Results 1 to 5 of 5
Thread: tuner defect ???
    RSP Enigma Team & GM michael86's Avatar
    01 Jun 2009
    Default tuner defect ???
    un clon de 800 nu mai vrea sa ia semnal nici de'al draq . incercat cu mai multe imagini ... crash-ul este acelasi :
    playing 1:0:1:78BE:2C5:600:E080000:0:0:0:
    not pauseable.
    RemovePopup, id = ZapError
    allocate channel.. 02c5:0600
    opening frontend 0
    [eDVBCAService] new channel 0x184f608!
    (0)tune
    prepare_sat System 0 Freq 12265000 Pol 1 SR 28000000 INV 2 FEC 5 orbpos 3592 system 0 modulation 1 pilot 2, rolloff 0
    tuning to 1665 mhz
    OURSTATE: tuning
    allocate Channel: res 0
    [eDVBCIInterfaces] addPMTHandler 1:0:1:78BE:2C5:600:E080000:0:0:0:
    allocate demux
    [SEC] set static current limiting
    [SEC] invalidate current switch params
    [SEC] setVoltage 1
    [SEC] sleep 10ms
    [SEC] setTone 1
    [SEC] sleep 10ms
    [SEC] update current switch params
    [SEC] startTuneTimeout 5000
    [SEC] setFrontend 1
    setting frontend 0
    [SEC] sleep 500ms
    (0)fe event: status 0, inversion off, m_tuning 1
    (0)fe event: status 1, inversion off, m_tuning 2
    (0)fe event: status 3, inversion off, m_tuning 3
    (0)fe event: status 1f, inversion off, m_tuning 4
    OURSTATE: ok
    [eDVBCAService] channel 0x184f608 running
    [eDVBLocalTimerHandler] channel 0x184f608 running
    allocate demux
    [eEPGCache] channel 0x184f608 running
    allocate demux
    [eEPGCache] no demux!!
    stop release channel timer
    allocate demux
    Allocating non--decoding a demux for now tuned-in channel failed.
    FATAL: scan.cpp:225 ASSERTION m_demux FAILED!
    Standard RSP member ASiX88796's Avatar
    20 Feb 2013
    LQFP 128
    Post
    Cel mai simplu era dacă aveai de unde să imprumuţi un tuner şi să verifici cum se manifestă cu el. Dacă nu ai alt tuner, atunci incercă cu un multimetru să-l diagnostichezi pe cel suspect: incepi cu tensiunea de ieşire către LNB (13Volţi pentru Vertical şi 18Volţi pentru Horizontal).
    21 Apr 2011
    1) pai nu inteleg, ecran verde ori nu vede /nu scaneaza tunerul ?
    2) si cum se manifesta receptorul cu tunerul scos ?
    01 Jun 2009
    daca conectez cablu' de la antena dupa ce pornesc "trotineta" imi da semnal si calitate dar nu face lumina :
    cred ca pe partea de semnal functioneaza , problema cred ca vine de undeva de la demodularea imagini ?!
    "[eEPGCache] no demux!!
    allocate demux
    FATAL: scan.cpp:225 ASSERTION m_demux FAILED!"
    cineva care le stie cu partea video ?
    crash da numai cu cablu de la antena in el , daca schimb canalele fara cablu acestea comuta cu mesajul 'tune failed' dar nu da crash .
    01 Jun 2009
    ssl suly . nu reusea demux din cauza driverelor . am gasit pe satuniverse de unde provine problema , search dupa eroare si am vazut ca trebuie revenit la ssl mai jos , in speta de la ssl72 la ssl70 .
