- 56
Problem Spark Software
There seems to be with all the spark software `s all brands of a problem.
The server returns wrong data by and here comes the spark software corrupt.
This is due to the weather plugin that gives false data by the recipient and if you reboot or turn off and then the receiver wil not boot on Spark.
temporarily solution remove all cities from the Weatherforecats
within hours ther will be a fix for this Spark software problem. (do not reboot first remove the cities)
