Results 1 to 4 of 4
Thread: Windows 10 news
    85 Post(s)
    Default Windows 10 news
    Sadly, Windows 10 Is Stealing Your Bandwidth 'By Default' — Disable It Immediately
    After installing Windows 10, Feeling like your Internet Bandwidth is dropping away? Windows 10 is stealing your network bandwidth.
    Along with the privacy features related to Wi-Fi Sense, Windows 10 users should check for another hidden by default feature that uses your network bandwidth to share updates with other Windows 10 users across the Internet.
    Microsoft launched Windows 10 on July 29 and offered a free upgrade to Windows 7,8 and 8.1 users, and for anyone who wants to download it. But, handling millions of simultaneous 3.5GB downloads is quite difficult for the company.
    So, in order to cope up with the issue, Microsoft has baked a new feature into its latest desktop operating system that uses the torrent-style approach to obtain software updates, allowing Windows 10 users to download updates from other users.
    Also Read: How to Fix 35+ Windows 10 Privacy Issues With Just One Click.
    Windows 10 is Stealing your Internet Bandwidth
    The feature, known as Windows Update Delivery Optimization (WUDO), is initially designed to help users get faster software updates, which is quite a good idea to handle massive internet traffic of up to 40 Terabits per second (TBps).
    WUDO works a lot like torrents work. Your computer running Windows 10 is used as part of a peer-to-peer network to deliver software updates faster to others, each person distributing a little bit of the files across multiple computers and helping everyone download updates quickly.
    But, this peer-to-peer sharing method offered by Windows 10 is using your precious Internet bandwidth, without hinting you about it, because the feature is enabled by default in Windows 10 Home and Pro edition. WUDO is also enabled in Windows 10 Enterprise and Education, but only for the local network.
    How to Disable Windows Update Delivery Optimization (WUDO)?
    You can disable the feature, but the option is buried deep in the Settings menu for Windows Update.
    To turn this feature OFF, follow these given steps:
    • Go to Settings in the Start menu
    • Search for Update & Security
    • Under Windows Update, open Advanced Options
    • Under Choose How Updates are Installed, select Choose how updates are delivered
    • Disable the toggle under Updated from More than One Place
    The feature is a good idea to speed up software updates, but enabling it by default without the knowledge of users is probably not at all a great idea.
    In a statement, a Microsoft said that the feature "helps people get updates and apps more quickly if they have a limited or unreliable internet connection" and that it "doesn't slow down your internet connection" because it uses a "limited portion" of idle upload bandwidth.
    Source
    nu sant aparatorul win 10 insa deja apar multi carcotasi....ca si la E2 si la win 10 tot felu de anonimi descopera tot felu de buguri desigur netestate,nu vad niciunde o poza cu teste
    eu am facut un test si aprox 15 min l am frecat si activ si dezactivat pe anumite distante.........ce pot sa zic e ca.....na,nu fura nimic,poate nu trage nimeni de la mine
    singura diferenta a fost ms de la ping.....insa chestiile astea se schimba de la secunda la secunda
    eu unu m am cam saturat sa tot citesc de la altii ce mari descoperiri au facut ei....pune ti mana si testati
    si la urma urmei nu e nimic in background e totu la vedere....iti instalezi win pai frate il cauti la oua si mai faci si tu ceva......daca esti din ala cu copy/paste ca la enigma2 posibil sa fi o victima UNIVERSALA a tuturor
    konstantine,wrote: " Only english coments,or translate "
    85 Post(s)
    This upg. mode,is like P2P.If your neighbors(network),requests
    major update,they literally steal your bandwith.I wrote on another board:
    Most big,and effective botnet.Maybe, im wrong...or not.
    Probabil au imprumutat tehnologie de la SKYPE .
    Era de asteptat sa faca asta, pana la urma nu e nimic rau sa se transfere kitul in sistem P2P.
