Page 2 of 10 FirstFirst 123456 ... LastLast
Results 16 to 30 of 149
Thread: Images Vu+ Zero
    Thumbs up VU+OpenHDF-5.3 Vu+ Zero Image
    Thumbs up VU+VTi 9.0.1 Vu+ Zero Image
    Thumbs up VU+PKT IMAGE HYPERION 5.1 Vu+ Zero Image
    https://mega.co.nz/#!9o8hwbrb!joV9e8...YfcP3sTNKxOEtM
    Thumbs up OpenViX 3.2 Release Image for Vu+ Zero
    http://www.openvix.co.uk/openvix-builds/Vu%2BZero/
    Thumbs up Black Hole 3.0.1 OE 3​ Image for Vu+ Zero
    Dear Vuplus-Community users,
    The Black Hole Team are proud to announce, the new Black Hole 3.0.1 image based on the new Vu+ OE3.0 for all Vu+ models.
    This new Black Hole 3.x image includes all the features of the previous Black Hole 2.x series, but also adds the foundations for new features in the future.
    Please be aware that there are currently issue's preventing the Vu+ Turbo usb tuner from working with the Vu+ Solo, Duo, Uno, Ultimo and Zero models, we hope to resolve this issue soon.
    http://www.mediafire.com/download/pg...24_bfd6ded.zip
    VU+OpenDroid 5.2 --------opendroid-5.2 :new: vuzero
    http://images.opendroid.org/5.2/VU+/vuzero/
    ---------- Post added at 11:55 ---------- Previous post was at 10:47 ----------
    VU+rudream-4-------VU+ Zero Image-----29.11.2015
    https://yadi.sk/d/OaAMikxGf6yhG
    http://www.mediafire.com/download/00...e-X3.0_CAM.zip
    There is a new online update available for all Vu+ models using the Black Hole 3.0.1 image.
    This is only a minor update:
    Fix teletext bug
    Fix https streaming bug
    This is available as an online update from 3.0.1
    VU+ Zero SFTEAM 4.2.2 Vu+ Zero Image
    http://speedy.sh/7uEuk/sfteam-4.2.2-...151201-usb.zip
    Thumbs up OpenLD VU+ Zero-----OpenLD 2.4
    VU+OpenHDF-5.3
    http://v53.hdfreaks.cc/vuzero/
    ---------- Post added at 10:05 ---------- Previous post was at 09:48 ----------
    OpenSPA-5.0.003 NEW UPDATE 04.12.2015
    http://openspa.webhop.info/Descarga%...151204_usb.zip
    Thumbs up OpenATV 5.1 Vu+ Zero Image
    http://images.mynonpublic.com/openat...hp?open=vuzero
    VU+OpenDroid 5.2 --------Vu+ Zero Image
    ---------- Post added at 17:47 ---------- Previous post was at 16:44 ----------
    SatDreamGr 4.0 Vu+ Zero Image
    new experimental gst1
    http://www.speedyshare.com/SwvtU/Sat...o-20151206.zip
    Open Source VU+ Zero Image 3.0
    http://code.vuplus.com/download/boxi...?v=30&m=vuzero
    OpenPLi-4 Gstreamer 1.6.x (master git) Zero Image
    http://anonymus-ulc.net/index.php?pa...823bd4790c7b52
    http://www.openvix.co.uk/openvix-builds/Vu+Zero/
    VU+ Uno : OpenPLi 4.0 with IPTV (More than 800+ IPTV FREE Channels) by MastaG and Japhar Team
    VU+ : OpenPLi 4.0 with IPTV (More than 800+ IPTV FREE Channels) by MastaG and Japhar Team
    Users running the previous Gstreamer 1.7.0 image, should be able to peform a Software Update!
    Changes since previous release:
    - mx3L's gstreamer revert which fixes mp4 playback from remote locations
    - Spark drivers updated to 20151113
    - Using aio-grab from oe-alliance which includes fixes for sprak receivers
    - New Japhar IPTV List (thanks to ToySoft).
    - DM8000 has no more gsod's now (thanks to ToySoft for testing!)
    Changes compared to openpli-oe-core gst-1:
    - Ships with gstreamer upstream master git:
    Using the same patches as openpli-oe-core gst-1 with only these changes:
    Removed: 0001-baseparse-post-tag-list-when-avg-bitrate-changes-at-.patch
    because this patch was already checked in upstream.
    Added: 0001-Revert-qtdemux-respect-qt-segments-in-push-mode-for-.patch
    By mx3L which fixes mp4 playback from remote locations.
    - Every receiver uses christophecvr's multibox dvbmediasink.
    - Using libtrmp and rtmpdump from oe-alliance.
    - Some small enigma2 patches for Dreambox receivers (ac3/dts bypass and blanking on zap support).
    These are only applied for Dreambox receivers.
    - AAC to AC3 transcoding V2 by mx3L (requires a fast cpu).
    - IPTV Player from samsamsam included (thx to Athoik for the recipe).
    - Large list of public IPTV streams included thanks to the Japhar Team.
    - Updated libcdio and cdtextinfo for audio-cd support by christophecvr.
    - DM800Se, DM7020HD and DM800SeV2 driver upgraded to 20151201:
    added si2166b blindscan support
    - Spark images includes the pti.ko from OpenATV so softcam's should work now.
    - Using aio-grab source from oe-alliance which includes fixes for spark receivers.
    - The 2.6.18 kernel will now always pass the vermagic check when loading modules.
    Now you can try and load any kernel driver from OE1.5 to 2.0.
    Known issues:
    - DM800 first boot will take a while, please be patient. The next boot will be faster.
    - On spark/spark7162 you need to set 'boxtype = dreambox' for oscam dvbapi.
    We're using the OE-A drivers and 'duckbox' doesn't seem to work on these.
    - On spark/spark7162 you need to set a skin which doesn't resize the framebuffer.
    Because sometimes it doesn't scale back to fullscreen.
    I've included the MX-HQ7 skin for use as workaround.
    - On Zgemma Star you cannot use fullHD skins.
    This is a hardware/driver limitation.
    Please don't try it, it will crash enigma2.
    - Some Dreambox remotes behave very sensitive.
    This causes button presses to register multiple times instead of just once.
    As a workaround you can adjust the key interval:
    Go to: Menu - System - Input devices - dreambox remote control (native).
    Set "Change repeat and delay settings" to yes
    Set "Interval between keys when repeating:" to 200ms or 300ms.
    Press green button (OK)
    Now set the same delay for: "dreambox advanced remote control (native)" as well.
    To find the download link, search for MastaG Japhar OpenPLi 4.0
    Enjoy !
    https://mega.nz/#!il1kGDKI!Y5XbQAY3g...v-mJb5GUvA9CzU
    Thumbs up VU+rudream-4-------VU+ Zero Image-----16.12.2015
