Thanks Thanks:  16
Likes Likes:  14
Page 5 of 10 FirstFirst 123456789 ... LastLast
Results 61 to 75 of 146
Thread: Smart TV
  1. #61
    30 Jun 2013
    Quote Originally Posted by zemura View Post
    Recomand Samsung ,poti avea root access pe el http://www.samygo.tv/ dar trebuie sa vedeti pe care model merge.Inca nu stiu daca merge oscam,discutii au fost dar nimic concret,poate pe viitor .
    Am 2 tv-uri samsung seria ES7000, oscam merge perfect de mai mult de 1 luna.
  2. #62
    24 Jun 2009
    Hamburg
    The company LG, involved in a scandal with tracking users SmartTV, recognized facts transmission, even when this option is disabled tracking, reports CNET.
    LG claims that the collection of data on viewing channels and media files used solely to provide users with relevant advertising and recommendations for viewing.«LG regrets the inconvenience that brought this functionality to users, and will strive to continue to meet the expectations of all our customers and the public," - said the representative of LG edition.
    The Korean company is working to develop a software updatewhich will be fixed bug with sending information when this option is disabled, and firmware will be removed from the transfer function list files from USB-drives and external network drives.
    informatia e luata de aici: http://habrahabr.ru/post/203354/
    It all started with the fact that I noticed an advertisement that shows my new SmartTV from LG. After a little investigation, I came across a video for corporate customers, telling about advertising opportunities LG. Video is long enough, the bottom line is that the LG Smart Ad collects information about your favorite apps userhis behavior in the network, including the collection of keywords used in searches and other information on personal preferences. All this is used to display targeted advertising.
    In fact, in the system settings there is an option «Collection of watching info» («The collection of information about viewing"), which is enabled by default. To see this setting, the user must scroll to the bottom of the menu. Also, this item is no context-sensitive help detailing options, in contrast to all other points.
    I decided to do a little analysis of the traffic that sends TV. It was found that the traffic is sent regardless of whether the flag is set, allowing the collection of information or not.
    mai multe aici: http://habrahabr.ru/post/202770/
    concluzia este cu aceste updeturi vin multe surprize
  3. #63
    38 Post(s)
    De unde? De la habrbabrrrbabuin? Fi serios!
  4. #64
    17 Jan 2008
    Si crezi ca este ceva nou? Sunt convins ca tot ce este legat la net „scapa„ date care sunt folosite de cineva si asta fara sa ne intrebe nimeni daca suntem de acord sau nu.
  5. #65
    19 Aug 2011
    UTC+13
    Conform LG, "gaura a fost astupata" prin ultimele update-uri.
    muta sobolanu` de aici
  6. #66
    19 Aug 2011
    UTC+13
    Pe al meu LG 47LA6918, nu am semnal pe niciun transponder DVB-S2 - no signal. A mai patit cineva asa ceva?
    Daca bag cablul in Alien, acesta vede semnal bun.
  7. #67
    7 Post(s)
    Ai setat totu corect ? ai umblat in setarile de serviciu ?
    19 Aug 2011
    UTC+13
    Eu cred ca e setat bine. La ce te referi cand zici de "setarile de serviciu"?
    Observatie: post HD = scrambled, dar nu deschide in niciun fel, dupa care incepe sa tuseasca diablo si nu mai deschide absolut nimic. Mut inapoi pe HD, fac un on/off cycle, si atunci apare "no signal". Daca scot Diablo din TV, nu primesc nicio eroare gen "no signal".
  9. #69
    95 Post(s)
    Pai aia apare datorita faptului ca Diablo omoara CI+.
    Asa se intampla, o sa ai semnal doar dupa restart TV.
  10. #70
    19 Aug 2011
    UTC+13
    Vrei sa zici ca nu voi vedea niciun post HD pe satelit?
  11. #71
    04 Jun 2007
    @zildan diablo nu omoara ci+,e o problema de compatibilitate cu televizoarele lg. Si mai ales la modele noi led3d.
    @tutri ar trebui sa incerci toate versiunile de soft aparute pentru televizorul tau sa vezi daca se impaca vreunul cu modulul diablo . Sau poate nu se impaca cu modelul de diablo pe care il ai . Ai incercat cu mai multe module?
  12. #72
    19 Aug 2011
    UTC+13
    Nu am incercat alte combinatii. Nu am de unde sa iau alt diablo (cunostiinte), iar ref firmware nu am si nu stiu cum sa fac downgrade.
  13. #73
    04 Jun 2007
    la majoritatea televizoarelor poti pune soft cu un stick usb ,acum numai sa ai de unde lua si versiuni mai vechi de soft pentru tv-ul tau. Conectat la net televizorul nu vei putea sa faci downgrade ,toti fabricantii nu iti lasa decit posibilitatea schimbarii intr-un singur sens adica upgrade in nici un caz down. In alta ordine de idei ce model de diablo ai? chiar sa nu ai pe nimeni prin apropierea ta dispus sa te ajute? spune si tu care iti este locatia .
  14. #74
    19 Aug 2011
    UTC+13
    Ref la downgrade stiu ca nu se poate face online (oficial), dar am inteles ca este si riscant. Am mai avut un LG de 37, pe care am activat functia divx dupa un downgrade - riscant.
    Am un diablo wifi 2.6, cu ultima imagine Underworld.
  15. #75
    04 Jun 2007
    la diablo wifi 2.3 singurele televizoare care fac probleme sint cele de la LG iar cele led3d si mai si ; merg o perioada de timp, 20-30minute, dupa care imaginea si sunetul merg dar nu mai raspund la telecomanda sau si mai rau intepeneste imaginea si nu mai ramine decit sa-l tragi din priza. Chiar daca multi zic ca modulul ver2.3 e mai slab pe partea de wifi eu as zice ca e mai stabil decit ver2.6 si mai e un user de aici de pe forum care a incercat mai mult decit mine ver2.6 ( a avut vreo 15-20 module )si are cam aceeasi parere. Poate o merge mai bine pe partea de retea si share dar daca o tine tot intr-un blocaj la fiecare ora/jumatate de ora nu prea e ok. Nu generalizez, poate sint alti useri care l-au configurat mai bine si le merge fara probleme .
    In Germania sint destui romani ,poate citeste cineva apropiat de tine si dornic sa experimenteze.
