Page 2 of 2 FirstFirst 12
Results 16 to 28 of 28
Thread: Amiko Alien 1 blocat la LOAD
    Doar aceste 3 fire sunt strict necesare. Faci log cu putty. 9600 8 n1 parca
    30 Mar 2010
    Asta imi apare din Putty:
    Board: STx7111-Mboard (MB618) [32-bit mode]
    info: Disregarding any EPLD
    U-Boot 1.3.1 (Nov 15 2010 - 17:57:53) - stm23_0043 - YW 1.0.018 Rel
    DRAM: 128 MiB
    NOR: 8 MiB
    NAND: 512 MiB
    In: serial
    Out: serial
    Err: serial
    IdentID : 09 00 0a 00 00 1f f8
    Hit ESC to stop autoboot: 3
    Force command mode:Select boot (current boot system : enigma2):
    1. spark(up key)
    2. enigma2(down key)
    3. RS232 Upgrade u-boot(left key)
    4. Force into factory mode(right key)
    Input Select:
    Force rs232 upgrade u-boot, need 524288 Bytes(512kB)
    ## Ready for binary (ymodem) download to 0x80000000 at 115200 bps...
    CCCCCCCCCCTimed out
    xyzModem - Cksum mode, 0(SOH)/0(STX)/0(CAN) packets, 20 retries
    ## Total Size = 0x00000000 = 0 Bytes
    Transmit filesize is 0, please check your choiced file
    Daca il pornesc normal asta imi apara in Putty
    DRAM: 128 MiB
    NOR: 8 MiB
    NAND: 512 MiB
    In: serial
    Out: serial
    Err: serial
    Hit ESC to stop autoboot: 0
    ## Booting image at a0080000 ...
    Image Name: Kernel-Ramdisk-Image
    Image Type: SuperH Linux Multi-File Image (gzip compressed)
    Data Size: 5867343 Bytes = 5.6 MiB
    Load Address: 80800000
    Entry Point: 80801000
    Contents:
    Image 0: 2970211 Bytes = 2.8 MiB
    Image 1: 2897119 Bytes = 2.8 MiB
    Verifying Checksum ... Bad Data CRC
    CCCCCCCCCCTimed out
    Vezi ce faci cu 3 !!!!
    Asa il strici!
    ---------- Post added at 19:36 ---------- Previous post was at 19:36 ----------
    Opreste boot-ul si da comanda "printenv" .
    30 Mar 2010
    cum opresc boot-ul? daca apas esc imi apare un meniu cu optiuni update uboot update kernel update rootfs exit boot reset loader
    30 Mar 2010
    MB618> "printenv"
    bootdelay=3
    baudrate=115200
    board=mb618
    monitor_base=0xA0000000
    monitor_len=0x00080000
    monitor_sec=0xa0000000 0xa007ffff
    load_addr=0x80000000
    unprot=protect off $monitor_sec
    update=protect off $monitor_sec;erase $monitor_sec;cp.b $load_addr $monitor_base $monitor_len;protect on $monitor_sec
    HOSTNAME=LINUX7109
    ethaddr=00:80:E1:12:06:38
    ipaddr=192.168.40.63
    netmask=255.255.255.0
    gatewayip=192.168.3.1
    serverip=192.168.40.19
    kernel_base_spark= 0xa0080000
    kernel_base_enigma2=0x18000000
    kernel_sec= a0080000 a077ffff
    kernel_len= 0x00700000
    update_kernel=protect off a0080000 a077ffff ;erase a0080000 a077ffff ;cp.b 0x80000000 0xa0080000 0x00700000 ;protect on a0080000 a077ffff
    rootfs_base=0xa0800000
    rootfs_sec=a0800000 a1ffffff
    menucmd=update
    tftp_kernel_name_spark=mImage
    tftp_kernel_name_enigma2=uImage
    tftp_userfs_name_spark=userfsub.img
    tftp_userfs_name_enigma2=e2jffs2.img
    kernel_name_spark=spark/mImage
    kernel_name_enigma2=enigma2/uImage
    userfs_name_spark=spark/userfsub.img
    userfs_name_enigma2=enigma2/e2jffs2.img
    userfs_base_spark=800000
    userfs_base_enigma2=18800000
    userfs_len_spark=17800000
    userfs_len_enigma2=7700000
    kernelnfspath=192.168.40.19:/opt/target
    rootfs_name=UserFS
    rootfsnfspath=192.168.40.19:/home/d22cj/workspace/target
    uboot_name=u-boot.bin
    ubootnfspath=192.168.40.19:/home/d22cj/workspace/target
    bootfromnfs=nfs a4000000 $kernelnfspath/$kernel_name;bootm a4000000
    bootargs_nfs=console=ttyAS0,115200 nwhwconf=device:eth0,hwaddr:00:80:E1:12:40:61 stmmaceth=msglvl:0,phyaddr:1:watchdog:5000 root=/dev/nfs nfsroot=192.168.40.19:/opt/target,nfsvers=2,rsize=4096,wsize=8192,tcp rw ip=192.168.40.61:192.168.40.19:192.168.3.1:255.255.0.0:LINUX7109:eth0ff bigphysarea=4000
    bootargs_flash=console=ttyAS0,115200 rw ramdisk_size=6144 init=/linuxrc root=/dev/ram0 nwhwconf=device:eth0,hwaddr:00:80:E1:12:40:69 ip=192.168.0.69:192.168.3.119:192.168.3.1:255.255.0.0:lh:eth0ff stmmaceth=msglvl:0,phyaddr:1,watchdog:5000 bigphysarea=4000
    bootargs_spark=console=ttyAS1,115200 rw ramdisk_size=6144 init=/linuxrc root=/dev/ram0 nwhwconf=device:eth0,hwaddr:00:80:E1:12:40:69 ip=192.168.0.69:192.168.3.119:192.168.3.1:255.255.0.0:lh:eth0ff stmmaceth=msglvl:0,phyaddr:1,watchdog:5000 bigphysarea=4000
    bootargs_enigma2=console=ttyAS0,115200 root=/dev/mtdblock6 rootfstype=jffs2 rw init=/bin/devinit coprocessor_mem=4m@0x40000000,4m@0x40400000 printk=1 nwhwconf=device:eth0,hwaddr:00:80:E1:12:40:61 rw ip=172.100.100.249:172.100.100.174:172.100.100.174:255.255.0.0:LINUX7109:eth0ff bigphysarea=6000 stmmaceth=msglvl:0,phyaddr:2,watchdog:5000
    magic_version=1.7
    filesize=4000000
    fuseburned=true
    bootargs=console=ttyAS1,115200 rw ramdisk_size=6144 init=/linuxrc root=/dev/ram0 nwhwconf=device:eth0,hwaddr:00:80:E1:12:40:69 ip=192.168.0.69:192.168.3.119:192.168.3.1:255.255.0.0:lh:eth0ff stmmaceth=msglvl:0,phyaddr:1,watchdog:5000 bigphysarea=4000
    kernel_base= 0xa0080000
    kernel_name=spark/mImage
    userfs_name=spark/userfsub.img
    tftp_kernel_name=mImage
    tftp_userfs_name=userfsub.img
    userfs_len=17800000
    userfs_base=800000
    boot_system=spark
    bootcmd=bootm 0xa0080000
    stdin=serial
    stdout=serial
    stderr=serial
    Environment size: 3127/131068 bytes
    Asta nu cred ca e normal:
    MB618> mtest
    Testing 80000000 ... 87d00000 (125 MiB):
    Pattern 00000000 Writing... Reading...
    Mem error @ 0x876DFA5C: found 87F0BC90, expected 01DB7E97
    Mem error @ 0x876DFA60: found 876DFA60, expected 01DB7E98
    Mem error @ 0x876DFA64: found 876DFA60, expected 01DB7E99
    Mem error @ 0x876DFA68: found 876DFA60, expected 01DB7E9A
    Mem error @ 0x876DFA6C: found 01DB7E9A, expected 01DB7E9B
    Pattern FFFFFFFF Writing...
    30 Mar 2010
    Se poate formata memoria, asemenea unui stick usb? Sau o pot inlocui, la fel cum inlocuiesti o memorie ram de pc?
    Se mai poate face ceva?
    30 Mar 2010
    Exista 2 versiuni de enigma 2 (Flash si USB), cum pot sa instalez enigma2 pe USB si sa bootez de pe stick, nu sa o incarce in Flash?
    Trebuie sa modifici parametrii de boot.
    30 Mar 2010
    Un link/tutorial ?
    Multumesc.
    Standard RSP member giku fredolin's Avatar
    20 Feb 2009
    ROMANIA
    Descarca prietene fisierul de la postul nr: 6 al meu si scrie acolo tot ce trebuie sa faci la punctul 2.6 ...succes !
    Dupa ce mai inveti cu u-boot gasesti aici cum faci sa plece de pe stick !
    E foarte riscant !
    20 Feb 2009
    ROMANIA
    Totul este riscant In viata ..fara a risca nu poti rezolva nimic !!!
