Black Hole Vu+ Solo2 1.7.9-2 (Transcoding)
1) New drivers: 20121217
- Fix instability issue
- Fix PIP problem
- Fix module init problem.
- Support Transcoding(Beta)
2) Add trasnscoding streaming plugin(e2), and client(transtreamproxy)
3)Adjust kernel config
4) Various fix on Usb Dtt drivers
5) Update Usbtuner
About Transcoding (Thx to Ev0 for tests):
The transcoding function has been tested and is working through the WebInterface with an iPad.
It works both inside and outside of the home network, therefore also works over the internet, if you have the correct ports open in your router. It also works via 3g (although this obviously isn't perfect).
WARNING: This Image is not compatible with the previous skins
- Integrated OpenEpg
- Rytec dedicated epg.dat
- New system epg.dat outside.
Download EPG from any channel
Yellow button = Time Shift
Addons
Infobar / OSD
Analog Clock Gui
Channel orbital location
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Black Hole Speed Up
Devices Manager
Usb Format Wizard
Telnet Panel ( Telnet Panel)
FTP Panel ( FTP Panel)
UPnP Client Djmount
UPnP Server Mediatomb
UpnP Server Minidlna
Pcsc Panel
Tuner Server
Network Browse & Mountpoints
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Red Panel
Black Hole
Avalon
Chaos
Ghost
Credits
Thanks to ambrosa (Pli Board) for ready-to-go A867 driver patch
DISCLAIMER
LICENSE (TERM OF USE)
