Asta imi apare din Putty:
Board: STx7111-Mboard (MB618) [32-bit mode]
info: Disregarding any EPLD
U-Boot 1.3.1 (Nov 15 2010 - 17:57:53) - stm23_0043 - YW 1.0.018 Rel
DRAM: 128 MiB
NOR: 8 MiB
NAND: 512 MiB
In: serial
Out: serial
Err: serial
IdentID : 09 00 0a 00 00 1f f8
Hit ESC to stop autoboot: 3
Force command mode:Select boot (current boot system : enigma2):
1. spark(up key)
2. enigma2(down key)
3. RS232 Upgrade u-boot(left key)
4. Force into factory mode(right key)
Input Select:
Force rs232 upgrade u-boot, need 524288 Bytes(512kB)
## Ready for binary (ymodem) download to 0x80000000 at 115200 bps...
CCCCCCCCCCTimed out
xyzModem - Cksum mode, 0(SOH)/0(STX)/0(CAN) packets, 20 retries
## Total Size = 0x00000000 = 0 Bytes
Transmit filesize is 0, please check your choiced file
Daca il pornesc normal asta imi apara in Putty
DRAM: 128 MiB
NOR: 8 MiB
NAND: 512 MiB
In: serial
Out: serial
Err: serial
Hit ESC to stop autoboot: 0
## Booting image at a0080000 ...
Image Name: Kernel-Ramdisk-Image
Image Type: SuperH Linux Multi-File Image (gzip compressed)
Data Size: 5867343 Bytes = 5.6 MiB
Load Address: 80800000
Entry Point: 80801000
Contents:
Image 0: 2970211 Bytes = 2.8 MiB
Image 1: 2897119 Bytes = 2.8 MiB
Verifying Checksum ... Bad Data CRC
CCCCCCCCCCTimed out
ff bigphysarea=4000
