Thanks Thanks:  2
Likes Likes:  1
Results 31 to 45 of 47
Thread: YouTube Plugin by Taapat
    Youtube_h1+git801+5c2c0f7-r0.0 20.04.2021
    ● Remove header and location lines in pot file
    enigma2-plugin-extensions-youtube_h1+git801+5c2c0f7-r0.0_all.ipk
    https://mega.nz/file/SY9V2QzL#wB91W9...irO6PGFwcfK0EE
    Thx @ Taapat
    youtube_h1+git806+275e67d-r0.0
    ● Add svg icons and scalable screens support
    enigma2-plugin-extensions-youtube_h1+git806+275e67d-r0.0_all.ipk
    https://mega.nz/file/DBk30AYS#OebeAZ...JGndkJO3gY4KHY
    Thx @ Taapat
    Youtube_h1+git824+9e892cb-r0.0.0 от 18.09.2021
    ● YouTubeSearch: fix vkey_icon problem on old images
    Add workaround to keep compatibility broken with changes in new images.
    ● Try fix test on openatv 7.0
    ● Ignore line too long error in enigma.py test file
    enigma2-plugin-extensions-youtube_h1+git824+9e892cb-r0.0_all.rar
    https://mega.nz/file/ecsxiYoY#pdjNwZ...tMhUdY-4AXIC2c
    Thx @ Taapat
    Youtube_h1+git847+4243836-r0.0.0 от 22.10.2021
    ● YouTubeDownload: remove unnecessary computing
    ● YouTubeUi: try fix rash when downloading a video on some buildsystems
    ● I did not see such a problem with myself, so I cannot test this.
    enigma2-plugin-extensions-youtube_h1+git847+4243836-r0.0_all.ipk
    https://mega.nz/file/Lcdi3b7Y#-GeKvS...6XJ9WWIXJ0FvIE
    Thx @ Taapat
    Youtube_h1+git866+4b9bfd1-r0.0.0 от 30.10.2021
    ● YouTubeUi: return flags=BT_SCALE in default skin
    If MultiContentEntryPixmapAlphaTest in image support this
    ● YouTubeUi: return domScreens element check
    Deleted in previus commit
    enigma2-plugin-extensions-youtube_h1+git866+4b9bfd1-r0.0_all.ipk
    https://mega.nz/file/3R1whY7L#_0569I...YgGXHrUHaucugc
    Thx @ Taapat
    YouTube git 904 +84fe359-r0.0 от 17.12.2021
    ● YouTubeUi: try fix GSOD on thumbnails or entry list update
    enigma2-plugin-extensions-youtube_h1+git904+84fe359-r0.0_all.ipk
    https://mega.nz/file/fR9SxCiK#fvyOjl...rz3PKM-7TCcpNw
    Thx @Taapat
    youtube_h1+git919+c3e3141-r0.0
    -YouTubeUi: ignore import shadowed by loop variable
    enigma2-plugin-extensions-youtube_h1+git919+c3e3141-r0.0_all.ipk.rar
    https://mega.nz/file/nUsUWKLQ#IfcnM-...mrM0qudQ1tfRQc
    enigma2-plugin-extensions-youtube_py3+git919+c3e3141-r0.0_all.ipk.rar
    https://mega.nz/file/OF9A0CqB#OzdOKr...oAuoA3PNavViFQ
    Thx @Taapat
    enigma2-plugin-extensions-youtube_h1+git939+b436064-r0.0_all
    ● Disable shallow clone on tests
    -Add YouTubeVideoUrl clean_html test
    -Set max resolution on python tests
    -Use updateSuggestions to set suggestions list in YouTubeSearch test
    -Test YouTubeSearch list methods only if it exist in image
    -Remove openMenu test for YouTubeSearch
    -Fix over indented in tests
    -Add tests for playback to to increase YouTubeMain code coverage
    -Add tests for YouTubePlayer methods to increase code coverage
    -YouTubeInfo: fix key_red valign argumnet in skins
    enigma2-plugin-extensions-youtube_h1+git939+b436064-r0.0_all.ipk
    https://mega.nz/file/SIUCQZzZ#udoXED...Z3k2rpsD_F-dhI
    enigma2-plugin-extensions-youtube_py3+git939+b436064-r0.0_all.ipk
    https://mega.nz/file/vQVC2Z5R#HwFyNi...hO_L_d-nj0GSw4
    enigma2-plugin-extensions-youtube_h1+git939+b436064-r0.0_all.deb..rar
    https://mega.nz/file/uAFGDbhI#UjQqmY...oP-9oD769yittY
    Thx @Taapat
    YouTube git 959 +da1995e-r0.0 от 08.01.2022
    ● YouTubeUi: fix unsubscribe from channel
    enigma2-plugin-extensions-youtube_h1+git959+da1995e-r0.0_all.ipk
    https://mega.nz/file/nFVkjZqL#gbQ056...yNhoS1UdwUw4yQ
    enigma2-plugin-extensions-youtube_py3+git959+da1995e-r0.0_all.ipk
    https://mega.nz/file/vBUSFZoZ#-7ItJK...llzHTcT8TnvUqQ
    Thx @Taapat
    Youtube_h1+git972+a8696e1-r0.0_22.01.2022
    -Fix gsod on images without getCurrentDescription method
    Thx @Taapat
    enigma2-plugin-extensions-youtube_h1+git972+a8696e1-r0.0_all.ipk.zip
    https://mega.nz/file/fdNGhZjA#MqcJTS...KerI1L7HRyNJ3M
    enigma2-plugin-extensions-youtube_py3+git972+a8696e1-r0.0_all.ipk.zip
    https://mega.nz/file/2YEwxLyJ#mvDSA6...dfzvUWpKMYbnfs
    Thx @Taapat
    Youtube_h1+git983+141efd7-r0.0_06.02.2022
    ●Use property getter in usePageToken
    enigma2-plugin-extensions-youtube_h1+git983+141efd7-r0.0_all.ipk
    https://mega.nz/file/7UcAEByZ#6WBGUN...rwgDbpKA4kDW7w
    enigma2-plugin-extensions-youtube_py3+git983+141efd7-r0.0_all.ipk
    https://mega.nz/file/GIECEBSZ#AJpPzT...n8ge5Nnvj7oDmU
    [enigma2-plugin-extensions-youtube_h1+git983+141efd7-r0.0_all.deb/b]
    https://mega.nz/file/DMci1LCL#Z1ZYej...IdnzpohuYtzk9g
    Thx @Taapat
    YouTube git1009 от Taapat 19.03.2022
    Citar
    ● Use timeout in urlopen
    ● Fix python version on OpenViX in test
    enigma2-plugin-extensions-youtube_h1+git1009+717f535-r0.0_all.rar
    https://mega.nz/file/3J0gAIpJ#zf_OC1...pbEHuypRWsaVLM
    enigma2-plugin-extensions-youtube_py3+git1009+717f535-r0.0_all.rar
    https://mega.nz/file/LIcGzCDK#CXpvpl...tYVTIYYJLdLTyk
    enigma2-plugin-extensions-youtube_h1+git1009+717f535-r0.0_DEB.zip
    https://mega.nz/file/fAVSxB5Q#OPxo7M...7ecYJOukf6h4W4
    Thx @Taapat
    YouTube git1018 от Taapat 14.04.2022
    ● Finnish_translation_for YouTube
    enigma2-plugin-extensions-youtube_h1+git1018+8f7571e-r0.0_all.rar
    https://mega.nz/file/TRkgkRTC#u2Mx3Z...yLFos39lmJq9ys
    enigma2-plugin-extensions-youtube_py3+git1018+8f7571e-r0.0_all.rar
    https://mega.nz/file/aAUh0ZpQ#8-bKfO...9r8G4tG-RzdWNc
    Thx @Taapat
    enigma2-plugin-extensions-youtube_1+git1033+93ddb0c-r0.0
    enigma2-plugin-extensions-youtube_1+git1033+93ddb0c-r0.0_mips32el.ipk
    https://mega.nz/file/2EtxFQTC#xiZAQN...EJ0CoegQM10mSs
    Thx @Taapat
    enigma2-plugin-extensions-youtube_1+git1034+dbf9d2a-r0.0_mips32el
    enigma2-plugin-extensions-youtube_1+git1034+dbf9d2a-r0.0_mips32el.ipk
    https://mega.nz/file/DMUUDAgT#koWmzT...ZsFajDR3Nl0HrU
    Thx @Taapat
