- Rep Power
- 155
Open Source Image 3.0 ----------------Update 29/01/2016
http://code.vuplus.com/download/boxi...=30&m=vusolo4k
- Rep Power
- 155
OpenNFR 5.1 VU+ Solo 4K Image
openNFR Update Februar 2016
Neuigkeiten / Änderungen
add Gst 1.7.1
add multiboot for vu+ solo 4k
Treiber Stand 31.01.2016
Treiberupdate VuPlus 4K (inkl. chromiumOS & youtubeTV)
Fix
Fix LCD-Display
Fix Skin
Fix Übersetzungen
Fix diverse kleinere Fehler
http://dev.nachtfalke.biz/nfr/feeds/...160129_usb.zip
- Rep Power
- 155
openATV 5.1 VU+Solo4k Image
- Rep Power
- 155
VTi "Vu+ Team Image Solo 4K" - V 9.0.2
25.01.2016 - Software Update
- update dvbapp2 (2016-01-25)
Timeshift: map function transform timeshift to REC button
Timeshift: remove duplicate menu entries
REC button: add transform timeshift to configuration choices
- update vtipanel (ver. 3.37)
fix image restore/flash tools
03.02.2016 - Software Update
- update dvbapp2 (2016-02-03)
Timers: fix repeating timers
Timeshift: enhance naming scheme for timeshift files
Timeshift: do not switch to live TV after event change
Timeshift: add option to to use < and > buttons for switching timeshift events
Timeshift: change default configuration for behaviour at event change
- update hbbtv (ver. 20151228) (solo4k)
- update skin mutespectator (ver. 2.9)
see TimeShift screen for new source TimeShiftService
05.02.2016 - Software Update
- update plugin camofs (ver. 11.0)
- update plugin fritzcall (2016-02-05)
- update plugin permanenttimeshift (2016-02-05)
keep compatibility to new dvbapp2 functions
- update plugin picturecenterfs (ver. 7.22)
06.02.2016 - Software Update
- update dvbapp2 (2016-02-06)
Common: fix releasing memory at loading epg data
- update plugin camofs (ver. 11.01)
07.02.2016 - Software Update
- update dvbapp2 (2016-02-07)
Timeshift: fix naming scheme of ts files
Timeshift: try to set correct file name for saved event
Timeshift: do not stop timeshift when channel selection will be closed without service change
- update gstreamer-plugin-dvbmediasink
fix sound dropouts at some media files
08.02.2016 - Software Update
miscellaneous bug fixes
fix AC3/DTS playback when PCM tracks are present
09.02.2016 - Software Update
- update dvbapp2 (2016-02-09)
[Timer] add option to avoid simultaneous timer starts
[Timeshift] add function to transform old timeshift events
[Timeshift] use begin time of event for ts file name
[Timeshift] add option to hide timeshift files in movie list
http://speedy.sh/gh7XV/vti-image-vus...-9-0-2-usb.zip
- Rep Power
- 155
http://images3.mynonpublic.com/opena...160212_usb.zip
http://dev.nachtfalke.biz/nfr/feeds/...160210_usb.zip
OpenPLi-4.0-beta-VU+ Solo 4K Image
http://openpli.org/download/vuplus/vusolo4k/
- Rep Power
- 155
OpenSPA 5.0.005 for VU+ Solo 4K NEW UPDATE 2016-02-16
Changelog:
- WeTek Play :
Kernel 3.10.93 and Drivers 2016-01-29
Improvements and fixes Enigma2
New plugin Selection Remote Contorl with support in the Wizard
- Gigablue:
Kernel 4.0.1
New drivers
GStreamer 1.7.1
- Zgemma:
New drivers 2016-01-21
- Kodi 15.2 for Vuplus Solo2, Solo SE, Duo2 and Solo 4K (thanks mx3l)
- New OpenSPA updates wizard (Allows install new firmware keeping settings and data)
- New skin Confluence 1080: based in Confluence_openspa
- Updated skin OpenSPA_JRLG1080 (more screens included)
- Updated plugin openSPA_JR (added new infobars, channel selection and chance to choose dark or light style)
- Updated GStreamer 1.6.x to 1.7.1
- Fixed issue with ecm line in infobars, because it was always shown in some skins.
- Translate improvements.
- Other minor fixes.
Password FTP/Telnet : openspa
To report bugs :http://openspa.info/forums/reportes-...n-openspa.265/
http://openspa.info/resources/opensp...d?version=1766
- Rep Power
- 155
openATV 5.2 VU+Solo4k Image
- Rep Power
- 155
VU+rudream-5-------Vu+Solo4K-----22.02.2016
- Rep Power
- 155
SatDreamGr v4.0 ------------VU+ Solo 4K
http://sgcpm.com/satdreamgr-images-e...l/vu/vusolo4k/
Backup Vu+ Solo4K Satdreamgr v4.0 by Prekon:
I put emulators Oskam-1.120, Wicardd-1.19
https://yadi.sk/d/rR4TV8oEpwzA9
- Rep Power
- 155
update new
- Rep Power
- 155
OpenSPA 5.0.006 for VU+ Solo 4K NEW UPDATE 2016-03-18
What is new?
- Kodi 16 "Jarvis" for Vuplus Solo2, Duo2, Solo SE and Solo 4K
- Fixes in EPG plugin to assign what screen you want to EPG button.
- Added new wget to improve safety.
- Fixes in OpenSPA updates wizard.
- Fixes in spaqbutton (remap keys).
- Added new renderer for better XPicons performance.
https://openspa.webhop.info/#Descarg...genes%2FVuplus
- Rep Power
- 155
openATV 5.3 VU+Solo4k Image
http://images.mynonpublic.com/openat...?open=vusolo4k
VU+rudream-5-------Vu+Solo4K-------24.03.2016
https://yadi.sk/d/I4i6yYG4mKfWF
- Rep Power
- 155
OpenDroid Image V.5.4 Image VU+Solo4k
New Release Opendroid V.5.4
The openDroid image Today is a brand new structure, Thank you all for the New Test !!!
New: OpenDroid 5.4
**developers Image openDroid**
gimsy,formianodicastellone
A special thanks to all the beta testers
Skinner:
Mmark
Porting e Mod Skin oDreamy:
Formianodicastellone,Satinfo
BootLogo and splash:
robijay
Picon default:
robijay
Beta Tester Spark:
juvent,
Very Thanks juvent!!!
New:New!! OE-Core 3.3
New:Bitbake: 1.27.1 to 1.29.0
New:Compiler: GCC 4.9.2 on GCC 5.3.0
New:Busybox: 1.23.2 to 1.24.1
New:Python: 2.7.9 to 2.7.11
Newhttp://www.satdreamgr.com/forum/imag...es/redface.pngpenssl: 1.0.2d on 1.0.2f
Newhttp://www.satdreamgr.com/forum/imag...es/redface.pngpenssh 6.8p1 server on 7.1.p2
Newhttp://www.satdreamgr.com/forum/imag...es/redface.pngpkg 1.0.2.4 to 1.0.3.1
New:Libcom 1.42.9 to 1.42.99
New:mtd util 1.5.1 to 1.5.2
New:libssl 1.0.2d on 1.0.2f
New:libcdio12 0.82 to 0.93
New:liborg 0.4.23 to 0.4.24
Newhttp://www.satdreamgr.com/forum/imag...ies/tongue.pngam-plugin-group 1.1.6 to 1.2.1
New:bluz5 5:32 to 5:37
Enigma2: (New:structur 2016-03-26)
Enigma2: Fixed and Update many file!!!
Remove: CrossEPG download it from feed
GStreamer: 1.7.1
Fixed: Mkv file
Fixed: MiniTV
Improved graphics!
New: bootlogo!
New: splash
New: Picon default
New: Translate ITA
New: Translate DE
New: Translate EN
New: Translate UK
Local Feed Opendroid
We thank the developers of the Opendroid image, Oe-Alliance and all betatesters for reports !.
Special thanks goes to Mmark for Skins, Satinfo and formianodicastellone for porting and **** the skin oDreamy, robijay and gimsy for several graphic parts including Bootlogo and Splash, Vhannibal for AUTOSETTinG plugin, and all their coder
NB: Not all third-party plug-ins have been tested and are guaranteed to be compatible
NOTE: Because there is not any kind of official support for these Opendroid-team receivers will deploy custom images using only our addons server that mirrors the standard server Opendroid and that will allow for online updates when available.
OpenDroid-Team-Not recommended to make On-Line software update !!!
possibly use the image on flash
http://images.opendroid.org/5.4/VU+/...p?dir=vusolo4k
- Rep Power
- 155
OpenNFR 5.2 VU+ Solo 4K Image
- Rep Power
- 155
openBH 0.4 Image VU+Solo4k
Whats New:
Completely new image
Based on OE-A core
Solo4K supported
Updated to Gstreamer 1.7.1
Updated to Python 2.7.9
Main Features:
MX HQ9W Full Hd skin (1920x1080)
Kodi 15.2 (Solo4K, Duo2, Solo2, SoloSE)
OpenMultiBoot (Solo4K supported)
OE-A Plugins
Black Hole:
Blue panel
Green Panel
Extra Settings
Addons panel
Compatible with OE-A and PLi plugins and Skins
What is openBH ?It is an exciting project from the same team that produce the Black Hole images.
This latest project is now based on the OE-Alliance git and coding infrastructure, which means it is not only Open Source, but it is also compatible with all OE-A and PLi plugins, feeds, skins and it also features full online update support (for those users that do not like having to do a full reflash everytime there is an image update). We have just given it the Black Hole touch.
This means it has the Green Panel and Blue Panels as found in the previous Open BlackHole and the standard Black Hole images, we have also added the BlackHole addons panel and included Full HD skin support, OpenGLes Animations and we have included Kodi 15.2.
As with the standard Black Hole images, we continue to support Genuine Vu+ Boxes only and therefore our images are optimised for Vu+ boxes and will only work on these models (any openBH, Open BlackHole, or Black Hole images you see on the internet for other box models or clone models are not official images and we offer no support for those boxes or images).
Do I have to upgrade to this new openBH image ?
No you don't have to upgrade to the new openBH image, this image is completely separate from the original Black Hole image, this is simply an alternative image so we can offer our users more choice, if you are happy with your current image, then you can continue to use that image, if you want to try the new openBH image then you can do so.
What about the Black Hole and Black Hole Prism Images ?
For those of you worried about the standard Black Hole and Prismcube image, please don’t worry, we remain committed to the standard Black Hole and Black Hole Prism images and image updates will continue as normal, this new openBH image is an additional project and we are fully committed to all images.
Where can I find the openBH git ?
The openBH git is located here: https://github.com/BlackHole
http://speedy.sh/M7wy9/openbh-0.4-vu...se-00abe27.zip
DISCLAIMER
THE OPEN BH IMAGE DOES NOT CONTAIN ANY EMULATOR, K E Y S, SOFTCAMS OR OTHER SYSTEM FOR VIEWING PAY - TV WITH OR WITHOUT A PAID SUBSCRIPTION.
THE OPEN BH IMAGE DOES NOT CONTAIN ANY SYSTEM TO DOWNLOAD PLUGINS OR EMULATORS FROM EXTERNAL SERVERS OR SOFTWARE THAT MAY BE USED FOR ILLEGAL PURPOSES SUCH AS CARD SHARING.
