Thanks Thanks:  1
Results 1 to 5 of 5
Thread: Upgrade E2/Spark cu TFTP
    RSP Enigma Team
    28 Aug 2009
    Departe
    Default Upgrade E2/Spark cu TFTP
    Poate mai este util cuiva, despre cum se poate instala E2 cu FTP. Mersi Zildan pt. link si informatie:
    http://www.cardsharing-x.com/others-...en-enigma.html
    (Nota: eu nu am testat metoda)
    Since we have some restrictions and can not support all ki$$$ of USB stick, we provide another option (TFTP) to upgrade Enigma2/Spark.
    Preparation:
    1. Install TFTP tools [csicotftp11.rar] to your PC
    2. Set your PC IP addr to [192.168.40.19]
    3. connect your PC to STB by LAN, now we only support LAN, do not support WLAN
    4. Set default booting system to [spark]
    Upgrade Step:
    1. copy [mImage] and [userfsub.img] to any folder of your PC, for example [Cspark]
    3. Keep Pressing [OK] Button in Front Panel, then power on STB.
    4. After 5 seco$$$ you will see [Forc] in LED, release [OK] button and press [Right]
    Button.
    5. if everything OK, You will see [T LD] shining in LED and you will see some debug
    information in TFTP Server, like
    Mon Oct 25 14:02:36 2010: Sending 'mImage' file to 192.168.40.19 in binary mode
    Mon Oct 25 14:02:39 2010: Successful.
    Mon Oct 25 14:02:50 2010: Sending 'userfsub.img' file to 192.168.40.19 in binary mode
    Mon Oct 25 14:03:33 2010: Successful.
    6. if upgrade success, You will see [SUCC] and STB reboot automatically
    If upgrade not finishes in 5 minutes, then there must be something wrong, please check your configuration and re-try.
    18 Jan 2010
    Pitesti
    Buna seara, doresc sa incerc si eu aceasta metoda dar nu am gasit csicotftp11.rar, ma poate ajuta cineva cu un link de unde se poate descarca? Multumesc.
    23 Apr 2007
    P3X-888
    Arhiva o poti descarca de aici : Cisco TFTP Server.rar
    95 Post(s)
    Eu folosesc pentru server TFTP: Tftpd32
    de Aici
    02 Nov 2008
    Default tftp
    te rog daca se poate sa explci pasi cum se face un upgrade enigma2 pentru amiko alien2 cu acest program
