Dislikes:
- Rep Power
- 154
OpenPLi-4 Gstreamer 1.6.x (master git) Vu+Duo/ Duo2 Image
- Rep Power
- 154
VU+ : OpenPLi 4.0 with IPTV (More than 800+ IPTV FREE Channels) by MastaG and Japhar Team
Users running the previous Gstreamer 1.7.0 image, should be able to peform a Software Update!
Changes since previous release:
- mx3L's gstreamer revert which fixes mp4 playback from remote locations
- Spark drivers updated to 20151113
- Using aio-grab from oe-alliance which includes fixes for sprak receivers
- New Japhar IPTV List (thanks to ToySoft).
- DM8000 has no more gsod's now (thanks to ToySoft for testing!)
Changes compared to openpli-oe-core gst-1:
- Ships with gstreamer upstream master git:
Using the same patches as openpli-oe-core gst-1 with only these changes:
Removed: 0001-baseparse-post-tag-list-when-avg-bitrate-changes-at-.patch
because this patch was already checked in upstream.
Added: 0001-Revert-qtdemux-respect-qt-segments-in-push-mode-for-.patch
By mx3L which fixes mp4 playback from remote locations.
- Every receiver uses christophecvr's multibox dvbmediasink.
- Using libtrmp and rtmpdump from oe-alliance.
- Some small enigma2 patches for Dreambox receivers (ac3/dts bypass and blanking on zap support).
These are only applied for Dreambox receivers.
- AAC to AC3 transcoding V2 by mx3L (requires a fast cpu).
- IPTV Player from samsamsam included (thx to Athoik for the recipe).
- Large list of public IPTV streams included thanks to the Japhar Team.
- Updated libcdio and cdtextinfo for audio-cd support by christophecvr.
- DM800Se, DM7020HD and DM800SeV2 driver upgraded to 20151201:
added si2166b blindscan support
- Spark images includes the pti.ko from OpenATV so softcam's should work now.
- Using aio-grab source from oe-alliance which includes fixes for spark receivers.
- The 2.6.18 kernel will now always pass the vermagic check when loading modules.
Now you can try and load any kernel driver from OE1.5 to 2.0.
Known issues:
- DM800 first boot will take a while, please be patient. The next boot will be faster.
- On spark/spark7162 you need to set 'boxtype = dreambox' for oscam dvbapi.
We're using the OE-A drivers and 'duckbox' doesn't seem to work on these.
- On spark/spark7162 you need to set a skin which doesn't resize the framebuffer.
Because sometimes it doesn't scale back to fullscreen.
I've included the MX-HQ7 skin for use as workaround.
- On Zgemma Star you cannot use fullHD skins.
This is a hardware/driver limitation.
Please don't try it, it will crash enigma2.
- Some Dreambox remotes behave very sensitive.
This causes button presses to register multiple times instead of just once.
As a workaround you can adjust the key interval:
Go to: Menu - System - Input devices - dreambox remote control (native).
Set "Change repeat and delay settings" to yes
Set "Interval between keys when repeating:" to 200ms or 300ms.
Press green button (OK)
Now set the same delay for: "dreambox advanced remote control (native)" as well.
To find the download link, search for MastaG Japhar OpenPLi 4.0
Enjoy !
https://mega.nz/#!yhdjRajJ!9aTrsBIl6...sw0Dy8T_MuXqMw
https://mega.nz/#!j8NgzAiY!F1qOaveAD...W-HJwz91kxxW4s
- Rep Power
- 154
OpenPLi 4.0 IPTV by MastaG with GStreamer 1.9.0.1 VU+ Duo2 Image
15/ 04/2016
Changes:
- New gstreamer 1.9.0.1 recipes based on christophecvr's github (small changes for PLi4)
- Upgrade glib2.0 and some other components like gobject-introspection to satisfy the new gstreamer recipes
- gstreamer1.0-libav is built using it's minimal libav with only support for wma (thank you chris)
It's pre-installed on all receivers except for the ones with only 64MB of flash (dm800/800se/500hd)
- Full ffmpeg 3.0.1 package is in the feeds for use with IPTV Player's exteplayer3 (thx to Taapat for the original bbappend)
Login with telnet and issue: opkg update && opkg install ffmpeg
- Latest openpli-oe-core changes
- Latest enigma2 changes
- spark: libeplayer3 is pre-installed now (also in the feeds) for movie players with support for this library
Note: servicemp3 still uses gstreamer
- spark: some OpenPLi enigma2 backports (since Taapat doesn't maintain his enigma2 branch anymore)
The servicemp3 memleak patch has been applied with some other patches/commits I found useful
- spark: don't force async mode on the dvbaudiosink anymore, it's now the same as all other receivers again
- Fixed e-star dm800 image now using correct drivers and working great
- Add Vu+ Solo 2 Lonrisun V4 (v1 and v2) images + feed
https://mega.nz/#!6c5QWZZa!hWafR_3Kd...umwJHPwS4tCEw8
- Rep Power
- 154
OpenPLi 4.0_ by mamba65 _with IPTV (1300+ FREE IPTV Channels)_CroSatel
OpenPLi 4.0_ by mamba65 _with IPTV (1300+ FREE IPTV Channels)_CroSatelite Team
- With GStreamer 1.9.0.1 Final Release recipes based on christophecvrs github (small changes for PLi4)
- gstreamer1.0-libav is built using its minimal libav with only support for wma (thank you chris)
Its pre-installed on all receivers except for the ones with only 64MB of flash
- Full ffmpeg 3.0.1 package is in the feeds for use with IPTV Players exteplayer3 (thx to Taapat for the original bbappend)
~~What's Included On VU+DUO 2~~
-Plugins-
M3uTo Bouquet ConverterPlugin
TSpanel_7.5
TS Media latest version
IpTV Player latest version
SubTitle Player 4.01
Kodi Direct latest version
LCD4Linux
Oscam Status View
Cccam Info v1.3c
QuickEcm Info
Clear Memory latest version
EPG Import
OpenWeb Streaming Info
Picon Manager
...and more
-Emus with active keys and already prepared-
Oscam with emu 11232
Doscam 0.25
Cccam 2.3.0
Mgcamd 1.38c
Last key by @macro
-Channel List-
ciefpsettings E2 & IPTV 19°13°16°
1300+ FREE IPTV Channels by MastaG
-Skin-
MX_HQ7_mod by mamba65
PLi-HD_default
-Booting-
New splash Bootlogo by mamba65
Restarting & Bootlogo by mamba65
-Password FTP and Telnet-
root
root
Restarting and Bootlogo by mamba65
DOWNLOAD
http://www.file-upload.net/download-...am.tar.gz.html
