Produs: OPTICUM 7300 PVR CI2CX PLUS VFD
Descriere: nou
Accesorii: cutie, telecomanda, etc.
Pret: 230
Garantie: 12
Alte detalii:
Schimb cu:
Contact:PM
General
Standard Full compatibility with MPEGII/DVB
OSD menu (languages)
English, Polish, Russian, Arab, Ukrainian, French, Italian, Portugal, Spanish, German, Turkish
Channel memory Max. 4000 TV and Radio channels
Input frequency range
950...2150 MHz
Input level
-65...-25 dBm (opcja)
Built-in CA modules
2 x CONAX
CI slot
1
DiSEq control
C1.0/1.2, USALS
LNB power 13 V / 18 V (max 500 mA)
LNB switching
22kHz
Modulation QPSK (SCPC, MCPC capable)
Symbol Rate 2...45 Mbps
Audio/Video
Video format MPEG-II Main profile/Main level
Audio format MPEG-II layer I&II Dolby AC-3
Aspect Ratio 16:9, 4:3
Audio sampling 32, 44.1, 48 kHz
Audio modes Mono, Dual Mono, Stereo, Joint stereo
Video system
720x576 (PAL), 720x480 (NTSC)
CPU and Memory
Processor 216 MIPS
RAM 128 Mbits
FLASH 32 Mbits
Power and Environment
Supplying voltage 100-250V AC, 50/60Hz
Power consumption
Max. 30W
Operating temperature range
5...45 °C
Physical specs
Display VFD 8 – alphanumerical
Weight 2.0 kg
Dimensions 260(W) x 190(D) x 65(H) mm
Connectors
SAT IF input F-female
SAT IF loop 950-2150 MHz
RS232 9-pin D-type DCE serial port
SCART TV/VCR
Video Composite Video I/O, RGB, CVBS
Audio RCA (L & R)
Control voltage output RCA (0/12V)
Modulator 75 ohm TV connector (UHF ch.21-69)
Optical output S/PDIF
HDMI output HDMI Type A
USB 2 x USB 2.0 – DATA & POWER
