Thanks Thanks:  16
Likes Likes:  27
Page 8 of 9 FirstFirst ... 456789 LastLast
Results 106 to 120 of 125
Thread: IPTV Player plugin
  1. #106
    Thumbs up enigma2-plugin-extensions-e2istream_20191212-r01_all
    - Fix youtube.
    - Fix Cloudflare protection used by some hosts.
    - Force Dailymotion videos playing with both players.
    - Fix hoofoot and ourmatch.
    - Fix okgoals and meczyki.pl.
    - Fix vod.tvp.pl.
    - Updated host infoversion.
    - Updated TSIPlayer to version 2019.12.12.0 ,check log info section.
    - Updated 18+ contents.
    notice :
    Delete any previous versions & unistall it & install new fresh .ipk to avoid any issues or errors , make sure old IPTVPlayer folder been deleted .
    Ftb .ipk file to /tmp.
    Install with following telnet command 'opkg update && opkg install /tmp/*.ipk' , all required dependencies for plugin will be installed from your image feed.
    E2 will Auto-restart after .ipk installation finished.
    enigma2-plugin-extensions-e2istream_20191212_r01_all.rar
    Código:
    https://mega.nz/#!rYcWjIgR!OhF-ilLrZ...XeXT1fy5O1t6gQ
  2. #107
    O lista de tipul nume.m3u o pot vizualiza cu asta? Daca da, unde trebuie amplasat fisierul meu?
    Gigel
  3. #108
    Thumbs up IPTVPlayer For DM and VU+ / FreeServer_6.8.6
    IPTVPlayer version 1+git3509+86nasspe-r3_all.ipk
    28-12-2019
    -Fix LETMEJERK
    -Fix solarmovie
    -Fix ANYBUNNY
    enigma2-plugin-extensions-e2iplayer_1+git3509+86nasspe-r3_all.ipk.rar (7.71MB)
    https://www.sendspace.com/file/xlw3hu
    https://mega.nz/#!7BsQUCRR!pbkDX7lgW...FsQplFIJWb00YY
    FreeServer_6.8.6
    Some errors were corrected in the plugin when entering the menu
    enigma2-plugin-extensions-freeserver_6.8.6_all.ipk
    Código:
    https://mega.nz/#!PcV3GCZZ!lTFY8SBQv...ShnvEz89_4WUeI
    enigma2-plugin-extensions-freeserver_6.8.6_all.deb
    Código:
    https://mega.nz/#!eMFziYKZ!o_uA1TxQq...JQ0oL6hBRCJEKw
  4. #109
    enigma2-plugin-extensions-e2iplayer_1+git3517+22f704a-r3_all.ipk
    -Fixed an issue where the games directory was only showing 30 results with no option of next page. Issue caused by API changes / JSON structure changes.
    -Added-WATCHPORNX
    -Added-WOXTUBE
    -Fix-PORNICOM
    -Fix-CROCOTUBE-remove-BEFUCK
    Código:
    https://mega.nz/#!aEUUlYAa!nGECd_Rcb...wmlaoA0ISiQTkw
    Maintainer:@enigma1969
  5. #110
    am incercat sa updatez dar imi da error
    ceva de genul json error
    cum sa fac sa updatez
    am versiunea de prin 26 oct 2019 acum pe receptor
    Pe openpli isi face update automat la deschiderea pornirea plugin-ului, atunci cand este cazul. Încearcă sa dezinstalezi pe cel vechi si sa reinstalezi varianta recenta.
  7. #112
    Am încercat, dar nu e ok pe Black Hole.
    Am încercat să instalez update cu update de aici.
    Până la un moment dat a mers după data de 26 a 10 2019 nu mai vrea.
    enigma2-plugin-extensions-e2iplayer_1+git3518+01dc7e3-r3_all.ipk
    -Fix wstream in urlparser
    -Fix last commits
    -Fix WATCHPORNX
    -Fix FREEOMOVIE
    -Fix FULLXXXMOVIES
    -Fix PORNRABBIT
    Código:
    https://mega.nz/#!eUc0SQ6R!e9XAZi4XM...7zWkzt2U3tb-Vg
  9. #114
    enigma2-plugin-extensions-e2iplayer_1+git3521+74b64a0-r3_all.ipk
    -Try to fix wiziwig1
    -Removing broken sites
    -Fix DAFTSEX
    -Fix PORNDOE
    -Fix CAM4
    -Added P720
    -Remove PORNOMENGE
    Código:
    https://mega.nz/#!OZVDmY6A!HNRVPmFh4...eltMpxd49b_ROw
    Maintainer: enigma1969
  10. #115
    Cool
    MIAMI BICI----comedie
    E2IPLAYER-TS IPLAYER--English Section--123Movies--Movies-Pag 1--1-2-3-4. direct link (toate valide verificat de mine inainte de postare)
    vizionare placuta tuturor
  11. #116
    enigma2-plugin-extensions-e2iplayer_2+git3474+5ad41c5-r4_all
    What's new
    ● Add-host-zalukaj.vip-del-host-videopenny.net
    ● Add-parser-upvideo.cc
    ● Fix-hosthdfilmetv
    ● Fix-hostjoemonsterorg
    ● Fix-hostwatchmovies
    ● Try to fix parserCDA
    ● Try to fix parserGOUNLIMITEDTO
    ● Fix-update
    ● Fix parserCDA
    ● Try to fix parseNETUTV
    ● Fix PORNHUB
    What's new on TSiplayer
    ● New Version 2020.04.03.0
    ● EGYBEST Fix links
    ● FIx mystream
    ● Fix vidbm.com
    enigma2-plugin-extensions-e2iplayer_2+git3474+5ad41c5-r4_all.ipk
    Código:
    https://mega.nz/file/qR0mFA4b#Rjig2a...0wbXfYah2G50aM
  12. #117
    enigma2-plugin-extensions-e2iplayer_2+git3479+51cd06e-r4_all
    Citar
    -Try to fix CF, add CF hCaptcha bypass (via 2captcha.com)
    -Fix ekino-tv search
    -Fix parser CLIPWATCHINGCOM
    enigma2-plugin-extensions-e2iplayer_2+git3479+51cd06e-r4_all.ipk
    https://mega.nz/file/KN0i0IBa#m5jjOE...R-HlvirvcRkxwA
  13. #118
    enigma2-plugin-extensions-e2iplayer_2+git3482+aaecf39-r4_all
    -Try to fix hostekinotv
    -Fix Popler
    -Fix Kamery SBL
    -Fix Echo24
    enigma2-plugin-extensions-e2iplayer_2+git3482+aaecf39-r4_all.ipk
    https://mega.nz/file/LZUgXYQZ#yFyDZN...1mrsrkbBAVSsgY
  14. #119
    enigma2-plugin-extensions-e2iplayer_2+git3557+1afa137-r4_all
    ●Fix vidcloud9
    ●Fix po and update version number
    ●Updated locale po files
    ●Add-gcloud.live-xstreamcdn-and-wip-vidcloud9
    ●Fix zdfmediathek not in iptvhostgroup
    ●Uptostream working in ymovies.to
    ●Fix uptostream
    ●Fix uptostream in urlparser
    ●Update credits in casacinema
    ●Urlparser new version of uptostream
    ●Wip adding cinemalibero
    ●Add mirrorace and fix linkhub in urlparser
    ●Add movcloud.net in urlparser
    ●Fix series9.to
    ●Try to fix filmstreamhd.it
    ●Update urlparser fix previous commit
    ●Add buckler.link to urlparser
    ●Fix vcrypt in urlparser
    ●Fix filmpertutti.pro
    ●Fix cb01.run
    ●Update-youtube
    ●Fix next page in altadefinizione.us
    ●Fix swatchseries.to
    ●Try to fix clouflare protection
    ●Fix altadefinizione01.photo and remove altadefinizione1
    ●Fix altadefinizione.us
    ●Fix altadefinizione.family
    ●Add streamtape.com in urlparser
    ●Fix mixdrop in url parser
    ●Try to add backin.net in urlparser
    enigma2-plugin-extensions-e2iplayer_2+git3557+1afa137-r4_all.ipk
    https://mega.nz/file/nJkyCYzT#o9_C3V...mLh9QSAI0Ef2m0
  15. #120
    enigma2-plugin-extensions-e2iplayer_2+git3634+d37cf40-r4_all
    • Lookmovie fix end of lines
    • Updated lookmovie to last codermik version not working yet
    • Update urlparser for using demjson library
    • Add library demjson
    • Add aparat in urlparser
    • Wip urlparser
    • Try to fix twitch
    • Try to add tantifilm.top in urlparser
    • Add-hdplayer.casa in urlparser
    • Fix tantifilm.cam
    • Fix youtube in musicbox
    • Try to fi -uploadit
    • Fix youtube empty lists
    • Add streamz in urlparser
    • Add streamcrypt.net and thevideos.ga in urlparser
    • Fix opendrive.top
    • Add opendrive.top in urlparser
    • Fix cda.pl in urlparser
    • Add uploadit.cc in urlparser
    • Add ogladaj and watch movies.pl
    XXX host:
    • VPORN PORNONE icons 8bit
    • Added FORCEDCELEBS
    enigma2-plugin-extensions-e2iplayer_2+git3634+d37cf40-r4_all.ipk.rar
    https://mega.nz/file/OdFH0KDB#jK4XBL...3ysPbEJYFPet8c
