Dislikes:
- Rep Power
- 58
satellites.xml personalizat
Daca aveti nevoie de acest fisier la zi, adaptat doar pentru sateliti pe care ii receptionati !
Fisierul va incarca spatiul din folderul "var" , doar cu datele care va sunt utile si la zi !
Daca threadul e inutil , rog un moderator sa-l stearga!
- Rep Power
- 58
-<?xml version="1.0" encoding="iso-8859-1" ?>
<satellites>
- <sat name="Astra 1KR/1L/1M/2C (19.2E)" flags="0" position="192">
<transponder frequency="10729000" symbol_rate="22000000" polarization="1" fec_inner="2" system="1" modulation="2" />
<transponder frequency="10744000" symbol_rate="22000000" polarization="0" fec_inner="4" system="0" modulation="1" />
<transponder frequency="10758000" symbol_rate="22000000" polarization="1" fec_inner="4" system="0" modulation="1" />
<transponder frequency="10773000" symbol_rate="22000000" polarization="0" fec_inner="3" system="1" modulation="2" />
<transponder frequency="10788000" symbol_rate="22000000" polarization="1" fec_inner="4" system="0" modulation="1" />
<transponder frequency="10803000" symbol_rate="22000000" polarization="0" fec_inner="3" system="1" modulation="2" />
<transponder frequency="10818000" symbol_rate="22000000" polarization="1" fec_inner="2" system="1" modulation="2" />
<transponder frequency="10832000" symbol_rate="22000000" polarization="0" fec_inner="2" system="1" modulation="2" />
<transponder frequency="10847000" symbol_rate="22000000" polarization="1" fec_inner="4" system="0" modulation="1" />
<transponder frequency="10862000" symbol_rate="22000000" polarization="0" fec_inner="5" system="0" modulation="1" />
<transponder frequency="10876000" symbol_rate="22000000" polarization="1" fec_inner="4" system="0" modulation="1" />
<transponder frequency="10891000" symbol_rate="22000000" polarization="0" fec_inner="2" system="1" modulation="2" />
<transponder frequency="10921000" symbol_rate="22000000" polarization="0" fec_inner="5" system="0" modulation="1" />
<transponder frequency="10936000" symbol_rate="22000000" polarization="1" fec_inner="2" system="1" modulation="2" />
<transponder frequency="10979000" symbol_rate="22000000" polarization="1" fec_inner="4" system="0" modulation="1" />
<transponder frequency="11023000" symbol_rate="22000000" polarization="0" fec_inner="4" system="0" modulation="1" />
<transponder frequency="11038000" symbol_rate="22000000" polarization="1" fec_inner="4" system="0" modulation="1" />
<transponder frequency="11053000" symbol_rate="22000000" polarization="0" fec_inner="2" system="1" modulation="2" />
<transponder frequency="11068000" symbol_rate="22000000" polarization="1" fec_inner="4" system="0" modulation="1" />
<transponder frequency="11082000" symbol_rate="22000000" polarization="0" fec_inner="3" system="1" modulation="2" />
<transponder frequency="11097000" symbol_rate="22000000" polarization="1" fec_inner="4" system="0" modulation="1" />
<transponder frequency="11127000" symbol_rate="22000000" polarization="1" fec_inner="2" system="1" modulation="2" />
<transponder frequency="11156000" symbol_rate="22000000" polarization="1" fec_inner="4" system="0" modulation="1" />
<transponder frequency="11186000" symbol_rate="22000000" polarization="1" fec_inner="4" system="0" modulation="1" />
<transponder frequency="11244000" symbol_rate="22000000" polarization="0" fec_inner="4" system="0" modulation="1" />
<transponder frequency="11259000" symbol_rate="22000000" polarization="1" fec_inner="2" system="1" modulation="2" />
<transponder frequency="11288000" symbol_rate="22000000" polarization="1" fec_inner="4" system="1" modulation="2" />
<transponder frequency="11303000" symbol_rate="22000000" polarization="0" fec_inner="2" system="1" modulation="2" />
<transponder frequency="11318000" symbol_rate="22000000" polarization="1" fec_inner="4" system="0" modulation="1" />
<transponder frequency="11332000" symbol_rate="22000000" polarization="0" fec_inner="3" system="1" modulation="2" />
<transponder frequency="11347000" symbol_rate="22000000" polarization="1" fec_inner="2" system="1" modulation="2" />
<transponder frequency="11362000" symbol_rate="22000000" polarization="0" fec_inner="2" system="1" modulation="2" />
<transponder frequency="11377000" symbol_rate="22000000" polarization="1" fec_inner="2" system="1" modulation="2" />
<transponder frequency="11391000" symbol_rate="22000000" polarization="0" fec_inner="4" system="0" modulation="1" />
<transponder frequency="11421000" symbol_rate="22000000" polarization="0" fec_inner="4" system="0" modulation="1" />
<transponder frequency="11436000" symbol_rate="22000000" polarization="1" fec_inner="2" system="1" modulation="2" />
<transponder frequency="11464000" symbol_rate="22000000" polarization="0" fec_inner="2" system="1" modulation="2" />
<transponder frequency="11479000" symbol_rate="22000000" polarization="1" fec_inner="4" system="0" modulation="1" />
<transponder frequency="11494000" symbol_rate="22000000" polarization="0" fec_inner="2" system="1" modulation="2" />
<transponder frequency="11509000" symbol_rate="22000000" polarization="1" fec_inner="4" system="0" modulation="1" />
<transponder frequency="11523000" symbol_rate="22000000" polarization="0" fec_inner="4" system="0" modulation="1" />
<transponder frequency="11538000" symbol_rate="22000000" polarization="1" fec_inner="4" system="0" modulation="1" />
<transponder frequency="11553000" symbol_rate="22000000" polarization="0" fec_inner="3" system="1" modulation="2" />
<transponder frequency="11568000" symbol_rate="22000000" polarization="1" fec_inner="4" system="0" modulation="1" />
<transponder frequency="11582000" symbol_rate="22000000" polarization="0" fec_inner="2" system="1" modulation="2" />
<transponder frequency="11597000" symbol_rate="22000000" polarization="1" fec_inner="4" system="0" modulation="1" />
<transponder frequency="11612000" symbol_rate="22000000" polarization="0" fec_inner="4" system="0" modulation="1" />
<transponder frequency="11627000" symbol_rate="22000000" polarization="1" fec_inner="2" system="1" modulation="2" />
<transponder frequency="11641000" symbol_rate="22000000" polarization="0" fec_inner="4" system="0" modulation="1" />
<transponder frequency="11656000" symbol_rate="22000000" polarization="1" fec_inner="4" system="0" modulation="1" />
<transponder frequency="11671000" symbol_rate="22000000" polarization="0" fec_inner="2" system="1" modulation="2" />
<transponder frequency="11686000" symbol_rate="22000000" polarization="1" fec_inner="4" system="0" modulation="1" />
<transponder frequency="11720000" symbol_rate="27500000" polarization="0" fec_inner="3" system="0" modulation="1" />
<transponder frequency="11739000" symbol_rate="27500000" polarization="1" fec_inner="3" system="0" modulation="1" />
<transponder frequency="11758000" symbol_rate="27500000" polarization="0" fec_inner="3" system="0" modulation="1" />
<transponder frequency="11778000" symbol_rate="27500000" polarization="1" fec_inner="3" system="0" modulation="1" />
<transponder frequency="11798000" symbol_rate="27500000" polarization="0" fec_inner="3" system="0" modulation="1" />
<transponder frequency="11817000" symbol_rate="29700000" polarization="1" fec_inner="2" system="1" modulation="2" />
<transponder frequency="11836000" symbol_rate="27500000" polarization="0" fec_inner="3" system="0" modulation="1" />
<transponder frequency="11856000" symbol_rate="27500000" polarization="1" fec_inner="3" system="0" modulation="1" />
<transponder frequency="11876000" symbol_rate="27500000" polarization="0" fec_inner="3" system="1" modulation="2" />
<transponder frequency="11895000" symbol_rate="27500000" polarization="1" fec_inner="3" system="0" modulation="1" />
<transponder frequency="11914000" symbol_rate="27500000" polarization="0" fec_inner="9" system="1" modulation="1" />
<transponder frequency="11934000" symbol_rate="27500000" polarization="1" fec_inner="3" system="0" modulation="1" />
<transponder frequency="11954000" symbol_rate="27500000" polarization="0" fec_inner="3" system="0" modulation="1" />
<transponder frequency="11973000" symbol_rate="27500000" polarization="1" fec_inner="3" system="0" modulation="1" />
<transponder frequency="11992000" symbol_rate="27500000" polarization="0" fec_inner="9" system="1" modulation="1" />
<transponder frequency="12012000" symbol_rate="29700000" polarization="1" fec_inner="2" system="1" modulation="2" />
<transponder frequency="12032000" symbol_rate="27500000" polarization="0" fec_inner="3" system="0" modulation="1" />
<transponder frequency="12051000" symbol_rate="27500000" polarization="1" fec_inner="3" system="0" modulation="1" />
<transponder frequency="12070000" symbol_rate="27500000" polarization="0" fec_inner="3" system="0" modulation="1" />
<transponder frequency="12090000" symbol_rate="29700000" polarization="1" fec_inner="2" system="1" modulation="2" />
<transponder frequency="12110000" symbol_rate="27500000" polarization="0" fec_inner="3" system="0" modulation="1" />
<transponder frequency="12129000" symbol_rate="29700000" polarization="1" fec_inner="2" system="1" modulation="2" />
<transponder frequency="12148000" symbol_rate="27500000" polarization="0" fec_inner="3" system="0" modulation="1" />
<transponder frequency="12168000" symbol_rate="29700000" polarization="1" fec_inner="2" system="1" modulation="2" />
<transponder frequency="12188000" symbol_rate="27500000" polarization="0" fec_inner="3" system="0" modulation="1" />
<transponder frequency="12207000" symbol_rate="29700000" polarization="1" fec_inner="2" system="1" modulation="2" />
<transponder frequency="12226000" symbol_rate="27500000" polarization="0" fec_inner="3" system="0" modulation="1" />
<transponder frequency="12246000" symbol_rate="29700000" polarization="1" fec_inner="2" system="1" modulation="2" />
<transponder frequency="12266000" symbol_rate="27500000" polarization="0" fec_inner="3" system="0" modulation="1" />
<transponder frequency="12285000" symbol_rate="27500000" polarization="1" fec_inner="3" system="0" modulation="1" />
<transponder frequency="12304000" symbol_rate="27500000" polarization="0" fec_inner="9" system="1" modulation="1" />
<transponder frequency="12324000" symbol_rate="27500000" polarization="1" fec_inner="3" system="0" modulation="1" />
<transponder frequency="12363000" symbol_rate="27500000" polarization="1" fec_inner="3" system="0" modulation="1" />
<transponder frequency="12382000" symbol_rate="27500000" polarization="0" fec_inner="9" system="1" modulation="1" />
<transponder frequency="12402000" symbol_rate="27500000" polarization="1" fec_inner="3" system="0" modulation="1" />
<transponder frequency="12422000" symbol_rate="27500000" polarization="0" fec_inner="3" system="0" modulation="1" />
<transponder frequency="12441000" symbol_rate="29700000" polarization="1" fec_inner="2" system="1" modulation="2" />
<transponder frequency="12460000" symbol_rate="27500000" polarization="0" fec_inner="3" system="0" modulation="1" />
<transponder frequency="12480000" symbol_rate="27500000" polarization="1" fec_inner="3" system="0" modulation="1" />
<transponder frequency="12515000" symbol_rate="22000000" polarization="0" fec_inner="4" system="0" modulation="1" />
<transponder frequency="12522000" symbol_rate="22000000" polarization="1" fec_inner="4" system="0" modulation="1" />
<transponder frequency="12545000" symbol_rate="22000000" polarization="0" fec_inner="4" system="0" modulation="1" />
<transponder frequency="12552000" symbol_rate="22000000" polarization="1" fec_inner="4" system="0" modulation="1" />
<transponder frequency="12574000" symbol_rate="22000000" polarization="0" fec_inner="2" system="1" modulation="2" />
<transponder frequency="12581000" symbol_rate="22000000" polarization="1" fec_inner="4" system="0" modulation="1" />
<transponder frequency="12604000" symbol_rate="22000000" polarization="0" fec_inner="4" system="0" modulation="1" />
<transponder frequency="12610000" symbol_rate="22000000" polarization="1" fec_inner="4" system="0" modulation="1" />
<transponder frequency="12633000" symbol_rate="22000000" polarization="0" fec_inner="4" system="0" modulation="1" />
<transponder frequency="12640000" symbol_rate="22000000" polarization="1" fec_inner="4" system="0" modulation="1" />
<transponder frequency="12663000" symbol_rate="22000000" polarization="0" fec_inner="4" system="0" modulation="1" />
<transponder frequency="12670000" symbol_rate="22000000" polarization="1" fec_inner="2" system="1" modulation="2" />
<transponder frequency="12692000" symbol_rate="22000000" polarization="0" fec_inner="4" system="0" modulation="1" />
<transponder frequency="12699000" symbol_rate="22000000" polarization="1" fec_inner="4" system="0" modulation="1" />
<transponder frequency="12722000" symbol_rate="22000000" polarization="0" fec_inner="3" system="1" modulation="2" />
<transponder frequency="12728000" symbol_rate="22000000" polarization="1" fec_inner="4" system="0" modulation="1" />
<transponder frequency="18359000" symbol_rate="6890000" polarization="0" fec_inner="3" system="1" modulation="1" />
<transponder frequency="18366000" symbol_rate="15000000" polarization="1" fec_inner="1" system="1" modulation="1" />
<transponder frequency="18754000" symbol_rate="4500000" polarization="0" fec_inner="3" system="0" modulation="1" />
<transponder frequency="18760000" symbol_rate="4875000" polarization="0" fec_inner="2" system="0" modulation="1" />
</sat>
</satellites>
Asta este pentru astra 19,2 E , pe data de 03 februarie 2014
Asta este o parte din ce-am vrut sa spun!
---------- Post added at 23:08 ---------- Previous post was at 22:46 ----------
Nu pot posta pentru mai multi sateliti intr-un singur post.
Daca aveti nevoie, pot sa va trimit fisierul satelites.xml , la zi, in orice combinatie de sateliti.
Eşti foarte amabil waynejames, mulţumim.
Noi de regulă downloadăm de aici: satellites-xml.eu, satellites-xml.org, etc
