Inca um pas catre IP TV ! bravo BH !
Mometan doar acesti membri...
Black Hole 1.7.7 HbbTv
- What is HBBTV?
HBBTV is a pan-European specification for interactive TV applications with its roll-out in Germany, France and more countries are now following. HBBTV has been developed in order to fulfil the needs of seeking ways to deliver interactive services through a single web-based user interface. The fundamental goal is to create open standards providing the seamless TV experience to customers.
- Note for Vu+ Ultimo and Vu+ Uno boxes:
Remeber to upgrade the firmware to the version 4.5 before you install Black Hole 1.7.7- Note HbbTv:
To access HbbTv functions: Short press red button / Long press blue button- Warning Parallel Universes:
Bh parallel universe panel has been moved to: Long press red button
- What is new ?
- Vu+ dvb drivers updated to 20120824
- Vu+ OE updated to 20120830
- Vu+ Enigma2 updated to 20120830
- Army skin Transparency-HD updated for HbbTv
- [librtmp] fix build bug
- Enigma2-defaultservices : update default services
- Opera hbbtv:
- upgrade libdvbsi++ package.
- include hbbtv plugin.
- packaging opera-hbbtv binutil.- Fix libpcsclite build
- RemoteControlCode : support for all models except duo/solo.
- [firmware upgrade] fix fimrware data filename.
- Add opera browser.(with hbbtv)
- handle error for forbidden stream.
- activate red button.(ready for ait..)- keymap.xml: Red button remapped: short = hbbtv, long = parallel universes
- BhEi: fix satellite name and position in osd (thx Sato)
- Add filesystem choice to usb format wizard
- Remove Vu+ Device Manager, using Bh device panel instead.
- Set platform profile and check HbbTv application version.
- HbbTv: fix bug of setting orgid.
- Fix lamedb.192.
- [hbbtv] fix bugs.
- add platform profile.
- add application version.
- notify error for failed to load.
WARNING: This Image is not compatible with the previous skins
- Integrated OpenEpg
- Rytec dedicated epg.dat
- New system epg.dat outside.
Download EPG from any channel
Yellow button = Time Shift
Addons
Infobar / OSD
Analog Clock Gui
Channel orbital location
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Devices Manager
Usb Format Wizard
Telnet Panel ( Telnet Panel)
FTP Panel ( FTP Panel)
UPnP Client Djmount
UPnP Server Mediatomb
Tuner Server
Network Browse & Mountpoints
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Red Panel
Black Hole
Avalon
Chaos
Ghost
Credits
Thanks to ambrosa (Pli Board) for ready-to-go A867 driver patch
DISCLAIMER
LICENSE (TERM OF USE)
Download here : http://www.mijnbestand.nl/Bestand-X66BQ7OS7VGE.zip
