1
3
Dislikes:
Chiar asa cu ce marci este compatibila telecomanda de la DM800SE .
---------- Post added at 15:58 ---------- Previous post was at 15:49 ----------
Niste coduri, sunt de incercat, nu stiu daca sunt si functionale: http://www.upc.ie/pdf/DVRManual.pdf
La pagina 35 sunt codurile.
- Rep Power
- 70
La telecomanda Dm800 SE sau Sunray care am eu se poate seta aproape orice telecomanda de televizor.Sau macar o parte din butoane.Butoanele on/off, butoanele numerice , si volumul.Se pun cele 2 telecomenzi fata in fata.Se apasa TV si dupa aia shift pana incepe sa palpaie tasta Shift.Se tine apasat tasta de on /off pe telecomanda televizorului si se apasa on/off pe telecomanda 800 se si se tine apasat pana cand tasta apasata de pe DM 800 SE incepe sa palpaie mai frecvent.Daca palpaie mai frecvent a si luat-o.Si asa mai departe.Sper sa nu gresesc.Am probat cu un Samsung 32EH4003 si un LG .
In engleza:
how to use learning type remote controller for Sunray4/SR4(chinese).
Operation steps:
1 select TV mode, press the learning type remote controller [ SHIFT ] on the key, approximately 3 Seconds after the TV indicator light on, enter [ learning ] mode.
2 press to a learning remote controller want to learn the key, the indicator slow flicker, said into the [learning mode] of waiting to receive a learning signal state.
3 will be a learning remote controller receiving tube on the original remote transmitting tube, between 2 to 3cm . The original remote control to learn button once, then learning
Remote indicating lamp by slow flicker for flash 3 times after Long light, said a key learning success.
4 , other learning button only needs to repeat the above 2, 3 step.
5 after the completion learning, then press [ SHIFT ] to save and exit learning state.
6 into the state of learning, interval 15S learning no press input signal input, remote control lights automatic
Extinguished, leaving [ learning mode ] and automatically save.
7 the same key to learning ,then save the last the code value.
The key to studying as follows:
include power, digital key 0-10,
The volume +, -, BOUQUET + volume,
The BOUQUET and TV keys
Press" DVB" and" TV ( SHIFT )" for mode conversion.
Reason: adding
Incearcă acest tutorial, pentru a afla ce cod şi-a luat telecomanda :
Once you have Set-Up your DREAM REMOTE, you can blink back your
SET-UP CODE for future reference.
Example: To blink out your Television code:
1 Press TV once.
2 Press and hold SHIFT until the DREAM REMOTE’s TV key
blinks twice (The TV key will blink once and then twice).
3 Press 9 9 0. The TV key will blink twice.
4 For the first digit of your four-digit code, press 1 and
count all the red blinks. If there are no blinks, the digit is
"0".
5 For the second digit, press 2 and count all the red blinks.
If there are no blinks, the digit is "0".
6 For the third digit, press 3 and count all the red blinks.
7 For the fourth digit, press 4 and count all the red blinks.
If there are no blinks, the digit is "0". Now you have your
four-digit code.
Membru de onoare
- Rep Power
- 120
Cred ca unii avem telecomenzi Sunray4 Learning.Delta pe a ta ce scrie?
ORCUM poate pun o poza cu ea,memoria din ea e 24c16.
Or fi diferenţe intre telecomenzile clonelor de DM800SE şi cele de Sunray. Telecomanda mea e neagră, scrie doar Dreambox. Eventual .. o să mai adaug nişte poze cu interiorul acesteia.
Membru de onoare
- Rep Power
- 120
Aha,atunci nu ai treaba cu ce a scris @zottya.Ale noastre pe care scrie Sunray pot invata,buton cu buton,dar nu poti programa toate butoanele.Nici nu stiu daca putem introduce coduri,e altfel,deci de aici mai departe te descurci singur pentru ca noi cu telecomenzi Sunray nu avem cum sa te ajutam.
- Rep Power
- 70
Ai dreptate Zmeura.Si a mea este telecomanda Sunray.Nu stiam ca la clone de 800 SE si Sunray nu sunt identice telecomenzile.
- Rep Power
- 56
Merge cu "invatatul" fata in fata si la clona 800se si la sunray.probat
Doar butonul on/off,butoanele numerice,volumul si canalele sus/jos
Sent from my GT-I9100 using Tapatalk 2
- Rep Power
- 0
La mine e telecomanda de la o clona 800 (cred ca are vre-o tre ani) si am reusit f.usor sa gasesc cod-ul potrivit pentru Philips-ul meu.
Dar nici de cum nu pot reusi la Samsung-le prietenilor mei. Am incercat cu vre-o doua liste de coduri (cea de pe site-ul oficial dream-multimedia si una de pe internet) dar fara rezultat. Stie cineva ceva , a reusit cineva sa "lege" telecomanda 800 cu un TV Samsung ?
Multumesc
Member
Visitor
- Rep Power
- 0
Stie cineva cum resetez telecomanda ? Pur si simplu vreau sa nu mai fie functional butonul de TV, deoarece se incurca copilul. Nu mai tin minte cum am programat-o.
Multumesc
