Thanks Thanks:  63
Likes Likes:  33
Results 1 to 15 of 46
Thread: Noutati la DUCKBOX GIT
    Default Noutati la DUCKBOX GIT
    In acest topic anuntam noutati la GIT-ul SH40.
    Incepand de azi se pot genera imagini folosind media framework astfel:
    1) eplayer3
    2) gstreamer
    3) use build-in
    4) gstreamer+eplayer3
    Ca noutate a aparut 4), deci noile imagini pot avea simultan gstreamer si eplayer3.
    27 Sep 2007
    Asteptam cu mare nerabdare. Multumim si succes in tot ce faci !
    Standard RSP member giku fredolin's Avatar
    20 Feb 2009
    ROMANIA
    Am o rugaminte Dl-e @zildan,poate compilezi imagine si pentru procesoare 7111 (Alien 1 & Golden media reloaded).
    Si poate inserezi si bootul de trecere din enigma2 direct In Spark !
    Multumim frumos pentru munca dumitale ANTICIPAT si SUCCES !!!
    Dupa ce merge acceptabil pe 7162 trecem la 7111 ... logic.
    25 Nov 2013
    asteptam ! multumim pt efortul depus,eu sant foarte multumit si de imaginea veche care are media playerul bun ,am lumina pe cablu si satelit.
    23 Dec 2012
    hi all
    thank you zildanfor opening this topic
    source for work
    Golden Media reloaded
    Sti 7111
    Spark / Enigma2
    23 Dec 2012
    hello
    i have this priblem
    Code:
    checking for python version... 2.7
    checking for python platform... linux2
    checking for python script directory... ${prefix}/lib/python2.7/site-packages
    checking for python extension module directory... ${exec_prefix}/lib/python2.7/site-packages
    checking for python2.7... (cached) /home/spark7111/Desktop/max-tdt/tdt/tufsbox/host/bin/python
    checking for a version of Python >= '2.1.0'... yes
    checking for the distutils Python package... yes
    checking for Python include path... -I/home/spark7111/Desktop/max-tdt/tdt/tufsbox/cdkroot/usr/include/python2.7
    checking for Python library path... -L/home/spark7111/Desktop/max-tdt/tdt/tufsbox/cdkroot/usr/include/python2.7 -lpython2.7
    checking for Python site-packages path... /home/spark7111/Desktop/max-tdt/tdt/tufsbox/cdkroot/usr/lib/python2.7/site-packages
    checking python extra libraries...  -ldl  -lutil
    checking python extra linking flags... -Xlinker -export-dynamic
    checking consistency of all components of python development environment... yes
    checking for swig... /usr/bin/swig
    checking for the pthreads library -lpthreads... no
    checking whether pthreads work without any flags... no
    checking whether pthreads work with -Kthread... no
    checking whether pthreads work with -kthread... no
    checking for the pthreads library -llthread... no
    checking whether pthreads work with -pthread... yes
    checking for joinable pthread attribute... PTHREAD_CREATE_JOINABLE
    checking if more special flags are required for pthreads... no
    checking ost/dmx.h usability... no
    checking ost/dmx.h presence... no
    checking for ost/dmx.h... no
    checking linux/dvb/version.h usability... yes
    checking linux/dvb/version.h presence... yes
    checking for linux/dvb/version.h... yes
    configure: found dvb version 5
    checking pkg-config is at least version 0.9.0... yes
    checking for BASE... no
    configure: error: Package requirements (freetype2 fribidi gstreamer-0.10 gstreamer-pbutils-0.10 libdvbsi++ libpng libxml-2.0 sigc++-1.2 libssl libcrypto) were not met:
    No package 'gstreamer-0.10' found
    No package 'gstreamer-pbutils-0.10' found
    Consider adjusting the PKG_CONFIG_PATH environment variable if you
    installed software in a non-standard prefix.
    Alternatively, you may set the environment variables BASE_CFLAGS
    and BASE_LIBS to avoid the need to call pkg-config.
    See the pkg-config man page for more details.
    make: *** [/home/spark7111/Desktop/max-tdt/tdt/cvs/apps/enigma2-pli-nightly/config.status] Error 1
    spark7111@ubuntu:~/Desktop/max-tdt/tdt/cvs/cdk$
    Sti 7111
    Spark / Enigma2
    Se poate genera imagine la zi OpenPLI cu gstreamer si sau eplayer3.
    Deja am compilat imagine functionala, pana sa fie beta mai e putin de lucru.
    Aparate "clone" Spark7162 pe piata:
    Golden Media Spark Triplex
    Golden Media Spark One
    SAB Unix Triple HD
    Amiko Alien 2
    Galaxy Innovations Avatar 2 und 3
    Visionnet Falcon
    Icecrypt S3700 CHD
    Truman Top Box 2 Tuners
    Am reluat compilarile la Spark7162.
    Sper sa am o imagine beta in scurt timp.
    Am reusit compilarea completa la 7162.
    Cand am timp trec la teste si eventual la generarea imaginii.
    Momentan e complet noua doar partea de linux, drivere etc, partea de e2 e din mai 2013.
    Dupa stabilizare trecem la zi cu E2, pentru asta trebuiesc multe patch-uri.
    Imaginea curata de pe GIT merge satisfacator de cateva ore.
    Urmeaza pasul spre "lumina" si adaptarile RSP.
