Black Hole 2.0.9
What is new ?
New bootlogo by mikark
Add option: "Preferred tuner" Available in menu->setup->system->customise (Expert mode). Configure which tuner will be preferred, when more than one tuner is available. If set to 'auto' the system will give priority to the tuner having the lowest number of channels/satellites.
Black Hole weather: switch to msn provider to fix bug when town not found and implement auto-langauge.
Teletext: Update to the latest tuxtxt version (this fix rai hd televideo too)
[hbbtv] updates:
1. works for compatibility.
2. enhancement for seek on VOD.
3. fix setDemension.
[hbbtv/youtubetv] improvement player to stable.
switch to black-hole-aio-grab and fix bug in grab picture with pig
hbbtv/browser updated.
- support seek at ARD Mediatek.
- fix video playback bugs at Tagesschau.
set dvbaudiosink caps to support mpeg 4 profile LC and apply relevant patches.
dvbapp : append gst-plugins-bad-faad on RDEPENDS.
[hbbtv] fix ait handling and transparency.
update driver
20131230
- Fix dual tuner problem(duo2)
[hbbtv] changed ait handle
servicemp3 : fix getSubtitleType
servicemp3 : fix wrong playing time.
[hbbtv] fix zapping delay from ait handling.
[hbbtv/youtubetv] fixed volume control bug.
[hbbtv] fixed a wrong red-button url bug.
[hbbtv] works for compatibility
[hbbtv] fix playing live stream after vod stop
[hbbtv] fix check vuplus
[hbbtv] fix crash restart after installation.
remove useless initialization.
WARNING: This Image has the latest drivers and CAN NOT be installed in multiboot. The image MUST be installed in flash.
- Integrated OpenEpg
- Rytec dedicated epg.dat
- New system epg.dat outside.
Download EPG from any channel
Yellow button = Audio menu
Addons
Infobar / OSD
Analog Clock Gui
Channel orbital location
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Black Hole Speed Up
Devices Manager
Usb Format Wizard
Telnet Panel ( Telnet Panel)
FTP Panel ( FTP Panel)
UPnP Client Djmount
UPnP Server Mediatomb
UpnP Server Minidlna
Pcsc Panel
Tuner Server
Network Browse & Mountpoints
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Online Feeds Settings update
Red Panel
BlackHole
Avalon
Chaos
Ghost
Credits
Thanks to Littlesat and Pli Team for the original autolanguage and subtitle options code
DISCLAIMER
LICENSE (TERM OF USE)
Code:
http://www.multiupload.nl/UNB5KJGA9J
Dislikes:
