Thanks Thanks:  1
Likes Likes:  12
Results 16 to 30 of 43
Thread: subtitrare la Discovery ID
    16 Feb 2009
    13 Post(s)
    Confirm si eu, pe niciun receptor E2 nu-mi merg subtitrarile pe Discovery, Discovery Showcase, ID, Animal Planet, nici pe 1w, nici pe 31,5E
    95 Post(s)
    Probat pe A5 merg in Android si in E2, pe K3 nu merge la DTX dar merg in PVU.
    Alienu 2 e pus pe cablu, dar e clar ca nu merge.
    Cred ca au codat streamul cu subtitrarile dar e lasat marcat FTA.
    Parca se poate in oscam sa fortezi emu sa decodeze un PID
    http://www.streamboard.tv/wiki/OSCam...g/oscam.dvbapi
    ---------- Post added at 10:58 ---------- Previous post was at 10:37 ----------
    La K3 am in oscam.dvbapi:
    P:1801
    I:0E00
    prima linie e pentru cablu, a 2-a sa ignore PVU !
    95 Post(s)
    Nu sun criptate subtitrarile, au schimbat ceva.
    Uite log din oscam de K3, A5 Android si A5 Enigma2
    La A5 le afiseaza si pe Android si pe E2
    29:40 _(client) plain dvbapi-client granted (k3, au=off)
    29:40 _(dvbapi) dvbapi channelcache loaded from /data/data/th.dtv/supercam/oscam.ccache
    29:40 _(dvbapi) Using sk_supercam listen socket, API forced to DVBAPIv3 (0), userconfig boxtype: 12
    29:41 _(dvbapi) Client connected: 'test client' (protocol version = 1)
    29:41 _(dvbapi) Demuxer 0 ecmpid 0 CAID: 1815 ECM_PID: 140E PROVID: 000000
    29:41 _(dvbapi) Demuxer 0 ecmpid 1 CAID: 0B02 ECM_PID: 153A PROVID: 000000
    29:41 _(dvbapi) Demuxer 0 ecmpid 2 CAID: 0D97 ECM_PID: 1792 PROVID: 000000
    29:41 _(dvbapi) Demuxer 0 ecmpid 3 CAID: 0653 ECM_PID: 18BE PROVID: 000000
    29:41 _(dvbapi) Demuxer 0 found 4 ECMpids and 2 STREAMpids in caPMT
    29:41 _(dvbapi) Demuxer 0 found channel in cache and matching prio -> start descrambling ecmpid 1
    29:41 _(dvbapi) Demuxer 0 trying to descramble PID 1 CAID 0B02 PROVID 000000 ECMPID 153A ANY CHID PMTPID 0000 VPID 02EF
    29:41 _   (ecm) k3 (0B02@000000/0000/77FA/84:EF792D5CF17B91829A35883CD327C99B): found (7 ms) by c...i - DTX
    29:41 _(dvbapi) Demuxer 0 found 4 ECMpids and 5 STREAMpids in PMT
    29:45 _   (ecm) k3 (0B02@000000/0000/77FA/84:30AEEECF691063CBAE9A0576D7F7967D): found (791 ms) by c.... - DTX
    36:31 _(client) plain dvbapi-client granted (A5, au=auto (3 reader))
    36:31 _(dvbapi) dvbapi channelcache loaded from /var/tuxbox/config/oscam.ccache
    36:31 _(dvbapi) Detected /dev/dvb/adapter0/demux0 Api: 0, userconfig boxtype: 0 maximum amount of possible filters is 19 (oscam limit is 32)
    36:31 _(dvbapi) Demuxer 0 ecmpid 0 CAID: 1815 ECM_PID: 140E PROVID: 000000
    36:31 _(dvbapi) Demuxer 0 ecmpid 1 CAID: 0B02 ECM_PID: 153A PROVID: 000000
    36:31 _(dvbapi) Demuxer 0 ecmpid 2 CAID: 0D97 ECM_PID: 1792 PROVID: 000000
    36:31 _(dvbapi) Demuxer 0 ecmpid 3 CAID: 0653 ECM_PID: 18BE PROVID: 000000
    36:31 _(dvbapi) Demuxer 0 found 4 ECMpids and 3 STREAMpids in caPMT
    36:31 _(dvbapi) Demuxer 0 found channel in cache and matching prio -> start descrambling ecmpid 1
    36:31 _(dvbapi) Demuxer 0 trying to descramble PID 1 CAID 0B02 PROVID 000000 ECMPID 153A ANY CHID PMTPID 02EE VPID 02EF
    36:31 _   (ecm) A5 (0B02@000000/0000/77FA/84:8B21E348246E5D0F7FFFD1B28650776C): found (4 ms) by ...i - DTX
    36:32 _(dvbapi) Demuxer 0 found 4 ECMpids and 5 STREAMpids in PMT
    36:35 _   (ecm) A5 (0B02@000000/0000/77FA/84:2A764B81ACE27CB012F93122337C8D02): found (674 ms) by c...i - DTX
     (dvbapi) Demuxer 0 found 4 ECMpids and 5 STREAMpids in caPMT
     (ecm) A5E2 (0B02@000000/0000/77FA/84:E665EB1FE0A26D76BF19E865A1F52029): found (35 ms) by c...i - DTX
     (ecm) A5E2 (0B02@000000/0000/77FA/84:3F5D12393C17F6DD46158DDA37139D32): found (477 ms) by c...i - DTX
    45 Post(s)
    Cu PowerVu emu 2.9.1 si DVBDream merg toate subtitrarile de pe 1W, 12303V27500 fara nicio modificare
    95 Post(s)
    Nu e vorba de transponderele PVU.
    De ex in
    0,8W 11938.00H, DVB-S, QPSK, 28000 7/8
    e DTX.
    17 Jul 2008
    In Tara
    @dingo31
    doar asta a mai ramas care merge subtitrearea.
    nici pa showcase n o mai vede.
    ca si pa animal planet,apare din cind in cind doar banda aia neagra din fundal.
    vad ca si pa bbc earth este ecran negru.
    ce plm fac astia,ne lasa fara documnetare.
    45 Post(s)
    @felix73
    am mai spus ca prin dvbviewer merg toate subtitrarile de pe canalele discovery, in romana, araba, greak, slo, rusa, gr, hebr, etc ... atat cele de pe 1W si cele de pe 4.8E cu powervu emu 2.9.1 sau 3.0.0. Ai aici Showcase HD din pachetul UPC 1W 11843V3000, conax. Pe receptoarele e2 nu am emulator de power vu, nu stiu cum e acolo. Vu uno si Vu duo2 le folosesc pe vti, cu cccam, asta nu stie powervu.
    ---------- Post added at 19:27 ---------- Previous post was at 19:17 ----------
    Revin cu o completare. Am testat si pe E2 cu vti vu uno si nu merge subtitrarea la showcase upc 11843V30000. Nu prea mai folosesc receiverele, pentru mine e mai comod pe PC. Acolo e totul, tv, facebook, jocuri, youtube, etc. De ce sa te mai deplasezi
    17 Jul 2008
    In Tara
    gata m am lamurit.
    vad ca bbc si a revenit intre timp.
    45 Post(s)
    @zildan
    Da, dar si pe 11938H28000 e ok subtitrarea si pe DTX. Evident, tot cu dvbviever. Am sa incerc mai tarziu si pe e2
    17 Jul 2008
    In Tara
    este singura care mai merge pa e2.
    06 Feb 2010
    Rezolvarea la subtritari : se face update la enigma 6.2 prima data, dupa scanare canale, retea, goleste lista inainte de scanare, ok si totul este ok ca inainte, merge toate subtritrarile, nici la mine nu a mers cateva zile.
    none
    01 Jan 1999
    acasa
    35 Post(s)
    confirm ca merg iar subtitrarile...dar nu am facut nici un scan, doar update la enigma...
    bafta
    17 Jul 2008
    In Tara
    la mine chiar azi a murit si ultima.
    pa dtx.
    cum adica update la enigma 6.2..
    open atv,openli?
    open pli 6.2...dar eu nu am avut asemenea prob..
    06 Feb 2010
    openatv 6.2 ,au rezolvat problema pin update software, degeaba se scaneaza canalele daca imaginea nu este la zi, nu merge subtritrarile.
