Thanks Thanks:  86
Likes Likes:  111
Dislikes Dislikes:  10
Page 6 of 29 FirstFirst ... 234567891016 ... LastLast
Results 76 to 90 of 424
Thread: Dezbatere OSCAM oldpost.
  1. #76
    Membru de onoare
    08 Apr 2007
    Ce fel de card?
    Ce nu vor sa inteleaga cei de la oscam e cam asa:
    -am lasat cardul meu 1802 doar cu baza (din services),asa nu trebuie sa testez pe HBO-urile unguresti sau alte programe ciudate care cateodata poate nu se deschid
    -dau linie catre un receptor client cu cccam (nu are importanta oricum ce emu e)
    -clientului primeste carduri din hop1 al oscam-ului (deci el din hop2) si se intampla cam asa pe baza:
    2013/04/28 10:14:49 2B15DFB8 c dm600cccam (1802&000000/0000/03F6/92:CC23BD7872A52B922DFF9EC6EB4DC2F1): found (287 ms) by digi (L/1/1/2) - Digi24
    2013/04/28 10:14:53 2B15DFB8 c dm600cccam (1802&000000/0000/03F6/92:4417F650E367B4357D8F7FA5FD4D8D71): found (282 ms) by digi (L/1/1/2) - Digi24
    e in regula,trage din readerul local.Daca merg pe un program din extra (care nu e deschis de local):
    2013/04/28 10:09:51 2B15DFB8 c dm600cccam (1802&000000/0000/062C/92:69A9A48982D4696ED53369A83B896932): found (341 ms) by alin - TV 1000
    2013/04/28 10:10:02 2B15DFB8 c dm600cccam (1802&000000/0000/062C/92:17AB83315B71ED0B11A09320DC92B698): found (602 ms) by alin - TV 1000
    Unde alin e linie primita,trage din ea deoarece localul nu deschide,e in regula dar in cccam surpriza:
    system: Kudelski SA
    caid: 0x1802
    provider: [N3] DigiTV (1W)
    provid: 0x000
    pid: 0x15df
    using: CCcam-s2s
    address: 192.168.1.13:xxxx
    hops: 1
    share: 1010101010101010_10000
    ecm time: 0.633
    Adica oscam zice ca deschide din share si cccam primeste ca si cum ar fi din local.
    Daca incerc un program de pe Focus (pe care nu il am local) e corect,oscam:
    2013/04/28 10:13:11 2B15DFB8 c dm600cccam (0B02&000000/0000/778E/4C:1DF41ED9682C51593FEAFF191E43418D): found (171 ms) by alin
    2013/04/28 10:13:20 2B15DFB8 c dm600cccam (0B02&000000/0000/778E/4C:B69E903BB3125238AD7A0E7216B4144D): found (175 ms) by alin
    si in cccam vad corect ca se deschide din hop2:
    system: Conax
    caid: 0xb02
    provider: [Conax] Focus(1W) / Redlight (13E)
    provid: 0x000
    pid: 0x15e5
    using: CCcam-s2s
    hops: 2
    share: xxxxxxxxxxxxxxxx_142ca
    ecm time: 0.174
    Daca exagerez cu setarile e si mai evident.
    -clientului cccam primeste carduri din hop0 al oscam-ului,deci numai localul.In cccam vad numai un singur card in hop1-oscam,cardul meu.
    Din nou incerc un program din extra si oscam trage din linii cu toate ca eu ii dau userului doar localul (cccmaxhops = 0) http://www.streamboard.tv/wiki/OSCam...ser#cccmaxhops
    2013/04/28 10:25:42 2B277538 c dm600cccam (1802&000000/0000/062C/92:A69D1FFF8E182A44C29784BFC5D26164): found (506 ms) by alin - TV 1000
    2013/04/28 10:25:52 2B277538 c dm600cccam (1802&000000/0000/062C/92:5D58743D94B8811875715E044D403657): found (583 ms) by alin - TV 1000
    Deci continua sa traga din share iar in cccam ar trebui sa vad ca vine din hop2 (cu toate ca de fapt nu ar trebui sa ii vina din hop2 fiind limitat in oscam), dar:
    system: Kudelski SA
    caid: 0x1802
    provid: 0x000
    pid: 0x15df
    using: CCcam-s2s
    hops: 1
    ecm time: 0.557
    In cccam apare in continuare ca si cum ar veni din localul oscam-ului.Deci daca eu imi pun un local cu pachet popular si zic ca am full punem pariu ca oricine ma testeaza si ia doar localul meu ii deschide tot (daca eu am linii din care sa ii dau) si lui ii apare ca deschide din localul meu?
    De fapt am testat si cum i-am explicat aluia pe tiket,am limitat ce primesc din cccam,setand de acolo sa primesc doar localul din oscam si .... aceeasi treaba,deci nu conteaza din care parte limitezi ca sa primesti doar localul de test.
    Si aici setarile:
    oscam.conf
    [global]
    logfile = /dev/tty
    preferlocalcards = 1
    lb_mode = 2
    lb_min_ecmcount = 2
    lb_max_readers = 2
    [cccam]
    port = xxxx
    nodeid = 1010101010101010
    version = 2.1.3
    reshare = 2
    forward_origin_card = 1
    [webif]
    httpport = 81
    httpuser = xxxx
    httppwd = xxxx
    httprefresh = 30
    httpallowed = 127.0.0.1,192.168.0.0-192.168.255.255
    Readere
    [reader]
    label = digi
    description = Digi-lower
    protocol = internal
    device = /dev/sci0
    services = digi
    caid = 1802
    boxid = xxxx
    boxkey = xxxx
    rsakey = xxxx
    ecmwhitelist = 92
    detect = cd
    mhz = 2700
    cardmhz = 450
    ident = 1802:000000
    group = 1
    lb_weight = 1000
    [reader]
    label = alin
    description = Alin
    protocol = cccam
    device = xxxx
    user = xxxx
    password = xxxx
    inactivitytimeout = 30
    group = 1
    cccversion = 2.1.3
    cccmaxhops = 2
    ccckeepalive = 1
    cccreconnect = 0
    audisabled = 1
    Client
    [account]
    user = dm600cccam
    pwd = xxxx
    description = Dm600CCcam
    group = 1
    cccmaxhops = 0
    cccreshare = 1
    Testat cu versiune la zi svn8631,ce nu apare in setari e clar pe default.Deci am pus:
    -forward_origin_card = 1
    -reshare mode cum vrea ala de la oscam pe default,adica 4 acum
    -minimizecards = 0 default,nu am umblat la el
    -ignorereshare = 0 pentru ca nu vreau sa manaresc reshare la cardurile primite.L-am pus si pe 1 (oricum la testul cu cccmaxhops=0 nu conteaza) dar bineinteles ca nu are nici un efect asupra problemei mele.
    Forward origin card pare sa aiba efect asupra cardurilor din share,adica pus pe 1 cererile astea se "tuneleaza" doar pentru cardul local (si poate linii N),dezactiveaza loadbalancing pentru cererile de la clienti dar nu pentru dvbapi!Chestii neexplicate bine in wiki ci doar aruncate acolo.Oricum cu forward origin card merge mai prost decat cccam pentru clienti (pentru dvbapi merge loadbalancing si de aia daca testezi numai cu dvbapi nu vezi nici un efect al acestei setari) si continua sa manareasca localul.
  2. #77
    17 Nov 2008
    ALBA
    scuze. am uitat sa precizez. este un card focus. la local nu scade sub 217ms. ma gandeam ca poate a nimerit cineva frecventa la card , eu am incercat cu tot felul si la fel parca n-are nici un efect.
  3. #78
    Pune 368 cu 600, 800 sau 961.
    Poate e readerul tau in neregula.
    La 800 in sci1 am 130ms
    Changed 5 minutes ago by stefansat
    • Cc stefansat@… added
    • Resolution invalid deleted
    • Status changed from closed to reopened
    • Type changed from enhancement to task
    @zmeura, Thank's to the fact that You sended full config's(instead of just yelling and insulting) , I finally was able to reproduce this problem .
    I will now reopen this ticket assign it to me but it will take a couple off weeks before it will be applied as extensive test will have to be done.
    comment:67 Changed 3 minutes ago by stefansat
    • Owner set to stefansat
    • Status changed from reopened to new
    Vad ca si tu esti... ca raia!
  4. #79
    Membru de onoare
    08 Apr 2007
    Buna si raia cateodata,poate corecteaza.
    Oricum tu stii situatia foarte bine si cat de greu e de explicat,ma enervam si eu cand vedeam ca nu inteleg.Doar cand testezi practic poti intelege,altfel din explicatii cred ca si ce am pus aici poate semana cu ceva scris in limba chineza.
    PS: Daca rezolva promit sa renunt la cccam de tot si ma "modernizez" si pe serverul principal.
  5. #80
    17 Nov 2008
    ALBA
    ma dau batut, m-am urat , am setat in toate felurile la fel.
  6. #81
    Membru de onoare
    08 Apr 2007
    Nu stiu, te poti gandi si la probleme pe partea de alimentare a receptorului,poate sa ii schimbi condensatorii din partea de alimentare,tot ce are valori intre 100 si 1000 uF la tensiuni de alimentare mica (3V-30V).
  7. #82
    Ai incercat si "smecheria" asta?
    http://sateliti.info/showthread.php?...l=1#post219749
    For cardmhz switching to MIPSEL Dreambox mode set to 2700, for cardmhz switching to PPC Dreambox mode set to 3150.
  8. #83
    17 Nov 2008
    ALBA
    daca setez la mhz 600 sau mai mult imi zice maximum frecventa it clocking 5,0 Mhz .
  9. #84
    Ai pus si asta?
    cardmhz = -1
    cu versiunea de oscam corespunzatoare!
  10. #85
    17 Nov 2008
    ALBA
    da nici o schimbare.
  11. #86
    23 Apr 2007
    P3X-888
    Deja este tot mai greu ... tot mai multi trec la oscam si din cauza setarilor proaste traficul este ingrozitor si daca nu ai scula buna da cu serverul 3C rapid de pamant .
    Scuze de offtopic
  12. #87
    Standard RSP member Scary's Avatar
    09 Nov 2007
    absolut in toate topicurile pe care le citesc și aici și in partea cealalată, toată lumea vorbește de setări proaste in oscam din această cauză se face trafic mare in cccam. De ce nu se dau setări pentru oscam, să meargă bine ca toată lumea să fie mulțumită? Pană acum am găsit setări doar pentru cateva carduri, zic cateva pentru că și acolo sunt puține. Hai să facem un topic și să ne consultăm ca să avem cea mai bună setare in oscam.
  13. #88
    02 Sep 2010
    Earth
    @stargate ; @scary
    Oscam este cel mai bun gestionar de card.
    Oscam configurat "bine" ca si server de cccam merge fluent si fara probleme.
    Obtin si uptime de 50 zile pe un 800se sim2.10
    Totul tine de cum stim sa configuram in raport de locale si de cartile care vrem sa le primim.
    Sunt multe chestii de setat, e mai dificil decat 3c, dar odata inteles ce vrem de fapt sa obtinem va garantez ca nu veti mai renunta la oscam.
    Excludem aici derbedeii care transforma linia C in N sau le "mulg" in multics.
    PS: la un trafic mai mare schimbul de cacheex e ca o gura de oxigen.
  14. #89
    dMd
    Guest
    ...De ce nu se dau setări pentru oscam, să meargă bine ca toată lumea să fie mulțumită? Pană acum am găsit setări doar pentru cateva carduri, ....
    Aici este marea problema (si nu o spun cu rautate), insa toti s-au invatat sa copieze niste setari luate de-a gata si poate ca asta e motivul pentru care oscamul merge haotic. Nu tot ce e valabil la mine va merge uns la celalalt. Setarile "bune" se obtin numai citind ce s-a scris pana acum pe forumuri despre oscam si consultand pagina lor wiki, in momentul cand oscam ruleaza cat de cat stabil se trece la teste cu un coleg de share.. numai asa poti sa vezi ce e bine pt serverul tau si implicit sa gasesti setarile minune. Altfel, cautand pe net setari universale - nu ai sa faci mare lucru si nu ai sa intelegi oscam niciodata, indiferent ca el este bun sau rau.
  15. #90
    23 Apr 2007
    P3X-888
    Quote Originally Posted by piccolo08 View Post
    @stargate
    Intreaba partenerii tai de share ce trafic le faci lor pe cardul tau local si o sa vezi ce bine merge DAR tie nu lor ... oscam este ca un Robin Hood in share adica ia de la toata lumea si da la toata lumea fara sa tina cont de reshare si de hop . Un server oscam facut doar din locale este excelent dar din pacate cred ca la ora actuala nici 20% din localele din share nu sunt reale si de aici si traficul marit .
