Thanks Thanks:  5
Likes Likes:  5
Page 8 of 9 FirstFirst ... 456789 LastLast
Results 106 to 120 of 130
Thread: Images Vu+ Solo 4K
  1. #106
    Thumbs up Black Hole 3.0.5.A Quad PiP Vu+ Solo4K Image
    What is new ?
    Update drivers(4k models)
    - Fix demux problem
    [bluetoothsetup/util] update for solo4k.
    [vuplus-blindscan-utils] update TT2L08/TT3L10
    [Scan] Fix DVB-T2 Network Scan. (need update libdvbsi++ 0.3.8)
    - Fix HDR/HLG problem
    - Fix grab problem
    - Fix demux problem
    - Improve overall performance
    - Update kernel config
    - Adjust driver memory allocations
    update kodiegl/chromium/directfb.
    [libdvbsi++] update to 0.3.8
    [dvbmediasink] update EXTRA_OECONF (solo4k, uno4k, ultimo4k, uno4kse).
    update driver(zero4k)
    - Fix DVB-CI problem
    - Fix PLS
    - Improve demux
    This is available as an online update from 3.0.5 or as a full flash update.
    https://mega.nz/#!LBNV1JpJ!wCo_xz0ht...j0cZ-q8yMWDSHM
  2. #107
    29 Sep 2017
    Bucharest
    The latest Black Hole image is 3.0.5.B Quad PiP
    What is new ?
    update driver(4k models)
    - Fix HDR/HLG(color) in some TVs
    This is only available as an online update from 3.0.5 or 3.0.5.A
  3. #108
    29 Sep 2017
    Bucharest
    The latest Black Hole image is 3.0.5.C Quad PiP
    What is new ?
    [vuplus-blindscan-utils] update for mips.
    update drivers(duo2, solo2, solose, zero)
    - Improve frontend(TT3L10, TT2L0
    - Improve demux
    update drivers(4k models)
    - Fix HDMI IN(ultimo4k, uno4kse)
    - Fix demux(zero4k)
    - Fix some proc entries in VideoEnhancement
    This is only available as an online update from 3.0.5, 3.0.5.A or 3.0.5.B
  4. #109
    Thumbs up Black Hole 3.0.5.E Quad PiP Vu+ Solo4K Image
    Black Hole 3.0.5.E
    What is new ?
    update drivers(uno4k, uno4kse, ultimo4k)
    - Fix DiSEqC timing
    - Support Dual DVB-S2X FBC tuner(needs E2 update)
    update drivers(solo4k, uno4k, uno4kse)
    - Fix media playback(24Fps)
    Fix default recording path and usb recording.
    [dvbapp] update.
    [autofs] remove sync option for broken recording issue for ext4 filesystem.
    [udev] fix automount.
    BlackHole-3.0.5-vusolo4k_usb_release_20180226_4accc58.zip
    https://mega.nz/#!zV0BXLbI!EEZjcnj0Q...hHWukXgXgcKupc
  5. #110
    29 Sep 2017
    Bucharest
    The latest Black Hole image is 3.0.5.H Quad PiP
    What is new ?
    Fix USB recording [uno4kse, zero4k , solo4k]
    [linux-vuplus-3.14.28] increase PR.
    [dvbapp] remove patches in bsp layer and cleanup unused patch files. (patches were applied to E2)
    Support DVB-S2X for uno4k, ultimo4k, uno4kse.
    update driver(ultimo4k)
    - Fix delsys in DVB-S2X FBC tuner
    [Blindscan] Support zero4k.
    [AnimationSetup] fix default animation speed for uno4k, uno4kse, zero4k.
    Support DVB-S2X
    *** THIS IS ONLY AVAILABLE AS AN ONLINE UPDATE FROM BH 3.0.5.F ***
  6. #111
    29 Sep 2017
    Bucharest
    The latest Black Hole image is 3.0.5.I Quad PiP
  7. #112
    29 Sep 2017
    Bucharest
    The latest Black Hole image is 3.0.5.J Quad PiP
    What is new ?
    [opera-hbbtv] update hbbtv
    [dvbapp] increase PR.
    update drivers(4k models) ...
    [dvbapp] increase dvbapp PR.
    [webkit-hbbtv] improve stability for some services.
    [RecordTimer] fix calculate filename for missing return value.
    support 2160p video(VP9) (4K models)
    fix fullbackup on uno4kse
    Add Relevant PIDs Routing. (for support Extra high bitrate in DVB-CI)
    *** THIS IS ONLY AVAILABLE AS AN ONLINE UPDATE FROM BH 3.0.5.I ***
  8. #113
    29 Sep 2017
    Bucharest
    The latest Black Hole image is 3.0.5.K
    *** THIS IS ONLY AVAILABLE AS AN ONLINE UPDATE FROM BH 3.0.5.J ***
  9. #114
    29 Sep 2017
    Bucharest
    Astazi sa lansat in sfarsit versiunea stabila:
    OpenPLi 6.2 » Stable release
    O puteti descarca de aici:
    https://openpli.org/download/vuplus/Solo+4K
  10. #115
    alaltaieri mai exact
    TOP5: Zgemma H9,
  11. #116
    29 Sep 2017
    Bucharest
    Era imposibil sa nu fi tu "Gica contra" si aici,ti-am mai spus si cand erau versiunile de test ca, nu este o versiune finala, tu..batman,batman, pana nu ai vazut ca, se schimbau versiunile ca pe ciorapi zilnic nu te-ai potolit, asa si aici...in mare parte este asa cum spui dar...alaltaieri sa lansat prima versiune stabila.....2018/05/12..din pacate nu a fost sa fie si au mai urmat inca 2 versiuni care au facut cateva corectii,ultima versiune stabila din toate punctele de vedere (momentan) este versiunea din data 2018/05/14 05:48 - fara bug-uri,deci...corect este cum am spus eu ca, sa lansat,fiecare dorim o imagine curata,fara bug-uri si fara surprize.
  12. #117
    chiar nu inteleg despre ce vb....normal ca vers de test apar zi de zi...e si normal pana apare vers finala ce va fi o data la sapt......nici acum nu e final....vu plange de buguri de la prima vers....asta asa ca fapt difers...
    si ca sa fiu giga cum spui......mutantu nu a avut o prob de la prima vers RC....tot asa ca fapt divers.....doar la o vers multiboot a dat cu verde
    nu stiu ce atata politica...cand eu am spus doar ca de fapt din data de 12 e lansata oficial.....ca si statistica
    nu e nici un final atata timp cat mereu vu are prob....deci....
    TOP5: Zgemma H9,
  13. #118
    29 Sep 2017
    Bucharest
    Am avut DM 500 inca de la aparitia lui,apoi am trecut pe VU+solo 2 tot de la aparitia lui pe piata,o schimbare majora pentru mine ca, hobby-st,in cele din urma am trecut la VU+solo 4K nu chiar de la inceput pentru ca, nu ma incanta ideea sa arunc cu banii pentru cateva programe 4K,per total sunt ani buni de cand folosesc marca VU+,chiar foarte multi asi putea spune,timp in care nu am avut nici cea mai mica problema,permanent am folosit aceiasi imagine Black-hole,din cand in cand fac teste cu alte imagini in multiboot,ceea ce vreau sa spun este faptul ca cel putin eu personal nu am avut parte nici macar de un semibug dar bug...asa ca...relax,VU este unul dintre cele mai bune si stabile receivere de pe piata,momentan inca nu are concurenta la: raport/pret/calitate/suport.
  14. #119
    cum spui tu..eu sant foarte relaxat.....si nici nu trebuie sa mi explici prea multe....de 20 de ani cred ca ma duce mintea sa stiu si eu ce si cum...pret/calitate/suport
    si eu sant foarte multumit de gigablue si mutant la configuratia ce o am in casa...antena..lnb..motor..tv...receptor...
    ce se intampla la altii nu e problema mea....PUR SI SIMPLU..sustin mereu...dezbat si ma contrazic pe ce a ce am...de restu...din ce ma informez...si m am informat mereu de giga..mutant dm si vu...deci le stiu pe toate ce le poate mintea si ce suport au....si mai stiu si de toate bugurile pe care ce i de la dm si vu le cam uita si le ascund...si cele de la gigablue stai lin.....deocamdata prob la mutant nu exista...DIN PACATE....doar catva razleti cu tuneru s2x ...cu semnalul real dar ata e o politica mare atat la team urile ce fac imagini cat si la producatori...mai era o prob...ca u se pozitiona motoru la secunda 0 pe satelit....dar sau convins ca era un bug din enigma2...dar unii vb ta...batman batman
    sti cum e piata nu?
    ca si incheiere generala....din tot ce am citit...aici ma refer la 4k.....DM si VU.....merg foarte bine doar cu imaginiile ...MAMA...sa zic asa...in rest o dau in balarii de numa...ca e stable ca e RC..iar unele imagini din astea no open sources ce se dau marete...fura de rup la open sources...NESIMTITI
    TOP5: Zgemma H9,
  15. #120
    .......fura de rup....... - Cea mai tare expresie pe care am citit-o - Mutantul , oare dupa ce este furat ?
    Daca tot vrei sa discutam de furat/cinste , oricum si Mutantul e o copie dupa alt receptor
    Ca sta mai bine pe partea de suport software poate DA , poate NU , pe mine NU ma intereseaza
    Atat DM-ul , cat si VU+ au parte de clone , asa ca treaba cu ''furatul'' e - Cine de la cine fura ?
    Pt mine ca user final ma intereseaza sa existe rezolvare la cea ce ma intereseaza , indiferent ca e DM/VU+/Mutant/Octagon sau mai stiu ce alta firma/receptor 4K
    Folosesc GP3.3 de cel putin 3 saptamani si nu am avut prb/ecran verde pana acum , in rest.......sunt pareri subiective
    Care uneori ajuta si de cele mai multe ori creaza contradictii
    Intr-un fel e bine daca aceste contradictii sunt constructive , niciodata nu mi-a placut sa existe intr-o comunitate toti de aceasi parere ( ca e buna sau rea )
    Si viata e COLORATA , nu numai ALB si NEGRU
