Page 3 of 4 FirstFirst 1234 LastLast
Results 31 to 45 of 58
Thread: Oscam - emu
  1. #31
    S-a reluat munca la OSEMU:
    October 2017 update (revised)
    As of October 2017 the BISS code has been greatly improved.
    The old code distinguished channels only by using the service id (sid) and any one of the ecm pid (which for 99.99% of the channels is the same) or the channel's video and audio pids. As a result there were too many key clashes in the SoftCam.Key file. These formal (legacy) methods of channel identification remain in the new code as well for backwards compatibility and for those users that have a small number of keys in their SoftCam.Key and don't experience collisions. This way no editing is needed for the SoftCam.Key to work with the revised BISS code.
    The revised code makes key searches based on crc32 hashes. There are two different hashes available:
    The namespace hash, which is calculated by the enigma2 namespace (orbital position, frequency, polarization) and the service id of the channel. These two alone are enough to create a unique channel identifier.
    There's also a universal hash, which is calculated using every pid of the channel (service id, pmt, video and audio pids). This universal hash, while not being unique as the namespace hash, is available on every box (enigma and non-enigma) and is a better alternative than oscam's constant cw protocol, since it takes audio pids into account, as well.
    Using hashes to match keys, we get a distinct (unique in the case of namespace hash) identifier for each channel, which makes OSCam-Emu ideal for descrambling not only a huge amount of regular channels, but also for occasional transmitions (feeds).
  2. #32
    12 Mar 2013
    Va rog un oscam emu pentru raspberry pi3,si cum pot sa-l pun, ce comenzi trebuiesc.
    Multumesc.
  3. #33
    08 Feb 2014
    @xrm
    aici ai unul compilat la zi cu tot ce-ti trebuie.
    folderul de config e in /usr/local/etc/
    extragi arhiva, il redenumesti in oscam, si il pui in /usr/bin/
    Din consola , sub root, executi
    chmod 755 /usr/bin/oscam
    apt update && apt upgrade
    apt install libusb-1.0 libssl-dev libpcsclite1 libpcsclite-dev nano
    Aici gasesti informatii despre cum sa-ti creezi un script systemd.
    De configurat ... fiecare are propriul lui server si la fiecare e altfel ... citeste aici
  4. #34
    12 Mar 2013
    Ok, multumesc.
    Mai am o intrebare:
    cum sterg vechiul oscam(normal) de pe raspberry pi3,ca sa-l adaug pe acesta?
  5. #35
    08 Feb 2014
    Il cauti unde este executabilul, il redenumesti la fel si il pui peste.
    Locatia probabila este in /usr/bin/ sau in /usr/local/bin/
    Cel mai usor cauti in service /etc/init.d/oscam (asta daca ai sysvinit)
  6. #36
    Standard RSP member alex07's Avatar
    12 Nov 2007
    Salutare, utimele versiuni de oscam nu au CacheEX, din cate am citit trebuie compilat oscam-ul lucru la care nu ma pricep, poate compila cineva o versiune si sa o puna pe site.
    Multumesc !
  7. #37
    18 Nov 2018
    depinde de cine a compilat aceea versiune, posibil sa fie o versiune lite. am rugamintea sa specifici si arhitectura pentru care doresti oscam-ul.
    Птицы ночи, где вы не ожидаете, я там.
  8. #38
    07 Sep 2013
    https://t.me/blackhatshiller
    are integrate prajiturile sau are nevoie de softcam.key?
    eu am pus separat osemu + reader in oscam din el....
    RSR Cache Blaster!
  9. #39
    05 Oct 2016
    Petrosani
    Salut... si Hristos a Inviat! de o saptamana ,ma lovesc de o problema. Am un Octgon sf8008 cu o imagine Openatv 6.2 .Si OSCam r11517-795.
    Scriu linia cccam [in oscam] readers, o salvez, se salveaza, dar nu se conecteaza, nu deschide....un ajutor va rog. Mentionez ca sunt novice in oscam. Dar promit ca o sa-mi pierd toata vara cu el. Multumesc pentru orice sfat!Chiar si in pm. va rog!
  10. #40
    Default Oscam - emu
    Foloseşte interfaţa web a Oscamului, şi va fi mai uşor.
  11. #41
    09 Apr 2007
    Am si eu o intrebare pentru cunoscatori. Am instalat ultima versiune de oscam emu. Am pus un softcam pt power vu key de pe 0.8W. A mers ok cateva zile apoi s-a oprit. Presupun ca s-au schimbat cheile. Emulatorul din oscam pt power face AU la Power VU? Trebuie facuta o setare speciala sau trebuie de fiecare data sa caut un softcam cu key actualizate? Sau trebuie sa activez ceva din oscam pt AU?
    Astea sunt setarile de reader:
    [reader]
    label = emulator
    description = emulator
    protocol = emu
    device = emulator
    disablecrccws_only_for = 0E00:000000
    caid = 0500,0604,0E00,1010,1801,2600,2602,2610
    detect = cd
    ident = 0500:000000,007400,007800,021110,023800;0604:000000;0E00:000000;1010:000000;1801:000000,001101,00211 1,007301;2600:000000;2602:000000;2610:000000
    group = 5
    emmcache = 2,1,2,1
    emu_auproviders = 0604:010200;0E00:000000;1010:000000;2610:000000
    [reader]
    label = SoftCam
    description = SoftCam
    protocol = emu
    device = /etc/tuxbox/config/SoftCam.Key
    caid = 090F,0500,1801,0604,2600,FFFF,0E00,4AE1,1010
    detect = cd
    ident = 090F:000000;0500:000000,023800,021110,007400,007800;1801:000000,007301,001101,002111;0604:000000;260 0:000000;FFFF:000000;0E00:000000;4AE1:000011,000014,0000FE;1010:000000
    group = 4
    multumesc
  12. #42
    16 Feb 2015
    Salutare
    Cine ma ajuta si pe mine....In ce varianta de Oscam sau Cccam merge Cartela de Zaharos Ro 39e si pe ce configuratie? ....Multumesc anticipat si Sanatate Maxima!!!!
  13. #43
    Pe forum subiectul e inchis, NU MERGE!
    Zvonuri "e" multe, prietenii te recomanda.
  14. #44
    17 Jan 2008
    Buna seara, CRACIUN FERICIT tuturor.
    Am nevoie de putin ajutor referitor la setarile oscam.
    Am un receptor Amiko VIPER 4K combo. Am tot cautat si incercat diferite variante pentru a seta oscam ca atunci cand deschid un un canal dvb-c sa deschida din softcam, nu dintr-o linie a unui partener.
    Multumesc .
  15. #45
    Adauga un reader-emu si softcam
