Merge bine.
Multumim oscam
Se pare ca dupa atata timp s-a rezolvat problema 1880 in oscam. Inainte am vazut ca mergea corect doar cu userul dvbapi, daca mai adaugai ceva in max 30-40 de min nu mai deschidea nimic
Azi am vazut ca au modificat consistent la readerul nagra
Link
si am zis sa pun si eu unu la munca. Si surpriza, dupa 4 ore merge bine cu 4 useri din acest card
Atasez mipsel+debian pentru cine vrea binurile gata compilate. debian nu are decat nagra, mipsel are nagra+viaccesCode:2012/08/05 15:03:01 77107090 c vuapi (1880&002111/0000/049C/89:D40E): found (414 ms) by jiji (L/1/4/5) - AXN 2012/08/05 15:03:03 77115AE0 c dig (1880&002111/0000/03F4/89:2CFC): found (394 ms) by jiji - Diva 2012/08/05 15:03:06 77111E70 c cTVR (0500&025900/0000/000F/6B:978A): found (89 ms) by tvr - TVR HD 2012/08/05 15:03:06 771188B8 c cccam (1880&002111/0000/03ED/89:08A0): found (391 ms) by jiji - TVR2 2012/08/05 15:03:07 77107090 c api (1880&002111/0000/049C/89:95EF): found (448 ms) by jiji (L/1/4/5) - AXN 2012/08/05 15:03:07 7710CE10 c oscam (1880&002111/0000/03F5/89:5425): found (392 ms) by jiji - DigiSport 1 2012/08/05 15:03:08 7710CE10 c oscam (1880&002111/0000/0D98/89:F27E): found (404 ms) by jiji - HBO Comedy 2012/08/05 15:03:10 77115AE0 c dig (1880&002111/0000/0D48/89:447E): found (411 ms) by jiji - PV TV 2012/08/05 15:03:16 77111E70 c cTVR (0500&025900/0000/000F/6B:968A): found (88 ms) by tvr - TVR HD 2012/08/05 15:03:16 773004F8 r jiji [nagra] vuapi emmtype=shared, len=139, idx=35, cnt=2: written (580 ms) 2012/08/05 15:03:17 771188B8 c cccam (1880&002111/0000/03ED/89:4B7E): found (492 ms) by jiji - TVR2 2012/08/05 15:02:54 7710CE10 c oscam (1880&002111/0000/03F5/89:AA9F): found (469 ms) by jiji - DigiSport 1 2012/08/05 15:02:55 7710CE10 c oscam (1880&002111/0000/0D98/89:2EB5): found (403 ms) by jiji - HBO Comedy 2012/08/05 15:02:57 77115AE0 c dig (1880&002111/0000/0D48/89:7448): found (410 ms) by jiji - PV TV
Download
Merge bine.
Multumim oscam
linux
E mult mai bine, dar daca il pui la munca ca lumea creste ecm dupa niste ore. Tot sbox merge mai bine. Mai asteptam...
Sent from my GT-I9100 using Tapatalk 2
Incepand cu versiunea #7386 cred ca e in regula, nu mai creste ecm si apoi sa o dea in timeout.
Din cand in cand apare o linie, cateodata des, la 16-40 de ecm, altadata aproape deloc
2012/09/09 12:00:20 53A0C2 r jiji [nagra] T1 Resync command succesfull ifsc = 160
Ceva setari pentru amatori:
Code:[reader] label = jiji description = enable = 1 protocol = smartreader device = 001:004 device_out_endpoint = 0x82 key = password = pincode = none readnano = services = popular,baza,extra1,extra2,maxpack,digifilm,radio,cablu_ro,bonus,ppv,!ungaria,!serbia,!croatia,!slovacia,!cehia,!fail resetcycle = 0 smargopatch = 0 sc8in1_dtrrts_patch = 0 fallback = 0 cacheex = 0 cacheex_maxhop = 0 logport = 0 caid = 1880 boxid = fix9993 = 0 rsakey = ................ ins7e = ins7e11 = force_irdeto = 0 boxkey = ....................... atr = ecmwhitelist = detect = cd nagra_read = 2 mhz = 480 cardmhz = 369 ident = 1880:002111,002011,002113 chid = class = aeskeys = group = 7 emmcache = 1,3,2 blockemm-unknown = 1 blockemm-u = 0 blockemm-s = 0 blockemm-g = 0 saveemm-unknown = 0 saveemm-u = 0 saveemm-s = 0 saveemm-g = 0 blockemm-bylen = lb_weight = 100 savenano = blocknano = disablecrccws = 1 ccchop = 0 deprecated = 0 audisabled = 0 auprovid = 002111 ndsversion = 0 ratelimitecm = 0 ratelimitseconds = 0 cooldown = 0,0Code:[dvbapi] enabled = 1 au = 1 pmt_mode = 0 request_mode = 0 request_mode = 0 reopenonzap = 0 delayer = 0 user = api boxtype = dreambox
Code:[account] user = api pwd = api description = disabled = 0 expdate = allowedtimeframe = group = 1,2,3,4,5,6,7,8,9 hostname = uniq = 2 cacheex = 0 cacheex_maxhop = 0 sleep = 0 monlevel = 0 au = 1 services = !baa # tvr conax allowedprotocols = caid = betatunnel = ident = chid = class = suppresscmd08 = 0 cccmaxhops = 2 cccreshare = 8 cccignorereshare = 1 cccstealth = -1 sleepsend = 0 failban = 0 keepalive = 1 numusers = -1 penalty = -1Combinatie vuduo/vix2.4/oscam7406/smargo/18802012/09/09 18:48:56 5B0498 c user (1880&002111/0000/0DDE/89:9B7B): found (369 ms) by jiji - Universal
smargo pe auto
Userul dvbapi face AU la toate cartile din oscam.
oscam-svn7410-mipsel-webif-libusb
oscam-svn7406-mipsel-webif-libusb
Build log 7410 (7406 nu are videoguard):
| Settings:
| CONF_DIR = /etc/tuxbox/config
| CC_OPTS = -O2 -ffunction-sections -fdata-sections
| CC_WARN = -W -Wall -fno-strict-aliasing -Wredundant-decls -Wstrict-prototypes -Wold-style-definition
| CFLAGS = -DWITH_LIBUSB
| LDFLAGS = -Wl,--gc-sections -DWITH_LIBUSB -Wl,-rpath,
| LIBS = -lusb-1.0 -lrt -lpthread -ldl
| Config:
| Addons : WEBIF HAVE_DVBAPI IRDETO_GUESSING CS_ANTICASC WITH_DEBUG MODULE_MONITOR WITH_LB CS_CACHEEX
| Protocols: CAMD35 NEWCAMD CCCAM RADEGAST
| Readers : WITH_CARDREADER NAGRA CONAX VIACCESS VIDEOGUARD
| Compiler : mipsel-unknown-linux-gnu-gcc (crosstool-NG-1.3.3) 4.3.2
| Binary : ../archiv/oscam-svn7410-mipsel-webif-libusb
Am un card jiji de prin 2008. De unde stiu ce caid este: 1802 sau 1880?
Rosu=1802
Galben=1880
Salut,
Cine ma ajuta sa scot un timp mai bun pe Vu+ Solo2 caid 1880?
local (1880&000000/0000/03F5/89A95C630AF8CF888A4A0491C7218DB33): found (656 ms) by DIGI_Intern
Code:[reader] label = DIGI_Intern description = DIGI Intern enable = 1 protocol = internal device = /dev/sci1 key = password = pincode = none readnano = services = resetcycle = 0 smargopatch = 0 sc8in1_dtrrts_patch = 0 fallback = 0 cacheex = 0 cacheex_maxhop = 0 cacheex_ecm_filter = cacheex_allow_request = 1 cacheex_drop_csp = 0 caid = 1880 atr = boxid = boxkey = ********************* rsakey = ******************* ins7e = ins7e11 = fix9993 = 0 force_irdeto = 0 ecmnotfoundlimit = 0 ecmwhitelist = 1880:89 ecmheaderwhitelist = detect = cd nagra_read = 0 mhz = 368 cardmhz = 368 ident = 1880:000000,002011,002111 chid = class = aeskeys = group = 18 emmcache = 0,1,0 blockemm-unknown = 0 blockemm-u = 0 blockemm-s = 0 blockemm-g = 0 saveemm-unknown = 0 saveemm-u = 0 saveemm-s = 0 saveemm-g = 0 blockemm-bylen = lb_weight = 100 savenano = blocknano = dropbadcws = 0 disablecrccws = 0 use_gpio = 0 cccreshare = -1 ccchop = 0 deprecated = 0 audisabled = 0 auprovid = 002011 ndsversion = 0 ratelimitecm = 0 ratelimitseconds = 0 ecmunique = 0 srvidholdseconds = 0 cooldown = 0,0
Solutia e deja pe forum
http://sateliti.info/showthread.php?...l=1#post219749
