Thanks Thanks:  26
Likes Likes:  36
Dislikes Dislikes:  1
Page 15 of 15 FirstFirst ... 51112131415
Results 211 to 225 of 225
Thread: Mut@nt digital technology ULTRA HD HD51 2160p 4K-BOX E2 Linux Receiver
  1. #211
    02 Sep 2010
    Earth
    Recomand folosirea Openatv 6.4 ( defauld full support ci+) si instalare de service app si satip client.
    Pentru cine vrea sa aiba ceva gata de start sunt destule aceste 2 plugin-uri.
    cine doreste si folosire de emu/cam-uri trebuie sa instaleze si alte plugin-uri.
  2. #212
    13 Post(s)
    13 Post(s)
    ATRESMEDIA 30 West Hispasat
    OK now, guys these is only for TESTING purposes and only for ARM receivers not mipsel!
    1. Download the necessary files
    2. Unzip the file
    3. Send via FTP all files to your E2 receiver running an OpenATV image EXCEPT dabstreamer. Files go to /usr/bin. If prompted to replace any files DO NOT replace.
    4. Give 755 permission to all files you sent to /usr/bin
    5. Send dabstreamer file to /etc/init.d, also give 755 permission
    6. Open a telnet session to your box and give this command, so dabstreamer runs at startup by default
    update-rc.d dabstreamer defaults 50
    7. Follow all instructions for adding FAN3 to your favourites list given in previous posts.
    Hopefully everything will work, note that for Silabs tuners, there might be problems locking the TP steadily!
    https://www.mediafire.com/file/mwrfx...S-ARM.zip/file
    thanks to:mcelliot_g
  4. #214
    6 Post(s)
    Azi am primit un mutant 51hd defect, fara video pe iesirea hdmi si nici pe av, usb frontal si cel posterior ne recunoscute 2.0, usb 3.0 ok, usb 2.0 sa dus FE1.1S USB 2.0 HUB, testat de pe un aparat donator, astept piesa noua, probemele continua, nu stiu ce este aceasta placa si ce rol are...
    Revin cu detali si logo serial.
    6 Post(s)
    Vin cu o parte din logo
    CPU 01
    BCM74390011
    PRID07251111
    v1.7
    RR:00000003
    BFW
    SEC
    seclib-1.5
    BBL v1.0.1
    AVS init...
    spare0/rmon_hz=017f7672
    spare1/rmon_vt=017f7572
    AVS init OK
    AVS load:select_image: addr_offset: 00051000 part_offset: 00000000 bootStatus: 2a002b00
    AVS load_code offset =00051000
    AVS: OTP Decrypt 0x00000000, OTP Verify AVS 0x00000000
    LOADED
    single board
    select_image: addr_offset: 00055000 part_offset: 00000000 bootStatus: 3d2b2500
    MemsysFW: OTP Decrypt 0x00000000, OTP Secure Boot 0x00000000
    SHMOO 01020000 BLD:9695 HW:hpf0_b1p6 V:1.2.0.0
    MCB: FIX
    AVS start:status=000000ff
    STB: Current voltage=0000039c(924)
     temperature=00009822(38946)
     PV=00000358(856)
     MV=0000039c(924)
    AVS FW rev=30333078 [0.3.0.x]
    OK
    DDR0: *@ ffe0ba98 <= ffe0ba98 MEMSYS-0 @ f1100000 OK
    DDR1: -
    Sdram Scramble OTP = 0x00000001
    Sdram Scramble OK
    select_image: addr_offset: 00020000 part_offset: 00000000 bootStatus: 1b25252b
    BFW load mode OTP = 0x0000000f
    bfw_hash_locked = 0x00000000
    BFW key3 OK, BFW load OK
    BFW v2.1.0
    COPY CODE... DONE
    OTP SSBL Encrypt 0x00000000
    OTP Sec Boot 0x00000000
    OTP read MichEn 0x00000000
    MICH: disable success
    SSBL
    no v092_to_v095 conversion is performed
    PINMUX
    CACHE FLUSH OK
    MMU ON
    CACHE FLUSH OK
    _fbss  0704cff0
    _ebss  0704eab8
    _end   0704ead8
    HEAP @ 07100000
    STACK @ 09200000
    ARCH: CONFIG OK
    CLR BSS 0704cff0 to 0704eab8 OK
    CLR SRAM  OK
    CACHE FLUSH OK
    CPU CLKSET OK
    GO!
      ,'/___, BOLT v1.07 v1.07-r27 hd51
    .'__  ,'  (2019-05-15 )
       /,'    Copyright (C) 2019 Broadcom Corporation
    Board: BCM97251SSV
    SYS_CTRL: product=72511, family=7439b1, strap=000000b2,
    otp @ 0xf0404030 = 0x822080e0: en_cr(0x00000060) en_testport(0x00000080) macrovision_disable(0x02000000) memsys_1_disable(0x00008000) moca_disable(0x80000000) rv9_disable(0x00200000)
    otp @ 0xf0404034 = 0x00000461: moca2_disable(0x00000001) pcie1_disable(0x00000040) rfm_disable(0x00000020) sata1_disable(0x00000400)
    CPU: 2x A15, 1719 MHz
    SCB: 432 MHz
    DDR0 @ 1061MHz, DDR1 N/A
    CS0: SFDP SPI, 8MB, 64kB blocks, 256B pages
    CS1: NAND: unrecognized ID: 0xffffffff 0xffffffff
    RTS0: 0x1101004, 256 clients, ok
    RTS1: 0x1181004, 256 clients, ok
    BOX MODE: 1
    AVS: park check
    AVS: temperature monitoring enabled
    AVS: STB: V=0.919V, T=+39.433C, PV=0.856V, MV=0.924V, FW=30333078 [0.3.0.x]
    USB otp=00000040
    board selection update!
    board was ?, now a (flags:0xffe00000)
    Loader:zimg Filesys:raw Dev:emmcflash0.linuxkernel File:(null) Options:root=/dev/mmcblk0p3 rootsubdir=linuxrootfs1 kernel=/dev/mmcblk0p2 rw rootwait hd51_4.boxmode=1
    Reading 4782416 bytes from zImage...........
    Starting program at 0x8000 (DTB @ 0x761c000)
    [    0.000000] Booting Linux on physical CPU 0x0
    [    0.000000] Linux version 4.10.12 (oe-user@oe-host) (gcc version 9.2.0 (GCC) ) #1 SMP Sun Oct 31 17:58:38 UTC 2021
    [    0.000000] CPU: ARMv7 Processor [420f00f3] revision 3 (ARMv7), cr=30c5387d
    [    0.000000] CPU: div instructions available: patching division code
    [    0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
    [    0.000000] OF: fdt:Machine model: BCM97251SSV
    [    0.000000] cma: Reserved 440 MiB at 0x0000000014800000
    [    0.000000] cma: Reserved 192 MiB at 0x0000000030000000
    [    0.000000] Memory policy: Data cache writealloc
    [    0.000000] percpu: Embedded 14 pages/cpu @d3ddd000 s26764 r8192 d22388 u57344
    [    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 260416
    [    0.000000] Kernel command line: root=/dev/mmcblk0p3 rootsubdir=linuxrootfs1 kernel=/dev/mmcblk0p2 rw rootwait hd51_4.boxmode=1 brcm_cma=440M@328M brcm_cma=192M@768M console=ttyS0,115200
    [    0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
    [    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
    [    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
    [    0.000000] Memory: 380524K/1048576K available (6675K kernel code, 365K rwdata, 1844K rodata, 352K init, 215K bss, 20884K reserved, 647168K cma-reserved, 65536K highmem)
    [    0.000000] Virtual kernel memory layout:
    [    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    [    0.000000]     fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
    [    0.000000]     vmalloc : 0xf0800000 - 0xff800000   ( 240 MB)
    [    0.000000]     lowmem  : 0xc0000000 - 0xf0000000   ( 768 MB)
    [    0.000000]     pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
    [    0.000000]     modules : 0xbf000000 - 0xbfe00000   (  14 MB)
    [    0.000000]       .text : 0xc0008000 - 0xc068d2e8   (6677 kB)
    [    0.000000]       .init : 0xc088a000 - 0xc08e2000   ( 352 kB)
    [    0.000000]       .data : 0xc08e2000 - 0xc093d790   ( 366 kB)
    [    0.000000]        .bss : 0xc093f000 - 0xc0974ff4   ( 216 kB)
    [    0.000000] Hierarchical RCU implementation.
    [    0.000000]  Build-time adjustment of leaf fanout to 32.
    [    0.000000]  RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2.
    [    0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=32, nr_cpu_ids=2
    [    0.000000] NR_IRQS:16 nr_irqs:16 16
    [    0.000000] irq_brcmstb_l2: registered L2 intc (mem: 0xf0805000, parent irq: 16)
    [    0.000000] irq_brcmstb_l2: registered L2 intc (mem: 0xf0807000, parent irq: 17)
    [    0.000000] irq_brcmstb_l2: registered L2 intc (mem: 0xf0809640, parent irq: 18)
    [    0.000000] irq_brcmstb_l2: registered L2 intc (mem: 0xf080b200, parent irq: 19)
    [    0.000000] irq_bcm7120_l2: registered BCM7120 L2 intc (mem: 0xfc40a700, parent IRQ(s): 2)
    [    0.000000] irq_bcm7120_l2: registered BCM7120 L2 intc (mem: 0xf080d380, parent IRQ(s): 3)
    [    0.000000] brcmstb: biuctrl: MCP: Write pairing already disabled
    [    0.000000] arm_arch_timer: Architected cp15 timer(s) running at 27.00MHz (virt).
    [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x63a1e71a3, max_idle_ns: 440795203123 ns
    [    0.000004] sched_clock: 56 bits at 27MHz, resolution 37ns, wraps every 4398046511093ns
    [    0.000012] Switching to timer-based delay loop, resolution 37ns
    [    0.000291] Console: colour dummy device 80x30
    [    0.000313] Calibrating delay loop (skipped), value calculated using timer frequency.. 54.00 BogoMIPS (lpj=27000)
    [    0.000324] pid_max: default: 32768 minimum: 301
    [    0.000430] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
    [    0.000436] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
    [    0.000894] CPU: Testing write buffer coherency: ok
    [    0.001147] CPU0: update cpu_capacity 1024
    [    0.001154] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
    [    0.001372] Setting up static identity map for 0x8440 - 0x8498
    [    0.003677] smp: Bringing up secondary CPUs ...
    [    0.004401] CPU1: update cpu_capacity 1024
    [    0.004404] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
    [    0.004466] smp: Brought up 1 node, 2 CPUs
    [    0.004476] SMP: Total of 2 processors activated (108.00 BogoMIPS).
    [    0.004481] CPU: All CPU(s) started in SVC mode.
    [    0.004884] devtmpfs: initialized
    [    0.011186] VFP support v0.3: implementor 42 architecture 4 part 00 variant 0 rev 0
    [    0.011384] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275000 ns
    [    0.011401] futex hash table entries: 512 (order: 3, 32768 bytes)
    [    0.025789] NET: Registered protocol family 16
    [    0.026207] DMA: preallocated 256 KiB pool for atomic coherent allocations
    [    0.031399] cpuidle: using governor ladder
    [    0.035655] cpuidle: using governor menu
    [    0.044797] No ATAGs?
    [    0.044887] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
    [    0.044895] hw-breakpoint: maximum watchpoint size is 8 bytes.
    [    0.059665] SCSI subsystem initialized
    [    0.060856] usbcore: registered new interface driver usbfs
    [    0.060923] usbcore: registered new interface driver hub
    [    0.060971] usbcore: registered new device driver usb
    [    0.061032] Linux cec interface: v0.10
    [    0.061079] Linux video capture interface: v2.00
    [    0.061144] pps_core: LinuxPPS API ver. 1 registered
    [    0.061150] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    0.061170] PTP clock support registered
    [    0.061656] Advanced Linux Sound Architecture Driver Initialized.
    [    0.062410] clocksource: Switched to clocksource arch_sys_counter
    [    0.062618] FS-Cache: Loaded
    [    0.068681] NET: Registered protocol family 2
    [    0.069047] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
    [    0.069088] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
    [    0.069161] TCP: Hash tables configured (established 8192 bind 8192)
    [    0.069248] UDP hash table entries: 512 (order: 2, 16384 bytes)
    [    0.069274] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
    [    0.069409] NET: Registered protocol family 1
    [    0.069781] RPC: Registered named UNIX socket transport module.
    [    0.069785] RPC: Registered udp transport module.
    [    0.069789] RPC: Registered tcp transport module.
    [    0.069792] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    0.070962] hw perfevents: enabled with armv7_cortex_a15 PMU driver, 7 counters available
    [    0.072288] workingset: timestamp_bits=14 max_order=18 bucket_order=4
    [    0.072779] FS-Cache: Netfs 'nfs' registered for caching
    [    0.072911] NFS: Registering the id_resolver key type
    [    0.072932] Key type id_resolver registered
    [    0.072937] Key type id_legacy registered
    [    0.072947] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    [    0.072953] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
    [    0.073087] FS-Cache: Netfs 'cifs' registered for caching
    [    0.073135] Key type cifs.spnego registered
    [    0.073267] fuse init (API version 7.26)
    [    0.075265] bounce: pool size: 64 pages
    [    0.075318] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 251)
    [    0.075327] io scheduler noop registered
    [    0.075333] io scheduler deadline registered
    [    0.075362] io scheduler cfq registered (default)
    [    0.075757] brcm-gisb-arb f0400000.gisb-arb: registered mem: f0a09000, irqs: 47, 48
    [    0.076068] brcm-sata-phy f0458100.sata-phy: registered 1 port(s)
    [    0.076511] brcm-cma brcm-cma.0: Initialized Broadcom CMA root device
    [    0.077144] brcm-cma brcm-cma.0: Added CMA device @ PA=0x14800000 LEN=0x1b800000
    [    0.077709] brcm-cma brcm-cma.1: Added CMA device @ PA=0x30000000 LEN=0xc000000
    [    0.111671] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
    [    0.113169] console [ttyS0] disabled
    [    0.113209] f040a900.serial: ttyS0 at MMIO 0xf040a900 (irq = 34, base_baud = 5062500) is a 16550A
    [    0.813649] console [ttyS0] enabled
    [    0.817726] f040a940.serial: ttyS1 at MMIO 0xf040a940 (irq = 35, base_baud = 5062500) is a 16550A
    [    0.827059] f040a980.serial: ttyS2 at MMIO 0xf040a980 (irq = 36, base_baud = 5062500) is a 16550A
    [    0.843360] brd: module loaded
    [    0.850220] loop: module loaded
    [    0.854215] OF: /rdb/sata@f045a000/sata-port@0: could not get #phy-cells for /rdb/sata-phy@f0458100
    [    0.863404] brcm-ahci f045a000.sata: masking port_map 0x3 -> 0x1
    [    0.869474] brcm-ahci f045a000.sata: SSS flag set, parallel bus scan disabled
    [    0.886708] brcm-ahci f045a000.sata: AHCI 0001.0300 32 slots 2 ports 6 Gbps 0x1 impl platform mode
    [    0.895688] brcm-ahci f045a000.sata: flags: 64bit ncq sntf stag pm clo pmp slum part
    [    0.904815] scsi host0: brcm-ahci
    [    0.908427] scsi host1: brcm-ahci
    [    0.911918] ata1: SATA max UDMA/133 mmio [mem 0xf045a000-0xf045aa9b] port 0x100 irq 44
    [    0.919854] ata2: DUMMY
    [    0.922314] brcm-ahci f045a000.sata: Broadcom AHCI SATA3 registered
    [    0.929263] libphy: Fixed MDIO Bus: probed
    [    0.933683] bcmgenet f0b00000.ethernet: GENET 4.5 EPHY: 0x1001
    [    0.951404] libphy: bcmgenet MII bus: probed
    [    0.978411] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
    [    0.984263] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
    [    1.010192] ehci-brcm: EHCI BRCM driver
    [    1.014154] ehci-brcm f0470300.ehci: EHCI Host Controller
    [    1.019588] ehci-brcm f0470300.ehci: new USB bus registered, assigned bus number 1
    [    1.037293] ehci-brcm f0470300.ehci: irq 147, io mem 0xf0470300
    [    1.047920] ata1: SATA link down (SStatus 0 SControl 300)
    [    1.049409] ehci-brcm f0470300.ehci: USB 2.0 started, EHCI 1.00
    [    1.049960] hub 1-0:1.0: USB hub found
    [    1.049984] hub 1-0:1.0: 1 port detected
    [    1.050271] ehci-brcm f0470500.ehci: EHCI Host Controller
    [    1.050283] ehci-brcm f0470500.ehci: new USB bus registered, assigned bus number 2
    [    1.060393] ehci-brcm f0470500.ehci: irq 148, io mem 0xf0470500
    [    1.067401] ehci-brcm f0470500.ehci: USB 2.0 started, EHCI 1.00
    [    1.067889] hub 2-0:1.0: USB hub found
    [    1.067933] hub 2-0:1.0: 1 port detected
    [    1.068155] ohci-brcm: OHCI BRCM driver
    [    1.068323] ohci-brcm f0470400.ohci: BRCM OHCI controller
    [    1.068338] ohci-brcm f0470400.ohci: new USB bus registered, assigned bus number 3
    [    1.068426] ohci-brcm f0470400.ohci: irq 149, io mem 0xf0470400
    [    1.126824] hub 3-0:1.0: USB hub found
    [    1.130616] hub 3-0:1.0: 1 port detected
    [    1.134796] ohci-brcm f0470600.ohci: BRCM OHCI controller
    [    1.140224] ohci-brcm f0470600.ohci: new USB bus registered, assigned bus number 4
    [    1.147889] ohci-brcm f0470600.ohci: irq 150, io mem 0xf0470600
    [    1.209786] hub 4-0:1.0: USB hub found
    [    1.213567] hub 4-0:1.0: 1 port detected
    [    1.217686] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
    [    1.224241] ehci-pci: EHCI PCI platform driver
    [    1.228748] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
    [    1.234947] ohci-pci: OHCI PCI platform driver
    [    1.239751] xhci-hcd f0471000.xhci: xHCI Host Controller
    [    1.245099] xhci-hcd f0471000.xhci: new USB bus registered, assigned bus number 5
    [    1.252797] xhci-hcd f0471000.xhci: hcc params 0x0250f17d hci version 0x100 quirks 0x00010010
    [    1.261366] xhci-hcd f0471000.xhci: irq 151, io mem 0xf0471000
    [    1.267808] hub 5-0:1.0: USB hub found
    [    1.271595] hub 5-0:1.0: config failed, hub doesn't have any ports! (err -19)
    [    1.278857] xhci-hcd f0471000.xhci: xHCI Host Controller
    [    1.284193] xhci-hcd f0471000.xhci: new USB bus registered, assigned bus number 6
    [    1.291735] usb usb6: We don't know the algorithms for LPM for this host, disabling LPM.
    [    1.300190] hub 6-0:1.0: USB hub found
    [    1.303974] hub 6-0:1.0: 2 ports detected
    [    1.308301] usbcore: registered new interface driver uas
    [    1.313711] usbcore: registered new interface driver usb-storage
    [    1.320019] mousedev: PS/2 mouse device common for all mice
    [    1.325883] i2c /dev entries driver
    [    1.329662] IR NEC protocol handler initialized
    [    1.334215] IR RC5(x/sz) protocol handler initialized
    [    1.339281] IR RC6 protocol handler initialized
    [    1.343823] IR JVC protocol handler initialized
    [    1.348364] IR Sony protocol handler initialized
    [    1.352994] IR SANYO protocol handler initialized
    [    1.357710] IR Sharp protocol handler initialized
    [    1.362426] IR MCE Keyboard/mouse protocol handler initialized
    [    1.368271] IR XMP protocol handler initialized
    [    1.372815] smssdio: Siano SMS1xxx SDIO driver
    [    1.377270] smssdio: Copyright Pierre Ossman
    [    1.381943] sdhci: Secure Digital Host Controller Interface driver
    [    1.388142] sdhci: Copyright(c) Pierre Ossman
    [    1.392511] sdhci-pltfm: SDHCI platform and OF driver helper
    [    1.431411] mmc0: SDHCI controller on f03e0200.sdhci [f03e0200.sdhci] using ADMA
    [    1.438984] hidraw: raw HID events driver (C) Jiri Kosina
    [    1.444581] usbcore: registered new interface driver usbhid
    [    1.450172] usbhid: USB HID core driver
    [    1.454575] NET: Registered protocol family 17
    [    1.459103] Key type dns_resolver registered
    [    1.463501] ThumbEE CPU extension supported.
    [    1.467793] Registering SWP/SWPB emulation handler
    [    1.480154] ALSA device list:
    [    1.483166]   No soundcards found.
    [    1.487422] Freeing unused kernel memory: 352K
    [    1.491884] This architecture does not have kernel memory protection.
    [    1.584360] mmc0: new high speed MMC card at address 0001
    [    1.590197] mmcblk0: mmc0:0001 4MEYMA 3.66 GiB
    [    1.594876] mmcblk0boot0: mmc0:0001 4MEYMA partition 1 2.00 MiB
    [    1.600931] mmcblk0boot1: mmc0:0001 4MEYMA partition 2 2.00 MiB
    [    1.607006] mmcblk0rpmb: mmc0:0001 4MEYMA partition 3 128 KiB
    [    1.616885] Alternate GPT is invalid, using primary GPT.
    [    1.622235]  mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8
    [    1.656432] usb 3-1: new full-speed USB device number 2 using ohci-brcm
    [    1.835927] EXT4-fs (mmcblk0p3): recovery complete
    [    1.843075] EXT4-fs (mmcblk0p3): mounted filesystem with ordered data mode. Opts: (null)
    [    1.855953] random: fast init done
    INIT: version 2.88 booting
    Starting fake hwclock: loading system time.
    Fri Feb 18 19:59:46 UTC 2022
    [    2.070315] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
    [    2.080301] usb 3-1: device not accepting address 2, error -62
    [    2.096683] Adding 262140k swap on /dev/mmcblk0p7.  Priority:-1 extents:1 across:262140k SS
    [    2.244463] usb 3-1: new full-speed USB device number 3 using ohci-brcm
    [    2.665421] usb 3-1: device not accepting address 3, error -62
    [    2.715734] hd51_1: module_layout: kernel tainted.
    [    2.720572] Disabling lock debugging due to kernel taint
    [    2.725908] hd51_1: loading out-of-tree module taints kernel.
    [    2.732140] usbcore: registered new interface driver tpm
    [    2.835411] usb 3-1: new full-speed USB device number 4 using ohci-brcm
    [    3.010397] usb 3-1: device descriptor read/64, error -62
    [    3.290400] usb 3-1: device descriptor read/64, error -62
    [    3.565401] usb 3-1: new full-speed USB device number 5 using ohci-brcm
    [    3.740399] usb 3-1: device descriptor read/64, error -62
    [    4.018455] usb 3-1: device descriptor read/64, error -62
    [    4.129511] usb usb3-port1: unable to enumerate USB device
    /dev/dvb/adapter0/video0: No such file or directory
    [    4.379733] EXT4-fs (mmcblk0p3): re-mounted. Opts: data=ordered
    ALSA: Restoring mixer settings...
    /usr/sbin/alsactl: load_state:1735: No soundcards found...
    net.ipv4.conf.default.rp_filter = 1
    net.ipv4.conf.all.rp_filter = 1
    vm.dirty_writeback_centisecs = 300
    vm.dirty_background_ratio = 1
    vm.min_free_kbytes = 8192
    vm.dirty_ratio = 60
    vm.swappiness = 30
    net.ipv4.tcp_timestamps = 0
    Starting stb hwclock: loading system time.
    INIT: Entering runlevel: 3
    Starting system message bus: dbus.
    Starting Dropbear SSH server: dropbear.
    Configuring network interfaces... [    5.864404] f0b00000.etherne:01: Broadcom BCM7439 (2) PHY revision: 0x10, patch: 1
    [    5.873733] bcmgenet f0b00000.ethernet: configuring instance for internal PHY
    udhcpc: started, v1.31.0
    udhcpc: sending discover
    [    9.418100] bcmgenet f0b00000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
    udhcpc: sending select for 192.168.100.245
    udhcpc: lease of 192.168.100.245 obtained, lease time 14400
    /etc/udhcpc.d/50default: Adding DNS 10.30.23.1
    /etc/udhcpc.d/50default: Adding DNS 5.249.128.38
    done.
    Starting rpcbind daemon...done.
    Fuse filesystem already available.
    Mounting fuse control filesystem.
    exportfs: can't open /etc/exports for reading
    starting 8 nfsd kernel threads: done
    starting mountd: rpc.mountd: svc_tli_create: could not open connection for udp6
    rpc.mountd: svc_tli_create: could not open connection for tcp6
    done
    Mounting remote filesystems...
    Starting automount: /sbin/stb-hwclock: line 24: /proc/stb/fp/rtc: No such file or directory
    done.
    starting statd: done
    Starting internet superserver: inetd.
    Starting Samba: smbd wsdd.
    Starting Shell In A Box server: shellinabox.
    Starting syslogd/klogd: done
    Starting telnet server: telnetd.
     * Starting Avahi mDNS/DNS-SD Daemon: avahi-daemon
    Process 1862 died: No such process; trying to remove PID file. (/run/avahi-daemon//pid)
       ...done.
    * starting FTP Server: vsftpd... done.
    Starting crond: OK
    /etc/rc3.d/S98createswap: line 4: fdisk: command not found
    [   15.446035] blk_update_request: I/O error, dev mmcblk0rpmb, sector 0
    [   15.472024] blk_update_request: I/O error, dev mmcblk0rpmb, sector 0
    Warning: Error fsyncing/closing /dev/mmcblk0rpmb: Input/o[   15.482646] blk_update_request: I/O error, dev mmcblk0rpmb, sector 0
    utput error
    Warning: Error fsyncing/closing /dev/mmcblk0rpmb: Input/output error
    Error: The backup GPT table is corrupt, but the primary appears OK, so that will be used.
    Warning: Not all of the space available to /dev/mmcblk0 appears to be used, you can fix the GPT to use all of the space (an extra 40960 blocks) or continue with the current setting?
    Running local boot scripts (/etc/rc.local).
    killall: showiframe: no process killed
    vm.dirty_ratio = 60
    vm.swappiness = 30
    PYTHONPATH: /usr/lib/enigma2/python
    DVB_API_VERSION 5 DVB_API_VERSION_MINOR 11
    /usr/bin/enigma2.sh: line 149:  1904 Segmentation fault      LD_PRELOAD=$LIBS /usr/bin/enigma2 $VERBOSE 2> /dev/null
    vm.dirty_ratio = 60
    vm.swappiness = 30
    Mesaju care se repeta
    /usr/bin/enigma2.sh: line 149:  6393 Segmentation fault      LD_PRELOAD=$LIBS /usr/bin/enigma2 $VERBOSE 2> /dev/null
    enigma2 is the main pvr application... adjust oom score!
    /usr/bin/enigma2.sh: line 123: /proc//oom_adj: No such file or directory
    vm.dirty_ratio = 60
    vm.swappiness = 30
    Nu stiu daca aceasta parte de boot este corecta
    none
    01 Jan 1999
    acasa
    35 Post(s)
    nu-ti vede ceva acolo:
    tre sa arate cam asa:
    bafta
  7. #217
    6 Post(s)
    Nu, nu am acest folder /dev/dvb/adapter0 care se generaza in automat cred.
    6 Post(s)
    Dupa mai multe cautari am descoperit ca, aceasta placa are rolul unui sim... den original/clona problemele sut tocmai din aceasta cauza, am o clona si vreau sa pun imagini originale...
    Quote Originally Posted by fery21 View Post
    ...nu stiu ce este aceasta placa si ce rol are...
    14 May 2011
    7 Post(s)
    Unde in interiorul receiverului e plasata acea placuta ? Poti pune o imagine ?
  10. #220
    6 Post(s)
    Am placa de baza desfacuta.
    Da se pare ca are rolul unui "sim" de recunoastere , la fel cum a fost si la "razboiul clonelor" in trecut
    Ai un cpu programabil , o memorie flash si un tranzistor/sursa de putere medie pentru a le alimenta
    Rezolvarea in "razboiul clonelor" daca iti mai aduci aminte Fery21 era sa modifici seria mac-ului cu una de original
    Se putea realiza prin "terminalul putty" parca.......poate...... poate.......
  12. #222
    6 Post(s)
    Find un stm32 cred ca poate fi programat separat.
    Teoretic DA , practic e mai greu , fiindca NU stiu daca il poti programa asa direct cum este el acum plantat pe placuta respectiva
    Deci ti-ar trebui unul ''bun'' nelipit pe placuta in cauza si apoi tu sa il deslipesti pe al tau....sa il reprogramezi si apoi sa il lipesti din nou
    Problema e....... ca sa nu aibe niste key dedicate/particularizate pe receptorul tau ....fiindca prin reprogramarea de la un alt receptor ......tu practic ''clonezi'' receptorul bun cu al tau
  14. #224
    6 Post(s)
    Am ramas mometan doar cu logo nu mai trece de partea de boot
    Dupa schimbarea unui condesator 16V470uf cu unul de 16v680uf
    CPU 01
    BCM74390011
    PRID07251111
    v1.7
    RR:00000003
    BFW
    SEC
    seclib-1.5
    BBL v1.0.1
    AVS init...
    spare0/rmon_hz=017d7470
    spare1/rmon_vt=017d7471
    AVS init OK
    LOADED
    single board
    MCB: FIX
    STB: Current voltage=00000399(921)
     temperature=0000ba60(47712)
     PV=00000357(855)
     MV=0000039b(923)
    OK
    MEMSYS ERROR: 00000001
    eMEMC:
     00000002
     ePHY: 00000000
    eSHMOO:  00000000 00000000 00000000▒CPU 01
    BCM74390011
    PRID07251111
    v1.7
    RR:00000203
    BFW
    SEC
    seclib-1.5
    BBL v1.0.1
    AVS init...
    AVS init OK
    AVS load:select_image: addr_offset: 00051000 part_offset: 00000000 bootStatus: 2a2f2b00
    LOADED
    single board
    MEMSYS:0000002f
    FATAL ERROR: Boot 2nd image failed
    Corect ar fi fost asa, preluat de la unul funtionant
    CPU 01
    BCM74390011
    PRID07251111
    v1.7
    RR:00000003
    BFW
    SEC
    seclib-1.5
    BBL v1.0.1
    AVS init...
    spare0/rmon_hz=0179706c
    spare1/rmon_vt=0179706d
    AVS init OK
    LOADED
    single board
    MCB: FIX
    STB: Current voltage=00000380(896)
     temperature=0000483c(18492)
     PV=00000343(835)
     MV=00000380(896)
    OK
    DDR1: -
    Sdram Scramble OK
    BFW v2.1.0
    COPY CODE... DONE
    SSBL
    PINMUX
    CACHE FLUSH OK
    MMU ON
    CACHE FLUSH OK
    _fbss  0704cf70
    _ebss  0704ea38
    _end   0704ea58
    HEAP @ 07100000
    STACK @ 09200000
    ARCH: CONFIG OK
    CLR BSS 0704cf70 to 0704ea38 OK
    CLR SRAM  OK
    CACHE FLUSH OK
    CPU CLKSET OK
    GO!
      ,'/___, BOLT v1.07 v1.07-r19 LOCAL BUILD
    .'__  ,'  (2016-09-21 )
       /,'    Copyright (C) 2016 Broadcom Corporation
    Board: BCM97251SSV
    SCB: 432 MHz
    BOX MODE: 1
    AVS: park check
    AVS: STB: V=0.891V, T=+18.492C, PV=0.835V, MV=0.896V, FW=30333078 [0.3.0.x]
    USB otp=00000040
    Loader:zimg Filesys:raw Dev:emmcflash0.kernel1 File:(null) Options:root=/dev/mmcblk0p3 rw rootwait
    Reading 4888800 bytes from zImage...........
    6 Post(s)
    Am gasit si informatile legate de conectare si pin out poate mai are nevoie cineva.
