Black Hole 1.7.5 "Multiple"
The "codename" of Black Hole 1.7.5 is Multiple because it is
- Multi Boot
- Multi Universes
- Multi Partitioning usb sticks
- Multi UPnP servers (Mediatomb and Minidlna)
What's New:
- Parallel Universes Setup with the option to protect access with a pin code
- Enigma2 dvbapp updated to 31 May 2012
- Army default Skin updated
- Added a second UPnP server (Minidlna) for maximum compatibility with all current tv's
Note on Multiple Partitioning:
The "Usb Format Wizard" of Black Hole 1.7.5 will allow you to partition and format your
usb sticks from 1 to 4 different partitions.
You can for example create 3 partitions in your usb stick and then mount them in 3 different mountpoints in device manager (i.e usb, universes, cf)
Note on Universes setup:
By clicking ok you will now access the Universe Configuration menu (Black Hole home doesn't need a config)
You will have 3 options:
- Universe access protected
- Universe access pin
- Force reboot in Black hole.
Setting the first option to Yes, will mean that the Universe will be protected with a pin
If you do not set a pin the default pin will be 0000
Setting force reboot in Black Hole means the image will not boot into this Universe (useful for a pin protected universe, to be sure that nobody can access it, if you forgot to switch to another dimension before you poweroff).
Note: the Universes pin and config are reset by a big bang
Note on Multiple UPnP servers.
Black Hole 1.7.5 include 2 different Dlna Servers:
- Mediatomb allows you to stream between two different boxes and take advantage of the BH Tuner/Server feature, but it is not compatible with many devices and the project is no longer updated.
- Minidlna is more upto date and compatible with many devices and most modern tv's. Use it if you want to connect from your tv or other devices to your box to share your media contents.
Warning: you cannot use old Universes on the new image version.
WARNING: This Image is not compatible with the previous skins
- Integrated OpenEpg
- Rytec dedicated epg.dat
- New system epg.dat outside.
Download EPG from any channel
Yellow button = Time Shift
Button Red = Red Panel (Parallel Universes Teleportation)
Addons
Infobar / OSD
Analog Clock Gui
Channel orbital location
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Devices Manager
Usb Format Wizard
Telnet Panel ( Telnet Panel)
FTP Panel ( FTP Panel)
UPnP Client Djmount
UPnP Server Mediatomb
Tuner Server
Network Browse & Mountpoints
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Red Panel
Black Hole
Avalon
Chaos
Ghost
Credits
Thanks to ambrosa (Pli Board) for ready-to-go A867 driver patch
DISCLAIMER
LICENSE (TERM OF USE)
