Black Hole 1.7.9
This is the first image for Solo2.
This image is Multiboot and MultiDimensional
  • Kernel 3.3.6
  • Vu+ drivers: 20121109
  • Enigma2 ver: 20121211
  • Support Usb tuners
  • Support Wifi dongles
  • Support 1080p
  • Support PIP 2 channels HD
  • Skin: Army Touch HD
  • Support 32 bit png
  • New Plugin AutoShutDown
  • Support Meoboot
  • Support Multiple Universes
  • Support full backup (by dpeddi)
  • Support ALL extra settings and panels of standard Black Hole images.
  • New New New Black Hole Speed Up
About Black Hole Speed Up:
As you know a large number of plugins are installed by default in our images.
During startup Enigma2 has to scan and check all the installed plugins.
Many of us don't use all of these plugins.
The new Black Hole Speed Up feature allows you to disable/enable the default plugins without having to completely remove the plugin.
By disabling all the plugins we are not using without having to remove them enables you to reinstate them at any time.
This will speed up the image performance.
WARNING: This Image is not compatible with the previous skins
- Integrated OpenEpg
- Rytec dedicated epg.dat
- New system epg.dat outside.
Download EPG from any channel
Yellow button = Time Shift
Addons
Infobar / OSD
Analog Clock Gui
Channel orbital location
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Black Hole Speed Up
Devices Manager
Usb Format Wizard
Telnet Panel ( Telnet Panel)
FTP Panel ( FTP Panel)
UPnP Client Djmount
UPnP Server Mediatomb
UpnP Server Minidlna
Pcsc Panel
Tuner Server
Network Browse & Mountpoints
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Red Panel
Black Hole
Avalon
Chaos
Ghost
Credits
Thanks to ambrosa (Pli Board) for ready-to-go A867 driver patch
DISCLAIMER
LICENSE (TERM OF USE)
Download :
http://www.mijnbestand.nl/Bestand-87UIKDIZTCTY.zip
