Thanks Thanks:  11
Likes Likes:  4
Page 1 of 3 123 LastLast
Results 1 to 15 of 44
Thread: PKT e2
    24 Jul 2011
    POL
    Wink PKT e2
    E2 OpenSource SH4 Duckbox Project GIT-4767 PKT SVN-2060 HYPERION Image STi 7111
    Added by PKT:
    [ALL] migration to OpenPLI
    [ALL] add more than 100+ plugins to download
    [ALL] fixed aspect ratio selection in A/V setting.
    [ALL] fix network setup
    [ALL] transparency fix if any window opend while infobar is dimming
    [ALL] added recording setup to menu
    [ALL] PermanentClock : added progress bar & other small fixes
    [ALL] fix subservices reload
    [ALL] fix green key support in infobar
    [ALL] Basic HD skin removed - it is already as default
    [ALL] fix opkg
    [ALL] add djcrash Updater v1.2.5
    [ALL] update Backup Manager v1.7
    - add /media/Points for backup
    - add backup of timer
    [ALL] converters update
    [ALL] new approach to control of FrontPanel
    [ALL] fix SCART Output
    [ALL] add missing: subtitle setup & autolanguage setup to main menu
    [ALL] fix GS when subtitled was selected by Audio Menu
    [ALL] GraphMultiEPG -fixed compatibility to other skins ( without our fonts )
    [ALL] 1st boot wizard fix
    [ALL] Languages: 1st is English, 2nd - Polish, others is alphabetical order
    [ALL] fix Backup Aurorestore - now 100% working
    [ALL] FrontPanel Setup extended to Time&Name, Time&Number
    [ALL] video settings optimization
    [ALL] update skins for PIG support
    [ALL] fix some STB's for PIG support
    [STI7111&7105] Fix CEC support
    [OCT1008+] fix picture viewer and videoplayback
    [GM7162] VFD icons support
    [GM7162] VFD Icons: 2nd record Icon, Full HD, HD, Disk Icon while REC.
    [GM7162] added CAM activation if is Disabled in Standby mode.
    [GM7162] fix icons off in standby/deepstandby
    [GM7162] keymap support Portal key
    [UFS910] fix restart network interface
    [SFXXX] added support of LongEPG key
    [IPBOX] optimization evremote
    [ALL] increase stability
    [...] and many many other changes not included in chagnelog.
    Known Issues:
    [Cuberevo] some STBs hang on if skin with PIG is used so we do not recommended such skins.
    [SF1008/SE] not tested so use at your own risk.
    [IPBOX] we're not sure about the TVN HD and other HD channels problems are solved
    Special THX to TDT and all betatesters.
    Specjalne podziękowania za wkład dla TDT i betatesterów.
    FTP login: root, passwd: pkteam
    http://egofiles.com/KAxL7SFsOfCX1oXc
    N-BOX HD , AMICO ALIEN HD , DM 500 , ILLUSION M5 , SKYSTAR 2
    09 Jun 2007
    Transylvania
    E foarte bun.Am folosit si pana acum PKT pe Alien1.Din vechea imagine am salvat datele cu backup manager si in 5 minute am imaginea noua cu toate setarile.Are deja webinterface OpenPli.Nici imaginea asta nu face scrrenshoot.
    02 Nov 2008
    in afara de HDMU nici o imagine nu face screenshot pentru alien2,in rest se misca bine .media playerul nu recunoaste nimik de pe stick(muzica,film)
    10 Apr 2011
    Am incercat pluginul Youtube si am ecran verde, restart pe Alien2.
    09 Jun 2007
    Transylvania
    Pe Alien 1 are bube.Dupa 2 ore de functionare s-a restartat si nu a mai pornit, ramanand la L 0 , deci nu s-a incarcat imaginea.La repornire tot asa.Am pus din nou , dar imaginea a inghetat si trebuia sa dau drumul din comutatorul din spate.
    23 Apr 2007
    P3X-888
    Imaginea se misca bine si este echipata corespunzator cu tot ce se doreste dar din pacate asemeni tuturor imaginilor E2 pentru Alien1 prezinta bug-urile istorice care incep se cred tot mai mult ca nici nu se vor rezolva , aceste bug-uri nu tin de dezvoltatorii de imagini ci de producatorul Fulan care nu face presiuni asupra STI pentru drivere de calitate . Din pacate in lipsa unor drivere de calitate diferenta intre imagini este facuta de catre floricele .
    Mediaplayerul citeste de pe stick , testat un film .avi , si incarca subtitrarea automat dar lipsesc anumite diacritice care sunt inlocuite cu diferite caractere ciudate si subtitrarea la pornire nu este sincronizata cu filmul. Pentru a vedea ce este pe stick trebuie montat , tasta albastra/Mount Center si de aici se face mount .
    Testat Youtube si functioneaza ok si cel din WebMedia si cel din YoutubePlus .
    01 Sep 2010
    Andromeda
    Testata de mine. functioneaza foarte bine, peste asteptari! Pentru a lua versiunea apasati pe
    imaginea cu sageata. Dupa parerea mea cea mai reusita de acest Team pana la ora actuala!
    E2 OpenSource SH4 Duckbox Project GIT-4767 PKT SVN-2060 HYPERION Image for Spark7111 Receivers
    Developed by: Polish Koders Team
    Boot Load
    Blue Panel
    Setari Panel
    Putem fixa pe display la receiver ora!
    Update:
    [ALL] fix opkg
    FTP login:
    User Name: root
    Passwd: pkteam
    Standard RSP member paduraru's Avatar
    16 Dec 2007
    Si eu am instalata imaginea care se misca foarte bine doar ca ECM este un pic mai mare ca la alte imagini de la PKT.
    DM 500S,HSS 7160
    23 Oct 2011
    Default pkt e2
    [QUOTE=Meridian;222158]=====================================================================
    ...de doua zile ma stradui sa descark aceasta imagine,dar in afara de reclama la porno nu apare nimic
    uite o sa pun aici un nou link aici
    01 Sep 2010
    Andromeda
    New links for this version!
    Download: Link 1 Link 2
    13 Feb 2007
    Default pkt
    m-am prostit de am pus si eu imaginea asta ,setez tot ce trebuie si intru in programe merge ok ,intru in programe care cu cealalta imagine mergeau gen iptv ,acolo am ramas , de cate ori apas vre-un buton la telecomanda apare ecranul verde cu restart si tot asa pana cand am sters tot si am revenit din nou la imaginea veche
    14 Jun 2013
    Default Pkt e2
    Quote Originally Posted by stargate View Post
    Rugaminte,
    in cadrul setarii pozitionerului, odata memorata pozitia dupa reglaje fine pe satelit, se pare nu se memoreaza pozitia reglata.Deoarece dupa momentul selectarii unui canal pozitia revine la setarea go to x (a pozitiei de baza colationata cu lat/log a locatiei).Este un alt mod de reglaj fin fara miscarea monturii HH ? (cu alt stb dream,opticum,strong este ok deci antena reglata bine pe axa 0)
    Multumesc
    14 Jun 2013
    Default PKT e2
    ptr golden media spark reloaded imagine este excelenta, bravo felicitari
    Daca imi este permis, aveam o intrebare legat de configurarea pozitionerului, dupa reglaj fin si memorare pozitie, la selectarea canalelor revine automat la pozitia goto x stabilita de corelatia lat/logitudine pe axa 0 .
    Nu memoreaza pozitia corectata, sau poate nu urmez eu pasi corectii pentru memorare index pozitie satelit
    23 Nov 2007
    E pozitioner sau motor H-H.
    Dac e motor......
    Pi corecteaza-i poziia motorului i atunci ai toi satelii ok. Mut-i setarea cu 0,1 din aproape in aproape pan ai semnalul ok pe un satelit i dac ai setat elevatia corect restul ar trebui s fie ok, altfel ai de ieit in soare la reglaj fin ....
    Dac e pozitioner nu tiu cum face ...
    Sent from my HTC Sensation XE with Beats Audio Z715e using Tapatalk 2
