Black Hole 1.7.8
WHAT IS NEW:
  • New Black Hole Weather (XBMC tribute)
  • New Full set of Usb Dvb drivers (porting from latest linux kernel)
  • Vu+ OE updated to 24 sept 2012
  • Vu+ dvbapp updated to 24 sept 2012
  • Army Skin Transparency-HD_VU updated to 1.7.8
  • Fix compatibility with streaming plugins like 1channel(putlocker)
  • Fix compatibility with Permanent Timeshift
  • Fix epg description "visibile gratis..."
  • Remove the ban on "enigma" word
  • Fix about IP streaming.
    1. IP streaming with gstreamer is seekable.
    2. Timeshift is not supported for TS IP streaming service.
  • [hbbtv] update.
    - fix rtl group connection.
    - add memory threshold
  • [openwebif] fix packaging.
About Black Hole Weather
The new Black Hole Weather function is available via Main Menu.
Bh Weather is simply and basic weather forecast.
It is a little tribute to XBMC and was coded by in high color definition to port in enigma2 graphics by Xbmc.
The Weather data are provided by YAHOO with the WOEID system.
The Woeid allow to select every cities in the world with an unique id.
Black Hole Weather credits:
  • Code by bh-c
  • Graphics idea and style by XBMC
  • Weather Data provider: Yahoo.com
WARNING: This Image is not compatible with the previous skins
- Integrated OpenEpg
- Rytec dedicated epg.dat
- New system epg.dat outside.
Download EPG from any channel
Yellow button = Time Shift
Addons
Infobar / OSD
Analog Clock Gui
Channel orbital location
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Devices Manager
Usb Format Wizard
Telnet Panel ( Telnet Panel)
FTP Panel ( FTP Panel)
UPnP Client Djmount
UPnP Server Mediatomb
Tuner Server
Network Browse & Mountpoints
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Red Panel
Black Hole
Avalon
Chaos
Ghost
Credits
Thanks to ambrosa (Pli Board) for ready-to-go A867 driver patch
DISCLAIMER
LICENSE (TERM OF USE)
Download here : http://www.mijnbestand.nl/Bestand-YRP3GPGI6XJT.zip
