new cores combined with Cortex 75-class cores in premium smartphone processors such as Exynos 9810 SoC, I had yet to see a...
    More...
    UMIDIGI Z2 Pro is one of the first Smartphones based on MediaTek Helio P60 SoC
    MediaTek unveiled Helio P60 Cortex A73/A53 processor with AI HW acceleration a few months ago, and we were promised smartphones would start selling in Q2 2018. Mediatek’s partners seem to be...
    More...
    HP t430 Thin client Works with a Single USB Cable
    Gemini Lake mini PCs are starting to sell and ship, and from the look of it, HP t430 appears to be yet another Gemini Lake mini PC based on an Intel Celeron N4000 processor. But the device is...
    More...
    Hexabitz Modular Prototyping Platform Enables Wire-Free 3D Electronics Designs (Crowdfunding)
    A few years ago, I made a Raspberry Pi case made of perfboard and created some sort of DIY modular 3D electronics design by using the top and sides of the case to also hold electronics components and...
    More...
    Pi-Hole Kit is a Raspberry Pi based Ad Blocker
    If you don’t like getting tracked or see ads, it’s normally easy enough to install an ad blocker plugin in your web browser. But if you want to save some resources on your computer(s)...
    More...
    96Boards GPS Mezzanine is the First Add-on Board part of 96boards Community Mezzanine Initiative (Group Buy)
    96Boards hardware development platforms support add-on boards called Mezzanines, and you’ll find a bunch of them on 96Boards website. Most are designed and manufactured by companies, but in...
    More...
    XU4Q Retro Gaming System Runs ODROID GameStation Turbo, Sells for $150 and Up
    One of the use case for little Arm Linux boards is retro gaming thanks to open source projects like RetroPie, RetrOrangePi, Lakka, and others. To get a complete & usable system, it’s...
    More...
    More...
  15. #675
    18 Jun 2016
    Default AsteroidOS 1.0 Released – An Open Source Linux OS for Wear OS Smartwat
    More...
    More...
    More...
    More...
    More...
    More...
    More...
    More...
    More...
    More...
