Page 10 of 10 FirstFirst ... 678910
Results 136 to 149 of 149
Thread: Images Vu+ Zero
  1. #136
    SatDreamGR 4.0 Vu+ Zero Image
    http://sgcpm.com/satdreamgr-images-e...o-20161230.zip
    VU+rudream-5 Vu+ Zero Image
    https://docviewer.yandex.com/?url=ya...c=586798747afd
  2. #137
    Open Source 3.0 Vu+ Zero Image
    http://code.vuplus.com/download/boxi...170702_usb.zip
  3. #138
    OpenDroid 5.5 Vu+ Zero Image
    http://images.opendroid.org/6.0/VU+/
    OpenViX 4.2.030 Vu+ Uno Image
    http://www.openvix.co.uk/openvix-bui...vuzero_usb.zip
    OpenHDF- 6.0 Vu+ Zero Image
    http://v60.hdfreaks.cc/vuzero/openhd...170207_usb.zip
    OpenATV- 6.0 Vu+ Zero Image
    http://images.mynonpublic.com/openat...hp?open=vuzero
    http://v60.hdfreaks.cc/vuzero/openhd...170210_usb.zip
  4. #139
    http://sgcpm.com/satdreamgr-images-e...o-20170224.zip
    http://v60.hdfreaks.cc/vuzero/openhd...170223_usb.zip
    http://code.vuplus.com/download/boxi...163405_usb.zip
    OpenDroid 6.0 Vu+ Zero Image
    http://images.opendroid.org/6.0/VU+/...170225_usb.zip
  5. #140
    OpenVIX 5 0 001 Vu+ Zero Image
    OpenSPA 7.0 Vu+ Zero Image
    https://openspa.webhop.info/Descarga...170301_usb.zip
    https://docviewer.yandex.com/?url=ya...c=58b5c72dcee8
    http://v60.hdfreaks.cc/vuzero/openhd...170226_usb.zip
    HDMU Vu+ Zero Image
    http://198.245.62.46/images/mips/vuz...2796_Flash.zip
    PBNIGMA-VX-6.0 Vu+ Zero Image
    http://www.pb-download.com/images/in...170228_usb.zip
  6. #141
    OpenSPA 7.0.004 Vu+ Zero Image
    https://openspa.webhop.info/Descarga...170401_usb.zip
    OpenVIX 5 0 009 Vu+ Zero Image
  7. #142
    PurE2 6.1 .usb Vu+ Zero Image
    Username: root
    Password: pure2
    http://pur-e2.club/OU/images/6.1/vup...171006_usb.zip
    http://pur-e2.club/OU/images/6.1/vup...171023_usb.zip
    PurE2 6.1 .usb Vu+ Zero Image 17.11.2017
    http://pur-e2.club/OU/images/6.1/vup...171117_usb.zip
  8. #143
    PurE2 6.1 .usb Vu+ Zero Image 29.11.2017
    http://pur-e2.club/OU/images/6.1/vup...171129_usb.zip
    http://v62.hdfreaks.cc/vuzero/openhd...171128_usb.zip
  9. #144
    Thumbs up Black Hole 3.0.5 Quad PiP Vu+ Zero Image
    Black Hole 3.0.5 Quad PiP​
    What is new ?​
    - Update and fix CrossEPG
    - Fix Timer recording bug
    - Fix USB recording
    - Add Overlayfs for new kernel (Uno4KSE, Zero4K)
    - Add Uno4KSE support
    - Add Zero4K support (beta)
    - Add VP9 Support (Ultimo4K, Uno4KSE, Uno4K, Zero4K)
    - Add Dvb-S2X support (Zero4K)
    - Add Multistream/PLS support (Zero4K)
    - Add Blindscan support (Zero4K)
    - Update Drivers (Ultimo4K, Uno4KSE, Uno4K, Solo4K, Zero4K, Duo2, SoloSE, Solo2, Zero)​
    BlackHole-3.0.5-vuzero_usb_release_20171224_610e58d.zip
    https://mega.nz/#!OU8SGK5S!gJmVeDVAJ...9sXPi1q6ubMqzc
  10. #145
    What is new ?
    - Fix USB recording
    PurE2 6. .usb Vu+ Zero Image 24.01.2018
    http://pur-e2.club/OU/images/index.php?dir=6.2/vuplus/
  11. #146
    Thumbs up Black Hole 3.0.5.A Quad PiP Vu+ Zero Image
    What is new ?
    Update drivers(4k models)
    - Fix demux problem
    [bluetoothsetup/util] update for solo4k.
    [vuplus-blindscan-utils] update TT2L08/TT3L10
    [Scan] Fix DVB-T2 Network Scan. (need update libdvbsi++ 0.3.8)
    - Fix HDR/HLG problem
    - Fix grab problem
    - Fix demux problem
    - Improve overall performance
    - Update kernel config
    - Adjust driver memory allocations
    update kodiegl/chromium/directfb.
    [libdvbsi++] update to 0.3.8
    [dvbmediasink] update EXTRA_OECONF (solo4k, uno4k, ultimo4k, uno4kse).
    update driver(zero4k)
    - Fix DVB-CI problem
    - Fix PLS
    - Improve demux
    This is available as an online update from 3.0.5 or as a full flash update.
    https://mega.nz/#!KJt30QDD!VCLmEXwcf...cypVX-XI9r86lw
  12. #147
    Thumbs up Black Hole 3.0.5.E Quad PiP Vu+ Zero Image
    Black Hole 3.0.5.E
    What is new ?
    update drivers(uno4k, uno4kse, ultimo4k)
    - Fix DiSEqC timing
    - Support Dual DVB-S2X FBC tuner(needs E2 update)
    update drivers(solo4k, uno4k, uno4kse)
    - Fix media playback(24Fps)
    Fix default recording path and usb recording.
    [dvbapp] update.
    [autofs] remove sync option for broken recording issue for ext4 filesystem.
    [udev] fix automount.
    BlackHole-3.0.5-vuzero_usb_release_20180226_4accc58.zip
    https://mega.nz/#!mMlGEQyR!Ftu9IbK73...1XykQhNREgEeOk
  13. #148
    SatDreamGR 6.0 Vu+ Zero Image
    http://sgcpm.com/satdreamgr-images-6/vu/
  14. #149
    Thumbs up The latest BlackHole image is 3.1.0 Multistream Vu+ Zero Image
    BlackHole-3.1.0-vuzero_usb_release_20201005_b5f1952.zip
    https://mega.nz/file/OVEjhK6I#4DqYWm...0f7iO8hcQyC5EE
