Results 1 to 9 of 9
Thread: OSCAM - OpenWrt
    19 Aug 2011
    UTC+13
    Default OSCAM - OpenWrt
    De azi dimi neata ma zbat sa compilez, in simplebuild, un oscam pentru un Buffalo WZR-HP-G300NH.
    Din ceva cauza, nu vrea sa plece nici daca ii dau in cap.
    Momentan ma chinui cu aceasta compilare:
    Code:
    +-------------------------------------------------------------------------------| OSCam ver: 1.20-unstable_svn rev: 10012 target: mips-openwrt-linux-uclibc-libusb
    | Tools:
    |  CROSS    = /opt/simplebuild/toolchains/tplink_backfire/bin/mips-openwrt-linux-uclibc-
    |  CC       = /opt/simplebuild/toolchains/tplink_backfire/bin/mips-openwrt-linux-uclibc-gcc
    | Settings:
    |  CONF_DIR = /usr/local/etc
    |  CC_OPTS  = -Os -ggdb -pipe -ffunction-sections -fdata-sections
    |  CC_WARN  = -w
    |  CFLAGS   = -DWITH_LIBUSB=1
    |  LDFLAGS  = -Wl,--gc-sections -DWITH_LIBUSB=1 -Wl,-rpath,/lib -Wl,-rpath,/usr/local/lib -Wl,-rpath,/usr/lib -L/opt/simplebuild/toolchains/tplink_backfire/lib
    |  LIBS     = -lusb-1.0 -lrt -lpthread -ldl -lrt
    |  UseFlags = USE_LIBUSB=1
    | Config:
    |  Addons   : WEBIF WEBIF_LIVELOG WEBIF_JQUERY TOUCH HAVE_DVBAPI IRDETO_GUESSING CS_ANTICASC WITH_DEBUG MODULE_MONITOR WITH_LB CS_CACHEEX CW_CYCLE_CHECK CLOCKFIX WITH_EMU
    |  Protocols: CAMD35 CAMD35_TCP NEWCAMD CCCAM CCCSHARE CONSTCW
    |  Readers  : NAGRA IRDETO CONAX CRYPTOWORKS SECA VIACCESS VIDEOGUARD
    |  CardRdrs : PHOENIX SMARGO SMARTREADER
    |  Compiler : mips-openwrt-linux-uclibc-gcc (GCC) 4.3.3
    |  Binary   : ../archiv/oscam-svn10012-tplink_backfire-webif-libusb-oscam-emu-patched
    Am incercat sa bifez, debifez, rebifez multe, dar nu vrea sa plece nicicum.
    Ceva pareri?
    muta sobolanu` de aici
    14 Jun 2008
    Ro
    Vad ca vrei sa-l faci cu patch. L-ai pus pe ultimul? Incearca prima data sa vezi daca reusesti fara emu. Eu am facut pe Debian in VM pt raspi, pt sh4 si pt Asus WL 500 gpv2(Tomato+optware) , toate cu emu si n-am avut probleme.
    19 Aug 2011
    UTC+13
    Nu am incercat fara patch. Incerc acum.
    Si eu sunt cu VM (ubuntu).
    ---------- Post added at 19:00 ---------- Previous post was at 17:02 ----------
    ...fara succes
    RSP Enigma Team & GM
    04 Feb 2007
    Daca nu te descurci , gata muncit un open-wrt cu toate cele inclusiv watchdog pentru oscam ai pe situl asta:http://www.digital-eliteboard.com/33...e-gesucht.html cu download de aici :http://oscamwrt.mooo.com/wrt/testing/ar71xx/.
    Eu il folosesc de ceva vreme si raman surprins de stabilitatea pe care o are pe un DIR825 .
    Daca te ajuta aici ai oscam compilat :http://oscamwrt.mooo.com/wrt/testing/ar71xx/packages/
    Sper sa te ajute si deasemenea sper ca nu am incalcat regulamentu postand link extern.
    f11
    14 Jun 2008
    Ro
    Am facut eu un bin. Testeaza-l.
    19 Aug 2011
    UTC+13
    f11, mersi de idei/linkuri, le-am epuizat.
    Am instalat acele resurse. Nu prea vreau sa instalez imagini neoficiale, mai ales cosmetizate in acest sens.
    Am adaugat oscamwrt.mooo.com/..... la lista de pachete din router, am instalat acel oscam, cu acela functioneaza. Dar eu il vreau pe cel compilat de mine.
    Relysat, mersi de link, eset smart security blocheaza fileshare, ca fiin nesigur. Ma voi ocupa de el, putin mai tarziu, in cel mai rau caz maine. Cu ce l-ai compilat? simplebuild?
    Daca nu voi avea succes, voi ramane la ipk-urile de pe oscamwrt.mooo.com + watchdog.
    19 Aug 2011
    UTC+13
    M-am saturat de Buffalo, i-am dat altceva de lucru, si am scos WDR4300 de la naftalina.
    Am instalat openwrt, am pus oscamu, watchdog, etc, dar asta nu vede niciun USB in /dev/
    Cititorul il recunoaste:
    root@tplink:~# lsusb
    Bus 1 Device 1: ID 1d6b:0002 Linux 3.10.49 ehci_hcd EHCI Host Controller
    Bus 1 Device 2: ID 05e3:0608
    Bus 1 Device 4: ID 0403:6001 Reader Serial gefunden (mouse) == AH01B841
    root@tplink:~# dmesg | grep usb
    [ 4.620000] usbcore: registered new interface driver usbfs
    [ 4.630000] usbcore: registered new interface driver hub
    [ 4.630000] usbcore: registered new device driver usb
    [ 5.070000] usb 1-1: new high-speed USB device number 2 using ehci-platform
    [ 5.510000] usb 1-1.1: new full-speed USB device number 3 using ehci-platform
    [ 1756.610000] usb 1-1.1: USB disconnect, device number 3
    [ 1759.660000] usb 1-1.1: new full-speed USB device number 4 using ehci-platform
    si aici incepe distractia:
    root@tplink:~# cat /proc/bus/usb/devices
    cat: can't open '/proc/bus/usb/devices': No such file or directory
    Idei?
    ---------- Post added at 15:15 ---------- Previous post was at 14:39 ----------
    rezolvat instaland kmod-usb-serial-option.
