Dislikes:
- Rep Power
- 154
OpenPLi-4.0-beta Vu+ Duo/ Duo2
- Rep Power
- 154
OpenPLi-4.0-beta Vu+Duo/ Duo2 Image
- Rep Power
- 154
OpenPLi 4.0 Japhar Vu+Duo/ Duo2 Image
with IPTV and GStreamer 1.6.2 released
- Gstreamer (v1.6.2) has been updated to master git which carries many fixes.
- No more internet connection required during bootup.
- Feeds online for online update of image and future updates/fixes if necessary.
- IPTV List and Jam Panel are now pre-shipped.
- Japhar Addon Manager 5.2 included.
- IPTV List built-in with 750+ IPTV FREE Channels.
- Many dvbmediasink fixes.
- Many stuff I forgot
https://mega.nz/#!Io4jHBzS!bdkQlhyZO...P17Vm7huMtQru4
https://mega.nz/#!E0ZwlLgD!TiJzLnpnA...n12yFtJy0nbnAw
- Rep Power
- 154
OpenPLi-4 / Gstreamer 1.7.1 (master git) images 2016-01-05
Please reflash your receiver since a software update will most likely fail.
Especially on spark/spark7162.
Changes since previous release:
- Gstreamer snapshot updated to 1.7.1:
* The mp4 issue when playing from remote locations has been fixed upstream, so I've dropped the revert.
* Libsoup has been updated so I've dropped the revert for the old libsoup as well.
- DM800Se V2 and DM500HD V2 kernel config has been cleaned and more in sync with PLi's config for the other Dreambox models.
- More free space by adding a task before do_package_write_ipk which will upx compress some binaries.
* This should give us a few more MBs to work with (Dreambox *cough*).
- Major rework of the meta-fulan BSP for spark thanks to Tapaat for helping me out.
* Now using Tapaat's drivers which fixes the frambuffer (and 22khz?) issue.
* Enable of the zram module.
* Shipping his wifi drivers.
* VFD time is now synced every 5 minutes using a cron job.
* Software update and plugin-installation has been fixed.
* Using Tapaat's lirc config for spark and spark7162.
- The usual batch of dvbmediasink fixes by Christophecvr and mx3L:
* A brand new divx/xvid bitstream unpacker by mx3L should fix playback of avi files with wrong fourcc.
- Libsoup has been updated to 2.52 (from master-next).
- Refactor wifi drivers a bit on Linux 2.6.18, not auto-loading the mt7600 anymore, the correct driver should hopefully be loaded when you plugin your wifi stick.
Changes compared to openpli-oe-core gst-1:
- Ships with gstreamer upstream master git:
Using the same patches as openpli-oe-core gst-1 with only these changes:
Removed: 0001-baseparse-post-tag-list-when-avg-bitrate-changes-at-.patch
because this patch was already checked in upstream.
- Every receiver uses christophecvr's multibox dvbmediasink.
- Using libtrmp and rtmpdump from oe-alliance.
- Some small enigma2 patches for Dreambox receivers (ac3/dts bypass and blanking on zap support).
These are only applied for Dreambox receivers.
- AAC to AC3 transcoding V2 by mx3L (requires a fast cpu).
- IPTV Player from samsamsam included (thx to Athoik for the recipe).
- Large list of public IPTV streams included thanks to the Japhar Team.
- Updated libcdio and cdtextinfo for audio-cd support by christophecvr.
- DM800Se, DM7020HD and DM800SeV2 driver upgraded to 20151201:
added si2166b blindscan support.
- Using aio-grab source from oe-alliance which includes fixes for spark receivers.
Known issues:
- DM800 first boot will take a while, please be patient. The next boot will be faster.
- On spark/spark7162 you need to set 'boxtype = dreambox' for oscam dvbapi.
Please use 'duckbox' instead.
- On Zgemma Star you cannot use full HD skins.
This is a hardware/driver limitation.
Please don't try it, it will crash enigma2.
- Some Dreambox remotes may behave very sensitive.
This causes button presses to register multiple times instead of just once.
As a workaround you can adjust the key interval:
Go to: Menu - System - Input devices - dreambox remote control (native).
Set "Change repeat and delay settings" to yes
Set "Interval between keys when repeating:" to 200ms or 300ms.
Press green button (OK)
Now set the same delay for: "dreambox advanced remote control (native)" as well.
TODO:
- Linux 2.6.18: Create a plugin / ppanel to select which Realtek/Ralink driver to load on startup (eg. rt3070, rt55xx, mt7600), since they cannot be loaded at the same time.
- Linux 2.6.18: Look into the v4l usb drivers.
- Add Spark specific plugins by gorski.
- Add meta-ini from OE-Alliance and shape it up for openpli-oe-core.
Link:
https://mega.nz/#F!z08HlZyA!Upawo32I...e-soQ!y0tFyK5R
- Rep Power
- 154
- Rep Power
- 154
OpenPLi 5.0 (next-master preview) Vu+Duo2 Image
- Rep Power
- 154
[BKP]Unofficial OpenPLI Vu+Duo2 Kodi 15.2
Backup date 31/01/2016
Kernel 3.13.5
Last Update 09/10/2016
Splash Screen PLI by robijay
Bootlogo by robijay
Spinner from arctic skin
Setting Whannibal Quadrifeed 13,0+19,2+23,5+28,2+DTT Italy
Language: English
Password FTP and Telnet: linuxsat
Whats Included ?
PLI Unofficial Image with KODI Isengard 15.2
Panel
LINUXSAT SUPPORT PANEL 1.2 FULL HD
Plugin Bouquets
AUTOBOUQUETS FOR 28,2 (NEW VERSION)
VHANNIBAL NGSETTING 1.3(NEW)
Addons
XBMC LAUNCHER
Repositories & Addons For XBMC Launcher Can Be Downloaded From LINUXSAT SUPPORT Addons
EPG IMPORT RYTEC
2BOOM'S M3U/XML BOUQUETS CONVERTER
COOL TV GUIDE 7.3.0
IPTV PLAYER 98.04.00.01
LIVE FOOTBALL 6.0
GLASS SISTEM UTILITY 6.5.0
LCD4LINUX
IPTV WORLD PLUGIN 2.0
MEDIAPLAYER2
SUBSSUPPORT PLUGIN
PICON MANAGER 2.2 (MOD)
WEBRADIOFS
ALTADEFINIZIONE 1.1.7 PLUGIN (SOON ON MEDIASTREAM 7.0)
CASACINEMA PLUGIN 1.0.0 (SOON ON MEDIASTREAM 7.0)
DARKSTREAM PLUGIN 1.0.0(SOON ON MEDIATREAM 7.0)
FILMXTUTTI PLUGIN 1.1.0 (SOON ON MEDIASTREAM 7.0)
GUARDARESERIE PLUGIN 1.1.4 (SOON ON MEDIASTREAM 7.0)
ITASTREAMING PLUGIN 1.0.0 (SOON ON MEDIASTREAM 7.0)
FOURTUBE XXX PLUGIN 1.0.2 (SOON ON MEDIASTREAM 7.0)
FULL FLASH BACKUP ON USBB/HDD
FULL FLASH BACKUP TO USB
MEDIAINFO 2.8 (NEW)
XBMC WEATHER
AND MORE..........
Emu
OSCAM 11209 (LATEST RELEASE)
DOSCAM 0.25
CCCAM 2.30
OSCAM STATUS VIEW
CCCAM INFO
Skin
ORIGINAL
MTERIXHD-MOD (DEFAULT)
Picons
13,0+19,2+DTT ITALY (INCLUDED THX TO NEO_3)
23,5+28,2 (INCLUDED OKTUS)
DOWNLOAD:https://mega.nz/#!0hNyzJSK!QLnC2nuaO...UxKXCIdMyXpcZQ
- Rep Power
- 154
OpenPLi 5.0 test 3.02.2016 Vu+Duo/ Duo2 Image
- Rep Power
- 154
OpenPLi-4 / Gstreamer 1.7.1 (master git) images 2016-02-17
Hi folks,
It took me a while to build these because there were lots of small bugs and user requests.
I did my best to answer them all.
But due to my limited time I couldn't fulfill all of them, so my apologies if I didn't respond to a PM or forum-post.
So anyways.. there are lots of changes compared to my last images.
Too much for me to remember, so I guess:
- Added new receivers: Zgemma H5 and LC, Vu+ Solo 4K, XpeedC (whatever that is) and Atemio Nemesis (user-request, not tested at all so beware).
There are no Wetek builds and I ain't gonna build them, so don't ask.
- I've fixed the feed for mips32el-nf receivers (et4x00, hd1100, hd500c and xp1000).
- Oscam bumped to rev. 11211 with Joeuser's patch (yes I know you guys were waiting for this one).
- Lots of fixes for spark and spark7162 with the help of my great friend Taapat, they should be of equal quality as other PLi 4 images now.
The libeplayer versions are in the "eplayer" directory, everything else is gstreamer.
- No more patches to enigma2's servicemp3.cpp (except the one for aac transcoding), so it should reflect the current state now.
- Latest gstreamer 1.7.1 master head as of today.
- Many backports from master-next and Taapat.
- Lot's of small things I forgot.
Note:
- If you get corrupted jpeg images on spark/spark7162 the hardware decoder is not working for you, simply login using telnet and type:
rm -f /usr/lib/libmme_host.so
Then restart enigma2 and they should display fine
- Zram is now disabled by default on spark/spark7162, if would like to use it anyways, simply login using telnet and type:
touch /etc/gimme-zram
Then reboot your receiver.
If I didn't mess up badly this time, this will be my last round of public images.
I don't think there's any benefit for releasing gstreamer master head images anymore, since the next stable gstreamer release will hit master-next and oe-alliance anyways.
And most work went into supporting non-PLi-supported receivers which takes lots and lots of time.
Thank you all for the great feedback !
You're the best!
https://mega.nz/#F!mk8jBRLQ!4_3w31ZR...n_gfA!vwkgGCpa
- Rep Power
- 154
OpenPLi-4.0-beta Vu+ Duo2 Image
OpenPLi-4.0-beta-vuduo2-20160419_usb.zip
http://downloads.pli-images.org/buil...160419_usb.zip
- Rep Power
- 154
20-04-2016
OpenPLi-4.0-beta-vuduo2-20160420_usb.zip
http://downloads.pli-images.org/buil...160420_usb.zip
- Rep Power
- 154
OpenPli 4.0 Beta VU+ Duo2 Image
- Rep Power
- 154
OpenPLi 4.0_ by mamba65 _with Panda FREE IPTV
~~What's Included On VU+DUO 2~~
-Plugins-
PoverVu Key Updater
M3uTo Bouquet ConverterPlugin
TSpanel_7.5
TS Media latest version
IpTV Player latest version
SubTitle Player 4.01
LCD4Linux
Clear Memory latest version
EPG Import
...and more
-Emus with active keys and already prepared-
Doscam 0.25
NCam
-Channel List-
ciefp-E2-68E-30W-IPTV-& mkv Movies-08.05.2016
-Skin-
Tiny HD by mamba65
PLi-HD_default
-Booting-
Restarting & Bootlogo by mamba65
-Password FTP and Telnet-
root
root
DOWNLOAD: http://www.file-upload.net/download-...65.tar.gz.html
