Results 1 to 6 of 6
Thread: QBox QBox One
    05 Feb 2007
    Default Re: QBox QBox One
    dreambox este si va ramane un receptor de prima clasa
    01 Apr 2007
    Apare prea tirziu .
    Bizareria cu Diablo integrata aete stranie
    La 220Eur va trebui sa lupte cu DM600 si nu cred ca are vreo sansa .
    O zi frumoasa! Snow's Avatar
    05 Jan 2007
    daca are suport e peste dm 600.
    -aceleasi dimensiuni
    -wireless integrat
    -internal hdd 2,5
    -sharp tuner blind scan
    twin tuner dtt dvb
    -3 USB ( one in front panel for fast connection to media USB, one on the back panel for external HD and a mini USB for connection with a pc)
    -recording with an external USB disk
    -2 card readers
    -ethernet
    -streaming delayer
    -2 scart (one can be used like component)and 1 rca
    -safe boot memory (you can't damage the bootloader)
    si exista si varianta Q-Box QBox One Light, insa aceasta nu dispune de wireless integrat si are doar un tuner
    Q-Box QBox One by Duolabs
    QBOX is the name of the Set Top Box and it's really something new. It is a Linux based decoder powered by an IBM 2500 250 Mhz chip kernel 2.6.17 - external alimentation 12 volt and OS. Only 6 x 23 x 15 cm in size (it's really very small). The box has a lot of extra features when compared to the main competitors.
    Wireless Integrated
    Internal HDD 2,5
    Sharp Tuner Blind Scan
    Twin Tuner dtt dvb
    Diablo inside (compatible with the Diablo emulator support) you don't need to update the VAR-Key with a ftp program, you will be able to update the Diablo emulator with a specific file from Stealth team using USB-Wireless-or Ethernet
    Enigma osd
    Recording with an external USB disk
    2 card readers
    Ethernet
    Streaming delayer
    2 Scart (one can be used like component)and 1 rca
    Safe boot memory (you can't damage the bootloader)
    Expected Release date March 2008
    Click HERE to order soon.
    The pictures are of a sample QBox (only 50 of these samples were made) You'll notice no markings on the rear of the receiver.
    I'll be taking pre-orders for QBox soon.
    Mmmmda...interesant!
    22 Apr 2007
