1
Dislikes:
Black Hole Vu+ Duo2 2.0.5 galaxy
Black Hole 2.0.5 galaxy
"The Black Hole is expanding in our galaxy.
We need more space..."
Starting from this version, the Black Hole image will fully support an internal hdd larger than 2 TB.
The new initialise function will partition your hdd with optimal alignment and will format it in the linux ext4 filesystem, which will give the best performance.
Warning: Duo2 requires a Cfe upgrade to V2 before you flash this image.
Main changes:
- New Support hdd larger than 2TB
- New Subtitle customisation
- Ttx subtitle font size
- subtitle delay when timing lags
- subtitle delay when timing is bad
- yellow Dvb subtitles
- centered Dvb subtitles
- Dvb subtitles black transparency
- New support for coldboot "Wake on Lan" (Duo2)
- New firmware upgrade option for Vfd controller and Front Processor (Duo2)
- New hotkey for Subtitle window: (2x Yellow button)
Vu+ Drivers updates (duo2):
- Fix WOL problem
- Add proc entry for WOL
- Fix loop-through problem when 2 dual tuners are installed
- Improve VFD controller update(VFD controller update will resolve remote control sensitivity issue)
- Fix Play/Pause key problem
- Support FP update
- Support VFD controller update
- Fix recording problem
- Fix no audio in radio channels
Misc:
- Add Tools/Alternatives
- Add WOLSetup (WakeOnLan) plugin (Duo2)
- Add parted tool to partion and format internal Hdd
- Switch to parted and ext4 in hdd inizailise function
- Change module description from RT2870 to RT3070/3370/5370/5372 and fixed module installation in the correct place
- Add patches for RT3070 ralink driver
- Fix rt5572 driver
- Add some devices not yet included into rt5572 supports
- Add web-manual Duo2
- [HbbTV] fix rtl auth problem
- Add fuse-module and fuse-utils for ntfs-3g
- [Kernel] Solo2 & Duo2: Add Nls modules for other charsets
- [Kernel] Fix flash_erase option on postinst
- [Dvbmediasink] Fix switching between aac and other codecs
- [Gst-plugins-bad] Update SRCREV & patches
- Add checkvfd package
- Added new driver mt7610u (802.11a/b/g/n/ac support)
- Update languages cs, da, fr, sk, sv.
- Integrated OpenEpg
- Rytec dedicated epg.dat
- New system epg.dat outside.
Download EPG from any channel
Yellow button = Audio menu
Addons
Infobar / OSD
Analog Clock Gui
Channel orbital location
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Black Hole Speed Up
Devices Manager
Usb Format Wizard
Telnet Panel ( Telnet Panel)
FTP Panel ( FTP Panel)
UPnP Client Djmount
UPnP Server Mediatomb
UpnP Server Minidlna
Pcsc Panel
Tuner Server
Network Browse & Mountpoints
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Online Feeds Settings update
Red Panel
Black Hole
Avalon
Chaos
Ghost
Credits
Thanks to Littlesat and Pli Team for the original autolanguage and subtitle options code
DISCLAIMER
LICENSE (TERM OF USE)
Download : http://www.mijnbestand.nl/Bestand-SSY4FVXLSJRB.zip
Black Hole 2.0.5 rev. B online upgrade available.
What is new:
- Vu+ drivers update: 20130802 (duo2 solo2)
- Improve occasional sluggish skip problem.
- Change play/pause button's key code to KEY_PLAYPAUSE(duo2)
- Enhance security
- Fix several minor bugs.Fix AGC in dual tuner & Solo2 internal tuner.
- [rtl8192cu] fixed the driver to avoid network lagging during the usage.
- [mt7610u] new driver revision v3.0.0.1 and respective patches included new configuration.
- TransCodingSetup : set defalut bitrate of SOLO2.
