Results 1 to 4 of 4
Thread: Optibox EVO E3HD - Odin E3HD
    23 Apr 2007
    P3X-888
    Default Optibox EVO E3HD - Odin E3HD
    Optibox EVO E3HD este ruda mai saraca a gamei EVO ... sarac in echiparea cu diferiti conectori si prin lipsa afisajului dar la fel de puternic din punct de vedere al chipsetului si al memoriei RAM aparatul fiind "motorizat" de acelasi chipset Broadcom BCM7358 si 512Mb RAM. Receptorul este bine dotat hardware si are deja suport software din partea grupului OE-Alliance si cred ca va prezenta un interes mare tinand cont ca va fi comercializat la un pret de cca 520 ron, asteptam cu interes aparitiei in magazine si eventualele impresii din partea celor ce il vor cumpara.
    Mai multe detalii vom sti in momentul aparitiei in magazine.
    Code:
    MAIN FEATURES:
    - Full HD Digital Hybrid Satellite Receiver and Media Player
    - MIPS CPU - 250Mb Flash Memory
    - Fast and Easy Installation with the Installation Wizard
    - One Card Reader
    - E2 Operating System - Linux Embedded
    - 3D Ready (3D compliant Enigma 2 image installed is required)
    - Two High Speed USB2.0 connections
    - Multimedia Playback (MKV, AVI, MPG, MP4, TS, WMA, MP3 and more...)
    - TimeShifting - Stop live television (USB hard drive required)
    - YouTube videos, Internet Radios and much more...*
    - Internet Streaming TV and Radio support*
    - Ethernet Connection and WiFi / 3G dongle support*
    - Easily expandable with addons and plugins
    - Live Streaming through network*
    - Remote Management through HTTP* / Telnet / SSH / FTP...
    - Media Playback and Recording via local network*
    - External USB DVD drive support*
    - Electronic Program Guide (EPG)
    - Multi-Satellite Controlled with DiSEqC1.0, 1.1, 1.2 and USALS
    - Automatic DiSEqC detection
    - User Friendly Multilanguage On-Screen Display (OSD)
    - High Resolution Graphic User Interface (GUI)
    - Customizable apperiance with Skins
    - NTP - Network Time Protocol
    - Multi-Language - Audio / Teletext / Subtitle - support
    - Easy Software Upgrades through the Internet
    - Full HD HDMI 1.4 Connection
    - Dolby Digital Bit-Stream out via Coaxial S/PDIF and HDMI
    - Fast and Easy software upgrades through USB
    - DC 12V Power Supply
    TECHNICAL SPECIFICATIONS:
    Tuner & Demodulation
    Tuner Type: 1 DVB-S/S2
    Input Connector: F-type, Connector, Female
    Signal Level: -65 to -25 dBm
    LNB Power & Polarization: Vertical: +13V/+14V, Horizontal: +18V/+19V
    Current: Max. 500mA Overload Protection
    22KHz Tone Frequency: 22±1KHz
    DiSEqC Control: Version 1.0, 1.1, 1.2, USALS
    Demodulation: QPSK, 8PSK
    Input Symbol Rate: 2-45 Mbps
    FEC: 1/2, 2/3, 3/4, 5/6, 7/8 and Auto
    MPEG TS A/V Decoding
    Transport Stream: MPEG4, MPEG2
    Profile Level: MPEG2 MP@HL, MPEG4 AVC
    MP@L3, MP@L4, HP@L4
    Video Resolution: 576i, 576p, 720p, 1080i, 1080p
    Aspect Ratio: 4:3, 16:9, Letterbox, Pan&Scan, Zoom
    Audio Decoding: MPEG1 L1/2, MPEG2 L2, AC3
    Dolby Digital plus, PCM with decoded stereo, AAC Stereo
    Audio Mode: Mono, Left, Right, Stereo, Dolby Digital
    System Resources
    CPU: 750 DMIPS Processor
    Flash Memory: NOR 4MB, NAND 256 MB
    DDR: 512 MB
    Power Supply
    Input Voltage: 12V, 2A
    Type: DC power adapter
    Power Consumption: Max. 30W
    10W MAX (Active Standby)
    0.5W MAX (Passive Standby)
    A/V & Data Input/Output
    RCA: Video CVBS, Audio L/R
    USB: 2 ports (USB2.0)
    HDMI: v1.4
    Ethernet: 10/100M
    SPDIF: Optical
    Physical Specifications
    Size[W*H*D]: 210x45x160mm
    Net Weight: Approx. 1.5kg
    Operating Temperature: +5ºC ~ +50ºC
    Storage Temperature: -40ºC ~ +65ºC
    Mai jos avem cateva imagini ale receptorului Optibox EVO E3HD.
    Standard RSP member dark7's Avatar
    31 Dec 2008
    Pe cand astfel de receptoare in magazinele de specialitate?
    23 Apr 2007
    P3X-888
    Se aude ca in curand dar data sigura nu se stie sa speram ca totusi intr-o saptamana doua sa fie in magazine.
    02 Nov 2008
    peste o saptamana pret estimativ 520lei
