Thanks Thanks:  22
Likes Likes:  30
Page 2 of 13 FirstFirst 12345612 ... LastLast
Results 16 to 30 of 187
Thread: Discutii si ajutor ALi HD & SD
    23 Jun 2008
    Ce incerci sa faci cu DCC?
    Amiko nu e dreambox
    85 Post(s)
    Default @cena133
    descarca de pe net fisierul model hsdata.cfg(pt amiko),iti actualizezi serverele, le pui in root pe usb,apoi :meniu,internet,net client config,tasta find de pe telecomanda si asta e...un forum e locul unde inveti sa inveti,nu sa-ti dai cu parerea,persiflandu-i pe incepatori...(mesaj pentru cei ce stiu ca nu stiu si dau sfaturi)
    23 Jun 2008
    Foloseste cineva Alma Micro HD ?
    Este stabil ? merge bine in share?
    Default Discutii si ajutor ALi HD and SD
    ALi Unveils Smart STB Solution M3932 Based on Latest Android 4.4 KitKat at CCBN 2014
    2014 / 03 / 14
    Taipei – March 14, 2014 – ALi Corporation, a leading Set-Top Box (STB) solution provider, today announced the launch of M3932, a high definition smart STB SoC solution based on the latest Android 4.4 KitKat, targeting applications including smart DVB or IPTV set-top boxes, OTT multimedia players, hybrid set-top boxes, and TV dongles. Mass production of M3932 is scheduled in Q2 2014.
    M3932’s dual-core ARM® Cortex™-A9 processor allows the set-top box to run Android 4.4 KitKat, which can support 512MB DDR SDRAM, offering optimized cost structure, and faster APK loading speed, providing enhanced user experience. With M3932’s efficient system core architecture, boot-up time is reduced to less than 20 seconds.
    Advancing with the multi-screen video sharing trend, M3932 supports DLNA that allows media content to be distributed across devices within the home network. M3932 also enables wireless display mirroring by supporting Miracast, enabling users to echo display from a small-screen device such as a smartphone or tablet onto a TV in real-time via a Wi-Fi Direct connection.
    By integrating a high-performance hardware video decode engine, M3932 supports various broadcast and web-based video standards, thus providing an ideal platform for seamless enjoyment of innovative entertainment services.
    M3932 features ALi Security Engine (ASE), which provides robust protection by implementing a chain of trust including secure boot, secure upgrade, in addition to a variety of latest attack resistance mechanisms.
    Jim Li, General Manager of ALi’s China Business Unit, comments, “ALi leverages our mature hardware, software, and security expertise to launch M3932. By building a highly-integrated and flexible platform based on Android 4.4 and supporting customers with development, testing, and mass production tools, M3932 significantly reduces development time and effort for customers, which translates to faster time-to-market.” “Furthermore, M3932 provides customers the ability to offer diverse services and brings consumers true freedom to enjoy high definition content across devices," adds, Jim Li.
    At CCBN 2014, to take place on March 20-22, 2014 in Beijing, ALi will showcase M3932 as well as another new product, M3381T-B, a high definition DTMB set-top box solution fully supporting AVS+, which is a new generation video compression standard being nationalized in China to support high definition and a key official requirement for set-top boxes addressing the Chinese market. Demonstrations of ALi platforms will be available at ALi's stand #1B201.
    17 Nov 2008
    ALBA
    Default Amiko Micro HD probleme comutator diseqc !
    Salutare , cine foloseste comutator diseqc pe Amiko Micro HD ? Cand pun comutatorul si schimb de pe un canal pe altul sa zicem trec de pe 1w pe 16est imi scade semnalul la 0 cateva secunde in timp ce vizionez canalul respectiv este enervant . Am pus mai multe comutatoare si la fel. Sa fie ceva din receiver sau soft? aveti astfel de probleme?
    17 Nov 2008
    ALBA
    Deci am mai facut niste teste si fara diseqc si la fel se manifesta in special cand schimb pe pro tv face figuri. Am pus receiverul si pe alta antena am mai multe la fel , cred ca are o problema receiverul. nu are nimeni modelul asta?
    85 Post(s)
    Incearca un downgrade la sw,de preferat unu' oficial.Sau pune aparatu' de masura pe intrarea
    tunerului,vezi ce zice.Daca scoate tensiune pt "h" intrerupta.
    17 Nov 2008
    ALBA
    Am incerrcat multe softuri si la fel se manifesta. Am sa incerc la tuner sa masor sa vad totusi daca se intrerupe alimentarea la LNB.
    31 Mar 2014
    Default Receiver blocat
    Salut. !
    Am un amiko combo, de curand am vrut sa-i pun un emu nou (luat de pe un forum)
    se numea AMIK-MINIHD_COMBO Multi 1.2.48 multi by dekolte dar dupa ce i-am facut upgrade
    decodorul nu mai functioneaza imi da pe TV mesajul IDENT-Error UNINIT !, acum vreau sa revin la versiunea oficiala emu 1.3.15 , dar nu mai pot utiliza stb-ul, cum il pot readuce la viata, merci!
    85 Post(s)
    Doar pe cablu rezolvi eroarea.Citeste aici.Ce fel de receptor ai?
    Ca acesta? Sau ca acesta?
    31 Mar 2014
    Amiko Mini Combo, azi l-am cumparat. mergea perfect cu primul emu, apoi am pus ala dekolte(desi descrierea e de MinicomboHD nu SE) imi da mesajul acela si nu pot scapa de el, mi-am confectionat un cablu ca sa-l bag in PC, dar ce trebuie sa fac, nu as vrea sa-l mai stric din nou. am eroarea IDENT ERROR - UNNIT
    Default Atentie dekolte - blocheaza bootloaderul
    Am patit-o si eu cu Galaxy Dekolte 1.3.10 - mare atentie la cei care vor sa folosesca versiunea aia. Cablul atasat in cutia cu care vine AMIKO MINI COMBO nu este bun pentru resuscitare? Trebuie confectionat altul conform schita de la postare #448, user @konstantine la topicul "amiko mini combo" ?
    31 Mar 2014
    @konstantine
    Am confectionat un cablu rs dintrun cap jack cu 4 striatii am legat firele de portul pcului mai departe ce trebuie sa fac
    85 Post(s)
    1) cu receptorul scos din priza,conectezi cablul intre pc si rec
    pe portul serial rs232 (de preferat ar fi cablul cu care vine din fabrica)
    2) pornesti programul Upgrade.exe ,incarci sotwareul AMIKO_MiniHD_Combo_1.2.96_conax.abs
    la ugrade type selectezi all sw+bootloader,dai next si alimentezi receptorul la retea.
    Procesul poate dura intre 20 si 30 de minute.Dupa terminarea procedurii de update,
    apesi pe tabul finish al Upgrade.exe.Tineti minte: intodeauna la sw update trebuie selectata
    optiunea all sw+bootloader indiferent daca e pe usb sau rs232.
    Un filmulet ai aici si cele necesare pt .update aici.
    "Succesuri"
    31 Mar 2014
    transfer data failed
