Dislikes:
VU ULTIMO 3 TUNERE 2xdvb-s/2 1dvb/t/c
Produs:
Descriere: Detali Technice:
· 400MHz Broadcom Mips Prozessor (BCM7413)
· Flash: 1GB
· RAM: 512MB
· Front panel
· Smart Card sSlot: 2x
· Common Interface: 2x
· USB 2.0: 1x
· Key 5 buttons (Standby, Vol +/-, Ch+/-)
· Display Graphic type Large VFD (256×64) pixels
· Rear panel
· Tuner 3x pluggable single tuner (DVB-S2/C/T) moglich
· Connection TV 1x Scart socet
· Video Output (composite) 1x Cinch socet
· Video Output (component) YPbPr
· Video/Audio Output (digital) 1x HDMI
· Audio output (analogue) 2x Cinch socet
· Audio output (digital) Standard optical (SPDIF)
· USB 2.0: 2x
· Ethernet: 1x
· RS232 Anschluss: 1x
· FAN Automatic FAN control
· e-SATA: 1
· Power
· Main range 100-250/50-60 V/HZ
· Power consumtion
· (Max./typ. Operation/Stand-by) 60/25/1 W
· RF
· RF range 47-864 MHZ
· FEC, de-multiplexer DVB-S2 / DVB-C / DVB-T standard
· Video
· Video resolution CCIR 601 (720×576 lines), 576p, 720p, 1080i
· Video decoding MPEG-2, MPEG-4 compatible
· Input data rate 2-45 Msymb/s
· S/N >53dB
· Audio
· Decoding AC3, MPEG-4 (AAC-HE), MPEG-1, Layer 1,2 and 3
· Sampling rate 32/4.1/48KHz
· S/N >65dB
· LNB
· LNB supply (hor./vert.) 14/18, max. 400 V/mA
· Control Signal 22KHz, ToneBurst, DiSEqC 1.0/1.1/1.2, USAL
· General
· Dimensions (WxHxD) 380 x 60 x 290mm
· Weight 3,0 Kg
· Remote Universal Remote / QUERTY Keyboard
Accesorii: cu ce vine in cutia originala
Pret: 450 EU
Garantie: inca 8 luni
Alte detalii: il vand de oare ce am trecut la iptv
Schimb cu: NU ACCEPT SCHIMBURI.
Contact: PM
