Robot
Most Wanted
- 82
ASRock is Expected to Launch Multiple Gaming Monitors
Several new ASRock products have passed through the KCC, which is the Korean equivalent of the FCC and normally this would be a new motherboard or maybe some small form factor system, but surprisingly enough, we're looking at gaming monitors. The leak comes courtesy of @momomo_us who's dug up a lot of juicy details on two of the models, whereas we only know the basic specs for the other models. First up, we have the PG34WQ15R, which is a 34-inch curved VA display with a 3440x1440 resolution. It supports FreeSync Premium and has a refresh rate range of 48 to 165 Hz over DisplayPort and 48-100 Hz over HDMI, which seems to be an HDMI 1.4 limitation. The next model is the PG27FF, which is a regular 1080p IPS display that also supports FreeSync Premium, here with a refresh rate range of 48 to 165 Hz over both DP and HDMI. There appears to be multiple sub SKUs of this model, but all start with PG27F.
Then we have the PG32QF, which should be a flat 32-inch display, with unknown specs, but the Q in the model name suggests that it's a 1440p monitor. Finally we have the PG42U, where the U in the model name suggests it's a 4K 42-inch display. The stand looks nearly identical to the one ASUS uses for its ROG Strix XG43UQ 4K screen and the specs are likely to be quite similar too, which means we might see support for 144 Hz or higher refresh rates. All four displays are manufactured by TPV Technology, which produces its own monitors under the AOC, Envision and Philips brands. It's unknown when these new monitors from ASRock will launch, but considering they've passed through certification, it's highly likely that they'll turn up sometime later this year.
More...
SilverStone Launches M.2 Riser Card for Two SSDs
For those with older systems, or for those just in need of additional M.2 slots in their system, SilverStone has launched the SST-ECM28 riser card. The SST-ECM28 is a low-profile solution that can house one M-key NVMe drive and one B-key SATA drive, as it allows a drive to be mounted on each side of the riser card. The SATA drive requires a SATA cable to be connected to the rear of the riser card and then to a SATA slot on the motherboard to function.
This isn't the first time we've seen a product that can handle two drives, but it's the first time we've seen one that is as compact as this. The downside is that there's no retention bracket and it appears that the only way to hold the SST-ECM28 is by fitting it into a physical x16 slot that has a locking mechanism for graphics cards, as the PCB has a retention hook, just as you get on most x16 cards. The SST-ECM28 uses a standard x4 PCIe interface, so it will fit in x4 slots as well, with the risk of it popping out of the slot if the system is moved around. Drives of all sizes from 2230 up to 2280 are supported for both SATA and NVMe drives.
More...
Intel Raptor Lake Launch and Availability Dates Revealed
A post on Chinese forum Bilibili has revealed more exact details with regards to when Intel's Raptor Lake series of processors will launch and if nothing changes between now and then, the K and KF SKU's should be announced as previously thought, at the Intel Innovation '22 event that kicks off on the 27th of September. Retail availability, alongside Z790 motherboards should be about a month later, starting the week of the 17th of October. We've confirmed these dates with our own sources, but as always with early information, these things can change.
The rest of the Raptor Lake family of CPUs, as well as the H770 and B760 chipsets are expected to launch at CES 2023 in January and the poster on Bilibili claims that retail sales should be sometime in the second half of January. We've not been able to confirm the latter information here. As per older rumours, Intel is expected to change the PCIe lane allocation for the Z790 chipset compared to Z690 and based on the information posted, Z790 will have 20 PCIe 4.0 and eight PCIe 3.0 lanes, vs. 12 PCIe 4.0 and 16 PCIe 3.0 for the Z690 chipset. Raptor Lake is also said to get native support for faster DDR5 5600 memory, rather than just 4800 MHz DDR5 for Alder Lake. There are apparently no changes to the CPU PCIe lanes and DDR4 support is still here, but once again, no changes have been made to the DDR4 memory controller.
More...
Intel Core i7-13700K Raptor Lake-S CPU Runs Geekbench
With Intel Raptor Lake-S desktop processors around the corner, we see an ever-increasing number of entries to the popular synthetic benchmark databases. Yesterday we had an Intel Core i5-3600K CPU, while today, we are presented with Core i7-13700K SKU. The new 13th generation Core i7-13700K CPU features eight P-cores and eight E-cores. Compared to the 12th generation Core i7-12700K, this is a step up with eight P-cores and four E-cores. According to Geekbench 5 benchmark, the new Qualification Sample (QS) of Core i7-13700K CPU was running at the minimum clock of 5.289 GHz, maximum clock of 5.381 GHz, and average speed of 5.36 GHz. It was tested on the same configuration as yesterday's i5 SKU with ASRock Z690 Steel Legend WiFi 6E motherboard with 32 GB of DDR4 memory.
As far as the results are concerned, the 13th gen i7-13700K SKU scored 2090 points in the single-core test, while the multi-core score totaled 16542 points. If we compare this to the 12th gen i7-12700K CPU that it replaces, the new model leads by about 10% and 17% in single-core and multi-core tests, respectively.
More...
Intel Xeon W9-3495 Sapphire Rapids HEDT CPU with 56 Cores and 112 Threads Appears
Intel's upcoming Sapphire Rapids processors will not only be present in the server sector but will also span the high-end desktop (HEDT) platform. Today, according to the findings of a Twitter user, @InstLatX64, we have an appearance of Intel's upcoming Sapphire Rapids HEDT SKU in Kernel.org boot logs. Named Intel Xeon W9-3495, this model features 56 cores and 112 threads. While there is no specific information about base and boost frequencies, we know that the SKU supports AVX-512 and AMX instructions. This is a welcome addition, as we have seen Intel disable AVX-512 on consumer chips altogether.
With a high core count and additional instructions for Deep Learning, this CPU will power workstations sometimes in the future. With the late arrival of Sapphire Rapids for servers, a HEDT variant should follow.
More...
(PR) CommScope Launches ARRIS SURFboard Wi-Fi 6E Network Upgrade Devices
As devices and gaming consoles are increasingly connected to home networks, consumers desire to improve the quality and performance of their Wi-Fi network and they can do that by upgrading their network to Wi-Fi 6E. A global leader in home networking solutions, CommScope is entering the retail Wi-Fi 6E market by offering two new ARRIS SURFboard solutions. These enable customers to upgrade their network quickly and easily without replacing any of their existing equipment.
"Augmented reality, virtual reality, and gaming consoles are establishing baselines of latency and jitter performance that are driving consumers to upgrade their home networks and improve their overall connectivity performance," stated Evan Groat, Senior Vice President, Smart Home Solutions and Retail Products, CommScope. "One way to accomplish this is by upgrading to Wi-Fi 6E technology which is exactly what these two new ARRIS SURFboard solutions achieve. Each allows consumers to connect more devices to their home network simultaneously with consistent speed and reliability, while also improving their gaming and streaming performance," Groat continued.
More...
TechPowerUp and Creative Hearing is Believing Giveaway: The Winners
TechPowerUp partnered with Creative, the pioneers of PC gaming audio, to bring you the "Hearing is Believing" Giveaway. Under Creative's technological leadership, PC gaming audio evolved with the times, and is now squarely in the era of game streamers and content creators. With the company's Sound Blaster GC7, not only do you get the highest quality audio tuned by experts, but also DSPs optimized for various game genres, and audio controls for content creators. We're giving away three prizes from the Creative stable, and without further ado, here they are:- @truehighroller1 from the US, wins the Creative Sound Blaster GC7
- Gabriele from Italy, wins the Creative Sound Blaster X4
- Jeff from the US, wins the Creative Sound BlasterX G6
A huge Congratulations to you three! TechPowerUp and Creative with more such interesting giveaways!
More...
Unofficial NVIDIA GeForce RTX 3060M Performs Within an Inch of the RTX 3060
Remember those unofficial GeForce RTX 3060 cards that sported "hackamajigged" Mobile versions of the NVIDIA RTX 3060 desktop GPU wrapped in a shiny, desktop-like shroud? Well, those cards are now surfacing again just as Ethereum's Merge approaches (for the umpteenth time, it has to be said). Miners have taken to offload their graphics cards in order to recoup their hardware investment costs. Despite the recent positive price action, which saw Ethereum in particular recovering 34% of its value in about a week, there's only so much time left to mine before all those re-purposed GPUs become "nothing more" than gaming graphics cards. And those are usually superfluous beyond one per rig - never mind the numbers used by miners.
As these cards are now surfacing in the secondary markets, some benchmarks are also leaking. According to a Korean YouTuber, It appears that the RTX 3060M is actually a pretty competent RTX 3060. The GeForce RTX 3060M makes use of the same GA106 (Ampere) silicon as the GeForce RTX 3060 Mobile, sporting 3,840 CUDA cores and 6 GB of 14 Gbps GDDR6 memory (256 more CUDA cores than the desktop version, as wider, lesser-clocked GPUs sport better power efficiency profiles). The desktop shroud does allow it to unlock an additional 300 MHz in core frequency, while reducing its TDP from 105 W down to just 80 W.
More...
(PR) Silicon Power Introduces Stream S05 Portable Hard Drive
The new Stream S05 from Silicon Power (SP) was designed to be the perfect portable hard drive for saving on the go. The Stream S05 will be your new favorite 2.5" portable hard drive. Intended for everyday use, its compact and lightweight design comfortably fits in your hand for ultimate portability. Bring it with you wherever you go to back-up everything from important documents to irreplaceable memories, reliably and securely. Photos, videos, songs, documents - whatever you need to back-up, the Stream S05 has space for tons of it with up to 5 TB of storage capacity. Plus, a super-speed USB 3.2 Gen 1 Type-A interface delivers rapid transfer rates to cut the time needed for storing your files in a safe place.
More...
Robot
Most Wanted
- 82
(PR) Discord Voice Chat Comes to Xbox Consoles
Get ready to connect with your Discord friends and communities on Xbox! Discord Voice chat is coming to your Xbox Series X|S and Xbox One consoles. You will be able to chat with anyone on Discord via voice channels or group calls directly from your console making it easy to connect with friends across mobile, Xbox, and PC. The update will start rolling out to Xbox Insiders today and will be available soon for everyone.
Today's update enables a highly requested feature - Discord Voice on Xbox consoles allows you to talk with your friends and community while you play your favorite games. Planning a few rounds of multiplayer action in Halo Infinite with buddies on both console and PC? Exploring new biomes with your friends in Minecraft? See them already playing a game that supports cross-play? Connect to their voice channel and chat as you all play.
More...
(PR) EK Launches Mousepads as Part of New EK Loot Product Line
Gaming is no good without the proper gear for your PC environment, and EK has decided to solve that issue for you! EK Water Blocks, the premium liquid cooling gear manufacturer, is preparing a brand new product category for gamers and PC enthusiasts called the EK Loot. Things are being kicked off with a couple of sleek minimalistic mousemats, ranging from small to extra large. But fear not; these will not be the only EK Loot products to hit the shelves since more cool essentials are soon to follow to create the right environment for your PC.
More...
(PR) Goodram Launches IRDM PRO DDR4 Crimson White Series
The IRDM gaming brand, meeting the expectations of gamers and PC builders, introduces new white DRAM memory modules, which are distinguished by red details and marking of heat sinks. The IRDM PRO DDR4 Crimson White series is a response to the growing interest in PC sets made of white components. The latest modules in the IRDM portfolio are characterized by a frequency of 3600 MHz with timings 18-22-22 and a voltage of 1.35 V. The offer includes single modules with capacities of 8 and 16 GB, as well as the increasingly popular Dual Channel 16 and 32 GB sets.
IRDM PRO DDR4 Crimson White is a memory designed for gamers, enthusiasts and users expecting fast and stable operation of their computer set. The memories are based on an 8-layer white PCB and selected Samsung D-Die memory chips. The whole module is enclosed in a stylish white heat sink with a distinctive crimson IRDM brand logo.
More...
Robot
Most Wanted
- 82
(PR) Jade Ember Studios Announces Reliquary, a Story-Driven Action-Adv
Jade Ember Studios is proud to announce Reliquary, a story-driven action-adventure game in which you explore the preserved ruins of a vanished empire as you fight your way through a land teeming with monsters, magic, and lost technology.
Reliquary is an original 3D, action-adventure title with an emphasis on character-driven story and ability-driven exploration and progression, taking influence from titles like Metroid Prime, Hyper Light Drifter, and Tomb Raider (2013), planned for release in the coming December-February window for Nintendo Switch, PS4, Xbox One, and PC, with additional PS5 and Xbox Series versions planned for 2023.
More...
(PR) Turtle Beach's New, Affordable Designed for Xbox REACT-R Controller Now Available for Gamers
Turtle Beach Corporation today announced that the all-new Designed for Xbox Turtle Beach REACT-R Controller is now available at retailers in the U.S. The first of Turtle Beach's new controller products to launch in 2022, the REACT-R is an ultra-affordable controller at $39.99 MSRP with many of the same core features as the highly rated Designed for Xbox Recon Controller (MSRP $59.99). This includes delivering the leading console gaming headset maker's exclusive, patented Superhuman Hearing sound setting to any connected wired 3.5 mm headset.
The REACT-R Controller launched in the UK and in Europe last month where it immediately garnered critical acclaim, including from GamesRadar with a 4.5/5 review score, calling it "stunning value for the money," and saying, "This gamepad looks, feels, and plays as a far more premium product." The REACT-R Controller is compatible with Xbox Series X|S, Xbox One, and Windows PCs and is available in Black, or White with Purple accents. Gamers can get their REACT-R Controller today from Turtle Beach and participating retailers for $39.99 MSRP.
More...
AMD Ryzen 7 7700X Sample Pictured in the Flesh
Someone with access to an AMD Ryzen 7 7700X "Zen 4" processor posted one of the first pictures of an AMD Ryzen 7 7700X "Zen 4" desktop processor installed on a motherboard. The picture shows the 7700X seated in the Socket AM5. The retention brace of the socket only clutches against two side protrusions of the IHS. AMD explained in its recent interview with us that the odd shape of the IHS is to accommodate the various electrical SMDs outside the IHS for better thermal management. With the processor installed, we can see that they're exposed and not covered up by the retention brace. The IHS is taller than the brace, so there will be some passive ventilation for the SMDs. Installing a Ryzen 7000 processor on Socket AM5 involves familiar steps to installing Intel mainstream-desktop processors for the past 15 years. This particular processor has the "D" marking on the IHS, which denotes a non-retail sample (possibly a review sample).
More...
(PR) Fractal Design Outs Focus 2 Case Series
The new Focus 2 mid-tower cases offer a precise, straight-forward design which has been carefully engineered to leverage the airflow potential of the case. Its innovative approach to the interior layout creates an unobstructed flow throughout the case, making it enjoyable to build and upgrade in, while unlocking the ability to cool components directly. This performance-centric design helps to enable a smooth experience, allowing users to focus on what's important to them.
Out of the box, its quality construction, clean exterior and airflow-enabling front mesh make Focus 2 a serious choice for gaming systems. Inside, it also offers quality-of-life building features such as an open and accessible interior, SSD quick clips, and intuitive cable management options. One of the many user benefits of Focus 2 is its adaptability and upgradeability, with available accessories including storage expansions and a USB-C upgrade kit.[Editor's note: Our in-depth review of the Fractal Design Focus 2 RGB is now live]
More...
(PR) EKSA Launches its New E900 x Lords Mobile Headset
Continuing its prestigious collection of gaming headsets, EKSA is pleased to announce a collaboration with Lords Mobile, a game that has won several awards and is highly rated on the Google Play Store and IOS App Store with its E900 x Lords Edition. Building upon the success of the E900 and upgrading its features and color set, EKSA's collaboration with Lords Mobile also offers customers a deluxe game pack worth USD 350 if used within 24 hours. The EKSA E900 X Lords Mobile Headset is available from the EKSA website and Amazon for $35.99/£29.85.
Since its release in 2016, Lords Mobile has become one of the most popular strategy games globally, with 490 million registered players. Creating the headset directly with Lords Mobile, it boasts several optimisation features made specifically for the game with upgraded 50 mm drivers to unlock greater sonic detail, depth, and clarity promise to allow for the battle videos featured throughout Lords to be even more immersive for gamers. In addition to this, owing to the enhanced audio quality of the headset, players can accurately identify the location of various in-game sounds, whether it is a gentle footstep or an enemy gunshot.
More...
(PR) EK Introduces Fluid Works Compute Series X7000-RM GPU Server
EK Fluid Works, a high-performance workstation manufacturer, is expanding its Compute Series with a rackmount liquid-cooled GPU server, the X7000-RM. The EK Fluid Works Compute Series X7000-RM is tailor-made for high-compute density applications such as machine learning, artificial intelligence, rendering farms, and scientific compute simulations.
What separates the X7000-RM from similar GPU server solutions is EK's renowned liquid cooling and high compute density. It offers 175% more GPU computational power than air-cooled servers of similar size while maintaining 100% of its performance output no matter the intensity or duration of the task. The standard X7000-RM 5U chassis can be equipped with an AMD EPYC Milan-X 64 Core CPU, up to 2 TB of DDR4 RAM, and up to seven NVIDIA A100 80 GB GPUs for the ultimate heavy-duty GPU computational power. Intel Xeon Scalable single and dual socket solutions are also possible, but such configurations are limited to a maximum of five GPUs.
More...
(PR) Tunermaxx Announces Snow Scout, a Virtual Reality Adventure On Skis
A year after their exclusive Meta Quest release "Rainbow Reactor: Fusion", Tunermaxx are back with an ambitious VR adventure on Steam VR. The game spent five months in Early Access and was shaped by feedback from the community. Players will be immersed in a majestic Alpine landscape, preparing a remote little ski resort for reopening - all by themselves.
With all the stress that has been invading our lives recently, Snow Scout offers a chance to virtually get away from it all. Players experience the game's story as themselves, having decided to volunteer with a non-profit organization, with the task of preparing a remote little ski resort for reopening. They will have to perform tasks based on real ski patrols, like opening and checking slopes, performing snow cover tests to determine avalanche risks and even triggering controlled avalanches, as well as side-tasks like recycling trash and taking pictures of elusive Alpine birds.
More...
(PR) Reach New Levels of Total Immersion with Logitech Chorus for Meta Quest 2
Logitech today announced a new integrated audio solution designed from the ground up for Meta Quest 2 to be the ultimate audio integration, the Logitech Chorus. "From the start, we wanted to help more people discover all that VR has to offer," said Vadim Kogan, head of AR/VR business group at Logitech. "Chorus enhances the fit and comfort of Meta Quest 2, while allowing those who love long play sessions to stay immersed in their favorite games and experiences through the audio integration in a comfortable design built for the VR gamer."
The new Logitech Chorus reaches a new level of immersive, ultra-realistic audio thanks to a new approach to headset design with custom-tuned off-ear acoustics. Featuring an open-back design, rotating speakers, and an integrated strap solution, this new design is the optimal solution for Meta 2 Quest users, allowing them to stay cool, while moving fast and free in the Metaverse. Nothing in or around your ear interferes with your game, your workout, or your creativity.
More...
Robot
Most Wanted
- 82
Intel Arc A380 Desktop Graphics Card Pre-Orders Open in USA for 139 US
The Intel Arc Alchemist A380 desktop graphics card is now available to pre-order in the USA with Newegg listing ASRock's Challenger ITX model for 139.99 USD and shipping from August 22nd. The ASRock Arc A380 Challenger ITX 6GB OC is a custom design featuring a singular cooling fan and a GPU clock speed of 2250 MHz running at a 75 W TDP paired with a single 8-pin power connector. The card features PCIe 4.0 connectivity and 8 Xe-Cores alongside triple DisplayPort 2.0 connectors and a single HDMI 2.0b. The card will compete with the similarly priced NVIDIA GTX 1650 and the AMD Radeon RX 6400 as seen in our review of the GUNNIR Photon Arc A380 model.
More...
(PR) Tachyum Submits Bid for 20-Exaflop Supercomputer to U.S. Department of Energy Advanced Computing Ecosystems
Tachyum today announced that it has responded to a U.S. Department of Energy Request for Information soliciting Advanced Computing Ecosystems for DOE national laboratories engaged in scientific and national security research. Tachyum has submitted a proposal to create a 20-exaflop supercomputer based on Tachyum's Prodigy, the world's first universal processor.
The DOE's request calls for computing systems that are five to 10 times faster than those currently available and/or that can perform more complex applications in "data science, artificial intelligence, edge deployments at facilities, and science ecosystem problems, in addition to the traditional modeling and simulation applications."
More...
Intel Core i9-13900K Reportedly 60% Faster Then i9-12900K in 7-Zip Decompression Test
The upcoming flagship Intel Core i9-13900K processor has recently appeared in a 7-Zip benchmark screenshot where the chip beat it's predecessor by 20% and 60% in compression and decompression tests respectively. The i9-13900K looks set to feature an additional 8 High-Efficiency cores for a total of 24 cores along with a higher boost clock of 5.8 GHz. This increased core count and clock speed account for the majority of the performance improvements with the i9-13900K reaching a max single thread clock of 5716 MHz and 4611 MHz on 16 threads compared to 5021 MHz and 4060 MHz with the i9-12900K. The processors were both paired with a 32 GB set of DDR5-6400CL32 memory on an unspecified motherboard. These results have not been confirmed with Intel expected to officially unveil the new lineup on September 27th.
More...
(PR) QNAP Launches Dual-port 100GbE Network Expansion Card
QNAP Systems, today launched the QXG-100G2SF-CX6 dual-port 100GbE PCIe 4.0 expansion card. Featuring an NVIDIA Mellanox ConnectX-6 Dx controller, the QXG-100G2SF-CX6 can be installed in a QNAP all-flash NAS or Windows /Linux workstations/servers to provide up to 200 Gbps total throughput. The QXG-100G2SF-CX6 is suited for overcoming performance bottlenecks with incredibly low-latency in bandwidth-demanding applications including data centers, virtualization, multimedia streaming/transfer, and mission-critical backup/restore tasks.
"Server efficiency and virtualization density drive the growing demands for higher bandwidth, and the QXG-100G2SF-CX6 network expansion card provides an accessible solution for upgrading to 100 GbE network environments to boost performance and reduce latency," said Andy Chuang, Product Manager of QNAP, adding "The QXG-100G2SF-CX6 is a feature-rich networking solution with advanced technologies for lowering CPU workloads, making it ideal for I/O-intensive, latency-sensitive virtualization and enterprise-class storage applications."
More...
Intel Intros NUC 12 Pro "Wall Street Canyon" Compact Commercial Desktops
Intel late-Tuesday (16/08) announced the NUC 12 Pro "Wall Street Canyon" line of compact desktops as enclosed prebuilt mini PCs, and bare motherboards. These are based on the 12th Gen Core "Alder Lake-P" (2P+8E) mobile processors paired typically with up to 16 GB of dual-channel DDR4 memory, up to 512 GB of M.2 NVMe Gen 4 SSD storage, an additional Gen 4 M.2 slot, and come with preinstalled Windows 11. Certain variants feature a slightly larger chassis with room for a 2.5-inch SATA 6 Gbps drive. Select SKUs come with Thunderbolt 4 ports, 20 Gbps USB 3.2x2 ports, 2.5 GbE, and Wi-Fi 6E networking. and certain SKUs even offer vPro management features for commercial environments.A video-presentation by SimplyNUC follows.
More...
(PR) Das Keyboard Introduces the MacTigr, a Low-Profile Mechanical Keyboard for the Mac
Das Keyboard, a leader in mechanical keyboards, today announced the introduction of the MacTigr, a modern, low-profile mechanical keyboard designed for the Mac. The new MacTigr has a sleek, modern design made with the highest-quality components to create the ultimate typing experience on Macs. The MacTigr features Mac-specific keys, linear Cherry MX Low Profile Red mechanical switches, low-profile double-shot PBT keycaps, a 2-port superspeed USB-C hub, volume knob, sleep button and media controls. Encased entirely in metal, the slim housing features a heavy-duty, matte black stainless steel top, and a gunmetal gray aluminium unibody, making it extremely rigid and durable.
"Mac users have been deprived of having high-quality, mechanical keyboards designed specifically for macOS," said Daniel Guermeur, co-founder and CEO of Das Keyboard. "Our new MacTigr is built to last and helps users achieve the highest levels of productivity and creativity, while the low-profile switches and soft PBT keycaps produce a supple, satisfying action, making it feel like you are typing on a cloud. We've brought the best of both worlds together - design and durable functionality - for a premium Mac typing experience. This is the Mac keyboard overachievers will love using."
More...
(PR) Townscaper VR Arriving in October
Raw Fury and Oskar Stålberg are happy to share the very fun news that Townscaper VR is coming this October 6th on Meta Quest VR and PICO. Townscaper was originally released in June 2020 and received rave reviews from players across the world.
This indie city builder allowed players of all experiences to build their own idyllic ocean-side towns with just a few clicks. Now fans and newcomers alike will be able to fully immerse themselves into the creative process and experience building their own quaint and colorful towns in a more immersive manner, through the power of VR. Players will be able to try this new way of building in Townscaper at Gamescom this year. You'll be able to locate the game and team over in HALL 9.1 Aisle B No: 049.
More...
(PR) Avermedia Launches the Live Gamer Extreme 3 with VRR support
AVerMedia Technologies, Inc., a leader in digital video and audio solutions, is thrilled to announce the launch of the Live Gamer EXTREME 3 (GC551G2). As AVerMedia's latest plug-and-play external 4K capture card, it can capture up to 4K 30fps in SDR while passing through gameplay at up to 4K 60fps in HDR. It is also AVerMedia's first capture card that supports variable refresh rate (VRR).
With VRR, the Live Gamer EXTREME 3 brings out the best performance for a competitive streaming session. VRR allows the monitor and gaming device to synchronize each frame to provide smooth tear-free gameplay so gamers can focus solely on the actions without getting distracted by any graphic delay. Additionally, the Live Gamer EXTREME 3's ultra-low latency feature enables zero lag between the gaming device and the monitor, ensuring the capture signal is delivered to the live stream equally fast. These two features allow gamers to enjoy the highest video quality for their gameplays and streams. And thanks to the use of UVC standard, the Live Gamer EXTREME 3 works out of the box without the need to install any drivers.
More...
(PR) AMD to Host Livestream Event on the 29th of August to Unveil Next Generation Ryzen Processors
Today, AMD (NASDAQ: AMD) announced "together we advance_PCs," a livestream premiere to unveil next generation AMD PC products. Chair and CEO Dr. Lisa Su, CTO and EVP Mark Papermaster, and other AMD executives will present details on the latest "Zen 4" architecture that powers upcoming AMD Ryzen processors and the all new AM5 platform built around the latest technologies including DDR5 and PCIe 5.0, all designed to drive a new era of performance desktop PCs.
The show will premiere at 7 p.m. ET on Monday, August 29, on the AMD YouTube channel. A replay can be accessed a few hours after the conclusion of the event at AMD.com/Ryzen.
More...
Robot
Most Wanted
- 82
(PR) HYPER Announces Availability of the World's First & Smallest 245W
Today, HYPER, the #1 Docking Station Brand in the USA, announced the immediate availability of the HyperJuice 245 W GaN Desktop Charger and 245 W USB-C Battery Pack after a successful crowdfunding campaign that garnered 5,000+ backers and generated over $1M in funding. The world's first and smallest HyperJuice 245 W GaN Desktop Charger is designed for the "work from home" professional or enterprise looking to maximize power connectivity when outlet space may be sparse. With four 100 W (max) USB-C Power Delivery ports powered by industry-leading GaN technology, users will be able to power four mid-size 60 W laptops (like the 13" MacBook Pro/Air) or quick charge two large 100 W laptops (16" MacBook Pro), tablet (iPad Pro) and smartphone (iPhone 13) all at the same time from a pocket-sized charger.
Need power on the go? The world's first HyperJuice 245 W USB-C Battery Pack takes the same 245 W of USB-C power on the road for the traveling professional. It boasts a whopping 100Wh/27000mAh airline-safe battery capacity, two 100 W (max) and two 65 W (max) USB-C Power Delivery ports, giving you the ability to charge four USB-C devices like laptops, tablets, DSLR cameras, smartphones, drones, gaming consoles all at the same time. It features an illuminated OLED screen to inform users about the remaining battery capacity and charging power of each port and comes with a 100 W input so that you can quickly recharge the battery in 1 hour using the HyperJuice 245 W GaN Charger or any 100 W USB-C charger.
More...
(PR) CORSAIR Ushers in the New Era of AMD with Support for AMD Ryzen 7000 CPUs
CORSAIR, a world leader in enthusiast components for gamers, creators, and PC builders, today announced its readiness for the new AMD Ryzen 7000 Series processors and accompanying motherboard chipsets. Featuring all new Zen 4 CPU architecture, AMD Ryzen 7000 Series chips deliver a substantial performance boost over previous-generation processors, and CORSAIR has the components to help support this generational upgrade. Those looking to build a new AMD system can take advantage of the free online CORSAIR PC Builder to help shortlist compatible parts for their new system.
CORSAIR has been working closely with AMD in the lead-up to the AMD Ryzen 7000 Series launch, and has already updated its PC Builder database to include the new processors so that you can curate a parts list for a powerful new AMD PC in minutes. The CORSAIR PC Builder takes your chosen CPU, graphics card, and motherboard and checks them for compatibility against a vast database of PC parts, coming up with a comprehensive list of CORSAIR parts guaranteed to work with your system. From a correctly sized case and appropriate fans, to a PSU rated to power your build and even RGB lighting, the CORSAIR PC Builder takes the guesswork out of building your new Ryzen 7000 Series powered PC. The CORSAIR PC Builder is even able to intelligently optimize the parts selected, so that you don't overspend or bottleneck your build with a mismatched component.
More...
AMD Ryzen 7000 Series Retailer Pricing 10% to 13% Higher Than Ryzen 5000
PC Canada has drawn first blood in registering pricing for AMD's upcoming Ryzen 7000 series, the successor to the successful 5000 series. As spotted by renowned leaker momomo_us and shared on Twitter, the specialist retailer based in Canada listed pricing for the Ryzen 7 7600X, 7700X, 7900X and 7950X CPUs. The pricing, if representative, shows an average increase that averages to 10%-12% across SKUs when compared to the previous generation Ryzen. The prices could be placeholders based on the retailers' own expectations, so this information should be taken with a grain of salt (or two).
After conversion from CAD to US dollars, pricing settles at $340 for the Ryzen 7 7600X ($299 for the 5600X at launch, for a 13% premium); $494 for the Ryzen 7 7700X (against the later-released, $299 Ryzen 7 5700X for a 65% premium); $625 for the Ryzen 9 7900X ($549 for the launch Ryzen 9 5900X, for a 13% increase) and finally, the Ryzen 9 7950X for $906 (against the Ryzen 9 5950X's $799 asking price, for another 13% premium).
More...
Robot
Most Wanted
- 82
(PR) ASUS Announces New AMD X670E Motherboards at Canadian National Ex
ASUS today announced a new generation of AMD-based motherboards to accompany the ROG Crosshair X670E Extreme and support the latest Ryzen 7000 processors: the ROG Crosshair X670E Hero, the ROG Strix X670E-E Gaming WiFi, and the TUF Gaming X670E-Plus WiFi. Introducing the new generation of AMD ROG motherboards: the X670E series. Featuring support for DDR5 memory modules and PCIe 5.0 devices, the ROG Crosshair X670E Hero, ROG Strix X670E-E Gaming WiFi, and TUF Gaming X670E-Plus WiFi is equipped with improved bandwidth capabilities, stability, and overall connectivity.
All three boards feature the latest ASUS Q-Design innovations. The ROG Crosshair X670E Hero and ROG Strix X670E-E Gaming WiFi includes the PCIe Q-Release button, a feature that lets users release their graphics card from the PCIe slot with one press. In addition, all three featured motherboards will include the single-sided Q-DIMM latching design to ensure ease of installation and allowing memory sticks to hold firmly in place. Lastly, the boards include the M.2 Q-latch, allowing users to secure or loosen an M.2 drive with just their fingertips.
More...
(PR) iVoler Introduces Coveted Pro Version Steam Deck Dock
Video game accessories company iVoler today announced a Pro version of its Steam Deck docking station. Compatible with Valve Steam Deck handheld gaming device, the dock provides an immediate solution for users who have been shut out by Valve indefinitely delaying their own proprietary docking station due to production issues. This Steam Deck dock pro will be available on September 5 in 7 Amazon marketplaces; US, CA, UK, DE, FR, IT, and ES with prime shipping service. iVoler also provides a 15% discount for social media pre-order.
iVoler Steam Deck Dock Pro is a 6-in-1 docking station that is specifically designed to work with Valve's handheld device. It also features three USB 3.0 ports with up to 5 Gbps data transmission, and one angled USB-C cable fitting angled connection for the Steam Deck device. Priced at $49.99, iVoler's dock is also a budget-friendly 6-in-1 docking station option that combines a USB hub and kickstand together.
More...
(PR) Alphacool Confirms that all its CPU Coolers are AMD Socket AM5 Compatible
Just in time for the launch of the new AMD processors in September 2022, we can announce that all CPU coolers and All-in-One solutions in the Alphacool product range are compatible with AMD's AM5 socket. The required mounting kit is included with all coolers and AIOs and enables the new Ryzen 7000 Series processors to be water-cooled with Alphacool products right from the start.
More...
(PR) AOC's Chic V5 Series Now Expanded with Webcam-equipped USB-C Monitors
Display specialist AOC announces three new multi-functional monitors from its V5 series aimed at home office users and students just in time before the next term. The triple addition in three sizes (24"/60.4 cm 24V5CW, 27"/68.6 cm Q27V5CW and the 34"/86.4 cm ultrawide CU34V5CW) features 2 MP built-in webcams with Windows Hello support for easy login and increased security, thus fulfilling today's requirements for video calls and meetings. The 3-sides borderless V5 models are thin displays with a versatile USB-C connection, offering 65 W Power Delivery to charge and power laptops or tablets with a single cable while transferring the display signal.
Unlike bulky, uninspiring monitors, the design of the V5 series brings a lightweight, contemporary look to modern desks and home offices. They feature a 3-sides borderless design with a narrow chin at the bottom bezel, a thin base (12.1 mm), and an ergonomic, height-adjustable stand: the V5 series does not compromise the chic interior design of any living spaces.
More...
TSMC has Seven Major Customers Lined Up for its 3 nm Node
Based on media reports out of Taiwan, TSMC seems to have plenty of customers lined up for its 3 nm node, with Apple being the first customer out the gates when production starts sometime next month. However, TSMC is only expected to start the production with a mere 1,000 wafer starts a month, which seems like a very low figure, especially as this is said to remain unchanged through all of Q4. On the plus side, yields are expected to be better than the initial 5 nm node yields. Full-on mass production for the 3 nm node isn't expected to happen until the second half of 2023 and TSMC will also kick off its N3E node sometime in 2023.
Apart from Apple, major customers for the 3 nm node include AMD, Broadcom, Intel, MediaTek, NVIDIA and Qualcomm. Contrary to earlier reports by TrendForce, it appears that TSMC will continue its rollout of the 3 nm node as previously planned. Apple is expected to produce the A17 smartphone and tablet SoC, as well as advanced versions of the M2, as well as the M3 laptop and desktop processors on the 3 nm node. Intel is still said to be producing its graphics chiplets with TSMC, with the potential for GPU and FPGA products in the future. There's no word on what the other customers are planning to produce on the 3 nm node, but MediaTek and Qualcomm are obviously looking at using the node for future smartphone and tablet SoCs, with AMD and NVIDIA most likely aiming for upcoming GPUs and Broadcom for some kind of HPC related hardware.
More...
ASUS Recalls ROG Maximus Z690 Hero Motherboards Due to Fire and Burn Hazard
Under the directions of the US Consumer Products Safety Commission (CPSC), the regulatory body overseeing consumer-safety for the US and Canada, ASUS has instituted a general recall of its Republic of Gamers (ROG) Maximus Z690 Hero Socket LGA1700 motherboard. This includes pulling the product from the market, as well as reaching out to current owners, informing them of a design flaw with the product that affects their safety, and offering replacements.
The general recall has its roots in a December 2021 announcement by ASUS that a batch of the motherboard is being voluntarily recalled by the company after it discovered that a capacitor that's part of the motherboard's VRM has been defectively installed in the opposite electrical polarity. This has the potential to cause a fire.
More...
(PR) Gigabyte Announces the AORUS Gen5 10000 SSD with Capacities up to 4 TB
GIGABYTE Technology, one of the top global manufacturers of motherboards, graphics cards, and hardware solutions, announces today the latest AORUS Gen5 10000 SSD with 10 GB/s read speed. Enhanced by the new generation PCIe 5.0 controller with ultra-fast 3D-TLC NAND Flash, AORUS Gen5 10000 SSD provides boosted performance of more than 55% over PCIe 4.0 SSDs and comes in 1 TB to 4 TB capacity variants using an M.2 2280 interface to deliver easy installation and superb capability. Additionally, the separate SSD and heatsink offers more flexibility in system build and thermal options for users. GIGABYTE's exclusive SSD Tool Box application provides users real-time status of SSD to leverage performance, thermal, stability and capability.
"With PCIe 5.0 support on new motherboard platform, the bandwidth and transfer performance are raised to the next level. As the first manufacturer to have both motherboards and SSD product lines in the market, GIGABYTE is also the first to unveil the AORUS Gen5 10000 SSD. This new product brings blistering fast storage performance with ultra durability and compatibility to users for optimal quality and performance." said Jackson Hsu, Director of the GIGABYTE Channel Solutions Product Development Division.
More...
Qualcomm Wants Server Market to Run its New Processors, a Re-Launch Could Happen
Qualcomm is a company well known for designing processors going inside a vast majority of smartphones. However, the San Diego company has been making attempts to break out of its vision to focus on smartphones and establish new markets where it could show its potential for efficient processor design. According to Bloomberg's insights, Qualcomm is planning to re-enter the server market and try again to compete in the now very diverse space. In 2014, Qualcomm announced that the company is developing an Arm ISA-based CPU that will target servers and be an excellent alternative for cloud service providers looking at efficient designs called Centriq. Later on, in November of 2017, the company announced the first CPU Centriq 2400, which had 48 custom Falkor cores, six-channel DDR4 memory, and 60 MB of L3 cache.
What happened later is that the changing management of the company slowly abandoned the project, and the Arm CPU market was a bit of a dead-end for many projects. However, in recent years, many companies began designing Arm processors, and now the market is ready for a player like Qualcomm to re-enter this space. With the acquisition of Nuvia Inc., which developed crazy fast CPU IPs under the leadership of industry veterans, these designs could soon see the light of the day. It is reported that Qualcomm is in talks with Amazon's AWS cloud division, which has agreed to take a look at Qualcomm's offerings.
More...
(PR) Ghostbusters: Spirits Unleashed Available for Pre-Order, Launches October 18
Ghostbusters: Spirits Unleashed, a 4v1 hunt or haunt action-packed asymmetrical multiplayer is available for pre-order, August 18, 2022, 8 a.m. PT. The latest game from IllFonic, Inc. will be playable Tuesday, October 18, 2022, on PC via Epic Games Store, PlayStation 4|5, Xbox Series X|S and Xbox One. Form a team with up to three other Ghostbusters to track down Ghosts haunting a number of locales. Sniff out paranormal activity with the P.K.E. Meter and charge it to unleash a short-range pulse disabling Ghost movement. Unveil hidden rifts acting as the Ghost's spawn points and teleportation portals, and destroy them. Use the powerful Particle Throwers to capture the Ghost, deploy a trap, and wrangle them into it before they escape!
Meanwhile, the Ghost works alone, roaming around stages like the Museum, an abandoned Prison, and other spooky locations, including a new one to be revealed at Gamescom. Frighten civilians to scare them away. Possess objects to raise the overall Global Haunt percentage, to regain ghost power, or just cause mass hysteria. Use slime to temporarily stun Ghostbusters. Move the rifts to keep them guessing, summon minions to make an escape, and show the Ghostbusters they should be afraid of this Ghost!
More...
Robot
Most Wanted
- 82
VANKYO Launches the World's Smallest Full HD 5G Wireless Outdoor Mini
VANKYO, the world's leading innovative home entertainment projector brand, launches its newest product in the Full HD projector series. The Leisure 470 Pro—the industry's smallest full HD 1080P LCD projector, representing a milestone in the development of VANKYO.
The Leisure 470 Pro is compact and lightweight, making it a true portable companion for outdoor activity lovers. The optimized display structure and chipset provide stunning Full HD 1080P (in resolution) images in 250 inches, bringing outdoor enthusiasts hands-free mobile enjoyment. The ground-breaking fundamental innovations have indeed granted a perfect mobile projection solution for indoor and outdoor entertainment. Also create smooth and responsive gaming on massive screens, good choice for entry-Level gaming Projector.
Buy VANKYO Liesure 470 Pro Compact Outdoor Full HD Projector at just $149.99 | Please use the coupon code techpowerup at check-out to avail the price you see here.Read on to know more about this slick piece of portable technology.
More...
(PR) CORSAIR VOYAGER a1600 Gaming & Streaming Laptop AMD Advantage Edition Available Now
CORSAIR, a world leader in high-performance gear and systems for gamers, content creators, and PC enthusiasts, today announced the availability of the CORSAIR VOYAGER a1600 AMD Advantage Edition laptop from the CORSAIR webstore and distributors worldwide. Starting at an MSRP of $2,699.99, the CORSAIR VOYAGER a1600 features state-of-the-art AMD processor and graphics for mobile systems working in tandem using exclusive AMD smart technologies, alongside CORSAIR and Elgato software and technologies, to create a gaming and streaming experience like no other.
The CORSAIR VOYAGER a1600 comes equipped with AMD's most advanced components to deliver high-end performance in an incredibly thin 19.8 mm form-factor. An 8-core, 16-thread AMD Ryzen 9 6900HS processor and AMD Radeon RX 6800M mobile graphics enable players to game at maximum settings while capturing gameplay at high frame rates, bolstered by AMD smart technologies such as AMD Smart Access Memory to get even more performance out of your top-of-the-line components. CORSAIR VENGEANCE DDR5 SODIMM memory rounds out the CORSAIR VOYAGER a1600's powerful hardware, delivering the incredibly high frequencies of the DDR5 platform.
More...
Alienware Announces 24.5-Inch 1080p 360 Hz and 27-Inch 1440p 280 Hz Monitors
Dell has launched a pair of new gaming focused displays under its Alienware badge and both are high refresh rate monitors. The 25-inch (or rather 24.5-inch) model goes under the model name AW2523HF and has a 1080p panel with a 360 Hz refresh rate. It supports Freesync Premium and it also supports VESA AdaptiveSync. It's said to have a 400 nits peak brightness fast IPS panel that has a colour gamut that covers 99 percent of the sRGB spectrum. Inputs consist of one DP 1.4 and two HDMI 2.0 ports, as well as a USB-B 3.0 input and four USB-A 3.0 outputs
The 27-inch model is called the AW2723DF and it sports 1440p resolution and here we're looking at a fast nano IPS panel that has a native 240 Hz refresh rate, but it can be pushed up to 280 Hz using an overclocking option. It supports FreeSync Premium, G-sync Compatible and AdaptiveSync, so here all your bases are covered regardless of which GPU you hook it up to. It's also an HDR 600 display with a typical peak brightness of 450 cd/m² and it has a wider colour gamut that supports 95 percent of the DCI-P3 spectrum. This is still an edge lit display, so don't expect amazing HDR performance. Connectivity is the same as for the AW2523HF, although it's said to support Picture-by-Picture and Picture-in-Picture, which the 25-inch model apparently doesn't. The AW2523HF will be available in early September for $450, while the AW2723DF will launch in early October for $650.
More...
(PR) CHERRY MX Keys Power CORSAIR Voyager a1600 AMD Advantage Edition
CHERRY MX, the market leader and expert for mechanical switches in keyboards, is the first choice for keyswitch technology for CORSAIR's laptop debut: the leading manufacturer of high-performance PC components and peripherals is shipping its brand-new high-end CORSAIR a1600 AMD Advantage Edition series laptops with the MX Ultra Low Profile Tactile switches. With this, the US company relies on mechanical precision made in Germany to meet the high demands of gamers, content creators, and other power users.
The CORSAIR Voyager a1600 is equipped with cutting-edge technology. Still, it remains surprisingly thin: Despite a height of only 19.8 millimeters, the mobile PC is equipped with the top processor AMD Ryzen 9 6900HS or Ryzen 7 6800HS, and the dedicated graphics solution Radeon RX 6800M. Together with 16 gigabytes of DDR5 memory from CORSAIR's Vengeance series, it is ensured that games run smoothly at maximum graphic details, and resource-intensive applications such as graphics or video editing software can be operated responsively. To adequately cool the high-performance components, CORSAIR relies on an advanced vapor-chamber cooling system that distributes heat evenly, keeping temperatures low even in this slim format.
More...
(PR) Apricorn Launches 2 TB Aegis Secure Key 3 with FIPS 140-2 Level 3 Hardware Encryption
Apricorn, the leading manufacturer of software-free, 256-bit AES XTS hardware-encrypted USB drives, today announced the release of the USB 3.2 Gen 1 Aegis Secure Key 3 2 TB encrypted flash key. Designed for organizations that need large amounts of encrypted storage with a minimal footprint, the new 2 TB Aegis Secure Key 3 is the industry's first hardware-encrypted flash key of this size, marking a time-honored tradition of innovation from Apricorn. Currently, the Aegis Secure Key 3 has eight capacity options ranging from 16 GB to 2 TB, pricing from $129.00 - $999.00 U.S.
The Aegis Secure Key 3, originally introduced in 2015, was the first Apricorn device to feature AegisWare, Apricorn's patent-protected firmware that first introduced Forced Enrollment, Programmable PIN lengths, Unattended Auto Lock and Lock Override. At 256 GB, this original version was already double the storage capacity of any encrypted flash key on the market. Fifteen months later, that maximum size doubled to 480 GB, and again doubled to 1 TB in November of 2018. Seven years after its initial launch, the Aegis Secure Key 3 has been adopted in myriad government, military, and corporate environments and remains Apricorn's fastest, most rugged flash key in the line.
More...
(PR) Line Games to Showcase Quantum Knights at Gamescom 2022
LINE Games Corporation announced today that it will participate online in Europe's biggest game exhibition Gamescom 2022 to showcase its upcoming PC title Quantum Knights. On August 24, LINE Games will present Quantum Knights on the official website of Gamescom 2022 with a new gameplay trailer. Currently in development by Space Dive Games, Quantum Knights is an online third-person looter shooter for PC. Set in a medieval fantasy open world where magic and firearms coexist, Quantum Knights offers stylish action based on shooter game's dynamic combat and movement mechanisms.
Each firearm featured in Quantum Knights has its own unique design and can be enhanced by carving in magic circles, which allows for the player to tailor the character's specialty and combat style accordingly. LINE Games plans on releasing Quantum Knights in 2023, and has opened a dedicated teaser site and social media channel where intrigued players can take a first look at the game.
More...
Robot
Most Wanted
- 82
Intel Arc A580 Hits AotS Benchmark Database, Roughly Matches RTX 3050
Intel Arc A580 is an upcoming entry-mainstream desktop graphics card based on the Xe-HPG "Alchemist" graphics architecture, and positioned between the A380 and A750. Based on the larger 6 nm DG2-512 silicon than the one powering the A380, the A580 is endowed with 16 Xe Cores, or double the SIMD muscle of the A380, with 2,048 unified shaders. The card enjoys 8 GB of GDDR6 memory across a 128-bit bus, which at 16 Gbps data-rate produces 256 GB/s bandwidth.
A leaked Ashes of the Singularity benchmark database entry reveals that the A580 scores roughly 95 FPS at 1080p on average, with 110 FPS in the normal batch, around 102 FPS in the medium batch, and around 78 FPS in the heavy batch. The benchmark used the Vulkan API, and an unknown 16-thread Intel processor with 32 GB of memory. These scores put the A580 roughly at par with the GeForce RTX 3050 "Ampere" in this test, which would make it a reasonable solution for playing popular online games at 1080p with medium-high settings, or AAA games at medium settings.
More...
(PR) Alphacool Presents Eiswolf 2 and Eisblock for GPU Cooling
Alphacool today releases a new Eiswolf 2 all-in-one water cooler as well as two other Eisblock water coolers for MSI and EVGA graphics cards. The Eiswolf 2 uses the 360 mm NexXxoS ST30 all-copper radiator. The Aurora Rise fan in the 120 mm version is included. The AIO is completed by the Eisblock Aurora water cooler, which in addition to the GPU chip actively cools all relevant components such as graphics memory and voltage converters and has brilliant aRGB lighting. The combination of all components results in a solution that is as easy to install as an AIO, but offers the performance of a pre-assembled and pre-filled custom loop.
The Eisblock is where performance meets brilliant design! Fully illuminated with aRGB LEDs, the full cover copper cooler with acrylic top and edge design not only looks great, but also impresses with its exceptional cooling performance.
More...
(PR) Klipsch and EAR Micro Launches the $2,500+ T10 Bespoke Ear Computers
EAR Micro and Klipsch Audio proudly announce the launch of T10 Bespoke Ear Computers at the Motorlux Event, Monterey Jet Center, August 18-19, 2022, to coincide with the 71st Concours D'Elegance.
T10 Bespoke represents an entirely new category of advanced hearables technology—tiny in-ear computers about a third of the size of traditional wireless earphones, yet significantly more advanced. T10 Bespoke Ear Computers seamlessly blend high-style luxury materials and hand craftsmanship typical of fine jewelry and watchmaking with state-of-the-art wireless hi-fi audio. The audio signal path boasts a stunning 96kHz/24-bit audio resolution rendered through the LDAC codec, further enhanced by twin Cadence/Tensilica Hi-fi DSP's, passed next through ultra-efficient class-D amplifiers, and finally into your ears through acoustically accurate Sonion precision balanced-armature transducers.
More...
Corsair Teases the Performance of its Upcoming MP700 PCIe 5.0 NVMe SSD
Corsair decided it was time to start teasing its upcoming MP700 PCIe 5.0 NVMe SSD, although the company didn't bother providing any images of the drive itself, or any specifications in the teaser. However, Corsair did provide some sequential performance figures, which end up being impressive and disappointing at the same time. The MP700 is said to offer sequential read speeds of up to 10 GB/s or 10,000 MB/s if you prefer and sequential write speeds of 9.5 GB/s. These are obviously very fast speeds, but quite far from what the PCIe 5.0 can deliver and the performance figures are only a bit faster than the best PCIe 4.0 drives. It's likely that we'll see better performance from second generation controllers, just as we did with PCIe 4.0 SSDs, as this gives both the SSD controller makers and the SSD makers a chance to refresh their products a year or two down the line.
More...
GoDeal24 MS Office Super Sale Rolls On: Up to 62% Discount on Genuine Software
GoDeal24 MS Office Super Sale continues into its second week. Get some of the lowest prices on the web for Genuine Microsoft Office 2021, and free yourself of annual 365 subscriptions. Get the powerful Office 2021 Professional Plus at just $25.61, with 2-PC, 3-PC, and 5-PC multi-packs at increasing discounts per PC. Also up on sale are various editions of Office 2019 and Office 2016, letting you save big if they fit your needs. Building a new PC or buying a notebook or desktop that lacks preinstalled software? Check out great deals on combinations of your preferred Office edition with those of Windows 11 or Windows 10.
Buy Office 2021 Professional Plus at $25.61 | Buy Office 2021 Professional Plus 2-PC at $40.98 | Buy Office 2021 Professional Plus 3-PC at $49.09 | Buy Office 2021 Professional Plus 5-PC at $67.63 | Buy Office 2019 Professional Plus at $24.59 | Buy Office 2016 Professional Plus at $18.68 | Buy Windows 10 Pro at $7.42 | Buy Windows 10 Pro 5-PC at $30.74 | Buy Windows 10 Home at $8.12 | Buy Windows 11 Pro at $10.24 | Buy Windows 10 Pro 2-PC at $12.67
Please use the coupon code SGO62 on the following items to avail the prices you see here.
Buy Windows 10 Pro + Office 2021 Professional Plus at $29.70 | Buy Windows 11 Pro + Office 2021 Professional Plus at $30.73 | Buy Windows 10 Pro + Office 2019 Professional Plus at $27.65 | Buy Windows 11 Pro + Office 2019 Professional Plus at $28.68 | Windows 10 Pro + Office 2016 Professional Plus at $24.58 | Buy Windows 11 Pro + Office 2016 Professional Plus at $25.60 | Buy Project Professional 2021 at $25.70 | Buy Visio Professional 2021 at $22.98 | Buy Office 2019 Home and Student at $31.15 | Buy Office 2021 Home and Business for Mac at $68.66 | Buy Office 2019 Home and Business for PC at $47.76 | Buy Office 2021 Home and Student at $40.45
Please use the coupon code SGO50 on the following items.
Buy Windows 10 Enterprise 2019 LTSC at $9.14 | Buy Windows 10 Enterprise 2021 LTSC at $12.81 | Buy Windows Server 2022 Standard at $26.12 | Buy Windows Server 2022 Datacenter at $30.75Check out great deals on system software you might want.
More...
Robot
Most Wanted
- 82
(PR) EK Announces Socket AM5 QuantumVelocity² CPU Water Blocks
EK, the leading computer cooling solutions provider, is announcing the latest generation of EK-Quantum Velocity² water blocks. These socket-specific water blocks are engineered specifically for the upcoming AMD AM5 socket and Ryzen 7000-series CPUs. Like its AM4 predecessor, the AM5 water block features EK-Matrix7 compatibility, which means it's designed according to the standard where the product's height and port distance are managed in 7 mm increments.
The product deploys a modified Velocity² cooling engine optimized for Ryzen 7000-series CPUs to ensure the best cooling performance and optimal coolant flow. While the mounting hole pattern of the new AM5 socket is still 54 x 90 mm, the AM5 motherboards now have an integrated CPU socket backplate with #UNC 6-32 threads, therefore requiring a new mounting system.
More...
(PR) UEFI Forum Releases the UEFI 2.10 Specification and the ACPI 6.5 Specification
The UEFI Forum today announced the release of the Unified Extensible Firmware Interface (UEFI) 2.10 specification and Advanced Configuration and Power Interface (ACPI) 6.5 specification. The new specification versions expand support for new processor types, memory interfaces and platform types, while allowing for crypto agility in post-quantum system security.
"We are excited to share the new Conformance Profiles feature, responsive to community pull for a way to make the UEFI Forum's work useful," said Mark Doran, UEFI Forum President. "The Conformance Profiles feature will expand the platform types UEFI can support to an ever wider range of platform types like IoT, embedded and automotive spaces - beyond general purpose computers."
More...
(PR) ASUS Republic of Gamers Announces ROG Loki Availability
ASUS Republic of Gamers (ROG) today announced the availability of the ROG Loki—the high-performance, high-wattage PSU series in a striking SFX-L form. Packed with large ROG heatsinks for rapid cooling, integrated ARGB lighting to project personal style and axial-tech fans for whisper-quiet operation, the Loki series is pumped and primed to power small-form-factor (SFF) builds.
Large showcase rigs will always be the lifeblood of the PC-building community, but SFF builds have become increasingly popular in recent years. It's easy to see why: for those that want a build that can comfortably fit on a smaller desk, or in an entertainment center for TV gaming, a Mini-ITX machine is the perfect choice. But cramming next-gen power into a tiny case can be a challenge, especially with the added heat those components can produce. ROG's new Loki power supplies were designed to keep efficiency up and footprint down, empowering avid PC DIYers to build no-compromise, console-crushing clones.
More...
(PR) ASUS Announces Vivobook 14 OLED, 15 OLED and 16 OLED
ASUS today announced Vivobook 14 OLED (X1405), Vivobook 15 OLED (X1505) and Vivobook 16 OLED (X1605), three feature-packed everyday laptops with OLED displays. These new Vivobook models deliver a stunning visual experience, featuring superb world-leading OLED NanoEdge PANTONE Validated displays with up to a 3.2K resolution and a 120 Hz refresh rate. Vivobook 14 OLED and 16 OLED have 16:10 aspect-ratio displays, while Vivobook 15 OLED has a traditional 16:9 aspect ratio. All displays have TÜV Rheinland low blue-light certification to ensure eye comfort during long viewing sessions.
Feature-packed specifications include a physical webcam shield on the HD 3DNR webcam for instant privacy; a full-size ASUS ErgoSense keyboard; a mega-sized touchpad that gives maximum room for fingers; an optional ASUS NumberPad 2.0 (Vivobook 14 OLED only) for easy data entry; and an optional fingerprint sensor on the touchpad. ASUS Antibacterial Guard protects against harmful bacteria.
More...
Latest Ryzen 9 7950X CPU-Z Bench MultiThreaded Score Puts it 8% Behind i9-13900K, 33% Ahead of i9-12900K
A screenshot of an alleged AMD Ryzen 9 7950X "Zen 4" processor surfaced on the web, courtesy of OneRaichu, and this time there's no blur-out with the score field—15645 points. When compared to the alleged CPU-Z Bench scores of the Core i9-13900K "Raptor Lake" from last week, the Intel 8P+16E hybrid processor ends up 7.9% faster than this score, but still a very close second.
The Ryzen 9 7950X ends up a significant 23.47% faster than the leaked score of the Core i7-13700K (8P+8E), and the AMD flagship scores 33.5% faster than the previous-gen Intel flagship Core i9-12900K. While both the i7-13700K and i9-12900K are 8P+8E, the "Raptor Lake" gets ahead with higher IPC for the P-cores, slightly higher clocks, and more cache for the E-core clusters. The 7950X is also 32.12% faster than its predecessor, the Ryzen 9 5950X "Zen 3," and a whopping 58.39% faster than the Core i7-12700K (8P+4E).
More...
ATX 3.0 PSU Specification Loophole Lets Manufacturers Evade Stringent Excursion Tolerance Testing by Simply Excluding the 12+4 pin Connector
When testing recent high-end GPU launches such as the AMD Radeon RX 6950 XT graphics card, we observed some system reboots that caused due to power-draw spikes (technically known as "excursions"). This is when a graphics card, for a brief moment, draws more power than the connector is capable of supplying, triggering the PSU's electrical protections, and causing a reboot. The new ATX 3.0 specification for the next-generation of desktop PC power supplies enable PSUs with a high tolerance for excursions, and prescribes testing standards to ensure a PSU meets the ATX 3.0 spec. Aris Mpitziopoulos (crmaris) and Jon Gerow (Jonnyguru) discovered wording in the latest Intel ATX 3.0 specification that could make you pay closer attention to reviews of ATX 3.0-spec PSU, when they're out.
In a Hardware Busters article, Mpitziopoulos clears the confusion that the ATX 3.0 power supply specs by Intel and the PCI-Express 5.0 power specification by the PCI-SIG, are mutually-inclusive—they're not. An ATX 3.0 PSU is not required to include a 12+4 pin (or 16-pin) ATX 12VHPWR connector, whether or not their nameplate Wattage is above 450 W, which means it's subjected to passing less stressful transient-response tests, particularly the ability to deal with a 200% excursion for at least 100 ms.
More...
NFT Craze Hits the Brakes as OpenSea Records 99% Volume Decline in 90 days
OpenSea, one of the most widely recognized NFT markets in the cryptocurrency world, has slammed into a wall of absence. Namely, the absence of volume: the decentralized marketplace has seen a 99% drop on NFT trading volume in merely 90 days. From its high of $405.75 million on May 1, transactions on Non- Fungible Tokens have petered out to just $5 million throughout the entire month of August.
Reduced volume connects to reduced demand, which has in turn led to reducing floor prices (the lowest available price for a given NFT) for even the most recognized collections: the cheapest Bored Ape Yacht Club NFT can now be had for 72.5 ETH ($104,634 at time of writing). That's a 53% reduction in its ETH price (153.7 ETH) from May 1st. But the drop is even more massive when one takes into account the devaluation of Ethereum itself: On May 1st, the 153.7 ETH asking price for the NFT equaled $434,048 (price has thus tumbled by 76% on a dollar basis). CryptoPunks, another popular Ethereum-based NFT collection, has seen its floor price decline by a less drastic 20%.
More...
Possible AMD Ryzen 7000 Series Launch SEP Prices Leaked
Possible launch SEP pricing of AMD's Ryzen 7000 series "Zen 4" desktop processors leaked to the web by Wccftech, which appear to be similar to those of the Ryzen 5000 "Zen 3" at launch. AMD will launch a slim set of four SKUs in its first round of these processors—the flagship Ryzen 9 7950X (16-core/32-thread), followed by the second-best Ryzen 9 7900X (12-core/24-thread), the Ryzen 7 7700X (8-core/16-thread), and the mid-range Ryzen 5 7600X (6-core/12-thread).
Apparently, the series debuts with the Ryzen 5 7600X at $299, or the same SEP of the Ryzen 5 5600X at launch. The Ryzen 7 7700X launches at $449. The Ryzen 9 7900X comes in at $549, and the flagship Ryzen 9 7950X at $799, which again, is identical to that of the 5950X. Besides processors, motherboard vendors are expected to launch their first Socket AM5 motherboards, debuting with the AMD X670E and X670 chipsets. There's talk of mid-range chipsets such as the B650 and B650E, but we haven't seen any confirmed products show up on motherboard vendors' websites, yet. Pre-launch pricing for the X670E and X670 put them at a significant premium over the current Socket AM4 flagship boards based on the X570. Besides processors and motherboards, we could see announcements from memory vendors launching their first DDR5 memory products to feature AMD EXPO technology.
More...
Intel Arc A380 Gains Ethereum Mining Support Reaching 10.2 MH/s
The Intel Arc A380 has recently been tested for crypto mining performance after support for the card was added in the latest release of Nanominer. The card achieved a hash rate of 10.2 MH/s while mining Ethereum Classic (ETC) without any optimizations at a TDP of 75 W equating to 0.136 MH/s per Watt which is significantly below other popular mining cards which can reach 0.38 MH/s per Watt. This limited performance can be partially attributed to the availability of only 8 Xe-Cores and the relatively small 96-bit memory bus. The card will struggle to mine Ethereum due to its limited 6 GB of VRAM while Ethereum Classic should work fine as demonstrated.
More...
Possible GeForce RTX 4070 "Ada" Specs Hit the Rumor Mill
Two sets of possible specifications of the upcoming performance-segment NVIDIA GeForce RTX 4070 "Ada" graphics card has hit the rumor-mill, according to kopite7kimi, a reliable source with NVIDIA leaks. The first set of specs sees the card feature 12 GB of 21 Gbps GDDR6X memory (possibly over a 192-bit wide memory bus), as many as 7,680 CUDA cores, a typical board power of 285 W, and an internal SKU code of "PG141-SKU340/341." It makes sense for 12 GB of memory across a 192-bit memory bus to be a logical choice for NVIDIA (as opposed to the previous-gen RTX 3070 with its 8 GB of 14 Gbps GDDR6 across 256-bit); as it allows the company to achieve a 50% memory size increase gen-over-gen, while reducing the number of memory chips on the card from 8 to 6 (by using six 16 Gbit GDDR6X chips).
The second set of specs doing rounds is the "PG141-SKU336/337," consisting of 7,168 CUDA cores, 10 GB of 21 Gbps GDDR6X memory across what we're assuming could be a 160-bit wide memory bus (five memory chips), and 250 W typical board power. The same source also claims that the SKU340/341 could have a performance target of over 11000 points in Time Spy Extreme, while the SKU336/337 could be designed with at least 10000 points in mind. It's quite possible that the second configuration is that of the RTX 3060 Ti-successor SKU. Given NVIDIA's top-down approach to product launches, we could expect performance-segment SKUs only toward the end of 2022, or early-2023.
More...
AMD B650E "Extreme" Chipset Confirmed, Brings PCIe 5.0 for GPU and SSD
AMD's upcoming launch of Ryzen 7000 series processors will bring an entirely new AM5 platform that will enable newer technologies and protocols. We have DDR5 memory and PCIe 5.0 connection with everything at level five. However, the upcoming chipsets AMD has designed to work alongside the new processors will be available in several variants. There will be regular X670 and B650 versions that support either a PCIe 5.0 GPU or a PCIe 5.0 M.2 NVIMe SSD. Today, we got a confirmation that not only the big X670 chipset has an "E" or "Extreme" version, but its smaller brother B650 as well. With X670E and B650E, users get both PCIe 5.0 connectivity for their GPU and M.2 NVIMe SSD. For more information, we have to wait for AMD's official launch information later today.
More...
Robot
Most Wanted
- 82
Intel 700-series Chipset Motherboards Feature Higher Memory OC Headroo
Intel 700-series chipset motherboards could come with improved memory overclocking capabilities, suggest an alleged leaked specs-sheet of an MSI Intel Z790 chipset motherboard. As the pioneering platform for DDR5, Intel 600-series chipset motherboards, particularly those based on the Z690, typically marketed DDR5 memory overclock speeds of around DDR5-6000 or DDR5-6200 in their specs sheets, as the then-expensive DDR5 memory kits started at JEDEC-spec speeds of DDR5-4800 in the entry-level, with performance-segment kits around the DDR5-6000 mark.
The unnamed MSI Z790 chipset motherboard supports DDR5 overclocked frequencies of over DDR5-6800 at 1DPC (one DIMM per channel) with single-rank modules; over DDR5-6400 with 1DPC + dual-rank modules; over DDR5-6400 with 2DPC + single-rank modules; and over DDR5-5600 with 2DPC + dual-rank. Earlier reports suggested that Intel is "discouraging" motherboard vendors from coming up with 700-series motherboards that feature DDR4 memory slots, but this doesn't mean there won't be any. MSI has an Intel Z790 motherboard with DDR4 slots in the works, and it's capable of overclocks of up to DDR4-5000 in the most optimal configuration, and DDR4-4000 in the least optimal one.
More...
AMD Ryzen 9 7950X Fmax Frequency Set at 5.85 GHz
Fmax (or Frequency max), is the maximum clock speed an AMD "Zen" processor will automatically boost/overclock to, at stock multiplier settings. To go beyond this, you'll have to increase the multiplier value, and overclock the traditional way. The Fmax value for AMD's upcoming flagship desktop processor, the Ryzen 9 7950X "Zen 4," is reportedly set at 5.85 GHz. To facilitate this, you'll have to enable settings such as Precision Boost Overdrive (PBO), to eke out the power limits needed to get here. Competing Intel parts, such as the "Raptor Lake" Core i9-13900K, is reported to have a similar maximum boost frequency, of 5.80 GHz, but that's just for its 8 P-cores.
More...
(PR) SSUPD Introduces the Meshroom S ITX Case
SSUPD, the sister brand of Lian-Li and a globally acclaimed manufacturer of high-end PC cases, today introduces the all-new Meshroom S ITX case, designed for gamers, content creators, and casual use. Sleek and refined, the all-new Meshroom ITX pc case lineup hits the shelves with two exciting new designs, the Meshroom S and the Meshroom D, with a build capacity of 14.93l and 14.97l, respectively. The new Meshroom S case launches today, with the Meshroom D to arrive in the near future.
Built to dominate the ITX case market, the new Meshroom S case carries the impeccable legacy of SSUPD's globally acclaimed "Meshlicious" ITX case with significant enhancements to its overall look,feel and functionality to suit all user needs. Available in three colors, Fossil Gray, Sage Green and Peacock Blue, these new cases from SSUPD are tailored to redefine the ITX case industry.
More...
(PR) BenQ Announces 48-inch Mobiuz OLED Gaming Monitor and More at Gamescom 2022
BenQ, a global consumer electronics brand, announces that, for the first time, visitors at Gamescom 2022 will be able to experience multiple new gaming monitors from MOBIUZ and the latest products from ZOWIE professional e-Sports brand. From 24th to 28th August in Cologne, Germany, visitors of the BenQ stand (stand A-031, Hall 08.1) will get the chance to explore an immersive gaming reality as they discover the next generation of top-performing displays, designed for gamers of all levels. This edition will be even more special because it will be held both in person and online.
'At BenQ, we are continuously striving to present gamers with ultimate audio-visual immersion and smart AI innovations to ensure an upgraded gaming experience. In this way, we can help players reach a next-level performance', says Steve Chu, President of BenQ Europe. 'Since our goal is to create premium experiences for gamers of all types, the natural next step for us was to bring our customers the latest display technology that will change the way they interact within their virtual worlds', continues the BenQ Europe president.
More...
KeysFan Back to School Sale: Get Windows and Office at Jaw-Dropping Prices
KeysFan is your best buddy in prepping to get back to school. With a little planning you can save big by opting to build your own desktop, or buying a laptop without included software; and let us help you power it with an edition of Genuine Windows 10, Windows 11, and Office that best suits your needs. Get Genuine Office 2021 Professional Plus at just $27.36. Save more as you buy multi-PC packs, to help yourself and a group of friends. Choose from any of the dozens of combinations of Windows and Office to keep saving.
Buy Office 2021 Professional Plus at $27.36 | Buy Office 2021 Professional Plus 2-PC at $43.75 | Office 2021 Professional Plus 3-PC at $54.00 | Buy Office 2021 Professional Plus 5-PC at $70.68 | Buy Office 2019 Professional Plus at $24.59 | Buy Office 2016 Professional Plus at $18.71 | Buy Windows 10 Pro at $7.43 | Buy Windows 10 Pro 2-PC at $12.98 | Buy Windows 10 Pro 5-PC at $30.74 | Buy Windows 10 Home at $8.15 | Buy Windows 11 Pro at $10.24 | Buy Windows 11 Home at $10.24
Please use the coupon code SKF62 on the following items to avail the prices you see here.
Buy Windows 11 Pro + Office 2021 Professional Plus at $32.78 | Buy Windows 10 Pro + Office 2021 Professional Plus at $31.76 | Buy Windows 11 Pro + Office 2019 Professional Plus at $30.73 | Buy Windows 10 Pro + Office 2019 Professional Plus at $29.70 | Buy Windows 11 Pro + Office 2016 Professional Plus at $27.65 | Buy Windows 10 Pro + Office 2016 Professional Plus at $26.63 | Buy Office 2021 Home and Student at $41.21 | Buy Project Professional 2021 at $25.70 | Buy Visio Professional 2021 at $22.97 | Buy Office 2021 Home and Business for Mac at $68.67 | Buy Office 2019 Home and Business for Mac at $66.22| Buy Office 2019 Home and Business at $31.15
Please use the coupon code SKF50 on the following items to avail the prices you see here.
Buy Windows 10 Enterprise LTSC 2019 at $9.14 | Buy Windows 10 Home 2-PC at $12.38 | Buy Windows 10 Enterprise LTSC 2021 at $12.81 | Buy Windows Server 2022 Datacenter at $27.16 | Buy Windows Server 2022 Standard at $25.62Also check out great deals on system software you may want.
More...
Intel Posts XeSS Technology Deep-Dive Video
Intel Graphics today posted a technological deep-dive video presentation into how XeSS (Xe Super Sampling), the company's rival to NVIDIA DLSS and AMD FSR, works. XeSS is a gaming performance enhancement technology where your game is rendered by the GPU at a lower resolution than what your display is capable of; while a high-quality upscaling algorithm scales it up to your native resolution while minimizing quality losses associated with classical upscaling methods.
The video details mostly what we gathered from our older articles on how XeSS works. A game's raster and lighting is rendered at a lower-resolution, frame-data along with motion vectors are fed to the XeSS upscaling algorithm, and is then passed on to the renderer's post-processing and the native-resolution HUD is applied. The XeSS upscaler takes not just motion vector and the all important frame inputs, but also temporal data from processed (upscaled) frames, so a pre-trained AI could better reconstruct details.
More...
(PR) BizLink Announces the World's First VESA Certified DP80 Enhanced Full-Size DP Cable
BizLink, a global leader in interconnect solutions, is proud to announce the release of the world's first VESA certified DP80 Enhanced full-size DP cable after the launch of DP80 mDP cable in March 2022. DP80 as the highest standard for cable configuration defines a new standard for display connectivity with emphasis on higher link rate. Certified with the latest version of DP technology, BizLink's DP80 Enhanced full-size DP cable provides a maximum throughput data rate up to 80 Gbps, covering new data rates per lane: UHBR10 (10 Gbps), UHBR13.5 (13.5 Gbps), and UHBR20 (20 Gbps).
In an era consisting of trends such as remote work and extended reality, to deal with the growing needs for high-performance displays and "stay connected" at the most elevated implementation levels becomes crucial. Satisfying user experience and reliable connectivity requires higher data rate conversion. The DP80-marked cable supports UHBR20 at their highest transfer rate, enabling ultimate connections of advanced and latest display applications and systems. With a satisfactory data rate value up to 80 Gbps, the DP80 standard unleashes new capabilities for bringing superior connection to achieve a given level of video quality as image capture and display technology advance.
More...
AMD Ryzen 9 7950X Allegedly 40% Faster than 5950X in CPU-Z Bench Multi-Threaded
The upcoming AMD Ryzen 9 7950X 16-core/32-thread processor is allegedly over 40% faster than its predecessor, the 5950X, at the CPU-Z Bench multi-threaded test, according to a leaked benchmark screenshot scored by harukaze5719, and tabulated by Wccftech. The 7950X is shown with a score of 16809 points, which puts it 41 percent faster than the 5950X, and 43% faster than the i9-12900K. It's also shown to be behind the leaked benchmarks of the i9-13900K by a whisker—with the upcoming Intel chip being 0.5% faster.
More...
Boost Frequencies of the All-important Core i5-13400 and i5-13500 Revealed
When it releases, the Core i5-13400 will join a long like of Intel processors that are extremely successful in the market—chips that are priced around the $200-mark, and bang in the middle of the market bell-curve. Other chips in the lineup include the i5-12400, i5-11400, i5-10400, and the i5-9400. With the 13th Generation "Raptor Lake," Intel is configuring the i5-13400, i5-13500, and the i5-13600 (non-K) as 6P+4E processors (that's 6 "Raptor Cove" P-cores with 4 "Gracemont" E-cores); whereas their 12th Gen predecessors only had 6 "Golden Cove" P-cores, and no E-cores. The top Core i5 part, the i5-13600K, will stand out featuring a 6P+8E configuration.
Maximum boost frequencies of the Core i5-13400 and i5-13500 surfaced on the web thanks to Passmark screenshots scored by TUM_APISAK. Boost frequencies of 13th Gen Core processors weren't part of the recent lineup leak. The i5-13400 has a maximum boost frequency of 4.10 GHz, while the i5-13500 comes with 4.50 GHz. Both SKUs have an identical base frequency of 2.50 GHz. The maximum turbo frequency of 4.10 GHz for the i5-13400 is significantly lower than the 5.80 GHz of the flagship i9-13900K, and the 5.10 GHz of the i5-13600K. It's also quite spaced apart from the i5-13500, with its 4.50 GHz. Perhaps Intel really wants some consumer interest in the Core i5 SKUs positioned between the i5-13400 and the i5-13600K.
More...
Robot
Most Wanted
- 82
More...
More...
More...
More...
More...
More...
More...
More...
More...
More...
More...
More...
Robot
Most Wanted
- 82
More...
More...
More...
More...
More...
More...
Robot
Most Wanted
- 82
(PR) Answer The Call: NBA 2K23 Now Available Worldwide
Today, 2K announced that NBA 2K23, the latest iteration of the top-rated NBA video game simulation series of the past 21 years, is now available worldwide on PlayStation 5 (PS5), PlayStation 4 (PS4), Xbox Series X|S, Xbox One, Nintendo Switch, and PC. NBA 2K23 offers an authentic and hyper-real basketball experience showcasing all-new gameplay innovations and animations, the coveted return of the Jordan Challenge mode, an immersive online community experience, and so much more.
"As a franchise, we strive to be at the forefront of basketball culture, and we're excited for players to get their hands on NBA 2K23 to see the game come to life," said Greg Thomas, President at Visual Concepts. "With the return of the Jordan Challenges, NBA 2K23 asks players to answer the call and experience some of the greatest performances in basketball history. The incredible attention to detail has led to our most realistic and authentic title yet, with fun integrations that long-time basketball fans and new players will enjoy."
More...
(PR) POINTek Shows Off Optical Fiber Array Product Families for Silicon Photonics Integrated Chips
POINTek, Inc., a global leader and provider of high performance athermal AWGs, announced launching of new Application- Specific Optical Fiber Array Products, Silicon Photonics (SiPh) Fiber Arrays, which is capable of supporting the back-end packaging for Silicon Photonics Integrated Circuits (PIC). This new Silicon Photonics Fiber Arrays have the excellent characteristics of a fine fiber-end mirror-surface quality and an accurate fiber protrusion length uniformity to match with the prefabricated V-grooves on a Silicon PIC chip. The required fiber protrusion length is typically 5 mm with ≤ ±2 mm length uniformity in an array. Both Single Mode (SM) Fiber Arrays and Polarization Maintaining (PM) Fiber Arrays are available with or without 12-channel MT ferrule termination.
"This new SiPh Fiber Array is designed to passively align the multiple optical fibers into the wafer-fabricated V-grooves on the Silicon PIC chip without the expensive and complicated active alignment equipment, and furthermore, the passive alignment of the Array can be accomplished without monitoring the optical power," according to Dr. Donald Yu, CMO of POINTek, operating from Los Angeles, California. Yu explains that the optical fiber array is a key component to efficiently assemble the PIC devices for coupling the multiple fibers into the multiple I/O waveguides on a PIC chip. In the conventional optical active alignment assembly process, the expensive automatic precision alignment equipment should be utilized while monitoring the optical power in the packaging process, and it often takes the long processing time. "However, for this new SiPh Fiber Array, the fibers can be precisely placed in the Silicon PIC's V-grooves with the minimal operation costs. Therefore, the passive alignment of Silicon PIC could result in the very affordable SiPh device price in the market," Yu adds.
More...
Core Performance Boost Contributes 14% to Ryzen 5 7600X Cinebench R23 Score
AMD Ryzen 5 7600X "Zen 4" 6-core/12-thread processor is shaping up to be a speed-demon for purely gaming builds, with the company claiming higher gaming performance than Intel current flagship Core i9-12900K. A combination of high clock speeds (4.70 GHz nominal, 5.30 GHz max boost), high power limits from 105 W TDP (130 W limit), the "Zen 4" IPC, and the fact that all that power headroom is available to just 6 cores, means that the chip is able to sustain boost frequencies better. But what when Core Performance Boost (CPB) is disabled? VideoCardz scored screenshots of a Cinebench R23 run to answer just that.
With CPB disabled (in the motherboard BIOS), the Ryzen 5 7600X scores 1681 points in the single-threaded test, and 13003 points in the multi-threaded one. With CPB enabled (which is the default setting), the 7600X bags 1920 points single-threaded, and 14767 points multi-threaded, which is a 14% performance increase just from the processor's boosting algo. Disabling CPB is generally seen as a silver-bullet against high temperatures for AMD processors, and even here, we see the chip running under 60°C, and pulling 60.2 W peak, as measured by HWinfo; whereas with CPB enabled, the chip can run as hot as 92.1°C, pulling up to 110 W, pushing clock speeds up to 4.45 GHz.
More...
(PR) Intel Breaks Ground in the Silicon Heartland
Today, President Joe Biden joins Intel, Ohio Gov. Mike DeWine and other federal, state and local officials to celebrate breaking ground in the Silicon Heartland on two of the world's most advanced chipmaking facilities. As part of Intel's commitment to develop a skilled talent pipeline for its two new leading-edge chip fabs, Intel also announced the first phase of funding for its Ohio Semiconductor Education and Research Program. During this first phase, Intel is providing $17.7 million for eight proposals from leading institutions and collaborators in Ohio to develop semiconductor-focused education and workforce programs.
"Today marks a pivotal moment in the journey to build a more geographically balanced and resilient semiconductor supply chain. The establishment of the Silicon Heartland is testament to the power of government incentives to unlock private investment, create thousands of high-paying jobs, and benefit U.S. economic and national security. We would not be here today without the support of leaders in the administration, Congress and the state of Ohio, who share a vision to help restore the United States to its rightful place as a leader in advanced chipmaking," said Pat Gelsinger, Intel CEO.
More...
Intel Expects to Lose More Market Share, to Reconsider Exiting Other Businesses
During Evercore ISI TMT conference, Intel announced that the company would continue to lose market share, with a possible bounce back in the coming years. According to the latest report, Intel's CEO Pat Gelsinger announced that he expects the company to continue to lose its market share to AMD as the competition has "too much momentum" going for it. AMD's Ryzen and EPYC processors continue to deliver power and efficiency performance figures, which drives customers towards the company. On the other hand, Intel expects a competing product, especially in the data center business with Sapphire Rapids Xeon processors, set to arrive in 2023. Pat Gelsinger noted, "Competition just has too much momentum, and we haven't executed well enough. So we expect that bottoming. The business will be growing, but we do expect that there continues to be some share losses. We're not keeping up with the overall TAM growth until we get later into '25 and '26 when we start regaining share, material share gains."
The only down years that are supposed to show a toll of solid competition are 2022 and 2023. As far as creating a bounceback, Intel targets 2025 and 2026. "Now, obviously, in 2024, we think we're competitive. 2025, we think we're back to unquestioned leadership with our transistors and process technology," noted CEO Gelsinger. Additionally, he had a say about the emerging Arm CPUs competing for the same server market share as Intel and AMD do so, stating that "Well, when we deliver the Forest product line, we deliver power performance leadership versus all Arm alternatives, as well. So now you go to a cloud service provider, and you say, 'Well, why would I go through that butt ugly, heavy software lift to an ARM architecture versus continuing on the x86 family?"
More...
Lian Li SP850 First SFX PSU with ATX 3.0 + PCIe Gen 5, Including ATX12HPWR
Lian Li unveiled the SP850, the first SFX form-factor power supply featuring ATX 3.0 specs readiness, and PCIe Gen 5 compliance, including a 12+4 pin ATX12HPWR connector for next-generation graphics cards. Available in black and white body-color variants, the it offers 850 W continuous output, including tolerance for +100% excursions for at least 100 µs intervals. and meets 80 Plus Gold efficiency. It features a single +12 V rail design, with most common electrical protections. The 92 mm fluid dynamic bearing fan keeping it cool offers fanless (zero RPM) cooling up to 340 W load (excluding excursions). The Lian Li SP850 offers full modular cabling. Besides the 12+4 pin ATXHPWR, you get two 8-pin EPS, and three 6+2 pin PCIe power connectors. Peripheral connectivity includes eight SATA power connectors. Lian Li is backing the SP850 with a 5-year warranty. Available now, it is priced at USD $150-170.
More...
GoDeal24 Autumn Sale: Get the Lowest Ever Prices on Genuine Windows and Office
Celebrate the onset of Autumn with the GoDeal24 seasonal sale. Get some of the lowest prices on the web for genuine, globally-valid software, and prepare to build next-generation desktops or power up a laptop that came without preinstalled software. Get Genuine Office 2021 Professional Plus, the most powerful productivity software, at just $25.61, and their multi-PC packs at decreasing per-PC prices. Windows 10 Pro can be had at just $7.42, or the latest and greatest Windows 11 Pro at $10.24. Combine your preferred edition of Windows and Office to save even more!
Buy Office 2021 Professional Plus at $25.61 | Buy Office 2021 Professional Plus 2-PC at $40.98 | Buy Office 2021 Professional Plus 3-PC at $49.09 | Buy Office 2021 Professional Plus 5-PC at $67.63 |Buy Office 2019 Professional Plus at $24.59 | Buy Office 2016 Professional Plus at $18.68 | Buy Windows 10 Pro at $7.42 | Buy Windows 11 Pro at $10.24 | Buy Windows 10 Pro 5-PC at $30.74 | Buy Windows 10 Home at $8.12 | Buy Windows 10 Pro 2-PC at $12.67
Buy Windows 10 Pro + Office 2021 Professional Plus at $29.70 | Buy Windows 11 Pro + Office 2021 Professional Plus at $30.73 | Buy Windows 10 Pro + Office 2019 Professional Plus at $27.65 | Buy Windows 11 Pro + Office 2019 Professional Plus at $28.68 | Buy Windows 10 Pro + Office 2016 Professional Plus at $24.58 |Buy Windows 11 Pro + Office 2016 Professional Plus at $25.60 | Buy Project Professional 2021 at $25.70 | Buy Visio Professional 2021 at $22.98 | Buy Office 2019 Home and Student at $31.15 | Buy Office 2021 Home and Business for Mac at $68.66 | Buy Office 2019 Home and Business $47.76
Buy Windows 10 Home at $12.38 | Buy Windows 10 Enterprise 2019 LTSC at $9.14 | Buy Windows 10 Enterprise 2021 LTSC at $12.81 | Buy Windows Server 2022 Standard at $26.13 | Buy Windows Server 2022 Datacenter at $30.75Check out great deals on system software you may want.
More...
AMD FidelityFX Super Resolution 2.1 Unveiled with Several Upscaler Changes to Improve Realism
AMD late Thursday unveiled the FidelityFX Super Resolution 2.1 (FSR 2.1) performance enhancement, which builds on the performance-quality gains of FSR 2.0, while improving the visual fidelity and correcting several kinds of upscaling artifacts visible to the keen eye. To begin with, it corrected ghosting issues with geometry carrying motion vectors not matching the underlying pixel colors, which were causing a "shimmering" effect. There are also changes to the disocclusion logic that let it detect disocclusions in areas with little depth separating objects, which again should address some ghosting issues.
Upscaled output quality has been improved by turning some upscaler computations from FP16 to FP32 (full-precision), which should improve color range and temporal stability of the upscaled image. Ghosting issues on transparent geometry has also been improved by updates to the reactive mask. Ghosting issues on geometry with motion vectors not matching underlying pixel colors have been addressed with improvements to the composition and transparency mask. AMD detailed FSR 2.1 in its GPUOpen page, and has made the software available to game developers. Any game currently implementing FSR 2.0 can release FSR 2.1 support through patches. The latest version 1.7.1 patch of Farming Simulator 2022 implements FSR 2.1.AMD also put together a video presentation with Farming Simulator 2022, highlighting the improvements made with FSR 2.1.
More...
Robot
Most Wanted
- 82
(PR) QNAP Launches the TS-253E and TS-453E Desktop NAS
QNAP Systems, Inc., a leading computing, networking, and storage solution innovator, today launched the 2-bay TS-253E and 4-bay TS-453E NAS. The TS-x53E series are powered by an Intel Celeron J6412 quad-core processor (burst up to 2.60 GHz), which will be available and supported by QNAP for an extended period (up to 2029). The TS-x53E series are ideal for managed service providers, system integrators, and other IT-related businesses requiring matching NAS models for long-term projects.
"Over the years QNAP has received many requests from businesses that require NAS with long-term availability," said Andy Chuang, Product Manager of QNAP, adding "the TS-x53E series, which will be available and supported by QNAP for an extended period, is a perfect fit for these businesses and other users who require the reassurance of long-term availability."
More...
Non-K 13th Gen Core i5 (such as i5-13400) Based on Older "Alder Lake" Architecture, Hints Intel Slide
Remember how 12th Gen Core i5 non-K was vastly different in performance from the Core i5 K/KF on account of being 6P+0E processors in comparison to more L3 cache and a 6P+4E core-count of the i5-12600K/KF? Intel is doubling down on creating architectural confusion in the mid-range, according to a 3DCenter.org article citing a leaked slide from Intel's 13th Gen Core launch press-deck.
We had earlier thought that the 13th Gen non-K Core i5 will have a 6P+4E core-config, but still be based on "Raptor Lake" (i.e. "Raptor Cove" P-cores + "Gracemont" E-cores), in comparison to the i5-13600K/KF, which are confirmed "Raptor Lake" chips with 6P+8E configuration; but it turns out that Intel is basing the non-K 13th Gen Core i5 on the older "Alder Lake" microarchitecture. These chips will be 6P+4E (that's six "Golden Cove" P-cores + four "Gracemont" E-cores), which make them essentially identical to the i5-12600K, but without the unlocked multiplier, and a lower 65 W processor base power.
More...
Intel Finalizes Arc A770 Specs to Feature 17.5 Gbps Memory
Intel on Thursday confirmed that there will be only four Arc "Alchemist" desktop graphics card SKUs in the retail channel, and that it will be led by the A770 Limited Edition, which maxes out the DG2-512 silicon, and features 17.5 Gbps memory across its 256-bit wide memory bus, putting 560 GB/s of memory bandwidth at its disposal. The A750 uses 16 Gbps memory data-rates, and has 512 GB/s of bandwidth. It turns out, that the mid-range A580 features a 256-bit wide memory bus, and not the previously-reported 192-bit, which means it has the same 512 GB/s bandwidth as the A750. The A580 and A750 come with 8 GB of memory, while the A770 tops out with 16 GB.
More...
(PR) Intel and Broadcom Achieve Major Wi-Fi 7 Industry Milestone
Today, Intel Corporation and Broadcom Inc. showcased the industry's first cross-vendor Wi-Fi 7 demonstration, with over-the-air speeds greater than 5 gigabits per second. The trial used an Intel Core processor-based laptop with a Wi-Fi 7 solution connected to a Broadcom Wi-Fi 7 access point.
"We are proud to highlight how next-generation Wi-Fi 7 can make new mobile PC experiences possible. Industry collaboration is essential to ensure we deliver on the promises of this new wireless technology. We would like to thank our colleagues at Broadcom for their great technical cooperation, which helped enable this unprecedented, first-of-its-kind demonstration of ultra-high speed and ultra-low latency Wi-Fi 7," said Carlos Cordeiro, Intel Fellow and Wireless CTO, Client Computing Group, Intel.
Vijay Nagarajan, vice president, Wireless Connectivity Division, Broadcom, said, "Today's milestone sends a clear message: the ecosystem is ready and Wi-Fi 7 is here to deliver extraordinary capacity and blazing fast speeds to extend gigabit broadband. The reliable, low latency communication provided by Wi-Fi 7 is a key element of Broadcom's vision for connecting everything as the Internet evolves to its next iteration replete with immersive experiences. Industry collaboration is key to making this unprecedented connectivity a reality and we were delighted to work with Intel to achieve another industry first."
More...
(PR) Comcast Kicks Off Nation's Largest Multi-Gig Network and WiFi Deployment, Will Begin Offering Symmetrical Multi-Gig Speeds in 2023
Comcast today announced it has begun a nationwide rollout of multi-gig Internet speeds - that will reach more than 50 million homes and businesses before the end of 2025 - making it the largest- and fastest-ever multi-gig deployment in the United States. New speeds will be paired with Comcast's multi-gig Wi-Fi experience, which delivers the industry's best combination of speed, coverage, and control, powered by one of the world's first Wi-Fi 6E Gateways.
As part of this initiative, Comcast is accelerating the transformation of its network to a virtualized cloud-based architecture that is fully prepared for 10G and DOCSIS 4.0. Comcast will begin offering 10G-enabled multi-gig symmetrical services in 2023.
More...
(PR) Bose Introduces the Quietcomfort Earbuds II with Bluetooth 5.3
The brand that invented noise cancelling headphones is once again transforming the industry. Today, Bose announces its next generation of truly wireless noise cancelling earbuds—the Bose QuietComfort Earbuds II. With Bose CustomTune sound calibration technology, QC Earbuds II intelligently personalize audio and noise cancellation performance to the unique shape of every ear—resulting in an unprecedented listening experience and the world's best noise cancellation from any headphone—banded or in-ear.
The QuietComfort Earbuds II have an all-new design. Each bud is about one-third smaller than its predecessor, weighs less than a quarter of an ounce, and they come in a pocketable charging case. And for further personalization, they also include an eartip Fit Kit featuring a new two-piece system with interchangeable stability bands and eartips—delivering the all-day comfort and wearability the QuietComfort name is known for.
More...
(PR) DFI Unveils ATX Motherboard ICX610-C621A
DFI, the global leading provider of high-performance computing technology across multiple embedded industries, unveils a server-grade ATX motherboard, designed for Intel Ice Lake platform, powered by the 3rd Generation Intel Xeon Scalable processors, and equipped with ultra-high speed computing that can support up to 205 W. ICX610-C621A also comes with built-in Intel Speed Select Technology (Intel SST), which provides an excellent load balancing between CPUs and multiple accelerator cards to effectively distribute CPU resource, stabilize computation loads and maximize computing power. As a result, it improves the performance by 1.46 times compared to previous generation.
Featuring powerful performance, the offers three PCIe x 16, two PCIe x8 slots and one M.2 Key and enables ultra-performance computing, AI workload and deep learning, specifically for high-end inspection equipment, such as AOI, CT, and MRI application. The ICX610 also supports ECC RDIMM up to 512 GB 3200 MHz enhances high end performance for advanced inspection equipment and improves efficiency.
More...
(PR) ASRock Announces New BIOS Decreasing Booting Time of AM5 Motherboards
Leading global motherboard manufacturer, ASRock, has built new BIOS decreasing AM5 booting time. ASRock is dedicated to providing products with the best user-experience. The new BIOS providing better compatibility and shorter booting time has been built, and it will be available on ASRock website after product launch. Besides, all ASRock X670E/X670 motherboards support BIOS flashback, which allows users to update their motherboards to the newest BIOS with merely 24-pin power supply and a USB drive.[Editor's Note: This news post will provide more context.]
More...
Robot
Most Wanted
- 82
(PR) CORSAIR Announces the K100 Air Wireless Keyboard with CHERRY MX U
CORSAIR a world leader in high-performance gear for gamers and content creators, today announced the upcoming CORSAIR K100 AIR Wireless Mechanical Gaming Keyboard, CORSAIR's thinnest high-performance keyboard ever, releasing on October 4th. From its elegant brushed aluminium frame to its versatile connectivity options for multiple devices, the K100 AIR delivers a modern, premium experience that meets the needs of gamers and productivity focused consumers alike.
With an unbelievably thin frame measuring just 11 mm at its slimmest point and a clean, minimalist aesthetic, the K100 AIR fits right in on any desktop or workstation. Hyper-responsive CHERRY MX Ultra Low Profile mechanical keyswitches provide the satisfying, tactile, and reliable keystrokes that users demand, without the height of a full-size keyswitch.
More...
(PR) Kingston FURY Adds AMD EXPO Certified DDR5 Memory to Lineup
Kingston FURY, the gaming division of Kingston Technology Company, Inc., a world leader in memory products and technology solutions, announced today the addition of AMD EXPO certified DDR5 modules to the Kingston FURY Beast line of memory. Always aiming to provide the latest options to gamers and enthusiasts, these new overclock specs modules and kits are optimized for AMD's upcoming AM5 platform with two factory tuned profiles, plus one user customizable profile.
Qualified by the world's leading motherboard manufacturers, the Kingston FURY Beast line offers aggressive speeds up to 6000MT/s1 with a bold low-profile heatspreader design. Now with AMD EXtended Profile for Overclocking, users can trust that their selected Kingston FURY Beast DDR5 modules and kits are exactly what their AMD AM5 system needs to maximize performance, while also maintaining stability.
More...
(PR) Neo Forza Server DRAM Available to DELL Data Center Customers
Goldkey Technology Corporation (TPEx : 3135), aka "Neo Forza", offers products and solutions marketed under the label Neo Forza successfully completed qualification of its server modules with Dell PowerEdge R650 and R750 series servers, which DELL loaned to Neo Forza. Following successful qualification, Neo Forza announces commercial and industrial channel partner availability of Neo Forza DDR4 RDIMM server memory in adherence to industry qualifications, ranging from DDR4 2133MT/s to 3200MT/s.
"Data center staff need to maximize platform performance and extend platform longevity. Neo Forza's qualified DDR4 server memory assures these factors are met cost-effectively," said Jess Kung, vice president of sales. "Goldkey Technology Corporation has been on the forefront of the memory industry and is an integrated-circuit (I/C) specialist with technical acumen of more than 15 years. The successful qualification program amplifies our intrinsic value to our global customers."
More...
NVIDIA Possibly Flags Off the RTX 40-series Hype Train with "Project Beyond"
NVIDIA in a cryptic tweet earlier this morning (evening September 7 in the US); teased something it calls "Project Beyond," with no further description. It comes with an animation showing a bunch of green rays projecting outward. We're inclined to believe Project Beyond is a marketing campaign leading up to the launch of the next-generation GeForce RTX 40-series "Ada" graphics cards, given that it was tweeted from the NVIDIA GeForce handle, and not the main NVIDIA (corporate) handle. Intel used a similar overarching marketing campaign for the Arc "Alchemist" series, under "Odyssey." We should hear a lot more about NVIDIA's Project Beyond at the GTC conference slated for a little later this month.
Update 11:49 UTC: We're learning that NVIDIA is planning a GeForce-exclusive event on September 20.
More...
