Results 1 to 2 of 2
Thread: BlackHole-2.1.5
    03 Sep 2008
    Default BlackHole-2.1.5
    http://www.girlshare.ro/34513938.8
    Black Hole 2.1.5​
    New: HQ 5 Full Hd Skin 1920x1080 (duo2, solo2, soloSe, uno, ultimo, zero)
    New: OpenGL animations and Xbmc (duo2, solo2, soloSe)
    All drivers updated
    fix autoresolution plugin
    [hbbtv] fix crash parsing xml
    [hbbtv] fix VOD play problem
    fix keymap bug
    fix channel skip
    change default resolution to 1920x1080 (only models with full hd skin)
    update languages hr, it, no
    meoboot: add support for OpenGL and Xbmc images
    update Usbtuner
    WIFI: update driver RTL8188EU
    WIFI: update driver RTL8812AU
    Warning: This image MUST BE INSTALLED IN FLASH.
    Warning: Don't mix images with OpenGL animations and images without animations in multiboot because they use different drivers. If you have an OpenGL image in flash you can only use OpenGL images in Meoboot.
    Warning: Previous personal backups are not compatible with this image. Please use software manager to backup your settings before you flash.
    Known Issues: Xbmc External Player not working yet.
    WARNING: This Image has the latest drivers and CAN NOT be installed in multiboot. The image MUST be installed in flash.
    - Integrated OpenEpg
    - Rytec dedicated epg.dat
    - New system epg.dat outside.
    Download EPG from any channel
    Yellow button = Audio menu
    Addons
    Infobar / OSD
    Analog Clock Gui
    Channel orbital location
    Signal SNR, BER
    Infobar picons
    Blue Panel
    Extra Settings
    Black Hole Speed Up
    Devices Manager
    Usb Format Wizard
    Telnet Panel ( Telnet Panel)
    FTP Panel ( FTP Panel)
    UPnP Client Djmount
    UPnP Server Mediatomb
    UpnP Server Minidlna
    Pcsc Panel
    Tuner Server
    Network Browse & Mountpoints
    Info Panel
    3 - About (info)
    Memory (Memory)
    Space (capacity)
    CPU (processor)
    Process (process)
    EPG Panel
    Green Panel
    Addons (added)
    Online Feeds Settings update
    Red Panel
    BlackHole
    Avalon
    Chaos
    Ghost
    Credits
    Thanks to Littlesat and Pli Team for the original autolanguage and subtitle options code
    DISCLAIMER
    LICENSE (TERM OF USE)
    This is free hobbyist software and it comes with absolutely no warranty. Use it at your own risk.​
    21 Sep 2008
    Am instalat pe Vu solo2 e OK.....
